 Latest: Docwits
 New Today: 0
 New Yesterday: 0
 Overall: 13244
 Members: 0
 Visitors: 32
 Total: 32
Who Is Where: Visitors:01: Forums
06: Home
19: Forums
20: Forums
21: Forums
22: Home
23: Forums
24: Home
25: Forums
26: Forums
27: Home
28: My Account
29: Forums
30: Forums
31: Forums
32: Forums
We have received 97137133page views since August 9, 2005
Forums › XJBikes Talk › XJ Chat › Working on my 1982 XJ750 Maxim
Working on my 1982 XJ750 MaximTechnical discussion ONLY for XJ Maxim/Seca...
Go to page 1, 2 Next
WileyDan 3rd gear
Joined: Jul 19, 2012 Posts: 83 Location: Rochester, MN
Posted: Mon Jul 30, 2012 11:19 pm Post subject: Working on my 1982 XJ750 Maxim |
I picked up a 1982 Maxim 750 a couple of weeks ago for $200. It's in really rough shape but I enjoy working on motorcycles and am in no rush to get it done - although it would be nice to get in a little riding time before winter (I'm in Minnesota).
I thought I'd start a thread detailing the work I'm doing and welcome any suggestions you may have.
Put in a new solenoid as it only wanted to turn over intermittently - works good now. Was able to get it started with starting fluid but wouldn't continue running - didn't figure it would but had to try.
I rebuilt the carbs using the advice from this forum - put in new v-seals on the throttle shafts, new o-rings on the fuel tubes between the carbs, new o-rings and washers under the mixture screw. I had to use easy outs to get the drain screws out of the bowls and replaced with stainless allen head screws from Chacal. I still have to see if the float levels are set correctly. I decided I better set the valves before I try the carbs out.
The bike has about 25000 miles on it. I checked the compression and the readings were 125, 115, 120 and 117.
I took the valve cover off this evening and will be checking the valve clearances after work tomorrow.
_________________ 1982 XJ 750 Maxim
Carburetors "zestfully Clean" - New shaft seals, fuel line o-rings
Rebuilt Master Cylinder
Valve clearances in spec - new valve cover gasket
mtnbikecrazy55 XJ Wizard
Joined: Dec 04, 2011 Posts: 2081 Location: Green Bay, Wisconsin
Posted: Tue Jul 31, 2012 2:08 am Post subject: Re: Working on my 1982 XJ750 Maxim |
sounds like you're well on track!!
Remember before you ride it:
-Check age of tires, anything over 5 years old replace.
-Check rear brake pads for delamination
-Check age of front brake lines, and replace if older than 4 years.
Enjoy!
_________________ - 1983 XJ750 Maxim -Back on the road-
- 1981 XJ550 Seca -Undergoing restoration- -Follow along here: Click Me! |
WileyDan 3rd gear
Posted: Tue Jul 31, 2012 8:29 am Post subject: Re: Working on my 1982 XJ750 Maxim |
| mtnbikecrazy55 wrote: |
Enjoy! |
Thanks for the advice. I'm sure the tires will need to be replaced they look really good but are definitely over 5 years old. - I'll definitely check the rear brakes and plan to put in stainless steel brake lines on the front.
For now I'm just hoping I can get it running well - then take it out for a quick mile or 2 ride to make sure it shifts through all the gears as it should and then get back to working on the rest of it.
Valve clearances in spec - new valve cover gasket |
jeffcoslacker Red Liner
Posted: Tue Jul 31, 2012 8:45 am Post subject: Re: Working on my 1982 XJ750 Maxim |
We're on similar tracks, I just bought an '82 XJ750 cheap too....non-runner, runs good now.
But this thing has been out of commission so long, every single aspect is proving to be a problem.
Carbs were totally stuck, but fortunately had all new parts. Tank full of scale, rust and old fuel...a gallon of vinegar, 3 feet of dog chain and a handful of nuts and bolts, and three days later it's clean as new.
Petcock needs rebuilt. Front brakes stuck. Had a Vetter fairing, trying to piece it back together with OE parts, the originals were lost.
But I'm in no hurry. If I was, I wouldn't have bought it. Like you, I'd like to ride it a little this summer just to see what else it needs before I really go through it this winter.
Good luck!
