 Latest: Midas
 New Today: 1
 New Yesterday: 2
 Overall: 13333
 Members: 6
 Visitors: 45
 Total: 51
Who Is Where: Members:01: darkfibre > Home
02: jkstull > Forums
03: JohnStonePhoto > Home
04: scott400 > Forums
05: tizzlebass > Forums
02: Home
09: Home
16: Downloads
19: My Account
20: Forums
21: Forums
22: Forums
23: Forums
24: Home
25: Forums
26: Forums
27: Forums
28: Forums
29: Forums
30: My Account
31: Forums
32: Home
33: Forums
34: Forums
35: Forums
36: Home
37: Home
38: Home
39: Forums
40: Forums
41: Forums
42: Forums
43: Forums
44: Forums
45: Forums
Hidden: 1
We have received 97495845page views since August 9, 2005
Forums › XJBikes Marketplace › XJ4Ever - Supporting Vendor › XJ MAXIM, SECA, AND TURBO PARTS CATALOG
XJ MAXIM, SECA, AND TURBO PARTS CATALOGYamaha XJ parts and accessories
Go to page 1, 2, 3, 4, 5, 6 Next
chacal Supporting Vendor
Joined: Aug 01, 2006 Posts: 4845 Location: At My Computer
Posted: Mon Dec 15, 2008 12:55 am Post subject: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
UPDATED LIST AS OF 02-08-2009:
NOTE: parts available are now listed by the SECTIONS outlined below. Note that some items will appear in more than one section, due to the overlap in applications. Hopefully this will make the search for items much easier!
Each section is a separate ad posting, and the section is listed in BOLD RED TYPE at the top of each ad.
As usual, if you have any questions, please write to us via a PM (Private Message) through this website, e-mail us via the "email" button on the bottom of this post, or e-mail us directly at:
info @ xj4ever.com
PLEASE NOTE!: our e-mail address does NOT have spaces before or after the "@" symbol........the posting system on this website automatically adds blank spaces before and after that symbol as an anti-spam feature! Make sure you eliminate those blank spaces when sending us an e-mail! Our e-mail address does NOT have any blank spaces in it!!
PLEASE!: on each and every correspondence with us, please tell us what YEAR and MODEL bike you have (example: 1982 XJ650 Maxim) and what your NAME (first name, at least!) is......that information really makes life a bit easier for us, and insures a more timely and ACCURATE response from us back to you!
SECTION A:
INTRODUCTION:
located on Page 1 (this page) of the Catalog
--Yamaha History:
--Model ID/VIN's:
--The Real Costs of Maintenance:
SECTION B:
LITERATURE:
--Service Manuals:
--Owner's Manuals:
--Other Literature:
SECTION C:
FUEL SYSTEM ITEMS:
--Hitachi Parts:
--Mikuni Parts:
--General Fuel System Tools & Parts:
--Airboxes, Air Filters, Rubber Boots & Parts:
--Intake Manifolds and Related:
--Fuel Tanks, Caps, Filters, Fuel Line and Vacuum Lines:
--Petcocks & Parts:
SECTION D:
ELECTRICAL SYSTEM:
located on Page 2 of the Catalog
--Electrical System Tools:
--Electrical System Wiring: Fuseboxes, Wiring harness components, and related.
--Charging System: AC Alternator/Generator, Regulator/Rectifier, and related.
--Ignition System: Ignition Switch, Keys, Pickup Coil, Ignition Coils, TCI-Igniter, Spark Plugs, Plug Caps, Diodes, and related hardware, etc.
--Starting System: Battery, Battery Cables, Solenoid, Starter Motor, Starter Switch, Relay, and related hardware, etc.
--Chassis Electrical System: Control Switches, Headlight, Relays, Horns, and related hardware, etc.
--Chassis Electrical System: Turn Signals, Tail Lights, Brake Lights, License Plate Lights, Lenses, Bulbs, Flashers, and related hardware, etc.
--Chassis Electrical System: Gauges and related hardware, etc.
SECTION E:
ENGINE PARTS:
located on Pages 2 and 3 of the Catalog
--Engine Gaskets:
--Oil System Parts:
--Valvetrain Parts: Valve Gaskets, Valvecovers, Valvecover Hardware, Valve Shims, Shim Tools.
--Valvetrain Parts: Valves, Valve Guides, Valve Springs, Keepers, and Hardware.
--Valvetrain Parts: Camshafts, Cam Chains, Guides, Tensioners, Tools and Hardware.
--Engine Mounts:
--Main and Rod Bearings:
--Pistons, Piston Rings, and Related:
--Connecting Rods and Hardware:
--Cylinders, Cylinder Heads, and Hardware:
--Oil Pump Engine Cover, Gaskets, and Hardware:
--Generator Cover, Shifter Cover, Clutch Cover, Gaskets, and Hardware:
SECTION F:
EXHAUST:
located on Page 3 of the Catalog
--Pipes: Headpipes, collectors, mufflers.
--Gaskets:
--Hardware and Tools:
SECTION G:
COOLING SYSTEM PARTS:
--for all you water-heads out there!
SECTION H:
CLUTCH/TRANSMISSION/DRIVETRAIN:
--Shifter Pedal, Pads, Clutch System Parts
--Drive Chain & Sprockets:
--Shaft Drive Parts:
SECTION J:
BRAKES:
located on Pages 3 and 4 of the Catalog
--Master Cylinders:
--Disc Brake Calipers and Parts:
--Disc Brake Pads and Parts:
--Disc Brake Rotors and Hardware:
--Rear Drum Brake Shoes and Parts:
--Brake Lines Introduction:
--Rubber Brake Lines:
--Braided Stainless Steel Brake Lines:
--Brake Line Hardware:
--Brake System Tools:
SECTION K:
STEERING/SUSPENSION:
located on Page 4 of the Catalog
--Steering: Handlebars, crowns, head bearings, etc.
--Front Suspension: Front suspension Overview.
--Front Suspension: XJ550 - XJ750 Forks, seals, springs, hardware, etc.
--Front Suspension: XJ900 - XJ1100 Forks, seals, springs, hardware, etc.
--Front Suspension: Fork Oil and Tools.
--Rear Suspension: Swingarm parts.
--Rear Suspension: Shock Absorbers, hardware, etc.
SECTION L:
WHEELS, AXLES, AND TIRES:
located on Page 5 of the Catalog
--Front Wheel Bearings, axles, speedometer drive, and related:
--Rear Wheel Bearings, axles, and related:
--Bearing Tools:
--Wheels & Tires:
SECTION M:
CONTROL CABLES & HAND LEVERS:
--Control Cables:
--Brake and Clutch Hand Levers:
SECTION N:
BODY & FRAME:
--Frame:
--Front Fairings and Windscreens:
--Fenders:
--Side Covers, Side Cowling, Rear Cowling:
--Seats, Seat Locks, Helmet Locks:
--Grab Bars, Grab Rails, Standing Handles, and Hardware:
--Mirrors:
--Footpegs:
--Kickstand, Centerstand, and Hardware:
SECTION O:
EMBLEMS, STRIPES, DECALS, AND PAINT:
located on Page 6 of the Catalog
--Emblems/Nameplates:
--Stripes and Decals:
--Paint:
SECTION P:
THE TOOLBOX:
--Chemicals, supplies, and general purpose tools.
--Specialty tools for specific areas of the bike.
--More specialty tools for specific areas of the bike.
FREE STANDARD SHIPPING {OR JUST $5.00 FOR PRIORITY MAIL} SHIPPING IN THE USA FOR ALL ORDERS OVER $100 !!!!
$7.50 STANDARD SHIPPING TO CANADA FOR ALL ORDERS OVER $100 !!!!
Paypal accepted. Worldwide shipping available. Shipping prices and insurance costs are NOT included in the prices of items unless specifically listed. Please write with your list of parts needs and I will be glad to quote your shipping costs to you.
You can either PM (Private Message) me through this website, e-mail us via the "email" button on the bottom of this post, or e-mail us directly at:
info @ xj4ever.com
_________________ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Posted: Mon Dec 15, 2008 1:07 am Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION A:
INTRODUCTION:
-- Yamaha History
The History of Yamaha
INTRODUCTION:
We all knew there had to be a reason.......
IN THE BEGINNING:
Yamaha is the world's second largest producer of motorcycles, but before making any motorcycles, Yamaha had become the world's largest piano maker, which explains their trademark "tuning forks" logo. So here's their story, which is also the story of your bike, and how it came about to be.
MR. YAMAHA HIMSELF:
Yamaha founder Torakusu Yamaha was raised in what is now the Wakayama Prefecture and received an unusual education from his samurai father, a surveyor with broad interests in astronomy and mechanics and a remarkable library. The Meiji Restoration, a government-subsidized effort to hasten the technological growth and development of Japanese society and industry during the late 19th century, put educated people such as Yamaha in a position to capitalize on the new growth.
At age 20 Yamaha studied watch repair in Nagasaki under a British engineer. He formed his own watchmaking company, but he was unable to stay in business because of a lack of money. He then took a job repairing medical equipment in Osaka after completing an apprenticeship at Japan's first school of Western medicine in Nagasaki.
As part of his job, Yamaha repaired surgical equipment in Hamamatsu, a small Pacific coastal fishing town. Because of their area's isolation, a township school there asked him in 1887 to repair their prized U.S.-made Mason & Hamlin reed organ. Seeing the instrument's commercial potential in Japan, Yamaha produced his own functional version of the organ within a year and then set up a new business in Hamamatsu to manufacture organs for Japanese primary schools.
In 1889 he established the Yamaha Organ Manufacturing Company, Japan's first maker of Western musical instruments. At the same time, the government granted Hamamatsu township status, which provided it with rail service and made it a regional commerce center.
Yamaha Organ used modern mass-production methods, and by 1889 it employed 100 people and produced 250 organs annually.
During the 1890's the more inexpensive upright piano surpassed the reed organ in popularity in U.S. homes. Yamaha saw the potential of this market. In 1897 he renamed his company Nippon Gakki Co., Ltd., which literally means "Japan musical instruments".
So the company that we today know as "Yamaha" began life in the music business, first producing organs in 1889. Within ten short years, it had become highly successful in this field and was renamed Nippon Gakki Limited and manufactured a wide range of reed organs and pianos.
Although building string instruments may seem, at first thought, to be mostly a skill of woodmakers and the like, in a large, integrated manufacturer such as this company became, there are also the machines that form the wood, saw the wood, make the brackets, as well as all of the extensive research into the strong, lightweight metal alloys needed for acoustic pianos.......and all of these metal working, engineering, and other such manufacturing skills were eventually applied directly to the creation of metal motorcycle parts.........but that's a story we're not quite ready to tell.
FAST FORWARD, 1941:
Japanese war efforts required the commandeering of all available manufacturing output for the production of wartime materials, most importantly aviation-related products. Nippon Gakki turned its technical, engineering, and associated manufacturing skills towards the successful production of propellers and fuel tanks for aircraft.
After the war, and the resultant economic hardships in the Japanese economy, there arose a large demand for inexpensive and reliable forms of transportation. Searching around for new markets in which to put their tremendous capabilities and skills to use, in 1953 company president Genichi Kawakami ushered in a new era by speaking these few words: "I want to carry out the trial manufacture of motorcycle engines."
He had explored and considered using Nippon Gakki's manufacturing resources to produce a range of different products, including sewing machines, auto parts, scooters, three-wheeled utility vehicles, and…..motorcycles.
At a later date, when asked about this critical decision, he stated, "I had my research division chief and other managers visit leading motorcycle factories around the country. They came back and told me there was still plenty of opportunity, even if we were entering the market late. As I didn't want to be completely unprepared in this unfamiliar business, we toured German factories before setting out to build our first 125cc bike. I joined in this tour around Europe during which my chief engineers learned how to build motorbikes. We did as much research as possible to insure that we could build a bike as good as any out there. Once we had that confidence, we started going."
A VISIONARY AT THE HELM:
"If you are going to make anything, make it the very best there is."
With this thought as their motto, the development team poured all their energies into building the first prototype, and ten months later, in August of 1954, the first model was complete. It was the Yamaha YA-1, powered by an air-cooled, 2-stroke, single-cylinder 125cc engine---basically a copy of the German DKW RT125 model. This bike, also known as the Akatombo (or "Red Dragonfly") of which only 125 units were built, was named in honor of the founder.
Once finished, it was put through an unprecedented 10,000 km endurance test to ensure that its quality was top-class, as well as winning two of Japan's premier road races of that era, the Mount Fuji Ascent Race and the Asama Volcano Highlands Event.
Due to the outstanding success of this first-ever model, in January 1955 the Hamakita Factory of the Nippon Gakki Company was built and full production of the YA-1 model began. With confidence in the new direction that Genichi was taking, Yamaha Motor Co., Ltd. was founded on July 1, 1955. Staffed by 274 enthusiastic employees, the new motorcycle manufacturer built about 200 units per month.
By 1956, a second model was ready for production. This was the YC-1, a 175cc single cylinder two-stroke. In 1957 Yamaha began production of its first 250cc, two-stroke twin cylinder model, the YD-1.
Based on Genichi's firm belief that a product isn't a product until it can hold it's own around the world, in 1958 Yamaha became the first Japanese maker to venture into the international race arena. The result was an impressive 6th place finish at the Catalina Grand Prix race in the USA.
Yamaha took quick action to build upon their momentum gained in the USA, and began marketing their motorcycles through an independent distributor in California. In 1958, Cooper Motors began selling the YD-1 250cc and the MF-1 (a 50cc, two-stroke, single cylinder, step-through street bike). Then in 1960, Yamaha International Corporation began selling motorcycles in the USA through its own network of dealers.
The modern Yamaha Motor Company had begun.
AN ENGINEERING COMPANY ON 2-STROKE FIRE:
In 1960, Genichi then turned his attention to the marine industry and began the production of the first Yamaha boats and outboard motors. This was the beginning of an aggressive expansion into these new fields utilizing new engines and FRP (fiberglass reinforced plastic) technologies. The first watercraft model was the CAT-21, followed by the RUN-13 and the P-7 123cc outboard motor.
In 1963, Yamaha demonstrated its focus on cutting-edge, technological innovations by developing the Autolube System---the separate oil injection system for two-stroke models, eliminating the inconvenience of pre-mixing fuel and oil. Further engineering developments such as torque induction, multi-ported engines, reed valves and power valves kept Yamaha at the forefront of two-stroke engine technology.
At the same time, Yamaha pioneered the idea of the "over-the-counter" racer bike, which became a reality with the introduction of the TD-1, the first in a long line of 2-stroke race bikes that were the standard for private race teams everywhere. Eventually, rules and competitive pressures changed, but the stage had been set for the introduction of mass-produced racers based on the same technology as the road bikes, and vice-versa.
Another example of the Genichi's belief in company efforts being focused on the needs of the customer was the Yamaha DT-1. The world's first true off-road motorcycle debuted in 1968 to create an entirely new genre we know today as "trail bikes". The DT-1 made a huge impact on motorcycling in the USA because it was truly dirt worthy. Yamaha definitely "read the flow" of consumer desires when it produced this 250cc, single cylinder, 2-stroke Enduro that put Yamaha On/Off-Road motorcycles on the map in the USA. The DT-1 exemplified the power of original ideas, forward vision, and quick action coupled with keeping in mind the customers' desires.
And once again, in 1975, Yamaha introduced the very first single-shock, production motocross bikes. This was the beginning of the YZ Monocross machines that changed motocross forever.
SO FOUR STROKES MUST BE TWICE THE FUN:
1970: Yamaha’s first 4-stroke motorcycle model, the XS-1 (650cc vertical twin) was introduced. A new era begins......
The XS-1 model was soon re-fashioned into the popular XS650 model, and quickly followed by the XS750 3-cylinder model in 1976. This was Yamaha's first large-displacement 4-stroke engine, and was also note-worthy as the first widely accepted shaft-drive motorcycle from Yamaha. Prior to its introduction, shaft drive motorcycles were associated only with higher-end, solid, dependable machines of limited performance appeal, such as the BMW and Honda Gold Wing designs.
As always, Yamaha was learning and refining their technologies and skills in order to better serve the developing needs of the marketplace and their customers.
As gas prices quenched the horsepower battle of the 1970's, the marketplace demanded more refined, mid-level machines that still performed well. Yamaha answered that challenge with the all new XJ series of bikes, which not only incorporated the now-refined shaft-drive technology (on all but the XJ550 models), but also introduced a newly developed and astonishingly narrow in-line four cylinder engine (achieved by moving the alternator from its usual location---at the end of the crankshaft---to above and behind the cylinders and driving it via a secondary, chain-driven shaft). This engine design proved so successful that it remained in production for over twenty years, while other major refinements were introduced in the area of suspension technology (air assistance and anti-dive valving on the front forks) as well as one of the first uses of computer-assisted operations on a motorcycle (although it was mainly a fancy gadget at that time, it was at the start of what obviously became the standard for the future), transistorized electronic ignition, and the recently developed YICS (Yamaha Induction Control System) performance enhancement for their cylinder heads.
Almost all XJ models incorporated many other desirable performance and safety-related features, such as:
- Self-canceling turn signals.
- Air adjustable front forks and rear shock absorber (on some models).
- Five position rear shocks, with adjustable damping.
- Lockable forks for security.
- A security chain (called a Powerlock) which is used to lock the bike to a pole.
- Trip odometer.
- A seat and helmet lock.
- YICS (Yamaha Induction Control System), a performance and fuel-saving engine system.
- Ignition cut-off safety system that does not allow the engine to be operated under certain conditions (if the kick stand is down, for example).
- One of the first uses of computerized systems monitoring systems, as introduced on the 1982 XJ750RH Seca models.
- Four-into-two exhaust design that provides for exceptional performance and acceptable sound levels.
The XJ-series were perhaps most unique in their consolidation of not only the technical refinements as described above, but also the integration of design and styling aesthtic elements that appealed to a wide population of buyers.....elements that still have strong appeal even today, 25+ years later. Let's take a quick detour and examine why.
A BRIEF HISTORY OF THAT TIME:
Most bikes (especially during the 1970's) were produced as street bikes, off-road, or dual-purpose bikes. Euro-style "café racers", touring bikes, low riders (choppers and semi chops) and the like were mostly custom modified versions of street bikes. During the early 70's most of the Japanese bikes (except Hondas) were powered by 2 stroke engines. By the mid-70's, the larger two stroke engines were being replaced with four stroke engines. Suzuki even introduced a bike that was powered by rotary engine! But by the end of the 1970's virtually all the street bikes being produced were 4-stroke, with Yamaha being no exception.
So by the end of the decade, the entire motorcycle industry was experimenting with giving a particular "style" to some of their newer models. By re-arranging the elements of what would basically be a standard road bike, the manufacturers produced an appearance similar to that of a customized motorcycle.....bringing to the mass marketplace what only the specialized customizers and choppers had been doing for some time.
Once again, it was this appreciation, understanding, and focus on the wants and need of the customers that fed-back into the entire organization---marketing, engineering, and production operations---that led to the development of these newer (and timeless in their appeal) XJ bikes.
So, starting with the XJ650H Maxim model (1980), these bikes featured a sloped down, almost "teardrop" syle fuel tank, a semi "king-and-queen" styled seat, and thus have a basic shape giving it the appearance similar to that of a cruiser. But this bike was no low rider...the seat is actually as high as what the earlier street bikes had. The handlebars of the Maxim are high enough and wide enough to provide both comfortable riding and exceptional control.
The Seca models took on more of a sport bike appearance, with flatter handlebars, more scalloped gas tank sides to allow for a more "forward leaning" riding position, and generally a sportier styling and appearance (even though the engine choices, power ratings, and performance were identical to their like-sized Maxim models).
Model choices soon proliferated around this basic design; the following list briefly summarizes the North American model availability:
- XJ550 Maxim and Seca models (1981 - 1983). The XJ550 and later FJ600 models are based on a different 4 cylinder, air-cooled inline DOHC powerplant than the larger 650cc-up models, and were never equipped with a shaft-drive system, only with a 6 speed chain drive transmission.
- XJ650 Maxim (1980-83) and Midnight Maxim (1981) models. Note that all of the Yamaha XJ650, XJ700 non-X, XJ750, and XJ900 models share the same basic air-cooled, inline DOHC four-cylinder shaft drive 5 speed powerplant and driveline.
- XJ650RJ Seca and XJ650RJC Seca (1982) models. The XJ650RJ Seca model was unique in that the USA versions were equipped with a non-YICS engine and no oil cooler....and were painted silver with blue graphics. The XJ650RJC Canadian versions were painted red, with red graphics, and had the YICS engine as well as a factory oil cooler. Some reports indicate that the red "RJC" model may have been available in the USA in limited quantities, and that it was equipped with the 750cc engine.
- XJ650 Turbo models (1982 and 1983). One of the very first factory-direct turbocharged models, these plastic-wrapped, full-fairing bikes still look modern today, and preceded the sportbike craze by almost a dozen years or so. While there are very few differences between the 1982 and 1983 models, the 1983 model does have a larger fuel tank, as well as a "power-up" kit that allowed for more boost pressure and subsequent higher horsepower ratings. The vacuum control module that was the main feature of the "power-up" kit was available a a retrofit to all 1982 models by Yamaha. 1983 XJ650LK Turbo models are very rare bikes.
- XJ700 models (1985 and 1986), both in a standard (air-cooled or "airhead") model and an "X" (water-cooled or "waterhead") version, further described below. The XJ700 models were produced as a response to US import tariffs set up to protect domestic (meaning Harley-Davidson) manufacturers from foreign (meaning Japanese) motorcycle sales sucess during the mid-80's, but those tariffs were soon dropped. Since Canada was obviously not subject to such restrictions, they got both the XJ700-X and XJ750-X models, while the USA dealers only got the 700cc versions, thus limiting the demand for such models. Therefore, XJ700 owners---of both the standard and "X" versions---and XJ750-X owners own a very rare machine and a testament to a part of USA legal history. An incredibly interesting review of the history of this situation can be seen at:
www.maxim-x.com/itc_70...tails.html
The XJ700-X and XJ750-X models have a water-cooled engine with the five-valves-per-cylinder Genisis engine based on the 1984 FZ750 model, but use the same bottom end and drive shaft unit as the other XJ650, XJ700, XJ750, and XJ900 models. The Maxim X was perhaps the fastest of the XJ series, as fast or faster than many sport-bikes of its day. And the XJ750-X models are indeed very rare bikes.
- XJ750 Maxim and Midnight Maxim (1982-83) models.
- XJ750 Seca (1981-84) models, although please note that the 1984 XJ750RL Seca is a Canadian- and Australian-only model, which is similar (possibly identical) to the XJ750-F in Europe. It's based on the XJ900, with a slightly different 750 motor than the Seca/Maxim 750 (it uses larger carbs, the airbox from the 900, and the same electronic ignition as the 900). It's so close to the XJ900 that the factory service manual is an XJ900 manual with a short (about 100 pages) addendum for the XJ750RL.
- XJ900RK Seca model (only available in 1983 in the USA).
- XJ1100 model (1982-83). The XJ1100 model was really a re-framed and re-named version of the already-popular XS1100 model, and did not use the XJ-series engine. The XJ1100 engine was based on the earlier XS1100 series, also a 4 cylinder, air-cooled inline DOHC shaft drive, and while the engine families are similar, there are some major design differences internally from the 650/700/750/900-based machines.
Besides the North American models, the rest of the world was also treated to XJ-Fever:
- the XJ550 model (no Maxim or Seca designation), from 1981 to 1983, which resembles the North American XJ550 Seca models (sans the front fairing). These models came with dual front disc brakes, unlike their USA and Canadian cousins. However, in 1984 only, there appears to have been a North-American style XJ550 that was offered in the European and U.K. markets, and it is based on the North American XJ550 Maxim model----meaning, it has only a single front disc brake on the left side, a Maxim style gas tank, and no fuel or volts gauge.
