 Latest: JimIndyV8
 New Today: 5
 New Yesterday: 6
 Overall: 8082
 Members: 11
 Visitors: 25
 Total: 36
Who Is Where: Members:01: bigfitz52 > Forums
02: deadohiosky > Forums
03: dltaylor > Forums
04: egisat > Forums
05: finch > Forums
06: Jay~Dub > Forums
07: markie > Forums
08: mdee > Forums
09: rmkopp > Forums
10: stereomind > Forums
11: Untaim1 > Forums
Visitors:01: Calendar
03: Home
04: My Account
16: Home
17: Members List
19: Forums
20: Home
21: Forums
22: Forums
23: Forums
24: Forums
25: Forums
We have received 35523211page views since August 9, 2005
Forums › XJBikes Talk › XJ Chat › i need help
i need helpTechnical discussion ONLY for XJ Maxim/Seca...
reichert35 1st gear
Posted: Mon Oct 27, 2008 12:15 pm Post subject: i need help |
i just adjusted my cam chain tensioner following the service manual step by step and now my bike (82 XJ650RJ seca) wont start!!!
bill XJ Wizard
Joined: Jun 20, 2008 Posts: 2813 Location: Raleigh, NC
Posted: Mon Oct 27, 2008 12:42 pm Post subject: Re: i need help |
Hi we need some details. Won't turn over, turns over but no spark, etc?
_________________ 82 XJ650J Maxim 43k miles and climbing - all stock
82 XS400J 16k miles (project bike right now)
Past rides:
66 Honda Superhawk (partial rebuild - sold in 2008)
71 Honda CB350 (sold after rebuilding engine)
81 XS850 Midnight special (never should have sold it)
| wizard wrote: |
| Yamaha Induction Control System, or in lay terms, a hole in the head. |
reichert35 1st gear
Posted: Mon Oct 27, 2008 1:16 pm Post subject: Re: i need help |
it turns over and all four plugs are sparking its acting like its not getting gas i sprayed starter fluid in the carb throats and still nothing.
bigfitz52 XJ Wizard
Joined: Jun 27, 2008 Posts: 7163 Location: Cows'n'Pigs'n'Chickens MICH
Posted: Mon Oct 27, 2008 1:29 pm Post subject: Re: i need help |
Sorry but I gotta ask: When you were adjusting the camchain, did you have the ignition cover off? If YES, were you careful turning the motor over by the end of the crank so the wrench DID NOT scrunch into the ignition pickups (and move them..?) If that answer is also yes, then the problem is almost certainly NOT related to adjusting the camchain, as long as you got the tensioner tightened back up correctly (manual tensioner only.) Did the adjustment procedure involve loosening a bolt and nut on the tensioner unit?
_________________ '81 XJ550RH Seca- Recommissioned original classic daily rider; 26K miles- stock except bars, seat, shocks and SS brake lines.
'83 XJ550RK Seca- "Toxic Asset"; 10K miles- restored, modernized and personalized (nearly stock)
Wish I hadn't sold my SR500
reichert35 1st gear
Posted: Mon Oct 27, 2008 1:34 pm Post subject: Re: i need help |
i dont think i touched the ignition pickups are they real easy to move how do i know if thats the problem? and yes i loosened the lock nut then the bolt and tightened them both back down
_________________ 82 XJ650RJ seca
second owner 13k miles
New Fuse block
4 into 1 aftermarket exhaust
aftermarket windshield and farings
new koni adjustable rear shocks
new fork springs and seals
and a new black matalic pearl paint job |
bigfitz52 XJ Wizard
Posted: Mon Oct 27, 2008 1:50 pm Post subject: Re: i need help |
No, the pickups aren't easy to move, you'd have had to mash into them pretty good to move 'em, and you'd know it. Just checking. Ok, good---did you use a torque wrench and/or go real easy on the bolt/locknut? If you followed the book (not hard at all) and did it all step by step, then you have a raw coincidence here, a simple camchain adjustment won't kill your bike. You said you have spark. Starting fluid isn't necessarily a good diagnostic aid. Put the petcock on PRI (don't leave it there forever) and let's see what happens.
asphaltgecko 2nd gear
Posted: Mon Oct 27, 2008 5:04 pm Post subject: Re: i need help |
any gas in the tank ?
_________________ God created man, SAM COLT MADE THEM EQUAL |
baz666 Red Liner
Joined: Jan 08, 2006 Posts: 389 Location: West Toronto Junction
Posted: Tue Oct 28, 2008 3:03 pm Post subject: Re: i need help |
the cam chain adjustment's got nothing to do with starting the bike. It'll still start, unless as Bigfitz mentioned, you displaced ignition components. Don't think of it as a cam chain related issue. Sometimes bikes like to lead you in the wrong direction. Check the obvious stuff first. Is your engine kill switch on? Is the battery topped up? Is there gas, as asphaltgecko asked.
Did you disconnect something else? Do you have a green neutral light when you've got the bike in neutral? Any fuses blown?
Check the troubleshooting section of your Haynes manual. You have one, right?
_________________ 81 XJ650H Maxim (Cafe mod)
81 XS650SH Special (party oem/partly not)
83 XJ900R Seca - (Ratbike Touring Beast)
83 XJ750H Seca - (parts bike)
83 Suzook GS750ES (half fairing model)
02 Half Moon 49cc scooter (Chinese crapola) |
Posted: Tue Oct 28, 2008 3:15 pm Post subject: Re: i need help |
check the battery terminals for tightness... TODAY, MY 750 WOULD CRANK BUT NOT START, RAN DOWN THE BATTERY PRETTY QUICKLY, WENT TO JUMP IT, THE + TERMINAL SCREW WAS LOOSE, TIGHTENED IT,
VAROOOOOOOM ! STARTED RIGHT UP......FUNNY THING, IT TURNED OVER AND OVER, LIKE IT WAS TRYING TO START, YOU WOULDNT HAVE SUSPECTED THE TERMINAL WAS LOOSE.
reichert35 1st gear
Posted: Wed Oct 29, 2008 8:53 am Post subject: Re: i need help |
turns out it was the battery i charged it and it started right up. thanks for all the help
New Fuse block
bigfitz52 XJ Wizard
Posted: Wed Oct 29, 2008 9:21 am Post subject: Re: i need help |
I experienced the same thing...My '83 would SPIN right over, quite fast, but absolutely not start; was showing 8V on the dash gauge. Charged the battery fully and it fired right up, showing 12V when the key was switched on. I had always assumed if the battery were down far enough to affect starting it would be spinning slower. NOT the case.
Posted: Wed Oct 29, 2008 1:13 pm Post subject: Re: i need help |
basics .. gas...electricity...air.... ingnition key... gotta have em...
wizard XJ Wizard
Joined: Mar 28, 2008 Posts: 3316 Location: melbourne australia
Posted: Wed Oct 29, 2008 2:30 pm Post subject: Re: i need help |
it's all about distribution of power, the juice is going to the starter & starving the coils.
_________________ 4 wheels move the body-2 wheels move the soul. |
bigfitz52 XJ Wizard
Posted: Wed Oct 29, 2008 2:34 pm Post subject: Re: i need help |
Apparently. Never experienced that with a vehicle before, but this is my first real experience with electric-start bikes. Every CAR I ever dealt with would still fire even if cranking slowly.