_________________ 1982 XJ750, 32,000 miles. No longer neverending problem. Beginning to show promise. |
WileyDan 3rd gear
Posted: Tue Jul 31, 2012 10:30 am Post subject: Re: Working on my 1982 XJ750 Maxim |
| jeffcoslacker wrote: |
Good luck! |
It really does sound like we are on the same track. Mine had the vetter fairing as well. Petcock seems ok but the front brakes are stuck as well. The inside of my gas tank looks ok but a lot of rust everywhere else - I may have to replace the front forks, but we'll see.
WileyDan 3rd gear
Posted: Tue Jul 31, 2012 8:01 pm Post subject: Re: Working on my 1982 XJ750 Maxim |
I checked the valve clearances and this is what I got:
Intake:
1 = .064 mm
2 = .127 mm
3 = .127 mm
4 = .102 mm
Exhaust:
1 = .178 mm
2 = .152 mm
3 = .127 mm
4 = .178 mm
I need to order the tool from Chacal to get the shims out and see what's in there so I know what new shims I need to order.
MN-Maxims XJ Wizard
Joined: May 03, 2008 Posts: 2436 Location: Saint Paul, MN
Posted: Tue Jul 31, 2012 8:13 pm Post subject: Re: Working on my 1982 XJ750 Maxim |
Welcome in up the road in St Paul. Good luck and post some pics of your project.
_________________ 1981 XJ650H (Silver)
1982 XJ750J (Black)
1982 XJ750J (Red)
1982 XJ750J (Primer)
1982 XJ1100J (Black)
1983 XJ750K (Black)
1982 XJ1100J (Needs 2nd gear fix) |
WileyDan 3rd gear
Posted: Wed Aug 01, 2012 7:28 am Post subject: Re: Working on my 1982 XJ750 Maxim |
I'll get some pics this evening and get them posted. Glad to know there is someone close by - I'm sure I'll be picking your brain from time to time as I work on this thing.
kudoskun 3rd gear
Posted: Wed Aug 01, 2012 1:48 pm Post subject: Re: Working on my 1982 XJ750 Maxim |
A few of us had a mini-meetup at a local viking MC riding chapter.
If there's enough interest perhaps we can plan another one.
_________________ ~~~~~~
82 XJ750 |
WileyDan 3rd gear
Posted: Thu Aug 02, 2012 4:10 pm Post subject: Re: Working on my 1982 XJ750 Maxim |
| kudoskun wrote: |
If there's enough interest perhaps we can plan another one. |
Sounds like fun. Let me know if you decide to put something together.
Riley/MN 1st gear
Joined: May 08, 2010 Posts: 15 Location: Wabasha County, MN
Posted: Sat Aug 04, 2012 4:12 pm Post subject: Re: Working on my 1982 XJ750 Maxim |
Hey Dan - Another one close by here... I had a guy in Elgin get my bike going when I first got it and then had a forum member here that is down in Leroy get her running real good.
Did you have the Vetter fairing or the Yamaha fairing?
_________________ 1982 Maxim 750 |
WileyDan 3rd gear
Posted: Sun Aug 05, 2012 10:44 pm Post subject: Re: Working on my 1982 XJ750 Maxim |
| Riley/MN wrote: |
Did you have the Vetter fairing or the Yamaha fairing? |
Glad to hear there's another XJ guy close by. I'm sure I'll need some help before I'm done.
I do have the vetter fairing - but not going to use it.
WileyDan 3rd gear
Posted: Mon Aug 06, 2012 8:50 pm Post subject: Re: Working on my 1982 XJ750 Maxim |
| WileyDan wrote: |
Intake:
1 = .064 mm
2 = .127 mm
3 = .127 mm
4 = .102 mm
Exhaust:
1 = .178 mm
2 = .152 mm
3 = .127 mm
4 = .178 mm
I need to order the tool from Chacal to get the shims out and see what's in there so I know what new shims I need to order. |
Got the tool this evening and removed the shims from the valves out of spec. intake 1 had a Y295 shim, Intake 4 had a y295 shim, Exhaust 2 had a Y270 Shim and Exhaust 3 had a Y270 shim.
So it looks like I need (2) 265 shims and (2) 290 shims. Let me know if I understand this correctly.
Thanks guys
MN-Maxims XJ Wizard
Posted: Mon Aug 06, 2012 8:56 pm Post subject: Re: Working on my 1982 XJ750 Maxim |
Just to clarify you did just take the shims out to see what size they were and put them back in so you are not turning the cams on the buckets without any shims in place?
1982 XJ750J (Black)
1982 XJ750J (Red)
1983 XJ750K (Black)