It should be noted that beginning in 1984, the XJ550 models became known as FJ600 models in the rest of the world, except for the above-referenced European/U.K. models.
- the XJ650 model (again, no Maxim or Seca designation), from 1980 to 1984, which also resembled the North American XJ650RJ Seca model. These models also came with dual front disc brakes and oil coolers, unlike the USA-Canadian versions.
- the XJ750 model, (guess what: no Maxim or Seca designation) from 1981 to 1984. As with the XJ650 models above, these bikes came stock with an oil cooler, unlike the North American models.
- the XJ900 model, which began production in 1983 and remained in production, off and on, in the rest of the world for almost a dozen years, where it was eventually known as the Diversion. As a special note, Yamaha changed the handlebar-mounted fairing to a frame-mounted style in 1984 (and apparantly refitted almost 1200 of the 1983 models----free of charge!---because of high-speed handling problems associated with the handlebar-mounted fairings). Also, the engine size was originally 853cc in 1983-84, and then increased to a "truer" 891cc's for the rest of its production life.
And finally, to throw a little bit of confusion into the mix, we have this:
- Yamaha also produced a couple of twin-cylinder XS400 bikes using the same Seca and Maxim designations for the North American markets. These bikes are the "younger cousins" of the XJ-series bikes, and are from the related-but-different "XS" series of models. Besides sharing the Maxim and Seca names, they use the XJ-series style engine (DOHC, alternator behind the crankshaft, YICS system). They were chain-driven (5-speed on the Maxim, 6-speed on the Seca models), and featured a unique mono-shock rear suspension system. They were available from 1982-83 in the USA, and lasted until until 1984 in Canada.
But, just to throw the usual Yamaha "twist" into the plot, there was also a 1982 XS400SJ "Special" model that was related to the older XS-series bikes, having the SOHC motor and a more typical dual-shock rear suspension...........
- Europe and Japan actually got a "real" XJ400 model --- a 4-cylinder Seca based on the XJ550. Similarly, the XJ600---also based originally on the XJ550 model---was produced in 1984-85, but was known as the FJ600 for the North American market. In later years, a new XJ600, with all-new frame and a mono-shock rear suspension system, was marketed as the Seca II in North America and the Diversion elsewhere.
- Somewhere along the line, Yamaha also introduced the XJR1200 (a chain-driven bike based on the FJ1100 and FJ1200 models) that never made it to North America either. In 2001 that was replaced by the XJR1300 and the FJR1300. Oddly enough, the XJR1300 is the chain drive, and the FJR1300 is the shaft drive, a reversal of the convention used originally in North America.
- Yamaha produced a few limited variations of their standard models over the years. There were Police versions of the XJ650 Seca, XJ750 Seca and the XJ900 Seca. The Japanese market had a fuel-injected XJ750-D model, while an XJ750-A model used the XJ650 Seca frame with the 750cc engine installed.
There---study and learn the above and you, too, can claim to be a certifiable XJ expert, nutcase, or both!
AND THEN SUDDENLY, THE MUSIC STOPPED:
However, not all things were quite as meets the eye, and it is an ironic twist of fate that what actually led to the development and introduction of the XJ-series of bikes also led to their demise.
The 1980's were actually a very difficult decade for the company.
In the late 70's/early 80's Yamaha made a conscious marketing and strategic business decision to try and overtake Honda as the largest builder of motorcycles, and that's what actually led to the amazing proliferation in both the number of models and production quantities.
Kawasaki and Suzuki quickly followed the herd, and soon the the world (especially North America, the biggest market) was awash in un-sold motorcycles, and the standard price wars that always follows over-production quickly started.
It has been noted that by the early 1980's that Yamaha alone had over 1 million unsold bikes in their dealer and factory inventory, and to try and move them out, huge price discounts started appearing......and that started eating into Harley-Davidson sales and profits.
This is when H-D went to the US Government and got an import tariff and restriction on 700+cc sized bikes. Which wasn't really necessary, since Yamaha had given up on their grand plan by then, and they and others simply slowly bled off the excess inventory via the discontinuance of most models (XJ's included) and no new production in most of 1983 and 1984.
In fact, soon after the 1985-86 models hit the showroom, H-D had gone back to the US Government and told them that the import restirctions were no longer needed! (and the restriction and tariff was lifted in 1987). Of course, for the USA, it was too late for those dealers to get the larger XJ750-X models........and by then, the consumer rush to the newer style model "sport" bikes and huge cruisers had started, and that was the end of the XJ-series of street-sport-cruiser style bikes.
So by this era---the mid-to-late 1980's---all manufacturers were styling most of their North American street bikes to fit into one of three basic categories:
Touring: Large, heavy bikes, with storage trunks, fairings, sound systems, and all sorts of comfort and convenience features----two wheeled "rolling couches".
Sport: Light, nimble, jack-be-quick race styled bikes, with lots of body shrouding ("plastic"), usually with high-revving, smaller displacement engines.
Cruisers: Smooth styling, low ride, mellow tuned.
All the major manufacturers produced some really great touring, sport, and cruising bikes; however, many motorcycle enthusiasts really did not see any of them falling into the category of what was really still desired.......and that being a capable, dependable, good-all-around "road bike".
The original XJ Seca and Maxim models seem to be some of the last of these "all around" road bikes that were available in the marketplace; that is, they don't really fit into one of the three basic categories above, but these bikes did have there own particular styling that suggested they were on the edge of both the cruising or sport styled categories. Sadly, models such as the XJ Maxim and the Seca did not continue in production anywhere, as the evolving Seca II type style (sport bike) seemed to become the market preference.
In years directly preceding and following these brilliant XJ-series of bikes, Yamaha continued to grow (and continues to this day). Product-line diversity increased with the addition of products including snowmobiles, race kart engines, generators, scooters, ATVs, personal watercraft and more.
Genichi Kawakami set the stage for Yamaha Motor Company's success with his vision and philosophies of total honesty towards the customer, making products that hold their own, and which provide an improved lifestyle to people through exceptional quality, high performance products. His history and influence with Yamaha was long and rich. He saw the new corporate headquarters in Cypress, California inaugurated in 1980, and the 25th Anniversary of Yamaha Motor Company become a reality in 1980. He also watched the 20-millionith bike roll off the assembly line in 1982. Genichi passed away on May 25, 2002 yet his vision lives on through the people and products of Yamaha, throughout the world.
XJ's FOREVER:
Today, it's no wonder there are riders and collectors that still prefer these classic bikes to anything they have seen produced since. While it is certainly true that these bikes have their share of flaws and faults----electrical system upgrades are a must on these older bikes, as they were barely adequate to begin with----but with some small changes such as upgraded technology and material usage in the brake system, they are one of the finest and most durable examples of the classic sport-cruiser models ever made, and thus retain their desirability, collectibility, and value even 25+ years after they were first introduced.
One owner sums up the XJ Experience with this insight:
"I just can't believe how much smoother the motor runs compared to my VMX. This old XJ motor is a real jewel. My brother rides a Yamaha FZR and he is very impressed with the smoothness of the XJ. He revs it up a bit at idle and remarks how much smoother it is than his FZR. With the stock pipes, the XJ750 sounds so sweet! It does this throaty 'woom-wooom' sound, and will rev to the moon and back, and it sounds just like music to my ears."
And so it should be, and perhaps was ordained to be. Yamaha started off almost a hundred years earlier making beautiful music---organs, pianos, and the like---and has never stopped.
Posted: Mon Dec 15, 2008 1:12 am Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION A:
INTRODUCTION:
--Model ID/VIN's
FRAME AND MODEL AND VIN NUMBERS, OH MY!!!
Okay, gather 'round friends and prepare yourself, 'cause we're about to go down the rabbit hole......
It goes without saying that the proper and correct identification of your bike is important for a number of purposes----first and foremost, so that you can order the correct parts for it! But equally important is making sure that your title is correctly identifying your bike for registration, title, and licensing purposes, as well as for insurance registration purposes, etc.
Our STRONGEST advice is to not rely on the information on your title, bill of sale, insurance documents, state registration certificates or any other PIECE OF PAPER-----always go "right to horse's mouth"----or in this case, your bike's frame, and absolutely verify 100% what bike you actually have! You'd would be quite surprised how many people we come across who are ordering parts, for example, for a 1981 model XJ-whatever because that's what it was sold to them as (or titled as), when in reality they have a 1982 model! YOUR FRAME AND ENGINE CASE ID NUMBERS ALWAYS SPEAKS THE REAL TRUTH! Some typed-up piece of paper from a government or insurance company clerk does not always fall into that same category of certainty!
ALSO: verify that the engine in your bike is the original engine! Since many of the XJ-series engines are physically interchangable with each other, you never know what's been done over the years as far as engine-swapping is concerned! Rings and pistons from a 650 model engine are NOT going to fit a 750 engine, even if the 750 engine is installed in an XJ650 frame!!! So please---spend the 90 seconds or so necessary to determine whether the engine is original to the bike, and if not, what year/make/model bike that the engine came from. The procedure for doing this is described completely further below.
And finally, if you take a little bit of study time all of the information below, then soon you, too, can start "code talking" about having a "1982 5N8 model" or a "750MK" and really impress the other guys at the shop with your intimate and devil-is-in-the-details knowledge about all things Yamaha......
Okay, as is proper with any good training video, we're going to start with the big picture and then work down to the nitty-gritty details.
So, buckle up, or hunker down, or whatever your favorite metaphor is------because there's going to be a pretty smooth take-off, but then expect some bumps in the road ahead.
NUMBERS, NUMBERS-----EVERYWHERE:
In order to provide a simple basis of communication both internally (between the engineering, sales, production, marketing, and other departments within a company) and also externally (retail dealers, customers, governmental and other outside parties), vehicle manufacturers of all kinds choose to (and are now required to) provide unique "shorthand" codes for each particular unit that they offer for sale. The most commonly used code is what is commonly known as a VIN or Vehicle Identification Number----a sort of "DNA fingerprint" for an individual product. Besides containing a unique serial number for an individual bike, the VIN number also identifies unique characteristics of a bike, such as the manufacturer, the model or "platform" identification, certain optional characteristics, the year of manufacture, etc.
Before we get down to deciphering a VIN number, let's take a brief step back in time, and recognize that prior to 1981, there was no real set standard for how VIN numbers had to be assigned.....in other words, the VIN Numbers used (by any vehicle manufacturer) prior to 1981 was more-or-less an internal-use number, and could be conjured up in whatever way struck a manufacturer's fancy and served their internal needs.
Starting in the late 1970's, with the proliferation of manufacturers, vehicle production volumes, and international sales, a solution to the "VIN dilemma" was suggested by the International Standards Organization (outlined in ISO Standard #3779, for the ultra-curious), and this standard was adopted and required to be used by all manufacturers that sold vehicles into the USA by the National Highway Traffic Saftey Administration (NHTSA) as of 1981. This is when the familiar, still-used-today 17-position VIN number came into use, and similar structured VIN formats were also adopted by Canada, the European countries, and many other countries around the world.
Prior to 1981, manufacturers could use a VIN number length of their choice, and Yamaha was no exception in this regard. In fact, because of the difficulty encountered with implementing this required 1981 changeover, Yamaha (and some other manufacturers) were granted a 9-month "stay of execution" for their 1981 model-year offerings, where they could still use their older (shorter) version VIN numbers to identify their products.
Thus 1980, 1981, and perhaps even some very early production 1982 model-year bikes use a shorter VIN number that appears on the frame of the bike (more about this later), and may also include a printed paper decal that lists a different (longer) VIN number that is the "extended", 17-posiiton version of the original, shorter VIN number.
Although for the purposes of absolutely, positively identifying your bike for exactly what it "is", the differences between the shorty VIN and the longer VIN are minor---although since the full 17-position VIN number contains more information, it makes the deciphering process a bit less time-consuming, but rest assured that----armed with the proper information---even a "shorty VIN" can be just as accurately and fully de-coded.
WHAT'S YOUR NAME, LITTLE XJ, BABY WHAT'S YOUR NAME?:
Okay, here is how Yamaha VIN's breakdown. We're going to start with the full 17-position VIN, and only later go backwards and look at the shorty VIN's and see how they inter-relate to each other.
As an example, we're going to play motorcycle manufacturer and we're going to build ourselves a 1981 XJ650 Maxim VIN.
Here is a standardized 17-position string of letters and characters that we'll use as an example:
1234567890abcdefg
Now, we're going to break up that 17-character string into it's component bits and pieces, like this:
123 -45678- -9- -0- -a- -bcdefg
It's broken up this way because each sub-group of positions (as shown above) has a specific meaning, and here they are:
The first 3-position field ("123") is known as the WMI, or World Manufacturer Identifier code. For Yamaha, their WMI is "JYA", and thus all Yamaha motorcycle VIN numbers from this era begin with JYA:
JYA -45678- -9- -0- -a- -bcdefg
For the curious, the WMI code actually has a specific meaning for each position: the first position identifies the country in which the vehicle was manufactured (J = Japan), the second position identifies the unique manufacturer (Y = Yamaha), and the third position identifies the vehicle type or manufacturing division (A = motorcycle).
The next 5-position field ("45678") identifies the vehicle characteristics, such a body style, engine type, model, "platform", series, etc. Since Yamaha only identified these bikes by their general MODEL ID CODE, this field is always populated by the 3-position model ID code (5N8, 5G2, 4H7, etc.) followed by two zeros (thus 5N800, 5G200, 4H700, etc.). Although Yamaha could have coded engine size, or paint color, or whatever else they wanted to into those extra two positions, they chose not to, and thus they are always filled with zeros:
JYA4H700 -9- -0- -a- -bcdefg
By the way, the "4H7" model ID code is for a USA-destined 1980-81 XJ650 Maxim model, just so you can follow along more easily.
The next 1-position field---position "9" above---is always a mathematically calculated "check digit" that looks at all other positions of the full VIN number, performs a mathematical formula (multiplying, adding, and then dividing according to a pre-determined routine), and uses the remainder as the check digit. This process insures that transcribing errors and forgery efforts can be identified more easily.
For our example, we're going to use the number 6 as the check digit:
JYA4H7006 -0- -a- -bcdefg
Okay, the next position---the tenth position in the VIN number (designated by the number -0- above) identifies the year of your bike. NOTE: the "year" actually refers to the MODEL YEAR of your bike, and not the year in which it was produced. Since "next year's" models normally are available in dealer showrooms sometime around September of the previous calender year, the model year of the bike and the calender year of a bike's production can differ.
In fact, on the VIN decal on your bike, besides the 17-position VIN number, you will also find the date of the bike production in the format MM/YY, such as 10/80 (meaning October, 1980). A 10/80-built bike would be a 1981 MODEL YEAR vehicle.
The model YEAR code in the tenth position of the VIN are as follows:
A = 1980
B = 1981
C = 1982
D = 1983
E = 1984
F = 1985
G = 1986
and so on......
Since we've agreed that we're putting together a 1981 model, then of course the tenth position is---from the chart above---the letter "B":
NOTE: we're going to confuse you now----and it won't be the last time. The year-designation letter codes listed above ONLY PERTAIN TO THE MODEL YEAR CODE USED IN THE VIN.
There is an alternative way of identifying the year of your bike by the Yamaha marketing "model name" of your bike, and it also uses a letter code for such year-model identification purposes, BUT SUCH MODEL DESIGNATION "NAMES" USE A DIFFERENT LETTER CODE THAN WHAT IS THE VIN "YEAR" IDENTIFIER CODE!
Okay, deep breath now, keep going, and forget about that last paragraph for now----but, do keep it in mind for later.........
JYA4H7006B -a- -bcdefg
The 11th position of a VIN number (-a-) is the location of the ASSEMBLY PLANT where the bike was made. All bikes in this era were produced in Japan, probably at their Iwata City production facility, which was the "A" location. Thus the 11th position of all XJ model bikes will be the letter "A":
JYA4H7006BA -bcdefg
And now we're down to the last 6 positions of the full VIN, and this is the unique, sequential "serial number" of each individual bike. Your own bike has a serial number that is different than every other one ever produced for your model and year bike.
For various reasons, Yamaha assigned a range of serial numbers for each bike year and model, and these numbers did not normally start with the number "000001". The starting point for each serial number differs by year and model. For the 1981 XJ650 Maxim used in this example, the serial number range starts with serial number "100101". Each subsequent 1981 XJ650 Maxim model 4H7 destined for the US marketplace got the next higher serial number, thus the second bike off the assembly line was #100102, etc.
Let's pretend that this was the 1,356th 1981 XJ650 Maxim destined for the US marketplace. So starting with the 100101 number, we add 1,356 to it, and get: 101457 ( = 1,356 + 100,101).
So our final VIN for this particular bike is:
JYA4H7006BA101457
which, breaking it down into its component, meaningful parts again, is this:
JYA -4H700- -6- -B- -A- -101457
Now, with all of the above in mind, we can see from the above 17-position VIN that most of the information that is USEFUL is really just the MODEL ID part (4H700), the year (B), and the unique serial number portion (101457).
In fact, in the model ID part, since positions 4 and 5 were not used by Yamaha to designate anything at all, and thus are always "00", then really only the model ID part (4H7) contain any useful infromation:
4H7---the model identification portion, in this case meaning a 1980 or 1981 XJ650 Maxim.
B---the model year, in this case 1981.
101457---the unique production number ("serial number") of this particular bike.
And Here's Where We Go Backwards:
From the example above, we see that although a full 17-position VIN number was required of Yamaha (and everyone else) beginning in 1981, all of the useful information contained in the 17-position VIN can just as easily be captured by a "shorty" version of the VIN, just as Yamaha used prior to 1981:
4H7-101457
That smaller string of numbers, above, is what was considered a "VIN" number for 1981 and prior years.
BUT WAIT!, I hear you cry.........where is that useful piece of information called the "YEAR"? (in the full "long VIN", recall that the 10th position uses a letter code to designate the model YEAR, and in our example it's the letter "B", since B = 1981).
Good question. And here's the good answer:
Recall this statement from above:
"For various reasons, Yamaha assigned a range of serial numbers for each bike year and model, and these numbers did not start with the number 000001."
Well, one of those reasons is that by assigning a defined RANGE of unique serial numbers to each year and model of bike, that unique serial number not only identifies the individual unit of production (thus completely serving the "serial number, DNA-fingerprint" purpose of that number), but also serves as a way of identifying the year of production, too!
Here, as an example, for the 1980 and 1981 XJ650 Maxim (4H7) models, we have:
1980: starting serial number of 000101
1981: starting serial number of 100101
Thus, if you come across this shorty VIN:
4H7-021338
then you know that since the "serial number" is less than the number 100,101 (which is the starting serial number for 1981 models), then it's a 1980 XJ650 Maxim.
But when you see this shorty VIN, as from our "Build-A-Bike" example above:
4H7-101457
then since that serial number is greater than the "100101" starting point for 1981 model year bikes, then you automatically know that it's a 1981 (and not a 1980) "4H7" bike (an XJ650 Maxim).
And In Confusion, Whoops, I Meant "Conclusion":
Because the rules changed in 1981, and forced vehicle builders to use a structured, standardized 17-position format for the VIN, the 1980 and 1981 model bikes can have both the long or the short (or both) VIN numbers on the bike. With a little bit of additional information (the serial number range), you can fully "translate" the shorty VIN into the longer 17-position VIN. The longer VIN is standardized, and I suppose that's good; and it also explicitly codes the model year (in the 10th position), which is really the ONLY feature that the shorty VIN does not clearly encode.
Now, onto the burning questions:
Where on my bike is this long, or short, or any other VIN's?:
I don't have the slightest idea.........
Just kidding. The number(s) are in at least two places, and on most bikes, three locations:
1) On the right side of the steering "neck" or tube (or "head pipe" as it is sometimes called), you'll find stamped the shorty VIN (1980 and early-1982 models) or the full 17-positions VIN (late-1981 and later years) is stamped, vertically, into the frame tube.
2) On the left side of the steering "neck" or tube, there will be a white printed decal that will have the full 17-position VIN, along with typical boilerplate "conforms with regulations blah-blah-blah" wording. NOTE: it is on this decal, and only on this decal, that the date of your bike's manufacture is also printed, in a MM/YY format (i.e. 10/81 = October 1981 = a 1982 model year bike).
Note that for late-1981 year bikes and on, that the full 17-position VIN number appears on both the left-side decal and right-side stamping of the frame's steering neck tube.
On some later model bikes----primarily late-model XJ900 models----this ID "decal" became a metal plate that was rivited to the right side frame down-tube.
3) On the engine case, just behind or beside the clutch cover on the right side of the engine, on a small, flat machined pad that faces up (towards the sky). On XJ550 models, this pad is oriented left-to-right on the engine case, while on all other models it is oriented front-to-back.
What will you find on this pad?
The "shorty" VIN, as described previously. In our 1981 XJ650 Maxim, example, this flat pad would have this number stamped into it (as long as the engine is the original engine that came with the bike):
4H7-101457
Note that it does not matter what year your bike is; even after 1981, the number stamped onto this engine case pad is ALWAYS the "shorty VIN" number, and never the 17-position VIN.
From our discussion above, it is clear that if the engine in the bike is the original engine, then this number on the engine case will match, exactly, the shorty VIN on the right side of frame neck tube (1980 to early-1981 models), or, working backwards, to the model ID (4H7) and unique serial number (101457) of the longer VIN on 1982-later models.
Also, in situations where the engine has been replaced, you can actually figure out not only what engine it is (from the shorty VIN stamped onto the engine case), but you can actually work out the actual VIN number of the bike that such engine came from! All you need to know is the model ID codes (listed below), the serial number ranges (also listed below), and from that you can figure out the YEAR of the engine (and thus the bike).......giving you that "missing" bit of information that the full 17-position VIN does explicitly code for.....and then, using the "check digit" computation routine, you can actually calculate the full, complete VIN for the bike that an engine came from!
Now that's some kinda special party trick, you gotta admit!
Some Other Semi-Useful Tidbits Of Information About VIN's:
* In order to avoid visual confusion errors, the letters I, O, and Q are not allowed in any position of a 1981-later VIN.
* In order to avoid visual confusion errors, the characters U, Z, and 0 (zero) are not used for the model-year designation (the 10th position); however, the letters U and Z and the number 0 can be used in any other positions of the VIN.
* Although you didn't ask, here is how you calculate the "check digit" that is in position #9 in the VIN:
A) All letters and characters in the long VIN are assigned a numerical value. Numbers, of course, keep their like-value (i.e. 1 = 1, 5 = 5, etc.) Letters are assigned the numerical values as follows:
1 = A or J
2 = B, K, or S
3 = C, L, or T
4 = D, M, or U
5 = E, N, or V
6 = F or W
7 = G, P, or X
8 = H or Y
9 = R or Z
B) A multiplication factor is assigned to each VIN character position:
1st position: x8
2nd position: x7
3rd position: x6
4th position: x5
5th position: x4
6th position: x3
7th position: x2
8th position: x10
9th position: unknown, this is what you're trying to figure out!
10th position: x9
11th position: x8
12th position: x7
13th position: x6
14th position: x5
15th position: x4
16th position: x3
17th position: x2
C) Okay, now convert the 17-position VIN to the numerical value as outlined in "A" above:
JYA4H700?BA101457 (the ? is the check digit we're trying to calculate)
becomes, from the coding routine in "A" above:
18148700?21101457
and multiply each position value by the multiplication factor in "B" above:
1st position: 1 x8 = 8
2nd position: 8 x7 = 56
3rd position: 1 x6 = 6
4th position: 4 x5 = 20
5th position: 8 x4 = 32
6th position: 7 x3 = 21
7th position: 0 x2 = 0
8th position: 0 x10 = 0
10th position: 2 x9 = 18
11th position: 1 x8 = 8
12th position: 1 x7 = 7
13th position: 0 x6 = 0
14th position: 1 x5 = 5
15th position: 4 x4 = 16
16th position: 5 x3 = 15
17th position: 7 x2 = 14
D) Now, add up all those sums from above:
8 + 56 + 6 + 20 + 32 + 21 + 0 + 0 + 18 + 8 + 7 + 0 + 5 + 16 + 15 + 14 = 226
Divide the sum (226) by 11 and note what the "remainder" is:
226 divided by 11 = 20 with a "remainder" of 6.........here, I'd forgotten basic math, too, so here's what a "remainder" is!:
226 divided by 11 is 20.5455, but the ".5455" part is not important. What IS important is that 11 x 20 = 220, and the "remainder" is 6 (because 220 + 6 is = 226). The "remainder" is the amount "left over" when you are using just whole numbers, no decimal places or fractions allowed.........
