XJBikes.com XJ4Ever
Toggle Content
Toggle Content Advertisement
Toggle Content Donate
Donate with PayPal!
Toggle Content Main Menu
Toggle Content User Info
Nickname
Password
Latest: Docwits
New Today: 0
New Yesterday: 0
Overall: 13244
Members: 0
Visitors: 34
Total: 34
Who Is Where:
 Visitors:
01: Forums
11: My Account
12: My Account
19: My Account
20: Forums
21: Forums
22: Forums
23: Forums
24: Forums
25: My Account
26: My Account
27: Forums
28: Home
29: Forums
30: Forums
31: Forums
32: Forums
33: Home
34: My Account
Staff Online:
No staff members are online!
Toggle Content Google Search
Toggle Content Total Hits
We have received
97026162
page views since
August 9, 2005
Forums › XJBikes Talk › XJ Chat › Vacuum Syncing
Vacuum Syncing
Go to page Previous  1, 2, 3, 4, 5  Next
Author Message
MisterShah
5th gear
5th gear
PostPosted: Thu May 24, 2012 4:14 pm    Post subject: Re: Vacuum Syncing Reply with quote
Right, I did get my valves in spec first...or so I thought. Looks like I put the wrong shim in that E4. Next time: check, and RE-check.
I have the correct shim now and I am doing it first thing...
Ultimately, my question is would one valve clearance being out of spec be what is fudging up my sync?
_________________
81 XJ 650H
Back to top
wizard
XJ Wizard
PostPosted: Thu May 24, 2012 4:39 pm    Post subject: Re: Vacuum Syncing Reply with quote
No, you're getting unwanted air, or it can be one butterfly just holding open, that would start the same cycle of events.
_________________
The myth buster.
4 wheels move the body-2 wheels move the soul.
Back to top
MisterShah
5th gear
5th gear
PostPosted: Thu May 24, 2012 5:29 pm    Post subject: Re: Vacuum Syncing Reply with quote
If it's air it only comes in when I adjust the 3&4 bank...not when I adjust any other bank or pull the throttle and release...and with starter fluid test I can't detect it...
If it is the throttle shaft seals, is there a better way (other than breaking the rack) to test for leaks?
_________________
81 XJ 650H
Back to top
bigfitz52
XJ Wizard
PostPosted: Thu May 24, 2012 5:51 pm    Post subject: Re: Vacuum Syncing Reply with quote
Here's the thing with worn out/cracked/dried out throttle shaft seals: They're almost impossible to "detect" at rest.
What happens is the seal will take a "set" at the position it spent the most time in relative to the shaft. Sometimes they dry out, crack, and become a collection of little dried out rubber rings.
Anyway, they will work reasonably well until you ROTATE the throttle shaft. Sometimes even a degree or two will do it. And in the rotated position, they fail to work (as in SEAL) but at rest--- they'll fool you every time. This may show up coming off idle, or only when you whack it WFO.
Here's the only test for throttle shaft seals, and it's a half-way deal at best:
Take the E-ring ("C" clip) and thin fiber washer off the shaft on the outsides of carbs #1 and #4. Have a look at the seals. If you're a hopeless optimist, carefully pop them out (use a moistened toothpick, they're soft.) If those seals are good, you have a 50-50 shot that the other 6 might just be OK too. If those two outer seals are bad, then guess what: the other 6, which have a had a harder life, are bad too.
Here's the kicker: Just because the outer two are OK, does NOT mean the others are too. The further in the rack you go, the harder the life they've led.
Then again, they could all be fine (for now anyway, they are 30 years old.)
_________________
Technical Writer & Advisor
Back to top
MisterShah
5th gear
5th gear
PostPosted: Fri May 25, 2012 10:36 pm    Post subject: Re: Vacuum Syncing Reply with quote
Got my valves all cleared up now. Even though it was only 1 that was out of spec, I knew it was critical.
Getting ready to take off the carbs to re-inspect them, I noticed this little gem:
This damn thing was such a PITA to get on there the both times I re-installed these carbs. The first time I boiled the boot and it stretched on there and stayed. This time, I didn't.
I know it might be a stretch, but could this be my vacuum culprit? Unrestricted, unfiltered air going into Carb#2? Just trying to eliminate all possibilities before breaking the rack, as to me that is the last resort.
_________________
81 XJ 650H
Back to top
biggs500
Red Liner
PostPosted: Fri May 25, 2012 11:00 pm    Post subject: Re: Vacuum Syncing Reply with quote
Absolutely get that boot to fit. It's not helping as it is in the picture.
_________________
Current:
'82 650 Seca bought new in '83
1982 750 Maxim bought as a project in 2012
'08 ZX 1400 Ninja bought new in '09 (very nice discount!)