So the check digit for this VIN is 6:
JYA4H7006BA101457
By the way, if the calculations for a particular VIN leaves a "remainder" of 10 or more, then the check digit becomes the letter "X".
NOW MY BRAIN HURTS.........PLEASE STOP!:
No, you're doing really good!
And now we're going to get to the devil-details. NOW you're gonna' become a full-fledged XJ Fanatic!
Here's a review of the YEAR CODES in the 10th position of the full 17-position VIN's:
A = 1980
B = 1981
C = 1982
D = 1983
E = 1984
F = 1985
G = 1986
and so on......
Well, in the time before 1981---when there was no 17-position VIN's, and thus no "year codes" as defined above---Yamaha did have a way to "code" the year model of their bikes. Truth Be Told, they actually had two different ways.
The first method, we've already reviewed: the "serial number range" method. For the people who had access to, or just flat-out memorized serial number ranges by bike model, this method works fine. Remember this?:
1981: starting serial number of 100101"
Sure you do.
Now, since most people weren't about to memorize serial number ranges, a second method was devised by Yamaha to code the year model into an easy-to-understand code.
In naming their bikes, Yamaha would refer to bikes by their MODEL NAME (i.e. XJ550, XJ650, etc.) and then add a---you guessed it---a LETTER CODE to the end of the model name, as such:
XJ550H
XJ750J
XJ900RK
Unfortunately, the letter codes used in this manner bear no relation to the letter codes used in the 17-position VIN schemes.
Here's the Yamaha letter codes:
A = 1974
B = 1975
C = 1976
D = 1977
E = 1978
F = 1979
G = 1980
H = 1981
J = 1982
K = 1983
L = 1984
N = 1985
S = 1986
A couple of things to note here:
a) Prior to 1974, no code was used to designate the model year.
b) The letter I is skipped from the 1981-1982 sequence.
c) The letter M is skipped from the 1984-1985 sequence.
d) The letter O, P, Q, and R are skipped from the 1985-1986 sequence.
So the Yamaha coding system for identifying a particular bike was the use of the MODEL NAME (XJ550, XJ750, etc.) and then adding a year "suffix" at the end:
XJ550H is a 1981 XJ550 Maxim (the letter "H" = 1981)
XJ750J is a 1982 XJ750 Maxim (the letter "J" = 1982)
XJ900RK is a 1983 XJ900 Seca (the letter "K" = 1983)
Uh-oh........that last one is a bit confusing (there's two suffixes....R and K).
Well, to distinguish between a regular Maxim model and a Seca (or other) model, Yamaha also used other suffixes:
nothing = a regular base model (Maxim is the base model in the USA and Canada)
R = Seca
C = could mean Canadian, or could mean California. Nice, huh?
M = Midnight version of a Maxim, if it's an XJ750, but "L" if it's an XJ650 model, unless, of course, it's a 1982 or 1983 XJ650 model, in which case "L" refers to the Turbo Seca model, and..........
L = any one of a number of different things....
I think the best thing we can say is that "perhaps it's better than nothing".
Perhaps.........
The key point to remember is the letter codes above refer to the years. Here's the complete list of North-American MODEL NAMES:
550's:
XJ550H = 1981 XJ550 Maxim
XJ550RH = 1981 XJ550 Seca
XJ550J = 1982 XJ550 Maxim
XJ550RJ = 1982 XJ550 Seca
XJ550K = 1983 XJ550 Maxim
XJ550RK = 1983 XJ550 Seca
650's:
XJ650G = 1980 XJ650 Maxim
XJ650H = 1981 XJ650 Maxim
XJ650LH = 1981 XJ650 Midnight Maxim
XJ650J = 1982 XJ650 Maxim
XJ650RJ = 1982 XJ650 Seca, USA
XJ650RJC = 1982 XJ650 Seca, Canada
XJ650LJ = 1982 XJ650 Seca Turbo
XJ650K = 1983 XJ650 Maxim
XJ650LK = 1983 XJ650 Seca Turbo
XJ650L = 1984 XJ650 Maxim
700's:
XJ700N = 1985 XJ700 Maxim, 49-state version
XJ700NC = 1985 XJ700 Maxim, California models
XJ700XN = 1985 XJ700 Maxim X, 49-state version
XJ700XNC = 1985 XJ700 Maxim X, California models
XJ700S = 1986 XJ700 Maxim, 49-state version
XJ700SC = 1986 XJ700 Maxim, California models
XJ700XS = 1986 XJ700 Maxim X, 49-state version
XJ700XSC = 1986 XJ700 Maxim X, California models
As an aside, I've always secretly admired these 1986 "X" model codes, as the model - year designation (XS and XSC) phonetically sound out the word "excess"......and I'd congratulate Yamaha on such a clever marketing tactic, but alas, it just seems like it was a "luck of the draw" sorta thing.........
750's:
XJ750RH = 1981 XJ750 Seca
XJ750J = 1982 XJ750 Maxim
XJ750RJ = 1982 XJ750 Seca
XJ750K = 1983 XJ750 Maxim
XJ750MK = 1983 XJ750 Midnight Maxim
XJ750RK = 1983 XJ750 Seca
XJ750RL = 1984 XJ750 Seca, Canada and Australia only
XJ750XN = 1985 XJ750 Maxim X, Canada only
XJ750XS = 1986 XJ750 Maxim X, Canada only
900's:
XJ900RK = 1983 XJ900 Seca
1100's:
XJ1100J = 1982 XJ1100 Maxim
BUT WAIT! IF YOU ORDER RIGHT NOW, WE'LL THROW IN A FREE MODEL ID CODES BOOKLET........
Okay, from the above you can see what the Yamaha coding of the model and year was in their "marketing" descriptions of their bikes.
But there's another way, too.....the MODEL ID CODE. You've actually already been exposed to it within the VIN section previously; now, let's get serious about these codes!
The Model ID Codes are just another way of using a short code to substitute for a longer description. In our original example, "4H7" is a shorthand way or expressing 1980 or 1981 XJ650 Maxim model.
Here's the list of 3-position MODEL ID CODES for North American models. Later, we'll provide a complete list of all the worldwide codes:
550's:
1981-83 XJ550 Maxim USA: 5K5
1981-83 XJ550 Maxim Canada: 5K6
1981-83 XJ550 Seca USA: 4U8
1981-83 XJ550 Seca Canada: 4U9
650's:
1980-81 XJ650 Maxim USA: 4H7
1980-81 XJ650 Maxim Canada: 4H8
1981 XJ650 Midnight Maxim USA: 4W5
1981 XJ650 Midnight Maxim Canada: 4W6
1982-83 XJ650 Maxim USA: 5N8
1982-83 XJ650 Maxim Canada: 5N9
1982 XJ650 Seca USA : 5V2
1982 XJ650 Seca Canada: 5V3
1982-83 XJ650 Seca Turbo USA : 16G
1982-83 XJ650 Seca Turbo Canada: 16H
700's:
1985 XJ700 Maxim USA: 1FG (49-state version)
1985 XJ700 Maxim USA: 1JJ (California version)
1985 XJ700 Maxim Canada: 1FH
1985 XJ700 Maxim X USA : 1AA (49-state version)
1985 XJ700 Maxim X USA: 1FJ (California version)
1986 XJ700 Maxim USA: 1NH (49-state version)
1986 XJ700 Maxim USA: 1NK (California version)
1986 XJ700 Maxim Canada: 1NJ
1986 XJ700 Maxim X USA: 1NW (49-state version)
1986 XJ700 Maxim X USA: 1LT (California version)
750's:
1982 XJ750 Maxim USA: 15R
1982 XJ750 Maxim Canada: 15T
1983 XJ750 Maxim USA: 22R
1983 XJ750 Maxim Canada: 22T
1983 XJ750 Midnight Maxim USA: 33N
1983 XJ750 Midnight Maxim Canada: 33U
1981-83 XJ750 Seca USA: 5G2
1981-83 XJ750 Seca Canada: 5H2
1985 XJ750 Maxim X Canada: 1FL
1986 XJ750 Maxim X Canada: 1MY
900's:
1983 XJ900 Seca USA: 35H
1983 XJ900 Seca Canada: 31E
1100's:
1982 XJ1100 Maxim USA: 10M
1982 XJ1100 Midnight Maxim Canada: 11G
1983 XJ1100 Maxim Canada: 11G
1984 XJ1100 Midnight Maxim Canada: 11G
Let's see, we can now identify your bike in at least four different ways! Using our original "Build-A-Bike" example from above, we have:
1) by the shorty VIN: 4H7-101457
From the chart above, we know that the "4H7" MODEL ID designation is a 1980 or 1981 XJ650 Maxim, and from the serial number (101457), we previously learned that this serial number falls into the 1981 model year range of serial numbers.
2) By the full VIN: JYA4H7006BA101457
This identifies it as a XJ650 Maxim (the "4H7" part), and a 1981 model (the letter "B" in the 10th position).
3) We can call it by the Yamaha MODEL NAME: XJ650H
Recalling from before, the "H" suffix means it's a 1981 XJ650 model.
4) By the "STREET-NAME" common usage method:
"I've got a 1981 XJ650 Maxim".
Note how all of the following ways of expressing this one bike ARE ALL IDENTICAL:
1981 XJ650 Maxim
XJ650H
4H7-101457
JYA4H7006BA101457
Suppose we wanted to tell someone that the Atlanta Braves beat the Denver Rockies by a score of 3-2. We could say:
"The Braves beat the Rockies 3-2."
"Atlanta defeats Denver by 3-2."
"The final score is: The Braves 3, the Rockies 2."
"The Braves outscored the Rockies by 3-to-2."
and it all means the same thing.
The same thought applies to VINs, both long and short versions, and Model Names and Model ID Codes. They all mean the same thing. They all tell the same story. The all communicate the same essential information about your bike: make, model, and year.
OPERATORS ARE STANDING BY.........:
There's one other thing you need to know, but don't really want to know (I'm already ducking for cover as I write this......). It muddies the waters, it puts a fly in the ointment, and a monkey-wrench in the works, etc.
It's sad, but it's true, so here goes:
Remember way back when, we were talking about the long 17-position VIN, and we referred to positions 4-8 as the vehicle's "characteristics" field:
"The next 5-position field ("45678") identifies the vehicle characteristics, such a body style, engine type, MODEL, "platform", series, etc. Since Yamaha only identified these era bikes by their general MODEL TYPE, this field is always populated by the 3-position model (5N8, 5G2, 4H7, etc.) followed by two zeros (thus 5N800, 5G200, 4H700, etc.). Although Yamaha could have coded engine size, or paint color, or whatever else they wanted to into those extra two positions, they chose not to, and thus they are always filled with zeros."
Note that pesky word "platform". It has now come back to haunt us.
For a car, a "platform" refers to the basic standardized frame or unibody, and as you probably realize, many cars in the same "family" from a manufacturer all share the same basic frame, but with different body features (sheetmetal, trim, interiors, etc.) tacked on to create a different model.
Well, the same thought kinda-sorta applies to motorcycles, too......and in the two-wheeled word, the "platform" is the basic motorcycle frame.
The same frame can be used to create any number of different models. For example, think of a Midnight Maxim: it's the same as the standard Maxim model that it's based upon, but with a special paint scheme and other minor feature differences. HOWEVER, from a marketing point of view, it's a different "model", and thus carries a different MODEL NAME and a different MODEL ID code.
But it's the same frame underneath.
As an example for all those "curiosity kills the cat" type of fellas out there: the XJ750 Midnight Maxim DID (logically) share the same frame with a 1983 XJ750 Maxim but---obviously---not the same model ID:
1983 XJ750 Maxim = 22R MODEL ID
1983 XJ750 Midnight Maxim = 33N MODEL ID
But both bikes share the same FRAME ID = 22R
This is unlike the differences between, let's say, a 1982 XJ650 Maxim and a 1982 XJ650RJ Seca----although you might think that it's just minor cosmetic and feature differences (different seat, different gauge cluster, slightly different side covers and fuel tank and handlebars and other "bolt-on" items, etc.), in reality, their basic frame and structural components are different. Similar, perhaps, but quite unique: the steering head angle is different, as are the footpeg, sidestand, and engine mount locations and features (super-quick XJ-Factoid detour here: except for the XJ550 Seca models, all other Seca and the XJ650 Turbo model bikes do not use rubber insulators to mount the engine to the frame---as the Maxim models used---thus using the engine as an additional "stressed frame member" for additional frame rigidity.....and, also, as a sometimes added "buzz" and vibration-producing component!). Those two bikes are not only different marketing "models" (and thus use different MODEL NAMES and different MODEL ID Codes), but also use different "platforms" as well......meaning different FRAME ID Codes.
And the truth be known, the number that is stamped into the steering neck tube is really the FRAME ID CODE, and not the MODEL ID CODE.
For most bikes.....meaning 99% of them on the NORTH AMERICAN XJ models.....the Frame ID Code and the Model ID Code are one and the same. It's why this is such a mis-understood and rarely-discussed issue.
But this distinction occurs very frequently in the "rest-of-the-world" (non-North American) models, and when you review the list of full bike codes below, you'll see these differences quite a bit on those models.
And now you know why.........
And one last issue that creeps in, to help make a mess of things, applies mainly to later model bikes (primarily 1988-later, which means it only applies to the XJ900 series of bikes in our beloved XJ-series), although this same issue manifests itself in the entire Yamaha line, and even continues to this day.......and that is, Yamaha apparently felt that they were going to run out of unique 3-position MODEL ID CODES, so they switched to 4-position Model ID Codes (such as the 4BB1, 4BB2, etc. codes that are seen on the 1990-later XJ900 models). HOWEVER, the FRAME ID's continued to be expressed as the same 3-position field as had always been used (example: 1989 XJ900 Model ID Code is a 3NG1, but the Frame ID Code is 58L).
Many of these type of variations seem to predominate in bikes made for the smaller markets, where some type of non-standardized modifications had to be made to the "standard" version of the bike to meet local laws, primarily for the European markets (since at that time, the EU began trying to standardize the often-varying laws that could be found in differing European countries, some of which still remain to this day.......for example, British headlights must be aimed left-of-center, French bikes are limited in their maximum horsepower ratings, etc.). Thus new Model ID Codes started proliferating to meet such challenges.
Just another tiny tidbit of information to keep in mind.......!
THE FULL MONTY:
Okay, what follows is the whole, fine kettle of fish, with all of the Model ID Codes, Frame ID Codes, frame serial number ranges, and Model Names all rolled into one chart. With this information at hand, you can properly identify your bike (or any other XJ-series bike) that you come across with absolute certainty. PLEASE BE AWARE THAT IN ORDER TO PROPERLY ORDER PARTS FOR YOUR BIKE, IT IS NECESSARY TO KNOW WHICH MODEL YOU ACTUALLY HAVE, AS THERE CAN BE SUBTLE OR MAJOR DIFFERENCES BETWEEN VARIOUS MODELS OF OTHERWISE SIMILAR BIKES!
Also, please note that certain models, such as the XJ250, XJ400, and XJ500 models, while being very similar to their larger North American "brothers", were never offered in the USA or Canadian marketplace, and therefore are not covered in much (if any) detail in our product listings (and unfortunately we do not have the product interchange information available for those models).
FINALLY: although many other Yamaha series of bikes from this era, such as the XS-series, XV-series, and others may have used some parts that are interchangable with the XJ-series models, we generally do NOT have such information available. In many instances, parts that may seem to be "the same" between various model lines may indeed be the same parts, but most times there are small variations in design, fit, or specifications that make such components not suitable for interchange between different series of bikes.
XJ250 Models
1984 XJ250 MODELS:
COUNTRY: GUAM
MODEL NAME: XJ250L
STREET NAME: 1984 XJ250
MODEL ID CODE: 49W
FRAME ID: 5K5
SERIAL NUMBER STARTS AT: 200101
XJ400 Models
NOTE: XJ400 models were styled and equipped almost exactly like the North American XJ550 Seca model, but used the small 400cc YICS engine (and no front fairing).
1981 XJ400 MODELS:
COUNTRY: EUROPE
MODEL NAME: XJ400
STREET NAME: 1981 XJ400
MODEL ID CODE: 4V7
FRAME ID: 4V7
SERIAL NUMBER STARTS AT: 000101
MODEL NAME: XJ400
MODEL ID CODE: 5F8
FRAME ID: 4V7
SERIAL NUMBER STARTS AT: 100101
COUNTRY: JAPAN
MODEL NAME: XJ400
MODEL ID CODE: 4G0
FRAME ID: 4G0
MODEL NAME: XJ400
MODEL ID CODE: 5M8
FRAME ID: 4G0
SERIAL NUMBER STARTS AT: 060101
MODEL NAME: XJ400H
MODEL ID CODE: 5M9
FRAME ID: 4G0
SERIAL NUMBER STARTS AT: 070101
MODEL NAME: XJ400
STREET NAME: 1981 XJ400 Special
MODEL ID CODE: 5L8
FRAME ID: 4G0
SERIAL NUMBER STARTS AT: 050101
1982 XJ400 MODELS:
COUNTRY: JAPAN
MODEL NAME: XJ400
STREET NAME: 1982 XJ400
MODEL ID CODE: 5M8
FRAME ID: 4G0
MODEL NAME: XJ400
MODEL ID CODE: 5M9
FRAME ID: 4G0
1983 XJ400 MODELS:
COUNTRY: EUROPE
MODEL NAME: XJ400
STREET NAME: 1983 XJ400
MODEL ID CODE: 28F
FRAME ID: 4V7
SERIAL NUMBER STARTS AT: 210101
COUNTRY: JAPAN
MODEL NAME: XJ400K
MODEL ID CODE: 39N
FRAME ID: 4G0
SERIAL NUMBER STARTS AT: 300101
MODEL NAME: XJ400Z
MODEL ID CODE: 33M
FRAME ID: 33M
MODEL NAME: XJ400ZE
MODEL ID CODE: 53U
FRAME ID: 33M
SERIAL NUMBER STARTS AT: 080101
MODEL NAME: XJ400ZS
MODEL ID CODE: 35J
FRAME ID: 33M
SERIAL NUMBER STARTS AT: 025101
COUNTRY: OTHER
MODEL NAME: XJ400P
MODEL ID CODE: 24H
FRAME ID: 24H
1992 XJ400 MODELS:
COUNTRY: JAPAN
MODEL NAME: XJ400S
STREET NAME: 1992 XJ400
MODEL ID CODE: 4BP1
FRAME ID: 4BP
1993 XJ400 MODELS:
COUNTRY: JAPAN
MODEL NAME: XJ400S
STREET NAME: 1993 XJ400
MODEL ID CODE: 4BP2
FRAME ID: 4BP
XJ500 Models
1981 XJ500 MODELS:
COUNTRY: EUROPE
MODEL NAME: XJ500
STREET NAME: 1981 XJ500
MODEL ID CODE: 5N4
FRAME ID: 5N4
1983 XJ500 MODELS:
COUNTRY: EUROPE
MODEL NAME: XJ500
STREET NAME: 1983 XJ500
MODEL ID CODE: 27E
FRAME ID: 5N4
SERIAL NUMBER STARTS AT: 005101
XJ550 Models
NOTE: Although the North American market was treated to two different versions of the XJ550 model (Maxim and Seca versions), the rest of the world generally had only one version available, and that version is most similar to what is known as the XJ550 Seca model in North America. In addition, these "overseas" versions came equipped with dual front disc brakes, which unfortunately was never offered on the USA or Canadian versions.
Although not generally referred to in the overseas markets as "Seca" models (since there was only one model available, there was no need to give it a "name" needed to differentiate it between a base Maxim model), these overseas versions came equipped with the "scalloped" design fuel tank, fuel gauge package, and other special components which are normally found in the North American XJ550 Seca models.
Also, although the XJ550 "evolved" over time into both the FJ600 and XJ600 bikes in various markets, these bikes---although sharing some features and components with the earlier XJ550 models----are different enough in most components and design to have very limited product or service interchange, and as such, are not listed nor covered by us.
1981 XJ550 MODELS:
COUNTRY: USA
MODEL NAME: XJ550H Maxim
STREET NAME: 1981 XJ550 Maxim
MODEL ID CODE: 5K5
FRAME ID: 5K5
MODEL NAME: XJ550RH Seca
STREET NAME: 1981 XJ550 Seca
MODEL ID CODE: 4U8
FRAME ID: 4U8
COUNTRY: CANADA
MODEL ID CODE: 5K6
FRAME ID: 5K6
USA MSRP PRICE: $ 2,299.00
MODEL ID CODE: 4U9
FRAME ID: 4U9
USA MSRP PRICE: $ 2,529.00
COUNTRY: EUROPE
MODEL NAME: XJ550
MODEL ID CODE: 4V8
FRAME ID: 4V8
NOTES: styling and features the same as North American XJ550 Seca model, has dual front disc brakes, no fairing, and an oil cooler.
COUNTRY: GERMANY
MODEL NAME: XJ550
MODEL ID CODE: 4V9
FRAME ID: 4V9
COUNTRY: OCEANIA
MODEL NAME: XJ550RH
MODEL ID CODE: 5F9
FRAME ID: 5F9
1982 XJ550 MODELS:
COUNTRY: USA
MODEL NAME: XJ550J
STREET NAME: 1982 XJ550 Maxim
MODEL ID CODE: 5K5
FRAME ID: 5K5
SERIAL NUMBER STARTS AT: 020101
USA MSRP PRICE: $ 1,999.00
MODEL NAME: XJ550RJ
STREET NAME: 1982 XJ550 Seca
MODEL ID CODE: 4U8
FRAME ID: 4U8
USA MSRP PRICE: $ 2,599.00
COUNTRY: CANADA
MODEL NAME: XJ550J
MODEL ID CODE: 5K6
FRAME ID: 5K6
MODEL NAME: XJ550RJ
MODEL ID CODE: 4U9
FRAME ID: 4U9
COUNTRY: EUROPE
MODEL NAME: XJ550
MODEL ID CODE: 26Y
FRAME ID: 4V8
COUNTRY: OCEANIA
MODEL NAME: XJ550RJ
MODEL ID CODE: 5F9
FRAME ID: 5F9
1983 XJ550 MODELS:
COUNTRY: USA
MODEL NAME: XJ550K
STREET NAME: 1983 XJ550 Maxim
MODEL ID CODE: 5K5
FRAME ID: 5K5
MODEL NAME: XJ550RK
STREET NAME: 1983 XJ550 Seca
MODEL ID CODE: 4U8
FRAME ID: 4U8
USA MSRP PRICE: $ 2,699.00
COUNTRY: CANADA
MODEL NAME: XJ550K
MODEL ID CODE: 5K6
FRAME ID: 5K6
MODEL NAME: XJ550RK
MODEL ID CODE: 4U9
FRAME ID: 4U9
COUNTRY: EUROPE
MODEL NAME: XJ550
MODEL ID CODE: 27A
FRAME ID: 4V8
COUNTRY: OCEANIA
MODEL NAME: XJ550RK
MODEL ID CODE: 31V
FRAME ID: 31V
SERIAL NUMBER STARTS AT: 001000
COUNTRY: OTHER
MODEL NAME: XJ550P
MODEL ID CODE: 24J
FRAME ID: 24J
SERIAL NUMBER STARTS AT: 100000
1984 XJ550 MODELS:
COUNTRY: EUROPE
MODEL NAME: XJ550L
STREET NAME: 1984 XJ550
MODEL ID CODE: 5K6
FRAME ID: 5K6
NOTES: styling the same as North American XJ550 Maxim model.
XJ650 Models
NOTE: Although the North American market was treated to two major versions of the XJ650 model (Maxim and Seca versions), the rest of the world generally had only one version available, and that version is most similar to what is known as the XJ650RJ Seca model in North America.
Although not generally referred to in the overseas markets as "Seca" models (since there was only one model available, there was no need to give it a "name" needed to differentiate it between a base Maxim model), these overseas versions came equipped with the dual front disc brakes, "scalloped" design fuel tank, and other special components which are normally found in the North American XJ650RJ and XJ650RJC Seca models.
NOTE: it has been suggested (but not fully verified) that some late-production 1982 XJ650RJ and RJC Seca model bikes came equipped from the factory with 750 engines (rather than 650 engines). All 750 engines are YICS engines, of course; so if your XJ650RJ/RJC bike has a YICS engine in it, it would be wise to check and make sure that it is indeed a 650 engine rather than a 750 engine......this can be easily determined by looking on the forward side of the cylinder "jugs" casting. Along the centerline of the cylinders, towards the top edge (at the mating surface between top of jugs and bottom of head) will be the engine cc displacement cast into the metal.
1980 XJ650 MODELS:
COUNTRY: USA
MODEL NAME: XJ650G Maxim
STREET NAME: 1980 XJ650 Maxim-I
MODEL ID CODE: 4H7
FRAME ID: 4H7
USA MSRP PRICE: $ 2,749.00
COUNTRY: CANADA
MODEL ID CODE: 4H8
FRAME ID: 4H8
COUNTRY: EUROPE
MODEL NAME: XJ650
MODEL ID CODE: 4K0
FRAME ID: 4K0
NOTES: styling and features the same as North American XJ650RJ Seca model, has dual front disc brakes, an oil cooler, and uses the non-YICS 653cc engine.
COUNTRY: JAPAN
MODEL NAME: XJ650 Special
STREET NAME: 1980 XJ650 Special
MODEL ID CODE: 4L6
FRAME ID: 4L6
NOTES: styling the same as North American XJ650 Maxim model.
1981 XJ650 MODELS:
COUNTRY: USA
MODEL NAME: XJ650H
STREET NAME: 1981 XJ650 Maxim
MODEL ID CODE: 4H7
FRAME ID: 4H7
USA MSRP PRICE: $ 2,899.00
MODEL NAME: XJ650LH
STREET NAME: 1981 XJ650 Midnight Maxim
MODEL ID CODE: 4W5
FRAME ID: 4W5
SERIAL NUMBER STARTS AT: 000001
USA MSRP PRICE: $ 3,099.00
COUNTRY: CANADA
MODEL NAME: XJ650H
MODEL ID CODE: 4H8
FRAME ID: 4H8
MODEL NAME: XJ650LH
MODEL ID CODE: 4W6
FRAME ID: 4W6
COUNTRY: JAPAN
STREET NAME: 1981 XJ650 Special
MODEL ID CODE: 10H
FRAME ID: 4L6
COUNTRY: OCEANIA
MODEL NAME: XJ650H
MODEL ID CODE: 4K1
FRAME ID: 4K1
COUNTRY: OTHER
MODEL NAME: XJ650
MODEL ID CODE: 5K3
FRAME ID: 5K3
NOTES: styling and features the same as North American XJ650RJ Seca model, has dual front disc brakes and an oil cooler.
1982 XJ650 MODELS:
COUNTRY: USA
MODEL NAME: XJ650J
STREET NAME: 1982 XJ650 Maxim
MODEL ID CODE: 5N8
FRAME ID: 5N8
USA MSRP PRICE: $ 2,498.00
MODEL NAME: XJ650RJ
STREET NAME: 1982 XJ650 Seca
MODEL ID CODE: 5V2
FRAME ID: 5V2
NOTE: these bikes were painted silver, and did not use a YICS-equipped engine, but instead used the 1980-81 style non-YICS 653cc engine.
MODEL NAME: XJ650LJ
STREET NAME: 1982 XJ650 Seca Turbo
MODEL ID CODE: 16G
FRAME ID: 16G
USA MSRP PRICE: $ 4,399.00
COUNTRY: CANADA
MODEL NAME: XJ650J
MODEL ID CODE: 5N9
FRAME ID: 5N9
MODEL NAME: XJ650RJ
MODEL ID CODE: 5V3
FRAME ID: 5V3
MODEL NAME: XJ650RJC
STREET NAME: 1982 XJ650 Seca Canadian
MODEL ID CODE: 15U
FRAME ID: 15U
NOTE: these bikes were painted red, had a YICS-equipped 653cc engine, and were probably not released until very late in the 1982 model year. Some of these bikes may have come with a factory-installed oil cooler.
MODEL NAME: XJ650LJ
MODEL ID CODE: 16H
FRAME ID: 16H
COUNTRY: EUROPE
MODEL NAME: XJ650
MODEL ID CODE: 11N
FRAME ID: 4K0
SERIAL NUMBER STARTS AT: 055101
NOTES: styling and features the same as North American XJ650RJ Seca model, has dual front disc brakes and an oil cooler. UK model.
MODEL NAME: XJ650
MODEL ID CODE: 11T
FRAME ID: 11T
COUNTRY: GERMANY
MODEL NAME: XJ650
MODEL ID CODE: 11R
FRAME ID: 4K0
COUNTRY: JAPAN
MODEL NAME: XJ650
MODEL ID CODE: 16F
FRAME ID: 4L6
MODEL NAME: XJ650LJ
MODEL ID CODE: 17Y
FRAME ID: 17Y
COUNTRY: OCEANIA
MODEL NAME: XJ650RJ
MODEL ID CODE: 14R
FRAME ID: 14R
NOTES: styling and features the same as North American XJ650RJ Seca model, has dual front disc brakes, an oil cooler, and uses a YICS-equipped engine
MODEL NAME: XJ650LJ
MODEL ID CODE: 17Y
FRAME ID: 17Y
1983 XJ650 MODELS:
COUNTRY: USA
MODEL NAME: XJ650K
STREET NAME: 1983 XJ650 Maxim
MODEL ID CODE: 5N8
FRAME ID: 5N8
USA MSRP PRICE: $ 2,999.00
MODEL NAME: XJ650LK
STREET NAME: 1983 XJ650 Seca Turbo
MODEL ID CODE: 16G
FRAME ID: 16G
USA MSRP PRICE: $ 4,999.00
COUNTRY: CANADA
MODEL NAME: XJ650K
MODEL ID CODE: 5N9
FRAME ID: 5N9
MODEL NAME: XJ650RK
MODEL ID CODE: 20F
FRAME ID: 20F
MODEL NAME: XJ650LK
MODEL ID CODE: 16H
FRAME ID: 16H
COUNTRY: EUROPE
MODEL NAME: XJ650
MODEL ID CODE: 27F
FRAME ID: 4K0
MODEL NAME: XJ650
MODEL ID CODE: 27G
FRAME ID: 4K0
MODEL NAME: XJ650
MODEL ID CODE: 30K
FRAME ID: 4K0
NOTES: styling and features the same as North American XJ650RJ Seca model, has dual front disc brakes and an oil cooler. Sold in Switzerland only.
COUNTRY: OTHER
MODEL NAME: XJ650K
MODEL ID CODE: 30U
FRAME ID: 30U
1984 XJ650 MODELS:
COUNTRY: CANADA
MODEL NAME: XJ650L
STREET NAME: 1984 XJ650 Maxim
MODEL ID CODE: 5N9
FRAME ID: 5N9
1985 XJ650 MODELS:
COUNTRY: EUROPE
MODEL NAME: XJ650POLICE
STREET NAME: 1985 XJ650 Police Special
MODEL ID CODE: 1FF
FRAME ID: 37G
SERIAL NUMBER STARTS AT: 002101
NOTE: for the Spanish market.
1988 XJ650 MODELS:
COUNTRY: OTHER
MODEL NAME: XJ650P88
STREET NAME: 1988 XJ650 Police Special
MODEL ID CODE: 37G
FRAME ID: 37G
XJ700 Models
NOTE: The North American market was treated to two different versions of the "XJ700" model (and, these bikes were never available overseas), the USA only received the smaller 700cc version of these bikes, which the Canadian market received both the 700cc and 750cc-engined versions. In addition, these bikes were produced in both a standard air-cooled version, and in a high-performance "Maxim-X" series that featured the 5-valves per cylinder "Genesis" engine, and these "X" models also featured a water-cooled engine block system.
Besides the engine-size and type differences, both the USA or Canadian versions are basically identical in design and features. The 750-engine versions of this bike (Canadian-only) are listed further below int he "XJ750 Models" section. ALL of the water-cooled, 750-engined versions of this "XJ700" style bike were the water-cooled versions and were "Maxim-X" models.
1985 XJ700 MODELS:
COUNTRY: USA
MODEL NAME: XJ700N
STREET NAME: 1985 XJ700 Maxim
MODEL ID CODE: 1FG
FRAME ID: 1FG
MODEL NAME: XJ700NC
STREET NAME: 1985 XJ700 Maxim California
MODEL ID CODE: 1JJ
FRAME ID: 1JJ
MODEL NAME: XJ700XN
STREET NAME: 1985 XJ700 Maxim-X
MODEL ID CODE: 1AA
FRAME ID: 1AA
USA MSRP PRICE: $ 3,499.00
MODEL NAME: XJ700XNC
STREET NAME: 1985 XJ700 Maxim-X, California
MODEL ID CODE: 1FJ
FRAME ID: 1FJ
USA MSRP PRICE: $ 3,699.00
COUNTRY: CANADA
MODEL NAME: XJ700N Maxim
MODEL ID CODE: 1FH
FRAME ID: 1FH
1986 XJ700 MODELS:
COUNTRY: USA
MODEL NAME: XJ700S
STREET NAME: 1986 XJ700 Maxim
MODEL ID CODE: 1NH
FRAME ID: 1NH
USA MSRP PRICE: $ 3,059.00
MODEL NAME: XJ700SC
STREET NAME: 1986 XJ700 Maxim-X, California
MODEL ID CODE: 1NK
FRAME ID: 1NKJ
MODEL NAME: XJ700XS
MODEL ID CODE: 1NW
FRAME ID: 1NW
USA MSRP PRICE: $ 3,799.00
MODEL NAME: XJ700XSC
MODEL ID CODE: 1LT
FRAME ID: 1LT
USA MSRP PRICE: $ 3,899.00
COUNTRY: CANADA
MODEL NAME: XJ700S Maxim
MODEL ID CODE: 1NJ
FRAME ID: 1NJ
CONTINUED IN NEXT POST.............
_________________ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
chacal Supporting Vendor
Joined: Aug 01, 2006 Posts: 4845 Location: At My Computer
Posted: Mon Dec 15, 2008 1:21 am Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION A:
INTRODUCTION: Model Identification Continued.
--Model ID/VIN's
XJ750 Models
NOTE: Although the North American market was treated to three different versions of the XJ750 model (Maxim/Midnight Maxim, Seca, and the previously mentioned XJ750 Maxim-X versions), the rest of the world generally had only one version available, and that version is most similar to what is known as the XJ750 Seca model in North America.
Although not generally referred to in the overseas markets as a "Seca" model (since there was only one model available, there was no need to give it a "name" needed to differentiate it between a base Maxim model), these overseas versions came equipped with the "scalloped" design fuel tank, gauge package, and other special components which are normally found in the North American XJ750 Seca models.
1981 XJ750 MODELS:
COUNTRY: USA
MODEL NAME: XJ750RH
STREET NAME: 1981 XJ750 Seca
MODEL ID CODE: 5G2
FRAME ID: 5G2
USA MSRP PRICE: $ 3,150.00
COUNTRY: CANADA
MODEL NAME: XJ750RH
MODEL ID CODE: 5H2
FRAME ID: 5H2
COUNTRY: UNITED KINGDOM
MODEL NAME: XJ750
MODEL ID CODE: 5N1
FRAME ID: 5N1
NOTES: styling and features the same as North American XJ750 Seca model, has dual front disc brakes and an oil cooler.
COUNTRY: JAPAN
MODEL NAME: XJ750A
MODEL ID CODE: 5G8
FRAME ID: 5G8
NOTES: uses the XJ650RJ Seca frame, but has the 750 engine.
1982 XJ750 MODELS:
COUNTRY: USA
MODEL NAME: XJ750J
STREET NAME: 1982 XJ750 Maxim
MODEL ID CODE: 15R
FRAME ID: 15R
MODEL NAME: XJ750RJ
STREET NAME: 1982 XJ750 Seca
MODEL ID CODE: 5G2
FRAME ID: 5G2
COUNTRY: CANADA
MODEL NAME: XJ750J
MODEL ID CODE: 15T
FRAME ID: 15T
MODEL NAME: XJ750RJ
MODEL ID CODE: 5H2
FRAME ID: 5H2
COUNTRY: EUROPE
MODEL NAME: XJ750
MODEL ID CODE: 11M
FRAME ID: 11M
COUNTRY: OE
MODEL NAME: XJ750
MODEL ID CODE: 5N1
FRAME ID: 5N1
SERIAL NUMBER STARTS AT: 003101
1983 XJ750 MODELS:
COUNTRY: USA
MODEL NAME: XJ750K
STREET NAME: 1983 XJ750 Maxim
MODEL ID CODE: 22R
FRAME ID: 22R
USA MSRP PRICE: $ 3,299.00
MODEL NAME: XJ750MK
STREET NAME: 1983 XJ750 Midnight Maxim
MODEL ID CODE: 33N
FRAME ID: 22R
USA MSRP PRICE: $ 3,599.00
MODEL NAME: XJ750RK
STREET NAME: 1983 XJ750 Seca
MODEL ID CODE: 5G2
FRAME ID: 5G2
SERIAL NUMBER STARTS AT: 150101
USA MSRP PRICE: $ 4,099.00
COUNTRY: CANADA
MODEL NAME: XJ750K
MODEL ID CODE: ???
FRAME ID: ???
MODEL NAME: XJ750MK
MODEL ID CODE: 33U
FRAME ID: 22T
MODEL NAME: XJ750MK
MODEL ID CODE: 22T
FRAME ID: 22T
MODEL NAME: XJ750RK
MODEL ID CODE: 5H2
FRAME ID: 5H2
SERIAL NUMBER STARTS AT: 110101
COUNTRY: EUROPE
MODEL NAME: XJ750
MODEL ID CODE: 28J
FRAME ID: 11M
MODEL NAME: XJ750
MODEL ID CODE: 28M
FRAME ID: 11M
COUNTRY: JAPAN
MODEL NAME: XJ750E-II
MODEL ID CODE: 29R
FRAME ID: 29R
NOTE: this model had a 750 engine in the XJ900 frame.
MODEL NAME: XJ750D
MODEL ID CODE: 5G8
FRAME ID: 5G8
NOTE: this model features fuel injection.
MODEL NAME: XJ750
STREET NAME: 1983 XJ750 Police Special
MODEL ID CODE: 33V
FRAME ID: 33V
SERIAL NUMBER STARTS AT: 103001
NOTE: this model is a Police Special.
MODEL NAME: XJ750P
MODEL ID CODE: 39Y
FRAME ID: 33V
NOTE: this model is a Police Special, New Zealand model.
COUNTRY: OE
MODEL NAME: XJ750
MODEL ID CODE: 5N1
FRAME ID: 5N1
MODEL NAME: XJ750P
MODEL ID CODE: 37H
FRAME ID: 37H
NOTE: this model is a Police Special. White painted frame, swingarm, and steering crowns, may have used 900 cams.
COUNTRY: OTHER
MODEL NAME: XJ750P
MODEL ID CODE: 24L
FRAME ID: 24L
1984 XJ750 MODELS:
COUNTRY: CANADA
MODEL NAME: XJ750ML
STREET NAME: 1984 XJ750 Midnight Maxim
MODEL ID CODE: 22T
FRAME ID: 22T
MODEL NAME: XJ750RL
STREET NAME: 1984 XJ750 Seca
MODEL ID CODE: 44X
FRAME ID: 44X
NOTE: 750 engine in an XJ900 frame. Approximately only 600 made.
COUNTRY: EUROPE
MODEL NAME: XJ750
MODEL ID CODE: 41Y
FRAME ID: 41Y
COUNTRY: AUSTRALIA
MODEL NAME: XJ750RL
MODEL ID CODE: 45T
FRAME ID: 45T
NOTE: 750 engine in an XJ900 frame. Approximately only 200 made.
1985 XJ750 MODELS:
COUNTRY: CANADA
MODEL NAME: XJ750XN Maxim
STREET NAME: 1985 XJ750 Maxim-X
MODEL ID CODE: 1FL
FRAME ID: 1FL
1986 XJ750 MODELS:
COUNTRY: CANADA
MODEL NAME: XJ750XS
STREET NAME: 1986 XJ750 Maxim-X
MODEL ID CODE: 1MY
FRAME ID: 1MY
900 Models
NOTE: Although available in the North American market for only one year (1983), the XJ900 models were actually the longest-running production version of any XJ-series bike of this era, and since so many of the sales of these bikes occurred in the "overseas" markets, it is hard to gather and portray information on many of those models (since we here in the USA generally do not have access to those sources of information). However, here are some general guidelines on these bikes that may perhaps prove interesting, if not valuable:
Most 1983-84 XJ900 models had an 853cc engine, which was later increased in size to an 891cc engine in late 1984-on. The North American XJ900RK model used the 853cc engine.
All of the 1983 and some early 1984 XJ900RK and XJ900RL models had an anti-dive front suspension system and DeCarbon remote-cannister rear shock absorbers, both of which were eliminated on the later models.
The 1983 XJ900RK models had a fork-mounted front fairing, which was prone to cause high-speed stability problems. The 1984-later models had a new, larger frame-mounted fairing, and some models were also fitted with a front "belly pan" surrounding the lower front exhaust header pipes and engine case area.
1983 XJ900 MODELS:
COUNTRY: USA
MODEL NAME: XJ900RK
STREET NAME: 1983 XJ900 Seca
MODEL ID CODE: 35H
FRAME ID: 35H
Note: 853cc engine, handlebar-mounted fairing.
COUNTRY: CANADA
MODEL NAME: XJ900RK
MODEL ID CODE: 31E
FRAME ID: 31E
COUNTRY: EUROPE
MODEL NAME: XJ900F
MODEL ID CODE: 31A
FRAME ID: 31A
Note: 853cc engine, handlebar-mounted fairing, belly pan.
MODEL NAME: XJ900F
MODEL ID CODE: 32F
FRAME ID: 31A
SERIAL NUMBER STARTS AT: 030101
NOTE: Switzerland. 853cc engine, handlebar-mounted fairing, belly pan.
COUNTRY: OCEANIA
MODEL NAME: XJ900U
MODEL ID CODE: 33F
FRAME ID: 33F
NOTE: 853cc engine, handlebar-mounted fairing.
1984 XJ900 MODELS:
COUNTRY: EUROPE
MODEL NAME: XJ900
STREET NAME: 1984 XJ900
MODEL ID CODE: 42R
FRAME ID: 31A
SERIAL NUMBER STARTS AT: 032101
NOTE: Switzerland. 853cc engine, frame-mounted fairing.
MODEL NAME: XJ900
MODEL ID CODE: 42N
FRAME ID: 31A
SERIAL NUMBER STARTS AT: 034101
NOTE: 853cc engine, frame-mounted fairing.
COUNTRY: OTHER
MODEL NAME: XJ900
MODEL ID CODE: 48G
FRAME ID: 31A
COUNTRY: OCEANIA
MODEL NAME: XJ900RL
STREET NAME: 1984 XJ900 Seca
MODEL ID CODE: 47L
FRAME ID: 33F
SERIAL NUMBER STARTS AT: 001101
Note: 853cc engine, frame-mounted fairing, belly pan.
1985 XJ900 MODELS:
COUNTRY: EUROPE
MODEL NAME: XJ900
STREET NAME: 1985 XJ900
MODEL ID CODE: 58L
FRAME ID: 58L
NOTE: Finland, Germany, Sweden, and England. 891cc engine, frame-mounted fairing.
MODEL NAME: XJ900
MODEL ID CODE: 1FW
FRAME ID: 58L
SERIAL NUMBER STARTS AT: 010101
NOTE: France. 891cc engine, frame-mounted fairing.
MODEL NAME: XJ900
MODEL ID CODE: 1FW
FRAME ID: ???
SERIAL NUMBER STARTS AT: 013101
NOTE: Denmark, Germany, Norway, Sweden. 891cc engine, frame-mounted fairing.
MODEL NAME: XJ900
MODEL ID CODE: 58N
FRAME ID: 31A
NOTE: Switzerland. 891cc engine, frame-mounted fairing.
COUNTRY: OCEANIA
MODEL NAME: XJ900N
MODEL ID CODE: 1FX
FRAME ID: 1FX
NOTE: 891cc engine, no fairing.
MODEL NAME: XJ900FN
MODEL ID CODE: 58M
FRAME ID: 58M
NOTE: 891cc engine, 891cc engine, frame-mounted fairing, non-air adjustable forks, non anti-dive system, belly pan.
MODEL NAME: XJ900Police
STREET NAME: 1985 XJ900 Police Special
MODEL ID CODE: 53M
FRAME ID: 33F
NOTE: 891cc engine, frame-mounted fairing.
1986 XJ900 MODELS:
COUNTRY: EUROPE
MODEL NAME: XJ900
STREET NAME: 1986 XJ900
MODEL ID CODE: 1FW
FRAME ID: 58L
1987 XJ900 MODELS:
COUNTRY: EUROPE
MODEL NAME: XJ900F
STREET NAME: 1987 XJ900
MODEL ID CODE: 2HL
FRAME ID: 58L
NOTE: Greece. 891cc engine, frame-mounted fairing, non-air adjustable forks, non anti-dive system, belly pan.
MODEL NAME: XJ900F
MODEL ID CODE: 58N
FRAME ID: 31A
SERIAL NUMBER STARTS AT: 051101
NOTE: Switzerland. 891cc engine, frame-mounted fairing, non-air adjustable forks, non anti-dive system, belly pan.
COUNTRY: OTHER
MODEL NAME: XJ900
MODEL ID CODE: 2UR
FRAME ID: 2UR
COUNTRY: OCEANIA
MODEL NAME: XJ900T
MODEL ID CODE: 2HM
FRAME ID: 1FX
1989 XJ900 MODELS:
COUNTRY: EUROPE
MODEL NAME: XJ900
STREET NAME: 1989 XJ900
MODEL ID CODE: 3NG1
FRAME ID: 58L
SERIAL NUMBER STARTS AT: 029101
1990 XJ900 MODELS:
COUNTRY: EUROPE
MODEL NAME: XJ900
STREET NAME: 1990 XJ900
MODEL ID CODE: 3NG2
FRAME ID: 58L
SERIAL NUMBER STARTS AT: 037101
1991 XJ900 MODELS:
COUNTRY: EUROPE
MODEL NAME: XJ900F
STREET NAME: 1991 XJ900
MODEL ID CODE: 4BB1
FRAME ID: 4BB
1992 XJ900 MODELS:
COUNTRY: EUROPE
MODEL NAME: XJ900F
STREET NAME: 1992 XJ900
MODEL ID CODE: 4BB2
FRAME ID: 4BB
SERIAL NUMBER STARTS AT: 008101
NOTE: XJ900 models were sold off-and-on in other parts of the world up until 1994, and in some countries was marketed under the name of the XJ900S Diversion series of bikes.