Past:
'03 Bandit 1200S bought new in '05 (sold in March of 2011)
'81 XS 400 SH (Traded in on the Seca in '83)
Back to top
MisterShah
5th gear
5th gear
PostPosted: Fri May 25, 2012 11:29 pm    Post subject: Re: Vacuum Syncing Reply with quote
See, I figured that was a problem...but would a leak on the airbox side of the carbs be what is causing a rev?
_________________
81 XJ 650H
Back to top
wizard
XJ Wizard
PostPosted: Fri May 25, 2012 11:39 pm    Post subject: Re: Vacuum Syncing Reply with quote
No, that won't cause the high revs.
_________________
The myth buster.
Back to top
MisterShah
5th gear
5th gear
PostPosted: Fri May 25, 2012 11:58 pm    Post subject: Re: Vacuum Syncing Reply with quote
Didn't think so.
_________________
81 XJ 650H
Back to top
Durk
4th gear
4th gear
PostPosted: Sat May 26, 2012 4:28 am    Post subject: Re: Vacuum Syncing Reply with quote
How are the intake manifold gaskets? If one (or more) is bad it will send you revving away when you sync.
_________________
82 Seca 750: SOLD
Back to top
View user's profile
MisterShah
5th gear
5th gear
PostPosted: Sat May 26, 2012 11:17 am    Post subject: Re: Vacuum Syncing Reply with quote
They seem good. No cracking or warping that I can see, and no revving when I spray them down with igniter fluid...
_________________
81 XJ 650H
Back to top
biggs500
Red Liner
PostPosted: Sat May 26, 2012 12:16 pm    Post subject: Re: Vacuum Syncing Reply with quote
At this point Shah I would order some throttle shaft seal and replace them, then you've ruled that out. It's not hard, just a bit time consuming and it will give you a chance to clean some of the hard to reach places on the carb bodies. Be sure to replace the fuel pipe o-rings and the butterfly screws also. Get the Allen head ones and a 2mm T-handle Allen wrench and don't forget a drop of blue thread locker. Take lots of before pictures, this will help tremendously with re-assembly.
Be sure to put the butterflies back in correctly as they are beveled and make sure they close completely after they are tightened down. If they don't they're not seated quite right. Very important. I found a good way is to take each individual carb body and look though it, actually press it up to you eye and you should see no light leaking through. If you do you'll get air as well.
Also use a bit of silicone grease (it's in the plumbing section) on the shaft seals and where the seal sits in the carb body. Just on the seals, not the shaft and the bore hole. You want this to rotate very freely.
This will help:
www.xj4ever.com/hitach...0seals.pdf
Good luck! Smile
_________________
Current:
Past:
Back to top
MisterShah
5th gear
5th gear
PostPosted: Sat May 26, 2012 4:04 pm    Post subject: Re: Vacuum Syncing Reply with quote
That doesn't seem too bad! Looks like I've got some parts to order. (again)!
Soon I'll be riding my bike more than working on it! *crosses fingers*
_________________
81 XJ 650H
Back to top
MisterShah
5th gear
5th gear
PostPosted: Mon May 28, 2012 9:36 pm    Post subject: Re: Vacuum Syncing Reply with quote
Alright, went out and did an inspection. C1's spark plug shows a lean condition for sure. Also Carb#1's outside throttle shaft seal is visibly wet with gas. I think it's fair to assume that these seals are done.
_________________
81 XJ 650H
Back to top
MisterShah
5th gear
5th gear
PostPosted: Mon Jun 04, 2012 10:25 pm    Post subject: Re: Vacuum Syncing Reply with quote
Seals getting delivered tomorrow. Got the carbs off the bike and started disassembly. I'm having a hell of a time getting the mounting screws out. These bad boys are seized. Any tips getting them out? I don't want to munge the heads...
_________________
81 XJ 650H
Back to top
Display posts from previous:
Page 2 of 5
Jump to:
lots of exhaust smoke and leak
Last post by scrubby in XJ Chat on May 18, 2013 at 07:30:18
dug into some tasty carbs today
Last post by waldo in General Lounge on May 18, 2013 at 07:15:38
Whoa! That's one pristine XJ550 for sale...
Last post by mtnbikecrazy55 in General Lounge on May 18, 2013 at 05:56:04
Repainting, Tank Emblem Question
Last post by pickax in General Lounge on May 18, 2013 at 05:37:00
xj550 sitting for ten years// first bike
Last post by Captainkirk in XJ Chat on May 18, 2013 at 04:33:48
XJ4ever parts & service
Last post by ol_750 in Service, Online, Retail Shop Review on May 18, 2013 at 04:32:42
keep it original or change it up?
Last post by razz1969 in XJ Chat on May 18, 2013 at 04:13:07
And so it begins.......
Last post by Captainkirk in XJ Modifications on May 18, 2013 at 04:07:37
deer hits
Last post by Douglash9 in General Lounge on May 18, 2013 at 04:03:17
Nice and cheap XJ900 FS
Last post by Captainkirk in Sell, Trade, Swap, Wanted on May 18, 2013 at 03:58:59