1100 Models
1982 XJ1100 MODELS:
COUNTRY: USA
MODEL NAME: XJ1100J
STREET NAME: 1982 XJ1100 Maxim
MODEL ID CODE: 10M
FRAME ID: 10M
COUNTRY: CANADA
MODEL NAME: XJ110MJ
STREET NAME: 1982 XJ1100 Midnight Maxim
MODEL ID CODE: 11G
FRAME ID: 11G
1983 XJ1100 MODELS:
COUNTRY: CANADA
MODEL NAME: XJ1100K
STREET NAME: 1983 XJ1100 Maxim
MODEL ID CODE: 11G
FRAME ID: 11G
1984 XJ1100 MODELS:
COUNTRY: CANADA
MODEL NAME: XJ110ML
STREET NAME: 1984 XJ1100 Midnight Maxim
MODEL ID CODE: 11G
FRAME ID: 11G
THE TEST:
Here are a couple of real XJ bike VIN's (mostly culled from bikes listed for sale from eBay). Go ahead and identify them for what they really are.
16G004078
JYA1FH009FA000241
JYA10M006CA004270
5G2-107546
JYA4U8004BA004890
For extra credit, determine the missing VIN "check digit" in the following VIN's:
JYA4H700?AA00638
JYA5K500?CA027661
JYA5V300?CA000432
Anyone who got all the answers correct should stay after class and clean the erasers.
CONCLUSIONS:
If you're not confused yet, then you haven't studied carefully enough.
Posted: Mon Dec 15, 2008 1:23 am Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION A:
INTRODUCTION:
--The Real Costs of Maintenance
Hint!: they arise (and rise!) from not doing things correctly in the first place!
An Insight:
"One of the reasons I kept this bike, even though I keep spending more and more time and money on it, is the simple fact that I will never have to take it to a mechanic. If something breaks I'll know how to fix it........if I am on a trip----I won't be at the mercy of a local repair shop (and I'd rather spend a couple hundred+ for new tools while on a trip if needed to do it myself then get ripped off).
In my opinion, this is what makes a 'biker' and a "guy who rides motorcycles" different."
An Observation:
It is a common myth that people believe that because these classic bikes are inexpensive to PURCHASE, that they are also inexpensive to MAINTAIN or REPAIR. That is the wrong, wrong, wrong way to think about it; a VERY BAD idea. Thinking like that will inevitably (almost 100% guaranteed) lead to frustration and added expense.
Among the many nice traits of these bikes is that they actually are simple enough for the average person to work on and to do repairs on SUCESSFULLY by themselves, as they were a pretty well-engineered design (except for the fusebox!) and very durable, easy to work on.
But "easy" doesn't mean "cheap" and if you are willing to skip steps in order to save a dollar or two, or a minute or two, then in many cases you're going to be doing that old Fram oil filter commercial thing: "you can pay me now, or you can pay me later". And that "future payment" is going to involve a lack of performance and more time and effort on your part until you eventually just give up, or buckle down and do things right.
The rule of thumb in the boating or aviation world is this: whatever you paid for the vehicle, expect to spend 10-20% PER YEAR of that purchase price in maintenance costs. Just because you could "afford" to buy the vehicle doesn't mean that you can "afford" the yearly preventative and service maintanence costs; and if not, well, then eventually you learn quickly why people say that a boat is just "a hole in the water that you throw money into". That's not really true, but that's what people who don't understand that on-going PROPER maintenance and repair costs need to be factored in when determining the real "price" of a bike, especially an older one which is going to require not just the normal on-going maintenance costs, but most probably also additional costs to make up for the previous owner(s) lack of proper maintenance.
The issue that arises with older vehicles is that the purchase price is quite low. That's a blessing, in some ways; but in other ways, that's bad because it lulls people into the belief that the maintenance "costs" (time AND money) will be cheap too. A MUCH BETTER WAY to understand it, I believe, is like this: IF your 1982 XJ650 Seca could be purchased BRAND NEW, today, the price would be $X (let's say, $8,000 ?). THEREFORE YOU SHOULD RELAISTICALLY EXPECT THE AVERAGE ANNUAL MAINTENANCE COSTS WILL BE $ 800 - $ 1,500 PER YEAR.
And never mind that maybe you get "free oil changes and service/maintenance" as part of a new-vehicle "warranty"---you PAID for those "free" maintenance costs in the purchase price of the bike, rather than in smaller chunks on down the road. In fact, "free" service warranties are really just a way of allowing a new vehicle purchaser of FINANCING those service and maintenance costs into the purchase price, rather than paying cash every 6 months for those maintenance and service fees.
And many (most?) OEM vehicle sellers make more money off their customers from those financing charges (assuming a purchaser finances through the OEM financing program, which most people do) than they make off building the vehicles! THAT'S why they offer the "free" service to you, so they can build up that purchase price, and thus financing fees, by "hiding" the 10-20% additional yearly costs into the purchase price. This gives people the completely wrong ideas and understanding about what the true, REAL costs of vehicle ownership are.
On used vehicles with no "free" warranty, those service and maintenance costs become very real, very quickly.
I understand and appreciate that some people are going to wildy disagree with me on the above statements, and that's cool. And since I offer parts for sale (for these bikes), many will say that I'm just trying to push people into spending needless amounts of money. Well, that's one possibility.
The other one is that the OEM engineers and manufacturers and experienced (honest) mechanics will also tell you pretty much exactly what I'm portraying here: doing things right actually saves you time and money in the long run, and that all complex mechanical objects (from your lawnmower on up) requires periodic, proper maintenance if you expect it to perform to the level it was designed to perform to, and have the life expectancy that it was designed for. These things aren't magic. They aren't due to luck. Having a bike perform properly is not akin to winning the lottery, i.e. some people get lucky and others don't and that's just life. If you dig deep, if you could stand over the shoulder of those who are successful and those who aren't, the ways in which success is determined are pretty clear-cut and straight-forward, as outlined above.
As are, unfortunately, the ways in which a lack of success are achieved.
A Great Question:
"Let me ask for your unbiased opinion.
Based on my calculations, I am looking at sinking $1000+ in this bike to get it in great shape. since you are very familiar with these bikes do you think it is worthwhile? I am torn, I am looking for a nice starter bike and this bike seems to fit that bill. I don't think I could get a nice bike for that price. If I did I would probably be looking at doing some of the same things that I need on this bike. Carb tune etc. My concern is that I spend 1000 now and then some thing else goes and then I am sinking another grand later.
Let me know what you think."
A Serious Answer:
Like you noted, you'll have to spend a bit of $$ now to both make up for previous owner's neglect, and also to acquire a lot of the tools needed to perform some of the tasks. The tool expenses will, of course, not repeat, but parts costs on older machines can and will be a factor. So you're looking at spending a significant amount of money up front, and with hopefully reduced amounts going forward into the future.
Of course, they are very nice starter bikes in the sense that they are relatively easy to ride and to work on, something that later model bikes can't always lay claim to. Plus you're going to learn A LOT about working on bikes with one of these! There's no real economic "value" to that besides satisfaction and knowledge and the ability to maintain/tune/etc. your bike in the future, which again goes further towards reducing the maintenance costs of the bike in the future.
Is it worth it? From a "can I sell it at a profit stand-point in a few months?" persepctive, the answer is: probably not. Although the prices of the bikes continue to escalate, parts and labor costs to put one of these into tip-top shape almost never get re-couped upon resale.
Hope these insights help with your decision making. They are great little bikes.
From Our Experience:
Since the carburetors are THE most troublesome (and thus most expensive) aspect of these bikes, let me offer a few dozen words and insights about them, their service, and expense:
These carbs are quite simple, mechanically speaking.
The process of making DARNED SURE that you get them unbelievably, positively zestfully clean is a matter of stick-to-it-ness and resisting all attempts to take "shortcuts" or to brush off the tedious aspects of it. Many of the passages in these carbs are tiny, and it's that "tiny-ness" that bites most people, as they don't want to or don't realize the amount of effort that has to be undertaken to deal with such small passages.
If you read through these forums, you'll see many tales of woe of people who are now "cleaning" their carbs for the 2nd, 3rd, or 4th time BEFORE they get it right. The problem is, they never really "cleaned" them correctly the first, 2nd, and 3rd time. After all of the frustration and hassle involved, by the time they get around to the 4th go-around, then they understand that when people who have SUCCESSFULLY rebuilt carbs say things like "you'd better make SURE that you get clear flow through each and every passage, and you'd better polish that piston diaphram bore", etc. aren't just saying that to be over-the-top retentive about their own habits and style of working on these carbs, what they're really doing is issuing an experienced WARNING: do it right, or keep doing it again, and again, and again. And although they're kind of fun little critters to play with, taking them all apart and putting Humpty Carby all back together again, well, it's time better spent on other things.
One last note: "cleaning" the carbs (internally, not just making them look pretty on the outside) is just one of the small subsets of tasks necessary to the proper REBUILDING of the carbs. I cannot stress this point enough. The use of the term "cleaning" is used as if it were the end goal of the process; in reality, the proper way to think about it would be this:
"A complete and exceptiional level of carb CLEANING is a vital and necessary part of the process of properly REBUILDING the carbs."
And what are the other componets of the rebuilding puzzle?
a) replacing the worn, missing, or necessary "wear parts" on the carb.
These would be the idle mixture o-rings, washers, and maybe even the springs.
The carb bowl gaskets.
The carb throttle shaft seals.
The float valve needles and seats.
Any incorrectly sized or damaged jets.
Inspection of the piston rubber disphram for any holes, thin spots, etc.
b) Proper "service" work to the carb bodies, especially:
- polishing the piston bore for silky smoothness.
- repair or clean up of any stripped threads in the carb bodies.
- replacement of any damaged or worn parts. In fact, the ability the recognize what is damaged and worn (besides the parts above which are designed to wear out) is the most difficult part of the entire task, since it requires a level of experience: are my needle tips worn? What, exactly, does a worn needle tip look like? How "smooth" is smooth enough? Etc. This is where the advice and experience of the members of this forum are invaluable.
c) Proper "settings" of the various components during re-assembly:
- the float heights
- the "basic or bench synch" of the throttle valves
d) On-bike "settings":
- first and foremost, the measurement and setting to specifications of the valve train (shim) clearancs. Failure to do this "wastes" 90% of your efforts involved with the carbs.
- final synch (using some type of mamometer and the YICS tool if your engine is YICS-equipped)
- idle mixture screw setting, preferrably using a Colortune plug.
One last thought about these carbs, since they are THE most troublesome aspects of these bikes, and something to consider:
- the four carbs concept is really neat looking, and certainly performance oriented to the extreme.
- for many of us who had lots of experience with automotive carbs, just beware that while these Hitachi and Mikuni carbs are a bit different in operation (and thus parts), a carb is a carb, and they're pretty basic little devices. The main difference is that the fuel circuit passages on these carbs can get bizarrely tiny, especially if you're used to working on automotive carbs (which have canyon-sized fuel passages compared to these carbs).
- like I've said, the cleanliness part is really just tedious work, with a couple of "tricks" thrown into the mix, given the small sizes you're having to deal with. The "rebuild" part is basic mechanical knowldege and skills, knowing which way to turn a screwdriver to loosen vs. tighten, when and how much force to use or not, being organized, stuff like that.
- but the "tuning" part will require some special tools, but no type of any rocket-science knowledge or skills----once you master the rebuild and tuning process with these bikes, you are pretty much a Carb Tuning God, as these carbs are about as "complicated" as it gets with carburators. I mean, VERY few vehicles have multi-carbs, not until you get to the really high-performance machines level in the automotive world.
- well, as "complicated as it gets" until you start adding pods, etc.----which if you do, I sure hope you've got every last one of the basics listed above down to a science, and you can do it all, properly, and blindfolded, too!
- finally, if you do not have a service manual(s) for your particular bike(s), and you're going to wrench on it and want to do things right, then the only thing I can surmise from such a course of action is:
a) you're already an expert, or.....
b) you aren't really serious about doing things right, and that's okay, too---just don't expect good, quick, or cheap results!
Posted: Mon Dec 15, 2008 1:29 am Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION B:
LITERATURE: Owner's Manuals, Service Manuals, and other literature items.
--Service Manuals
--Owner's Manuals
NOTE!: All aftermarket service, workshop, and owner's manuals will feature varying levels of quality (especially picture or image quality) that can be far INFERIOR to that of an original printing manual.....they are "copies of a copy" and as such, image quality can degrade significantly.
Also, there will be quite a few errors (in specs, diagrams, parts ID, wiring diagrams, etc.) that occurred in original manuals, and are thus copied over to the aftermarket and reproduction manuals. This is unfortunate, but it is pretty much a "fact of life" in the vehicle service manual business!
SERVICE MANUALS:
Although it's fun to be adventurous, creative, and daring at times, wrenching on the bike is not one of those times......
Some people seem to think that working on a bike is "simple", and therefore they don't need a service manual. While we agree that for some operations and procedures this may be correct, for many of the routine maintenance tasks you're going to need a service manual in order to figure out what may seem, at first glance, to be a "simple" task (actually, those things that you think are really simple can be the most mind-bending in complexity, until you've done them a time or two.....).
So, our advice is don't be penny-wise and pound-foolish----if it helps at all, just think of a service manual as a very useful tool for your toolbox, just like the proper sized socket or screwdriver, and one that is necessary to do a job properly.
Aftermarket Service-Repair-Workshop Manuals:
lm1) The ever-popular Haynes or Clymer WORKSHOP MANUALS line of "enhanced" factory service manuals cover all major service, repair, rebuild, and maintenance procedures (sometimes in excruciating detail, and usually with many more pictures and illustrations than the factory service manual does), and also includes wiring diagrams and other useful specifications.
HCP1094 Clymer SERVICE-REPAIR-WORKSHOP MANUAL for all 1981-83 XJ550 models, as well as 1984-92 XJ600 and FJ600 models. Softcover, almost 300 pages, a must-have manual if you own one of these machines. Each:
$ 32.00
HCP1093 Haynes SERVICE-REPAIR-WORKSHOP MANUAL for all 1980-84 XJ650 (except Turbo) and XJ750 models, softcover, over 275 action-packed pages, a must-have manual if you own one of these machines. Each:
$ 29.00
NOTE: the 1984 XJ750RL Seca models (Canada and Australia only) models used the XJ900 frame and chassis with a 750 engine. In order to service this model correctly, you would need to purchase BOTH the Haynes HCP1093 and the HCP1092 manuals to fully cover all aspects of engine and chassis service.
HCP1092 Haynes SERVICE-REPAIR-WORKSHOP MANUAL for all 1983-94 XJ900 models, hardcover, over 210 pages, even has a nice color-coded wiring schematic, bless you guys at Haynes! Each:
$ 33.00
lm2) Original reprinted FACTORY SERVICE MANUALS are also available. These full-size manuals covers all aspects of diagnosis, repair, and assembly for specific model bikes. These brand new, official Yamaha manuals are one of those "must-have" tools if you're going to be wrenching on your own bike. Plenty of photographs, diagrams, flowcharts, wiring charts (some of them even being correct!), torque values, etc. NOTE: cover design, color, and appearance may differ from originals.
NOTE: originally, Yamaha would not release a new service manual for each year's production, unless there had been significant changes in design, service procedures, features, etc......and even in those cases, even if there HAD been significant changes, they would not release an entirely new service manual, but merely a "supplement" to the past service manual for that model, and that supplement would highlight only the changes to procedures, etc. that would need to be followed.
For example: the 1980 XJ650 Maxim---being the first model in the XJ650 series---was issued a service manual by Yamaha. The 1981 XJ650 model, having no significant differences from the 1980 model, used the same 1980 XJ650 service manual. However, the 1982 XJ650 Maxim models had a number of meaningful difference in service procedures (first and foremost, the introduction of the YICS cylinder head design and system, which required a different synchronization procedure, a variation to the engine teardown and re-build procedures, etc.).
Rather than publish a brand new service manual for the 1982 XJ650 Maxim models, Yamaha merely published a service manual Supplement and instructed dealers to use the 1980 XJ650 Base Service Manual along with the 1982 XJ650 Supplementary Service Manual to properly service those bikes.....after all, 90% of the procedures in the 1980 XJ650 "base" Service Manual still applied and were valid for the 1982 XJ650 Maxim models, so why publish an entire new manual, when just a "supplement" would work?
This same process applies to many of the original models and their service manuals. The 1982 XJ750 Maxim models, for instance, used that same 1980 XJ650 Maxim Service Manual as the "base manual", and had a 75-page XJ750J Supplementary Service Manual that was to be used in conjunction with the base (1980 XJ650) manual.
That was then.
This is now: all of the Supplementary Service Manuals are rolled into the front of the "base manuals" for the individual manuals listed as reprints below. So for instance, the 1982-3 XJ650 Maxim Service Manual has both the 1980 XJ650 "Base" Service Manual AND the 1982-3 XJ650 Supplementary Service Manual bound together into one book.....no need to acquire two different books to have all of the correct procedures for working on your 1983 XJ650 Maxim. Same thought applies to the XJ750 Maxim Service Manuals.....they have the "base" 1980 XJ650 Maxim Service Manual, and also the XJ750 Maxim Supplementary Manual all bound together into one book.
Some manuals, such as the XJ550 Maxim and Seca Service Manual, will be labeled (on the cover) as a 1981 XJ550 Maxim/Seca Service Manual, when in fact it covers all three model years.
So when you purchase one of the manuals listed below, rest assured that it will have ALL of the correct procedures and information that will apply to the specific models for which it is listed as covering.
Reprinted Original Service Manuals:
HCP1128 Reprinted factory SERVICE MANUAL covers all XJ550 Maxim and XJ550 Seca models 1981-83.
$ 84.95
HCP1134 Reprinted factory SERVICE MANUAL covers all XJ650 Maxim and Midnight Maxim models 1980-83.
$ 84.95
HCP1139 Reprinted factory SERVICE MANUAL covers all XJ650 Turbo models 1982-83. NOTE: the factory Yamaha manual for the XJ650 Turbo models is composed of the original 1980 XJ650G service manual, and an additional bound-in Turbo Supplement section of about 125 pages, and this manual was produced for the 1982 models.
Although there may have originally been a 1983 supplemental version also, we have never been able to locate one. Given that the meaningful differences between 1982 and 1983 XJ650 Turbo models are few, the 1982 version of the manual is the only thing available for 1983 owners .
$ 84.95
HCP1138 Reprinted factory SERVICE MANUAL covers all XJ650RJ Seca models 1982.
$ 84.95
HCP1143 Reprinted factory SERVICE MANUAL covers all XJ700 non-X models 1985-86.
$ 84.95
HCP1145 Reprinted factory SERVICE MANUAL covers all XJ700 "X" models 1985-86.
$ 84.95
HCP1151 Reprinted factory SERVICE MANUAL covers all XJ750 Seca models 1981-83. NOTE: the wiring diagram that is printed in this manual is not correct (at all) for these models. The correct wiring diagram can be found in the HCP1093 Haynes manual listed above.
$ 84.95
NOTE: the 1984 XJ750RL (Canada and Australia only) models used the XJ900 frame and chassis with a 750 engine. In order to service this model correctly, you would need to purchase BOTH an XJ900RK service manual and the XJ750 Seca 1981-83 service manual (or the HCP1093 Haynes manual) to fully cover all aspects of engine and chassis service.
HCP1152 Reprinted factory SERVICE MANUAL covers all XJ750 Maxim models 1982.
$ 84.95
HCP1154 Reprinted factory SERVICE MANUAL covers all XJ750 Maxim & Midnight Maxim models 1983.
$ 84.95
HCP1157 Reprinted factory SERVICE MANUAL covers all XJ900RK Seca models 1983.
$ 84.95
HCP1158 Reprinted factory SERVICE MANUAL covers all XJ1100 Maxim models 1982.
$ 84.95
NOTE: The question naturally arises: should you order the aftermarket Clymer or Haynes manual or the reprinted Yamaha Factory Service Manual (for those models that have both types available?). At the risk of sounding like a pushy salesman, I'd honestly have to answer this question with the advice: "Order both".
Although the aftermarket service manuals are adapted from the factory manuals---and thus there are some areas where there is quite a bit of similarity in content between the two manuals---there are enough areas where there are meaningful differences in the photographs, illustrations, and especially in the descriptive and instructive content that most people (meaning "non-professional mechanics") will appreciate having two different "versions" of the same procedure to refer to.
lm3) Original reprinted FACTORY OWNER'S MANUALS are now available. These small booklet-sized manuals covers all of the basic aspects of proper operation, controls, riding tips, basic preventative maintenance and repair, and assembly for specific model bikes. These brand new, official Yamaha manuals are one of those "must-have" tools if you're going to be wrenching on your own bike. NOTE: cover design, color, and appearance will differ from originals.
HCP1096 Reprinted factory OWNER'S MANUAL for XJ550 Maxim 1982. This manual can be successfully used for all 1981-83 XJ550 Maxim models, even though it will say "1982" on the cover.
$ 19.95
HCP1101 Reprinted factory OWNER'S MANUAL for XJ550 Seca 1983. This manual can be successfully used for all 1981-83 XJ550 Seca models, even though it will say "1983" on the cover.
$ 19.95
HCP1105 Reprinted factory OWNER'S MANUAL for XJ650 Maxim 1982. This manual can be successfully used for all 1980-83 XJ650 Maxim models, even though it will say "1982" on the cover.
$ 19.95
HCP1108 Reprinted factory OWNER'S MANUAL for XJ650 Maxim 1983. This manual can be successfully used for all 1980-83 XJ650 Maxim models, even though it will say "1983" on the cover.
$ 19.95
HCP1104 Reprinted factory OWNER'S MANUAL for XJ650 Midnight Maxim 1981.
$ 19.95
HCP1112 Reprinted factory OWNER'S MANUAL for XJ700 N/NC Maxim 1985.
$ 19.95
HCP1116 Reprinted factory OWNER'S MANUAL for XJ700 S/SC Maxim 1986.
$ 19.95
HCP1122 Reprinted factory OWNER'S MANUAL for XJ750 Seca 1982. This manual can be successfully used for all 1981-83 XJ750 Seca models, even though it will say "1982" on the cover.
$ 19.95
HCP1121 Reprinted factory OWNER'S MANUAL for XJ750 Maxim 1982. This manual can be successfully used for all 1982-83 XJ750 Maxim models, even though it will say "1982" on the cover. The section on the gauges and headlight/auxiliary light information will pertain only to the 1982 models, though.
$ 19.95
HCP1124 Reprinted factory OWNER'S MANUAL for XJ750 Midnight Maxim 1983.
$ 19.95
HCP1126 Reprinted factory OWNER'S MANUAL for XJ900RK Seca model 1983.
$ 19.95
FREE STANDARD SHIPPING {OR JUST $5.00 FOR PRIORITY MAIL} SHIPPING IN THE USA FOR ALL ORDERS OVER $100 !!!!
$7.50 STANDARD SHIPPING TO CANADA FOR ALL ORDERS OVER $100 !!!!
Paypal accepted. Worldwide shipping available. Shipping prices and insurance costs are NOT included in the prices of items unless specifically listed. Please write with your list of parts needs and I will be glad to quote your shipping costs to you.
You can either PM (Private Message) me through this website, e-mail us via the "email" button on the bottom of this post, or e-mail us directly at:
info @ xj4ever.com
PLEASE NOTE!: our e-mail address does NOT have spaces before or after the "@" symbol........the posting system on this website automatically adds blank spaces before and after that symbol as an anti-spam feature! Make sure you eliminate those blank spaces when sending us an e-mail! Our e-mail address does NOT have any blank spaces in it!!
PLEASE!: on each and every correspondence with us, please tell us what YEAR and MODEL bike you have (example: 1982 XJ650 Maxim) and what your NAME (first name, at least!) is......that information really makes life a bit easier for us, and insures a more timely and ACCURATE response from us back to you!
MORE XJ PARTS IN THE FOLLOWING POST!!
Posted: Mon Dec 15, 2008 1:36 am Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION C:
FUEL SYSTEM ITEMS: Including Airboxes, Carbs, Intakes, Fuel Tanks, Petcocks, Gas Caps, Tank Mounts, Etc.
-- Hitachi Parts
HITACHI CARB REBUILD PARTS:
NOTE: Hitachi carbs were originally used on all Yamaha XJ650 models (except Turbo models), all XJ750 models, and all XJ700 (non-"X") models. All other XJ models from this era (XJ550, XJ650 Turbo models, XJ700 "X" models, XJ900, and XJ1100 models) used Mikuni carbs.
NOTE: "OEM" refers to an original Yamaha factory part, whereas "Replacement" or "Aftermarket" refers to a part not made by Yamaha or one of their original suppliers. NOTE THAT AN "OEM" PART may be made by Yamaha's original supplier, even though such part is no longer serviced through the Yamaha factory parts system.
j1) XJ models Hitachi HSC32/HSC33 USED PARTS.....jets, bowls, bodies, diaphrams/slides, floats, brackets, screws, etc. I have multiple used sets of carbs that I can part out for the items that you need, let me know what specific parts you're looking for.
THROTTLE SHAFT REBUILD PARTS:
THROTTLE SHAFT SEALS:
aaa) Aftermarket Hitachi HSC32/33 series carb THROTTLE SHAFT V-SEALS (sometimes called an "O-Ring", but it's not!)...these are the seals on the outside of the carb body that the throttle shaft passes through. Uses 2 per carb, BUT......without taking the carbs apart from the rack, the only ones you can replace are the outer seals on the #1 and the #4 carbs. Unlike the QR-series "o-rings" that many people recommend using---AND WHICH DO NOT FIT PROPERLY---these "V-Seals" do have the correct O.D., I.D., and thickness to fit both the throttle shaft and the carb shaft seal bore recess correctly. These V-seals are a superior sealing solution versus any other product out there!
HCP38B Aftermarket Hitachi throttle shaft V-SEAL, single:
$ 4.00
HCP38BSET2 Aftermarket Hitachi throttle shaft V-SEALS, pair:
$ 7.75
HCP38BSET8 Aftermarket Hitachi throttle shaft V-SEALS, set of 8:
$ 28.95
COMMENTARY: These seals are a VERY common source of vacuum leaks into the carbs, making tuning (synch, colortune, etc.) somewhere between very difficult and next-to-impossible. And here's the dirty little secret that no one really talks about:
If you read through these boards often and enough---or any other websites or lists devoted to these XJ bikes----you'll find a common theme in regards to these bikes, and it goes something like this:
"My bike doesn't run right."
And 9 times out of 10, it's due to a carb problem. And to make matters worse, these bikes don't just use one carb, they use four, which means that the synchronization of the four carbs to each other is critical in order for them to perform properly.
And 95% of the problems with the carbs is this: they are dirty (more like filthy!) inside due to age, and these seals are worn out. But to replace these seals (and also to properly get the insides of the carbs absolutely, positively, ZESTFULLY! clean), you're gonna have to pull the carb rack apart. Although that task is not mechanically difficult....nor does it take any special tools to do it.....the re-assembly process will MERCILESSLY PUNISH the careless or impatient mechanic or hobbyist. A tremendous attention to detail and organization is needed before you begin to take these carbs apart, so that you will have all the proper notes, drawings, sketches, etc. to put humpty-dumpty back together again, properly.
Since most people lack those skills or discipline, you will find most of the experienced experts on the various boards and forums telling you to NOT take the carbs apart, and to forego the proper cleaning and parts replacement steps needed.
I'm not trying to tell you to do, or not to do the task properly yourself; all I can tell you is what my own personal experience is. If you have the proper tools, time, and organizational skills and the PATIENCE to do the job right, breaking a rack apart and doing the job properly isn't that difficult. If you don't, it's a nightmare.
And the other dirty little secret is this: before you can synch and tune your carbs properly, you MUST check and adjust your valve clearances (replace worn valve shims), or all the synching and colortuning in the world isn't going to give you optimal results.
Sorry to be the bearer of such bad news, but as always, the truth will set you free (or at least solve most of your tuning and performance issues!).
Luckily, all of the parts and special tools needed to perform a proper tune up ARE available. I guess we should appreciate the little things in life more than we usually do........
We also strongly recommend the purchase of a new set of throttle shaft butterfly retaining screws, as it is very common to strip the heads out of the original screws while removing them. Replacement screws are listed further below.
Also, you are going to find it next-to-impossible to properly remove the original screws without using the proper JIS-style screwdriver. Typical "American" style screwdrivers do not have the proper tip design to engage the slots on JIS-specifications screws (which all screws on Japanese bikes are) and tend to very easily strip out the screw heads. We offer both a complete 4-piece set of various sized JIS screwdrivers, but those people wanting only the correct size screwdriver for these throttle shaft screws should order the HCP5901 (size #2) screwdriver:
HCP5901 Aftermarket size #2 JIS-standards SCREWDRIVER, for m3-m5 sized screws.
$ 11.95
HCP5904 JIS-standards SCREWDRIVER SET. Japanese phillips drive screws have sharper corners than regular phillips screwdrivers so they won't turn out under heavy torque. In order to take advantage of this feature, and to avoid stripping out the JIS screw heads by using US-standard phillips screwdrivers, it's a good idea to invest in a set of quality JIS-standard screwdrivers. This set of 4 contains one each of #1, #2, #3, and #4 sized-tip screwdrivers, and this range of sizes will handle everything down to an M2 sized screw (that's tiny, smaller than the size of the petcock faceplate mounting screws) all the way up to screws bigger than anything I've seen used on these bikes. They all feature sturdy plastic handles, chrome plated steel shafts, and come in a handy vinyl storage pouch.
$ 37.95
bbb) Aftermarket Hitachi HSC32/33 series carb THROTTLE SHAFT SEAL PLASTIC SHIM WASHER...these washers go directly "outside" of the HCP904 o-rings or the HCP38B v-seals listed above. Same notes as listed above about the seals (regarding the ease of replacement) also applies to these shims. NOTE: these shims do NOT "wear out" like the seals do; you only need to replace them if your shim washers are broken or missing. ALSO: although these replacement shims have the correct O.D. and I.D. as the originals, they are only 1/2 the thickness of the originals, and thus you will have to use two (2) of these shim washers to replace one (1) original shim washer.
HCP39C Aftermarket Hitachi throttle shaft seal SHIM WASHER, single:
$ 2.00
HCP39CSET2 Aftermarket Hitachi throttle shaft seal SHIM WASHERS, pair:
$ 3.75
HCP39CSET4 Aftermarket Hitachi throttle shaft seal SHIM WASHERS, four shims:
$ 7.25
HCP39CSET16 Aftermarket Hitachi throttle shaft seal SHIM WASHERS, set of sixteen shims:
$ 20.00
THROTTLE SHAFT HARDWARE:
v5) Aftermarket Hitachi throttle shaft BUTTERFLY VALVE MOUNTING SCREW. Each round aluminum butterfly "valve" is held to the steel throttle shaft via two tiny phillips head screws. The throttle shaft has self-locking threads which makes the removal of these screws both a chore and usually results in a buggered phillips head slot. These replacement screws come in a variety of materials and drive styles. Use 2 per carb, 8 per entire carb rack.
Also, unless you have reasons for doing otherwise, I always recommend upgrading the butterfly valve retaining screws to the 18-8 stainless steel HCP2561 button head hex-key style-----they are more durable than stock phillips headed plain steel, and much easier to remove in the future if the need ever arises.
HCP1347 aftermarket Hitachi butterfly valve retaining SCREWS, pan-head standard alloy steel screw with a phillips-drive, each:
$ 1.00
HCP1347SET2 aftermarket Hitachi butterfly valve retaining SCREWS, pan-head standard alloy steel screw with a phillips-drive, set of 2:
$ 1.75
HCP1347SET8 aftermarket Hitachi butterfly valve retaining SCREWS, pan-head standard alloy steel screw with a phillips-drive, set of 8:
$ 5.00
HCP1348 aftermarket Hitachi butterfly valve retaining SCREW, pan head 18-8 stainless steel screw with a phillips-drive, each:
$ 1.50
HCP1348SET2 aftermarket Hitachi butterfly valve retaining SCREWS, pan head 18-8 stainless steel screw with a phillips-drive, set of 2:
$ 2.75
HCP1348SET8 aftermarket Hitachi butterfly valve retaining SCREWS, pan head 18-8 stainless steel screw with a phillips-drive, set of 8:
$ 10.00
HCP1349 aftermarket Hitachi butterfly valve retaining SCREW, low-profile hex-drive allen-head screw made from 18-8 stainless steel, each:
$ 1.50
HCP1349SET2 aftermarket Hitachi butterfly valve retaining SCREWS, low-profile hex-drive allen-head screw made from 18-8 stainless steel, set of 2:
$ 2.75
HCP1349SET8 aftermarket Hitachi butterfly valve retaining SCREWS, low-profile hex-drive allen-head screw made from 18-8 stainless steel, set of 8:
$ 10.00
HCP2561 aftermarket Hitachi butterfly valve retaining SCREW, low-profile hex-drive button-head screw made from 18-8 stainless steel, each:
$ 1.00
HCP2561SET2 aftermarket Hitachi butterfly valve retaining SCREWS, low-profile hex-drive button-head screw made from 18-8 stainless steel, set of 2:
$ 1.75
HCP2561SET8 aftermarket Hitachi butterfly valve retaining SCREWS, low-profile hex-drive button-head screw made from 18-8 stainless steel, set of 8:
$ 5.00
ts5) Hitachi HSC-32 and -33 series carb THROTTLE SHAFT RETAINER E-CLIP...these shaft retainer clips go directly "outside" of the plastic shim washers listed above on the #1 and #4 carbs only. Used on all XJ650 except Turbo, all XJ700 non-X, and all XJ750 models.
HCP6836 OEM throttle shaft end retaining E-CLIP, bright plated spring steel, each:
$ 3.50
HCP6836SET2 aftermarket throttle shaft end retaining E-CLIPS, set of 2:
$ 6.75
HCP905 aftermarket throttle shaft end retaining E-CLIP, black-phosphate coated spring steel as original, each:
$ 1.00
HCP905SET2 aftermarket throttle shaft end retaining E-CLIPS, set of 2:
$ 1.50
HCP2909 aftermarket throttle shaft end retaining E-CLIP, type 420 stainless spring steel, each:
$ 1.75
HCP2909SET2 aftermarket throttle shaft end retaining E-CLIPS, set of 2:
$ 3.00
HITACHI IDLE - PILOT MIXTURE SCREW PARTS:
NOTE: idle mixture screws are also referred to as "pilot mixture screws" or "pilot screws".
If you've never delved into the guts of your carburetor idle mixture screw port, it can sometimes be confusing. Here's the playbook for this critical area:
If we were looking at a cut-away of the carb body/idle mixture screw bore, the order of parts, from bottom to top, would be:
a) HCP895 o-ring
b) HCP896 spring seat washer
c) HCP6573 tension spring
d) the idle mixture screw
e) the anti-tamper cap.
What is mostly confusing is the order of the o-ring versus the spring seat washer....which goes in the hole first? The answer is that the HCP895 O-ring does. The HCP896 washer primarily acts as the lower "seat" for the HCP6573 tension spring, while also keeping the o-ring firmly and securely in place.
ims83) Aftermarket replacement IDLE MIXTURE SCREWS (sometimes referred to as pilot screws, or pilot mixture screws, or "those stripped out things in that hole up front"), for all Hitachi HSC-32 and -33 series carbs as used on XJ650 (except Turbo), all XJ750 Maxim and Seca models, and XJ700 non-X (air-cooled) carbs. Correct reproduction screws are available in the original styles to exactly replace damaged, stripped, or missing originals.
The original screws were available in three versions:
a) Alloy steel, with coarse-pitch threads, used on 1980-81 XJ650 Maxim and Midnight Maxim model carbs. The best description I can give for "coarse" threads is that the threads are sized much like you would see on a standard screw (like the carb bowl drain screws, etc.).....the threads are rather "wide apart". This is in contrast to..........
b) Alloy steel, with ultra-fine-pitch threads, used on 1982-up XJ650 models with Hitachi carbs, all XJ750 Maxim and Seca models, and possibly on early model XJ700 non-X Hitachi HSC33 series carbs. Ultra-fine thread pitch looks like screw threads used on some kind of jeweler's or watchmaker's incredibly-closely-spaced threads.
c) Brass, with ultra-fine-pitch threads, used only in XJ700 non-X Hitachi HSC33 series carbs.
Note that the determination of which style screw YOUR carbs have can vary from what MODEL AND YEAR bike you have, as someone may have switched a carb body, an entire rack of carbs, or due to original mass-production and supplier differences and timing of production.
ALL ORIGINAL HITACHI IDLE MIXTURE SCREWS ARE IDENTICAL AS TO FUNCTION AND DIFFER ONLY BY THEIR THREAD PITCH (coarse versus ultra-fine) AND THE MATERIAL THEY WERE MADE OF (alloy steel versus brass). Owners of carbs with the ultra fine-pitch threaded screws CANNOT use coarse-thread pitch screws, and vice-versa.
However, owners of carbs with the (much more common) ultra-fine pitch threaded bores and screws can use either the steel or brass screws interchangeably----although we recommend sticking with one or the other in a full rack of carbs.
Why did Hitachi change from using coarse thread (1980-81) to fine-threaded screws? Who knows, but it probably has something to do with the fineness of the adjustability needed for these precision mixture screws.....a fine-threaded screw offers a much more precise level of fine-tuning adjustability than a coarse-threaded screw does ("coarse-pitch" screws move the screw further along it's bore for each given amount of turning, so a 1/4-revolution turn of a coarse-pitch screw will move that screw FURTHER up or down in its bore than the same 1/4-revolution turn will move a fine-pitched screw).
Thus the standard advice of using the 2.5-to-3 turns out (from bottoming) as a "starting point" for the idle mixture screw setting is really based on the use of the fine-pitched screws; the earlier coarse-pitch screws would need to be initially set at about 1.5-to-2 turns out as an initial starting point.
More questions from the audience: Why did Hitachi change from using steel screws (most 1980-83 model carbs) to brass screws (1985-86 models)? Who know, but it was either a cost saving measure (brass is not normally cheaper than steel, but it is much easier to machine precisely), or, given how these screws are known for seizing up in their bores, perhaps it was to provide a material that was not as susceptible to seizure (such as brass).
Either way, since you will be using some anti-seize fluid when installing your new screw (or even when re-using your old screws during a rebuild), this is not really an issue any more. Right? RIGHT? I mean, you WILL use anti-seize, won't you?
These idle mixture screws are exact reproductions of the originals, with the original straight-blade screw head, and are available in either the coarse-pitch in a Type 304 stainless steel material (instead of the original alloy steel), or in the fine pitch versions----and the fine pitch versions are available in either a Type 304 stainless steel material (instead of the original alloy steel) or screw-grade Brass.
HCP8392 Aftermarket Hitachi stainless steel IDLE MIXTURE SCREW with coarse threads, for all Hitachi HSC32 carbs with coarse threads in the idle mixture bore holes. Normally found on 1980-81 XJ650 models, but this "rule" may vary, so check your original screws or carb bore threads before ordering. Each:
$ coming soon!
HCP8392SET4 Aftermarket Hitachi stainless steel IDLE MIXTURE SCREWS with coarse threads, set of 4:
$ coming soon!
HCP8392KIT Aftermarket Hitachi stainless steel IDLE MIXTURE SCREW KIT with coarse threads, complete with one each of an HCP8392 stainless steel mixture screw, an HCP895 O-ring, the HCP6573 tension Spring, and the HCP896 spring seat Washer. Does one carb:
$ coming soon!
HCP8392KIT4 Aftermarket Hitachi stainless steel IDLE MIXTURE SCREW KITS with coarse threads, set of 4 does one entire rack of carbs:
$ coming soon!
HCP8393 Aftermarket Hitachi stainless steel IDLE MIXTURE SCREW with ultra-fine threads, for all Hitachi HSC-32 and -33 series carbs with fine threads in the idle mixture bore holes. Normally found on 1982-84 XJ650 models and all XJ750 models, but those "rules" may vary, so check your original screws or carb bore threads before ordering. Each:
$ 14.95
HCP8393SET4 Aftermarket Hitachi stainless steel IDLE MIXTURE SCREWS with ultra-fine threads, set of 4:
$ 54.95
HCP8393KIT Aftermarket Hitachi stainless steel IDLE MIXTURE SCREW KIT with ultra-fine threads, complete with one each of an HCP8393 stainless steel mixture screw, an HCP895 O-ring, the HCP6573 tension Spring, and the HCP896 spring seat Washer. Does one carb:
$ 19.95
HCP8393KIT4 Aftermarket Hitachi stainless steel IDLE MIXTURE SCREW KITS with ultra-fine threads, set of 4 does one entire rack of carbs:
$ 69.95
HCP8394 Aftermarket Hitachi brass IDLE MIXTURE SCREW with ultra-fine threads, for all Hitachi HSC-32 and -33 series carbs with fine threads in the idle mixture bore holes. Sometimes found on original 1983 XJ650 and XJ750 carbs, and always used on 1985-86 XJ700 non-X (air-cooled) models, but these "rules" may vary, so check your original screws or carb bore threads before ordering. Each:
$ coming soon!
HCP8394SET4 Aftermarket Hitachi brass IDLE MIXTURE SCREWS with ultra-fine threads, set of 4:
$ coming soon!
HCP8394KIT Aftermarket Hitachi brass IDLE MIXTURE SCREW KIT with ultra-fine threads, complete with one each of an HCP8394 brass mixture screw, an HCP895 O-ring, the HCP6573 tension Spring, and the HCP896 spring seat Washer. Does one carb:
$ coming soon!
HCP8394KIT4 Aftermarket Hitachi brass IDLE MIXTURE SCREW KITS with ultra-fine threads, set of 4 does one entire rack of carbs:
$ coming soon!
ddd) Aftermarket Hitachi IDLE MIXTURE SCREW O-RING.....a "must-replace" item when rebuilding your carbs. Made of long-lasting, fuel-resistant Buna-N material.
HCP895 Aftermarket Hitachi idle mixture screw O-RING, each:
$ 1.50
HCP895SET4 Aftermarket Hitachi idle mixture screw O-RINGS, set of 4:
$ 4.95
eee) Aftermarket Hitachi IDLE MIXTURE SCREW SPRING SEAT WASHER.....also a "must-replace" item when rebuilding your carbs. Made of long-lasting, fuel- and water-resistant 18-8 stainless steel material.
HCP896 Aftermarket Hitachi idle mixture screw spring seat WASHER, each:
$ 1.75
HCP896SET4 Aftermarket Hitachi idle mixture screw spring seat WASHERS, set of 4:
$ 5.95
ims6) Aftermarket carb IDLE MIXTURE SCREW TENSION SPRING, brand new reproductions exactly replace damaged, rusted, or missing originals. High-strength carbon-steel coil springs have a baked yellow-zinc plating as original.
HCP6573 Aftermarket reproduction idle mixture screw TENSION SPRING, fits all Hitachi HSC32 and HSC33 model carbs as used on all XJ650 (except Turbo), XJ700 non-X, and all XJ750 models, each:
$ 3.50
HCP6573SET4 Aftermarket reproduction idle mixture screw TENSION SPRINGS, fits all Hitachi HSC32 and HSC33 model carbs as used on all XJ650 (except Turbo), XJ700 non-X, and all XJ750 models, set of 4:
$ 10.95
HCP2398 THREAD CHASER & CLEAN-UP TAP, made from a high-speed uncoated steel. For use on all Hitachi idle mixture screw ports, for models using ultra-fine threaded idle mixture screws. NOTE: these threaded holes almost always need cleaning or re-tapping.
$ 33.00
HCP6335 THREAD CHASER & CLEAN-UP TAP, made from a high-speed uncoated steel. For use on all Hitachi idle mixture screw ports, for models using coarse threaded idle mixture screws. NOTE: these threaded holes almost always need cleaning or re-tapping.
$ 24.00
HCP254 Idle Mixture Screw REMOVAL AND ADJUSTER TOOL, fits all Hitachi models and all Mikuni idle mixture screws.
$ 17.95
HITACHI IDLE SPEED SCREW PARTS:
Not to be confused with the idle MIXTURE screw listed above, the IDLE SPEED SCREW is the large knurled-head screw that lives dead center, at the bottom of the carb rack, in-between the #2 and #3 cars, and pointing straight back. This screw is used to adjust the idle speed of the engine, and has no effect on the idle mixture nor the carb (engine) "synch" settings!
HCP9849 Aftermarket Hitachi idle speed screw rubber GROMMET, fits into the lower carb rack bracket opening where the idle speed screw enters the bracket. This replacement grommet is quite a bit larger than the stock grommet, but fits and works properly. Use a little bit of silicone grease on the screw's shaft where it passes through this grommet and it will be silky-smooth in operation. Fits all XJ650 (except Turbo), XJ700 non-X, and XJ750 models using Hitachi carbs.
$ 1.95
HCP4024 Aftermarket Hitachi carb idle speed screw WASHER, not an original part, but if you use a set of these thin flat plastic shimming washers in-between the spring and the screw, and between the spring and the bracket (in other words, on either end of the spring), it greatly reduces the friction between the two and makes the idle screw silky-smooth to adjust! Fits all XJ650 (except Turbo), XJ700 non-X, and XJ750 models using Hitachi carbs. Each:
$ 0.75
FUEL PIPE O-RINGS:
mmm1) OEM and Aftermarket Hitachi fuel rail Connector Pipe O-RING.....all fours carbs share a common fuel supply, and this fuel supply is distributed to each carb via a brass or aluminum tube that connects one carb to another. These tubes fits into a machined bores in the carb base, and the tubes are sealed in their bores with these rubber o-rings. NOTE: original seals were "D-rings" rather than "O-rings", but are now serviced only as o-rings (both OEM and replacements), but are the correct shape and firmness to provide a leak-proof fit. You will only be able to access these seals if you break the carbs out of their rack! (and if you do break the rack, you need to replace these seals). Aftermarket seals comes in your choice of either a lower-cost Buna-N material, or a longer-life Viton material. Either one will work just fine and last until the next time you take your carbs apart!
The viton material is much harder than the Buna-N material and the use of the viton seals requires quite a bit of effort to install the connector tube into the carb fuel port bores!
- Use 2 seals per tube, or a total of 6 seals per entire carb rack, for HSC32 series carbs (XJ650 except Turbo, XJ750 all).
- Use 2 seals per tube, or a total of 10 seals per entire carb rack, for HSC33 series carbs (all XJ700 non-X models).
HCP92 OEM Hitachi fuel supply tube O-RING, each:
$ 1.50
HCP92SET2 OEM Hitachi fuel supply tube O-RINGS, each:
$ 2.75
HCP92SET6 OEM Hitachi fuel supply tube O-RINGS, set of 6:
$ 7.50
HCP92SET10 OEM Hitachi fuel supply tube O-RINGS, set of 10:
$ 9.00
HCP2421SET2 Aftermarket Hitachi Buna-N material fuel supply tube O-RINGS, pair:
$ 2.00
HCP2421SET6 Aftermarket Hitachi Buna-N material fuel supply tube O-RINGS, set of 6:
$ 4.95
HCP2421SET10 Aftermarket Hitachi Buna-N material fuel supply tube O-RINGS, set of 10:
$ 7.50
HCP2420SET2 Aftermarket Hitachi Viton material fuel supply tube O-RINGS, pair:
$ 2.50
HCP2420SET6 Aftermarket Hitachi Viton material fuel supply tube O-RINGS, set of 6:
$ 6.95
HCP2420SET10 Aftermarket Hitachi Viton material fuel supply tube O-RINGS, set of 10:
$ 8.95
HITACHI MAIN FUEL JETS:
ee) Aftermarket Hitachi brass MAIN FUEL JETS, sizes as follows, fits all XJ650 (except Turbo), all XJ750, and all XJ700 (exc. "X") models.
NOTE: stock Hitachi XJ series carbs used the following original sizes:
#102: XJ750E-II models (cylinders #2 & #3)
#105: XJ750E-II models (cylinders #1 & #4)
#106: 1984 XJ750RL Seca models.
#107: all XJ700 non-X models.
#110: all XJ650 North American models (except 1982-84 Canadian models) and all 1980-81 XJ650 UK/European (4K0 and 4K1) models.
#112: all 1982-84 XJ650 UK/European (11N and 14R) models and 1982-84 XJ650 Canadian models.
#120: all XJ750 North American and UK/European models except the 1984 XJ750RL models.
All the other sizes are for "tuning" or re-jetting purposes when changing intakes or exhaust systems.
HCP10228 Aftermarket brass #102 MAIN FUEL JET, stock size for XJ750E-II models, each:
$ 7.95
HCP10228SET4 Aftermarket brass #102 MAIN FUEL JETS, set of 4:
$ 27.95
HCP10229 Aftermarket brass #105 MAIN FUEL JET, stock size for XJ750E-II models, each:
$ 7.95
HCP10228SET4 Aftermarket brass #105 MAIN FUEL JETS, set of 4:
$ 27.95
HCP6316 Aftermarket brass #106 MAIN FUEL JET, stock size for '84 XJ750RL Seca models, each:
$ 7.95
HCP6316SET4 Aftermarket brass #106 MAIN FUEL JETS, set of 4:
$ 27.95
HCP6317 Aftermarket brass #107 MAIN FUEL JET, stock size for XJ700 non-X models, each:
$ 7.95
HCP6317SET4 Aftermarket brass #107 MAIN FUEL JETS, set of 4:
$ 27.95
HCP6318 Aftermarket brass #108 MAIN FUEL JET, each:
$ 7.95
HCP6318SET4 Aftermarket brass #108 MAIN FUEL JETS, set of 4:
$ 27.95
HCP6319 Aftermarket brass #109 MAIN FUEL JET, each:
$ 7.95
HCP6319SET4 Aftermarket brass #109 MAIN FUEL JETS, set of 4:
$ 27.95
HCP10601 Aftermarket brass #110 MAIN FUEL JET, stock size for most XJ650 models, each:
$ 6.95
HCP10601SET4 Aftermarket brass #110 MAIN FUEL JETS, set of 4:
$ 24.95
HCP10602 Aftermarket brass #112 MAIN FUEL JET, each:
$ 6.95
HCP10602SET4 Aftermarket brass #112 MAIN FUEL JETS, set of 4:
$ 24.95
HCP8366 Aftermarket brass #114 MAIN FUEL JET, each:
$ 6.95
HCP8366SET4 Aftermarket brass #114 MAIN FUEL JETS, set of 4:
$ 24.95
HCP10082 Aftermarket brass #116 MAIN FUEL JET, each:
$ 6.95
HCP10082SET4 Aftermarket brass #116 MAIN FUEL JETS, set of 4:
$ 24.95
HCP10606 Aftermarket brass #118 MAIN FUEL JET, each:
$ 6.95
HCP10606SET4 Aftermarket brass #118 MAIN FUEL JETS, set of 4:
$ 24.95
HCP8365 Aftermarket brass #120 MAIN FUEL JET, stock size for most XJ750 models, each:
$ 6.95
HCP8365SET4 Aftermarket brass #120 MAIN FUEL JETS, set of 4:
$ 24.95
HCP10607 Aftermarket brass #122 MAIN FUEL JET, each:
$ 6.95
HCP10607SET4 Aftermarket brass #122 MAIN FUEL JETS, set of 4:
$ 24.95
HCP10608 Aftermarket brass #124 MAIN FUEL JET, each:
$ 6.95
HCP10608SET4 Aftermarket brass #124 MAIN FUEL JETS, set of 4:
$ 24.95
HCP10609 Aftermarket brass #126 MAIN FUEL JET, each:
$ 6.95
HCP10609SET4 Aftermarket brass #126 MAIN FUEL JETS, set of 4:
$ 24.95
HCP10610 Aftermarket brass #128 MAIN FUEL JET, each:
$ 7.95
HCP10610SET4 Aftermarket brass #128 MAIN FUEL JETS, set of 4:
$ 27.95
HCP10611 Aftermarket brass #130 MAIN FUEL JET, each:
$ 7.95
HCP10611SET4 Aftermarket brass #130 MAIN FUEL JETS, set of 4:
$ 27.95
HCP10612 Aftermarket brass #132 MAIN FUEL JET, each:
$ 7.95
HCP10612SET4 Aftermarket brass #132 MAIN FUEL JETS, set of 4:
$ 27.95
HCP11152 Aftermarket brass #134 MAIN FUEL JET, each:
$ 7.95
HCP11152SET4 Aftermarket brass #134 MAIN FUEL JETS, set of 4:
$ 27.95
xx3) Reproduction Hitachi main fuel jet SPACER WASHER, round flat copper washer goes under the head of the main fuel jet. Perfectly replaces missing or bowed originals.
HCP887 Hitachi carbs main fuel jet SPACER WASHER, each:
$ 4.50
HCP887SET4 Hitachi carbs main fuel jet SPACER WASHERS, set of 4:
$ 14.95
HITACHI MAIN AIR JETS:
The main air jets on all Hitachi HSCxx series carbs are located under the vacuum piston diaphram, and are a small, brass "headless" screw-in jet. On some model carbs, these air jets live under a small, curved flay metal "cover plate" which is retained by a special shouldered screw (most later-model Hitachi carbs seem to have dispensed with this air jet cover plate, although its threaded mounting hole still remains in the carb body).
Replacement Hitachi main air jets are now available for these model carbs, in both their original sizes and in optional "tuning" sizes for use with pod filters or other special tuning purposes.
#50: all XJ650 models.
#70: all XJ700 non-X models, XJ750RL Seca models, and XJ750E-II models.
#80: all 1981-83 XJ750 North American models and 1981-84 XJ750 UK/European (11M) models.
NOTE: the Haynes workshop manual for the XJ650 and XJ750 models has the incorrect placement noted for these air jets----the main air jet and pilot air jets are reversed in their picture and caption. Just remember that the main air jet goes directly above the main fuel jet, and is thus located in the "center" of the three holes in this area.
HCP6305 Aftermarket Hitachi brass MAIN AIR JET #40, not an original size, used for fuel mixture tuning purposes only. Each:
$ 8.95
HCP6306 Aftermarket Hitachi brass MAIN AIR JET #45, not an original size, used for fuel mixture tuning purposes only. Each:
$ 8.95
HCP6307 Aftermarket Hitachi brass MAIN AIR JET #50, original size for all XJ650 models. Each:
$ 7.95
HCP6308 Aftermarket Hitachi brass MAIN AIR JET #55, not an original size, used for fuel mixture tuning purposes only. Each:
$ 8.95
HCP6309 Aftermarket Hitachi brass MAIN AIR JET #60, not an original size, used for fuel mixture tuning purposes only. Each:
$ 8.95
HCP6310 Aftermarket Hitachi brass MAIN AIR JET #65, not an original size, used for fuel mixture tuning purposes only. Each:
$ 8.95
HCP6311 Aftermarket Hitachi brass MAIN AIR JET #70, original size for all XJ700 non-X (air-cooled) models, XJ750RL Seca models, and XJ750E-II models. Each:
$ 7.95
HCP6312 Aftermarket Hitachi brass MAIN AIR JET #75, not an original size, used for fuel mixture tuning purposes only. Each:
$ 8.95
HCP6313 Aftermarket Hitachi brass MAIN AIR JET #80, original size for all XJ700 non-X (air-cooled) models, XJ750RL Seca models, and XJ750E-II models. Each:
$ 7.95
HCP6314 Aftermarket Hitachi brass MAIN AIR JET #85, not an original size, used for fuel mixture tuning purposes only. Each:
$ 8.95
HCP6315 Aftermarket Hitachi brass MAIN AIR JET #90, not an original size, used for fuel mixture tuning purposes only. Each:
$ 8.95
HITACHI PILOT FUEL JETS:
ff) Aftermarket Hitachi PILOT FUEL JET, sizes as follows, fits all XJ650 (except Turbo), all XJ750, and all XJ700 (exc. "X") models.
#36.5: all XJ700 non-X models.
#40: all 1980-83 XJ650 USA models, 1980-81 XJ650 Canadian models, 1982 XJ650RJ and RJC Seca Canadian models, 1980-82 XJ650 UK/European (4K0) models, 1981-83 all XJ750 USA models, XJ750E-II models, and XJ750RL models. NOTE: the factory service manual references a pilot air fuel jet for the XJ750RL models as being either a #40 or a #41 size. We are not sure which size is actually correct.
#43: all 1982-84 XJ650 Canadian models, 1982-84 XJ650 UK/European (11N and 14R) models, 1981-83 XJ750 Maxim, Midnight Maxim Canadian models, and 1981-84 XJ750 UK/European (11M) models.
The #41, #42, and #45 sizes can also be used for "tuning" or re-jetting purposes when changing intakes or exhaust systems.
HCP6321 Aftermarket brass #36.5 PILOT FUEL JET, each:
$ 6.95
HCP6321SET4 Aftermarket brass #36.5 PILOT FUEL JETS, set of 4:
$ 24.95
HCP885 Aftermarket brass #40 PILOT FUEL JET, each:
$ 6.95
HCP885SET4 Aftermarket brass #40 PILOT FUEL JETS, set of 4:
$ 24.95
HCP886 Aftermarket brass #41 PILOT FUEL JET, each:
$ 6.95
HCP886SET4 Aftermarket brass #41 PILOT FUEL JETS, set of 4:
$ 24.95
HCP6326 Aftermarket brass #42 PILOT FUEL JET, each:
$ 6.95
HCP6326SET4 Aftermarket brass #42 PILOT FUEL JETS, set of 4:
$ 24.95
HCP6320 Aftermarket brass #43 PILOT FUEL JET, each:
$ 6.95
HCP6320SET4 Aftermarket brass #43 PILOT FUEL JETS, set of 4:
$ 24.95
HCP9661 Aftermarket brass #45 PILOT FUEL JET, each:
$ 7.95
HCP9661SET4 Aftermarket brass #45 PILOT FUEL JETS, set of 4:
$ 27.95
HCP9815 Aftermarket brass #46 PILOT FUEL JET, each:
$ 7.95
HCP9815SET4 Aftermarket brass #46 PILOT FUEL JETS, set of 4:
$ 27.95
HCP9816 Aftermarket brass #47 PILOT FUEL JET, each:
$ 7.95
HCP9816SET4 Aftermarket brass #47 PILOT FUEL JETS, set of 4:
$ 27.95
HCP12616 Aftermarket brass #50 PILOT FUEL JET, each:
$ 7.95
HCP12616SET4 Aftermarket brass #50 PILOT FUEL JETS, set of 4:
$ 27.95
HITACHI PILOT AIR JETS:
The pilot air jets on all Hitachi HSCxx series carbs are located under the vacuum piston diaphram, and are a small, brass "headless" screw-in jets. On some model carbs, these air jets live under a small, curved "cover plate" which is retained by a special shouldered screw (most later-model Hitachi carbs seem to have dispensed with this air jet cover plate, although its threaded mounting hole still remains in the carb body).
Replacement Hitachi pilot air jets are now available for these model carbs, in both their original sizes and in optional "tuning" sizes for use with pod filters or other special tuning purposes.
#195: all 1980-81 all XJ650 North American models, all 1982 XJ650RJ and RJC Seca, and 1980-82 XJ650 UK/European (4K0 and 4K1) models.
#205: all 1982-84 XJ650 Maxim North American models, 1982-84 XJ650 UK/European (11N) models, 1981-83 XJ750 Canadian models, and 1981-84 XJ750 UK/European (11M) models.
#210: all XJ700 non-X models.
#225: all 1982 XJ650 UK/European (14R) models, all 1981-83 XJ750 USA models, XJ750E-II models, and XJ750RL models.
NOTE: the Haynes workshop manual for the XJ650 and XJ750 models has the incorrect placement noted for these air jets----the main air jet and pilot air jets are reversed in their picture and caption. Just remember that the pilot air jet goes directly above the pilot fuel jet, and is thus located in the "forward-most" of the three holes in this area.
HCP6289 Aftermarket Hitachi brass PILOT AIR JET #175, not an original size, used for fuel mixture tuning purposes only. Each:
$ 8.95
HCP6290 Aftermarket Hitachi brass PILOT AIR JET #180, not an original size, used for fuel mixture tuning purposes only. Each:
$ 8.95
HCP6291 Aftermarket Hitachi brass PILOT AIR JET #185, not an original size, used for fuel mixture tuning purposes only. Each:
$ 8.95
HCP6292 Aftermarket Hitachi brass PILOT AIR JET #190, not an original size, used for fuel mixture tuning purposes only. Each:
$ 8.95
HCP6293 Aftermarket Hitachi brass PILOT AIR JET #195, original size for all 1980-81 all XJ650 North American models, all 1982 XJ650RJ and RJC Seca, and 1980-82 XJ650 UK/European (4K0 and 4K1) models. Each:
$ 7.95
HCP6294 Aftermarket Hitachi brass PILOT AIR JET #200, not an original size, used for fuel mixture tuning purposes only. Each:
$ 8.95
HCP6295 Aftermarket Hitachi brass PILOT AIR JET #205, original size for all 1982-84 XJ650 Maxim North American models, 1982-84 XJ650 UK/European (11N) models, 1981-83 XJ750 Canadian models, and 1981-84 XJ750 UK/European (11M) models. Each:
$ 7.95
HCP6296 Aftermarket Hitachi brass PILOT AIR JET #210, original size for all 1985-86 XJ700 air-cooled engines. Each:
$ 7.95
HCP6297 Aftermarket Hitachi brass PILOT AIR JET #215, not an original size, used for fuel mixture tuning purposes only. Each:
$ 8.95
HCP6298 Aftermarket Hitachi brass PILOT AIR JET #220, not an original size, used for fuel mixture tuning purposes only. Each:
$ 8.95
HCP6299 Aftermarket Hitachi brass PILOT AIR JET #225, original size for all 1982 XJ650 UK/European (14R) models, all 1981-83 XJ750 USA models, XJ750E-II models, and XJ750RL models. Each:
$ 7.95
HCP6300 Aftermarket Hitachi brass PILOT AIR JET #230, not an original size, used for fuel mixture tuning purposes only. Each:
$ 8.95
HCP6301 Aftermarket Hitachi brass PILOT AIR JET #235, not an original size, used for fuel mixture tuning purposes only. Each:
$ 8.95
HCP6302 Aftermarket Hitachi brass PILOT AIR JET #240, not an original size, used for fuel mixture tuning purposes only. Each:
$ 8.95
HCP6303 Aftermarket Hitachi brass PILOT AIR JET #245, not an original size, used for fuel mixture tuning purposes only. Each:
$ 8.95
HCP6304 Aftermarket Hitachi brass PILOT AIR JET #250, not an original size, used for fuel mixture tuning purposes only. Each:
$ 8.95
WHAT ABOUT RE-JETTING FOR PODS, ETC?:
It's a question we get asked often and unfortunately, one that we cannot answer honestly about your specific bike besides with "it depends".
Which is a nice way of saying "you're about to enter the seventh circle of hell......."!
Carb jet tuning required by aftermarket modifications is somewhat of a black art, part science, part skill, part luck. It depends on the current state of tune of your engine, your altitude, the mix of aftermarket parts on your bike, etc........a lot of variables.
The best advice we can offer is: Just Say No. Don't do it! Leave everything stock!
But, since most people---with good reason, I might add---don't always listen to our well-intentioned advice, then the next best recommendation we can offer is: "if you want more power get a bigger bike!".
And since that doesn't cut it with many owners, either, for the remaining stalwarts out there who insist on "experimenting" with aftermarket intake and exhaust systems, here's the best information that we've come across to give you some GUIDANCE, which you should take as just that, and not as ANSWERS, because it isn't!
MAIN FUEL JET SIZE CHANGES NEEDED PER TYPICAL MODIFICATION:
Typical Exhaust Changes:
+2 main fuel jet size for custom 4-into-2 exhaust
or
+4 main fuel jet sizes for 4-into-1 exhaust
or
+4 main jet sizes for no muffler (open headers)
Typical Intake Changes:
+2 main fuel jet sizes for single K&N filter (inside a stock airbox)
or
+2 main fuel jet size for drilling holes in the airbox with stock filter
or
+4 main fuel jet sizes for individual pod filters (no airbox)
Additional changes:
- Add up all the main fuel jet size increases and subtract 2 sizes.
- Decrease main fuel jet size by 2 sizes per every 2000' above sea level.
- Under a mis-match condition, such as when using pod filters with a 100% stock exhaust, or 4-into-1 header with stock filter and air box, then subtract 2 main fuel jet sizes.
PILOT FUEL JET SIZES CHANGES NEEDED PER TYPICAL MODIFICATION:
Pilot fuel jet size changes are related only to the change in main fuel jet sizes according to the main fuel jet size formula described above. Note that this pilot fuel jet rule is for the main fuel jet size change BEFORE any main fuel jet altitude compensation is factored in:
Increase the pilot fuel jet size +1 for every +3 main fuel jet size increases.
Additional changes:
- Decrease pilot fuel jet size by 1 for every 6000' above sea level.
PRECAUTIONS:
- Make sure your carbs are in perfect working order before making ANY jet changes....meaning fully cleaned internally and rebuilt, operating properly in their stock configuration, proper sized air jets and needles, etc. Otherwise, you'll like find that all of your efforts are going to be a HUGE waste of time.
- Check plug color often and adjust as needed, 2 main fuel jet sizes at a time and 1 pilot fuel jet size at a time. Bright white plug insulators are a sign of an overly lean fuel mixture condition and WILL cause damage to your engine over time, up to and including engine seizure!
- Synch the carbs after each jet change.
- Make sure the floats are set correctly
- Seriously consider purchasing a Colortune Plug Tuning kit.
- You may find it necessary to make changes to the size or shimming of the main jet needle. There are no guidelines on what or how to do these changes, this is true trial-and-error tuning!
EXAMPLE:
A 1982 XJ750RJ Seca using an aftermarket Supertrapp 4-into-1 exhaust and a single K&N air filter in the stock, unmodified airbox. Bike is primarily operated at an altitude of 2600 feet above sea level.
XJ750 Seca Stock Hitachi HSC32 Carb Jetting:
#120 Main Fuel Jet
#40 Pilot Fuel Jet
#50 Main Air Jet
#225 Pilot Air Jet
Y-13 Needle
MAIN FUEL JET SIZE CALCULATIONS:
Changes made:
Exhaust:
4 into 1 with Supertrapp = +4 Sizes Main Fuel Jet
Intake:
K&N Pod Filters = +4 sizes Main Fuel Jet
Equals: +8 main fuel jet sizes above baseline
Subtract: -2 main fuel jet size per formula above
Equals: +6 main fuel jet sizes due to modifications, thus:
Stock main fuel jet size is: #120
+ 6 additional sizes
= a #126 main fuel jet size
Subtract: -2 main fuel jet sizes for Altitude of 2500' Average
= #126 calculated from above
-2 jet sizes for altitude adjustment
= a #124 main fuel jet size.
PILOT FUEL JET SIZE CALCULATIONS:
The formula is: +1 pilot jet size increase for every +3 main jet sizes increased.
Stock pilot fuel jet size is: #40
+ 2 additional jet sizes (since we went up +6 main fuel jet sizes before the altitude compensation was factored in):
= a #42 pilot fuel jet size.
Note that no altitude compensation is needed on the pilot fuel jet since our elevation is less than 6000' a-s-l.
RESULT:
A #124 Main and #42 Pilot is A GOOD STARTING POINT.
Note that the above calculations do NOT take into account any possible changes in the sizes of the air jets nor the main needle size, which are additional variables and opportunities for tuning excellence (or frustration!).
For further insights and understanding, the Holy Grail (meaning: the whole miserable, un-varnished truth of what a real chore carb tuning is going to be, written by people who actually know what they're talking about, rather than by people who are trying to sell you something) can be found at:
www.factorypro.com
and then click on the "Product Support/Technical Support" link at the top of the page, then on the "Motorcycle Tuning Tech" link, and then the "CV Carb Tuning" link........and then read, weep, study, and do....if you still dare to! HINT: if reading through it makes you think to yourself "sheesh, this sounds like an incredible amount of effort!", well, you're right! That's just some of the joys (and pitfalls) of getting to play "tuning engineer", which is what you're going to be doing. Yamaha probably has 10 of those types of guys on staff, and millions of dollars of test equipment, both physical and computer-aided, that allowed them to get the mixture settings just right---from an overall drivability AND power output standpoint----and now, since you're changing the airflow parameters thru the engine, you'll have to figure it all out "from scratch", but WITHOUT the benefit of 10 trained engineers and all that test equipment and experience.
That's why we warn you that setting up a bike for pods can be quite a bit of trial-and-error procedure. You can make the calculations according to what is shown in that guideline and then order the jets that the "formula" recommends, and that should serve as a good STARTING POINT............you may (or may not!) have to do more tuning and trial-and-erroring substitution of different jet sizes, etc. to get it performing to you satisfaction, with the recognition that you may ALWAYS end up with a situation that has some kinds of trade-offs.....lazy at the lower end but runs well at mid/upper-ranges, or runs well at the lower end but a "flat-spot" at some other rpm range, etc. Unfortunately there is no magic formula........you might want to read through the factorypro.com article that I list at the end of that section, and you will get a better understanding of what is involved to get the carbs set-up properly in a non-stock configuration.
CARB FLOAT BOWL PARTS:
gg) OEM and aftermarket Hitachi FLOAT BOWL GASKETS & O-RINGS:
Die-cut replacement carb bowl-to-carb body gaskets correctly replace your torn or leaking originals. Fits all XJ650 (except Turbo), all XJ700 non-X, and all XJ750 models with Hitachi carbs.
HCP50 OEM Hitachi carb BOWL GASKET, single:
$ 6.50
HCP50SET4 OEM Hitachi carb BOWL GASKETS, set of 4:
$ 22.95
HCP862 Aftermarket Hitachi carb BOWL GASKET, single:
$ 4.00
HCP862SET4 Aftermarket Hitachi carb BOWL GASKETS, set of 4:
$ 14.95
Okay, everyone asks, so here goes: should you use the OEM Yamaha or the aftermarket bowl gaskets? Well, the OEM Yamaha gaskets look and feel more substantial, and have a somewhat waxy coating to them, which is there for a reason I suppose---probably has to do with the longevity of the gasket when the float bowls are being removed and replaced quite often. HOWEVER, I've used both the OEM and the replacement bowl gaskets on my own bikes and carb sets and have never had either style leak. I make more money selling the aftermarket gaskets, but for the small difference in price, if you're not on an ultra-tight budget, I'd use the OEM gaskets on my own personal bikes..........just my thoughts.
ALSO: if you use any type of sealant on these gaskets, use it on the BOWL side of the gasket (something like Permatex Copper Spray-A-Gasket is a fine choice). On the carb body side of the gasket, use a light oil....like Marvel Mystery Oil or the like....and barely moisten the gasket surface. This will allow the new gasket to soften slightly and allows the gasket to form itself to the raised mounting ridge that is cast onto the carb body mating flange.....and also allows for an easy, no-stick removal of the float bowl in the future!
CARB FLOATS & FLOAT NEEDLE VALVES:
NOTES on float needle valve Seats and Needles:
- original seats had a fuel inlet boss (where the inlet filter screen sits) of either 5.10mm (and uses a flat screen) or a 6.57mm boss with a 7.30mm "lip" (this style uses a domed screen).
- The HCP1 kit comes without a screen but the float seat has a 5.10mm screen mounting boss, so an original FLAT screen can be used with these if you still have your original flat screens. The needle is slightly longer (about 1mm) than on the HCP10 needle. The needle seat Washer is made of a stiff fiber material, as opposed to the original metal washer.
- The HCP10 kit comes with a flat screen and the float seat has a 5.10mm screen mounting boss. The needle is slightly shorter than on the HCP1 needle. The needle seat Washer is made of copper as original.
- The HCP872 and HCP2776 kits comes with a screen and the float seat has a 4.53mm screen mounting boss. The needle is slightly longer (about 1mm) than on the HCP10 needle. The needle seat Washer is made of metal like original, but it's aluminum rather than copper.
- There is a third style of seat and it uses a "domed" style screen. The mounting boss for the screen on the seat is 7.25mm OD and it is "stepped". This style seat and screen are not currently available.
- The HCP870 Needle Only uses a needle that is slightly taller (about 1mm) than stock. It is the same needle as used in the HCP872 complete kit.
- On all of the float needles that use a retaining clip, please note that the clip can be installed in two different ways (oreientations). User experience seems to indicate that positioning the clip so that the "open" area of the clip (that part of the clip that snaps over ridge on the top of the needle) should be oriented towards the "back" of the carbs; in other words, the open area should be towards the airbox.
QUESTION: does it matter which style float seat/needle/etc. is used in your carbs?
ANSWER: Not really, although it's probably best (but not absolutely necessary) to make sure that all 4 carbs use the same style set-up. Also, while it states that the kits that have the same height needles "may not" require float level re-adjustment after installation, I wouldn't count on it. You should ALWAYS check and adjust your float levels anytime you go into your carbs----and periodically even if you don't! I know, it's a pain-in-the-tail light to adjust the float levels----but correct float levels really will help make sure that your bike performs at its best.
fs17) OEM Hitachi FLOAT NEEDLE VALVE ASSEMBLY---contains the float valve Needle with retainer clip, float valve needle brass screw-in Seat, and the metal seat Washer. The seat DOES include the filter screen, but this kit does NOT include the idle mixture screw block-off cap. NOTE: the float Needle that comes with this set is approximately the same height as the factory Yamaha needle, and it may not be necessary to re-adjust the float level height after installation.
For all XJ650 (except Turbo), all XJ750, and all XJ700 (except "X") models:
HCP10 OEM Hitachi Float Needle VALVE ASSMEBLY, single:
$ 64.00
HCP10SET4 OEM Hitachi Float Needle VALVE ASSMEBLIES, set of 4:
$ 239.00
fs3) Aftermarket Hitachi FLOAT VALVE NEEDLE ONLY (includes the retainer clip)...for those who wish to do an extreme-budget rebuild, you can buy the rubber-tipped float valve needle by itself (without its brass seat). Needle includes its hanger/retainer arm clip. NOTE: this Needle is approximately 1mm taller than a factory Yamaha needle, and will require that you re-adjust the float level height after installation. For use on all XJ650 (except Turbo) models, all XJ700 non-X models, and all XJ750 models.
HCP870 Aftermarket Hitachi float valve NEEDLE with clip, each:
$ 7.50
HCP870SET4 Aftermarket Hitachi float valve NEEDLES with clip, set of 4:
$ 28.00
jj) Aftermarket Hitachi FLOAT NEEDLE VALVE ASSEMBLY---contains the float valve Needle with retainer clip, float valve needle brass screw-in Seat, and the metal seat Washer. The seat DOES include the filter screen, but this kit does NOT include the idle mixture screw block-off cap. NOTE: the float Needle that comes with this set is approximately 1mm taller than a factory Yamaha needle, and will require that you re-adjust the float level height after installation.
HCP872 Aftermarket Hitachi FLOAT NEEDLE VALVE ASSEMBLY, single:
$ 11.00
HCP872SET4 Aftermarket Hitachi FLOAT NEEDLE VALVE ASSEMBLIES, set of 4:
$ 39.00
nn) Aftermarket Hitachi carbs LOWER END STANDARD REBUILD KIT---contains the float needle with retainer clip, float valve brass screw-in seat, a fiber seat washer, idle mixture screw block-off cap, and an aftermarket bowl gasket. The float needle seat does NOT include the filter screen. NOTE: the float Needle that comes with this set is approximately the same height as a factory Yamaha needle, and it may not be necessary to re-adjust the float level height after installation.
For all XJ650 (except Turbo), all XJ750, and all XJ700 non-X models:
HCP1 Aftermarket Hitachi carb LOWER END STANDARD REBUILD KIT, single:
$ 19.00
HCP1SET4 Aftermarket Hitachi carb LOWER END STANDARD REBUILD KITS, set of 4:
$ 69.00
fs2) Aftermarket Hitachi carb LOWER END DELUXE REBUILD KIT---contains the float needle with retainer clip, float valve brass screw-in seat, a metal seat washer, and a factory bowl gasket. The float needle seat DOES include the filter screen. NOTE: the float Needle that comes with this set is approximately 1mm taller than the factory Yamaha needle, and will require that you re-adjust the float level height after installation.
HCP2776 Aftermarket Hitachi carb LOWER END DELUXE REBUILD KIT, single:
$ 24.00
HCP2776SET4 Aftermarket Hitachi carb LOWER END DELUXE REBUILD KITS, set of 4:
$ 88.00
fs7) OEM Hitachi fuel bowl FLOAT HINGE PIN, brand new steel pin used with the HCP2 floats above. Fits all XJ650 (except Turbo) models, all XJ700 non-X models, and all XJ750 models.
HCP3 Hitachi carb FLOAT HINGE PIN, each:
$ 8.50
HCP3SET4 Hitachi carb FLOAT HINGE PINS, set of 4:
$ 29.00
NOTE: good used floats, float pins, and float bowls and mounting hardware are also available, please inquire.
HITACHI VACUUM DIAPHRAM AND PISTON ASSEMBLY:
fs5) OEM Hitachi HSC32 series carbs VACUUM DIAPHRAM AND PISTON ASSEMBLY, the slide piston with the non-detachable rubber vacuum diaphram seal. Although it is possible to repair TINY pin-holes that occur in original diaphrams, anything greater than that will require replacement, as these diaphram are under a lot of pressure and stress and the continued flexing of the rubber will eventually lead to failure. Fits all XJ650 (except Turbo) models, and all XJ750 models.
HCP69 OEM Hitachi carb VACUUM DIAPHRAM AND PISTON ASSEMBLY[b], brand new, each:
$ 244.95
HCP69SET4 OEM Hitachi carb [b]VACUUM DIAPHRAM AND PISTON ASSEMBLIES, set of 4:
$ 929.95
bb3) HCP8540 Aftermarket carb diaphram rubber RnR FLUID. Dissolved and chlorinated paraffin wax is the best (and perhaps the only) way to safely bring some life back into stiff, worn rubber material... such as that found in those all-important carb piston diaphrams. Years of hard life inside of your carb take their toll, and whenever your carb is apart for service, and generous application of this product will help to clean, maintain, and restore the flexibility, while prolonging their usable service life. 10cc dripper bottle contains enough fluid to do about eight diaphrams. Simple to use, spread on, wait a few seconds, wipe off, repeat and you're done!
$ 9.95
HITACHI CARB HATS:
Hitachi Carb Hats:
Reproduction Hitachi CARB DIAPHRAM COVERS, commonly called carb "hats", are the bright polished upper covers with the "sloped dome" shape. Brand new stampings perfectly replace rusted and pitted originals, add a final "crowning" touch to your carb restoration project. All hats will fit all Hitachi HSC32 or HSC33 series carbs as used on the XJ-series bikes.
HCP9162 Aftermarket Hitachi POLISHED SILVER CHROME CARB HAT, mirror finish as used on all fours carbs on all XJ650 Maxim models, XJ650RJ Seca models, and all XJ750 Maxim and Seca models. Also used on the outboard carbs (#1 and #4) on all XJ700 non-X (air-cooled) models. Each:
$ 29.95
HCP9162SET2 Aftermarket Hitachi POLISHED SILVER CHROME CARB HATS, set of 2:
$ 49.95
HCP9162SET4 Aftermarket Hitachi POLISHED SILVER CHROME CARB HATS, set of 4:
$ 89.95
HCP9163 Aftermarket Hitachi POLISHED GOLDEN CHROME CARB HAT, golden mirror finish as used on all fours carbs on all XJ650 Midnight Maxim and XJ750 Midnight Maxim models. Each:
$ 39.95
HCP9163SET2 Aftermarket Hitachi POLISHED GOLDEN CHROME CARB HATS, set of 2:
$ 59.95
HCP9163SET4 Aftermarket Hitachi POLISHED GOLDEN CHROME CARB HATS, set of 4:
$ 99.95
HCP9164 Aftermarket Hitachi NATURAL ZINC-CAD PLATED CARB HAT, dull silver finish as used on the inner carbs only (#2 and #3) on all XJ700 non-X (air-cooled) models. Each:
$ 27.95
HCP9164SET2 Aftermarket Hitachi NATURAL ZINC-CAD PLATED CARB HAT, set of 2:
$ 47.95
info @ xj4ever.com
_________________ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
chacal Supporting Vendor
Joined: Aug 01, 2006 Posts: 4845 Location: At My Computer
Posted: Mon Dec 15, 2008 1:41 am Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION C:
--Hitachi Parts Continued
HITACHI FUEL SYSTEM HARDWARE:
A variety of different style fasteners and finishes are available, ranging from original OEM grade and finish to stainless steel, polished, or black-oxide coated fasteners. This is the easiest way to replace your missing or damaged original hardware or to upgrade the appearance or durability of your hardware! Many different styles are available for most fasteners, so review your choices carefully.
HITACHI CARB BOWL HARDWARE:
fff) OEM Hitachi carb BOWL-TO-BODY MOUNTING SCREW, stock. Does not come with the lock washer, which has to be ordered below separately. NOTE: original screws had integral captured lock washers, the replacement ones do not. These replacement phillips-head screws have a black-oxide finish, as opposed to the natural finish used originally. Use with the HCP59 lock washers listed below.
HCP2940 OEM Hitachi carb bowl-to-body black oxide MOUNTING SCREW, each:
$ 1.50
HCP2940SET4 OEM Hitachi carb bowl-to-body black oxide MOUNTING SCREWS, set of 4:
$ 5.00
HCP2940SET16 OEM Hitachi carb bowl-to-body black oxide MOUNTING SCREWS, set of 16:
$ 18.00
m5) Aftermarket Hitachi carb BOWL-TO-BODY MOUNTING SCREW, stock style. Does not come with the lock washer, which has to be ordered below separately. NOTE: original screws had integral captured lock washers, the replacement ones do not.
Replacement screws come in a variety of different finish and head drive styles, so please review the descriptions below carefully!
These replacement phillips-head screws have a natural finish as used originally. Use with the HCP913 lock washers listed further below:
HCP2643 aftermarket carb bowl-to-body natural finish MOUNTING SCREW, each:
$ 0.75
HCP2643SET4 aftermarket Hitachi carb bowl-to-body natural finish MOUNTING SCREWS, set of 4:
$ 2.50
HCP2643SET16 aftermarket Hitachi carb bowl-to-body natural MOUNTING SCREWS, set of 16:
$ 9.00
These replacement phillips-head screws have a polished finish and are made from 18-8 stainless steel. Use with the HCP57 lock washers listed further below:
HCP302 aftermarket carb bowl-to-body 18-8 stainless steel MOUNTING SCREW, phillips-head, each:
$ 1.00
HCP302SET4 aftermarket Hitachi carb bowl-to-body 18-8 stainless steel MOUNTING SCREWS, phillips head, set of 4:
$ 3.50
HCP302SET16 aftermarket Hitachi carb bowl-to-body 18-8 stainless steel MOUNTING SCREWS, phillips head, set of 16:
$ 12.00
These replacement button-head screws have a polished finish, and are made from an18-8 polished stainless steel. Use with the HCP57 lock washers listed further below:
HCP303 Replacement Hitachi carb bowl-to-body stainless button-head MOUNTING SCREW, each:
$ 1.50
HCP303SET4 Replacement Hitachi carb bowl-to-body stainless button-head MOUNTING SCREWS, set of 4:
$ 5.00
HCP303SET16 Replacement Hitachi carb bowl-to-body stainless button-head MOUNTING SCREWS, set of 16:
$ 16.00
These replacement allen-head screws have a polished finish, as and are made from an18-8 polished stainless steel. Use with the HCP57 lock washers listed further below:
HCP56 Replacement Hitachi carb bowl-to-body stainless allen-head MOUNTING SCREW, each:
$ 1.50
HCP56SET4 Replacement Hitachi carb bowl-to-body stainless allen-head MOUNTING SCREWS, set of 4:
$ 4.50
HCP56SET16 Replacement Hitachi carb bowl-to-body stainless allen-head MOUNTING SCREWS, set of 16:
$ 15.00
These replacement allen-head screws have a black-oxide finish, and are made from alloy steel material. Use with the HCP59 lock washers listed further below:
HCP58 Replacement Hitachi carb bowl-to-body black allen-head MOUNTING SCREW, each:
$ 1.00
HCP58SET4 Replacement Hitachi carb bowl-to-body black allen-head MOUNTING SCREWS, set of 4:
$ 3.50
HCP58SET16 Replacement Hitachi carb bowl-to-body black allen-head MOUNTING SCREWS, set of 16:
$ 12.00
These replacement phillips-head screws have a golden chromate finish, as opposed to the natural finish used originally, and come with the intergral captured lockwasher as original:
HCP1358 Replacement Hitachi carb bowl-to-body gold chromate MOUNTING SCREW with lockwasher, each:
$ 1.00
HCP1358SET4 Replacement Hitachi carb bowl-to-body gold chromate MOUNTING SCREWS with lockwasher, set of 4:
$ 3.50
HCP1358SET16 Replacement Hitachi carb bowl-to-body gold chromate MOUNTING SCREWS with lockwasher, set of 16:
$ 13.00
ggg) Replacement Hitachi carb Bowl-to-Body Mounting Screw LOCK WASHERS, available in a variety of finishes to match the above screws,
These replacement lock washers have a black-oxide finish. Use with the HCP2940 or the HCP58 screws listed above:
HCP59 Replacement Hitachi carb bowl-to-body black oxide LOCK WASHER, each:
$ 1.00
HCP59SET4 Replacement Hitachi carb bowl-to-body black oxide LOCK WASHERS, set of 4:
$ 3.00
HCP59SET16 Replacement Hitachi carb bowl-to-body black oxide LOCK WASHERS, set of 16:
$ 9.00
These replacement lock washers have a natural finish as used originally. Use with the HCP2643 screws listed above:
HCP913 Replacement Hitachi carb bowl-to-body natural finish LOCK WASHER, each:
$ .20
HCP913SET4 Replacement Hitachi carb bowl-to-body natural finish LOCK WASHERS, set of 4:
$ .75
HCP913SET16 Replacement Hitachi carb bowl-to-body natural finish LOCK WASHERS, set of 16:
$ 2.50
These replacement lock washers are made from an 18-8 stainless steel material for durability. Use with the HCP56, HCP302, or HCP303 screws listed above:
HCP57 Replacement Hitachi carb bowl-to-body stainless LOCK WASHER, each:
$ 1.00
HCP57SET4 Replacement Hitachi carb bowl-to-body stainless LOCK WASHERS, set of 4:
$ 3.00
HCP57SET16 Replacement Hitachi carb bowl-to-body stainless LOCK WASHERS, set of 16:
$ 9.00
HITACHI CARB BOWL DRAIN SCREW:
e5) OEM Hitachi carb BOWL DRAIN SCREW. Cad-plated alloy steel phillips head, taper-point screw fits into the drain hole passage of each carb bowl. Made by the original Yamaha supplier.
HCP864 OEM phillips-head cad-plated alloy-steel carb BOWL DRAIN SCREW, each:
$ 14.00
HCP864SET4 OEM phillips-head alloy-steel carb BOWL DRAIN SCREWS, set of 4:
$ 49.00
e6) Aftermarket Hitachi carb BOWL DRAIN SCREW. Natural finish alloy steel phillips head, taper-point screw fits into the drain hole passage of each carb bowl. Just like the original Yamaha screw but without the bright cad plating.
HCP3113 Aftermarket phillips-head alloy-steel carb BOWL DRAIN SCREW, each:
$ 4.50
HCP3113SET4 Aftermarket phillips-head alloy-steel carb BOWL DRAIN SCREW, set of 4:
$ 17.00
f5) Aftermarket Hitachi carb BOWL DRAIN SCREW. Bright finish 18-8 stainless steel phillips head, taper-point screw fits into the drain hole passage of each carb bowl. Just like the original Yamaha screw but made of stainless steel.
HCP3112 Aftermarket phillips-head stainless-steel carb BOWL DRAIN SCREW, each:
$ 5.00
HCP3112SET4 Aftermarket phillips-head stainless-steel carb BOWL DRAIN SCREWS, set of 4:
$ 18.00
g5) Aftermarket Hitachi carb BOWL DRAIN SCREW. Bright finish 18-8 stainless steel allen head (hex-drive socket head), taper-point screw fits into the drain hole passage of each carb bowl. Works better than the original Yamaha screw; not only is it made of stainless steel, but the larger allen-head design allows for more torque to be applied to the screw, forever ending the stripped/stuck/ruined drain screw problem that has plagued Yamaha owners forever! Note that by their design, the large allen head portion of this drain screw will be located OUTSIDE of the drain screw bore hole in the bowl, and sticks out about 1/4" from the bowl body. This additional length does not cause any problems, and after looking at them (installed) on the carb bowls, at first glance they might look "odd" the way the stick out, but after the third or fourth look, they appear normal and oddly interesting with that extended length.
NOTE: do NOT "bottom" the heads of these screws against the bowl! Tighten them to 4-5 foot-pounds of torque, just enough to seat them snugly.
Fits all XJ650 (except Turbo) models, all XJ700 non-X, and all XJ750 models using the Hitachi HSC-32 or -33 series factory carbs.
It is recommended that anti-seize compound be used on the screw threads when fitting them into the carb bowl passage.
HCP54 Aftermarket Hitachi allen-head stainless-steel carb BOWL DRAIN SCREW, each:
$ 5.00
HCP54SET4 Aftermarket Hitachi allen-head stainless-steel carb BOWL DRAIN SCREWS, set of 4:
$ 17.95
HITACHI CARB HAT HARDWARE:
h5) Hitachi carb diaphram cover (chrome "dome" or "Hat") MOUNTING SCREW, available in both short and long versions, and in a variety of original and aftermarket styles and finishes.
The short screws are used in any position that does not have a clip or bracket associated with it. You will need to use a total of 10 of these short screws per complete carb rack.
The long screws are used in any position that has a clip or bracket associated with it. You will need to use a total of 6 of these long screws per complete carb rack.
NOTE: originally, all carb hat screws were a natural finish, panhead style, phillips-drive with a captive lock washer. Current OEM screws and all aftermarket screws do NOT have an integral lock washer and the lock washer must be ordered separately from the choices listed further below.
- These replacement panhead phillips-drive screws have a natural finish and are made from alloy steel. Use with the HCP326 or HCP922 lock washers listed further below:
HCP322 OEM alloy-steel natural finish, panhead phillips-drive carb hat short MOUNTING SCREW, each:
$ 1.25
HCP322SET10 OEM alloy-steel natural finish, panhead phillips-drive carb hat short MOUNTING SCREWS, set of 10:
$ 10.00
HCP323 OEM alloy-steel natural finish, panhead phillips-drive carb hat long MOUNTING SCREW, each:
$ 1.25
HCP323SET6 OEM alloy-steel natural finish, panhead phillips-drive carb hat long MOUNTING SCREWS, set of 6:
$ 7.00
HCP918 Aftermarket alloy-steel natural finish, panhead phillips-drive carb hat short MOUNTING SCREW, each:
$ 1.00
HCP918SET10 Aftermarket alloy-steel natural finish, panhead phillips-drive carb hat short MOUNTING SCREWS, set of 10:
$ 6.00
HCP919 Aftermarket alloy-steel natural finish, panhead phillips-drive carb hat long MOUNTING SCREW, each:
$ 1.00
HCP919SET6 Aftermarket alloy-steel natural finish, panhead phillips-drive carb hat long MOUNTING SCREWS, set of 6:
$ 4.00
- These replacement phillips-head screws have a polished finish and are made from an 18-8 stainless steel. Use with the HCP336 lock washers listed further below:
HCP1355 Aftermarket 18-8 stainless-steel polished finish, phillips-head carb hat short MOUNTING SCREW, each:
$ 1.20
HCP1355SET10 Aftermarket 18-8 stainless-steel polished, phillips-head finish carb hat short MOUNTING SCREWS, set of 10:
$ 8.00
HCP2641 Aftermarket 18-8 stainless-steel polished finish, panhead phillips-drive carb hat long MOUNTING SCREW, each:
$ 1.20
HCP2641SET6 Aftermarket 18-8 stainless-steel polished finish, panhead phillips-drive carb hat long MOUNTING SCREWS, set of 6:
$ 5.00
- These replacement button-head, hex-drive screws have a polished finish and are made from an 18-8 stainless steel. Use with the HCP336 lock washers listed further below:
HCP332 Aftermarket 18-8 stainless-steel polished finish, button head hex-drive carb hat short MOUNTING SCREW, each:
$ 1.40
HCP322SET10 Aftermarket 18-8 stainless-steel polished finish, button head hex-drive carb hat short MOUNTING SCREWS, set of 10:
$ 10.00
HCP333 Aftermarket 18-8 stainless-steel polished finish, button head hex-drive carb hat long MOUNTING SCREW, each:
$ 1.40
HCP333SET6 Aftermarket 18-8 stainless-steel polished finish, button head hex-drive carb hat long MOUNTING SCREWS, set of 6:
$ 7.00
- These replacement allen-head, hex-drive screws have a polished finish and are made from an 18-8 stainless steel. Use with the HCP336 lock washers listed further below:
HCP329 Aftermarket 18-8 stainless steel polished finish, allen head hex-drive carb hat short MOUNTING SCREW, each:
$ 1.40
HCP329SET10 Aftermarket 18-8 stainless steel polished finish, allen head hex-drive carb hat short MOUNTING SCREWS, set of 10:
$ 10.00
HCP330 Aftermarket 18-8 stainless steel polished finish, allen head hex-drive carb hat long MOUNTING SCREW, each:
$ 1.40
HCP330SET6 Aftermarket 18-8 stainless steel polished finish, allen head hex-drive carb hat long MOUNTING SCREWS, set of 6:
$ 6.00
- These replacement allen-head, hex-drive screws have a black oxide-coated finish and are made from alloy steel. Use with the HCP342 lock washers listed further below:
HCP339 Aftermarket black oxide-coated steel finish, allen head hex-drive carb hat short MOUNTING SCREW, each:
$ 1.20
HCP339SET10 Aftermarket black oxide-coated steel finish, allen head hex-drive carb hat short MOUNTING SCREWS, set of 10:
$ 9.00
HCP340 Aftermarket black oxide-coated steel finish, allen head hex-drive carb hat long MOUNTING SCREW, each:
$ 1.20
HCP340SET6 Aftermarket black oxide-coated steel finish, allen head hex-drive carb hat long MOUNTING SCREWS, set of 6:
$ 6.00
k5) Hitachi carb diaphram cover mounting screw LOCK WASHER.....uses 16 per carb rack. NOTE: originally, these washers were integral to the mounting screws and featured a natural finish. Current OEM screws and all aftermarket screws do NOT have an integral lock washer and thus the lock washers must be ordered separately from the choices listed below. These lock washers will fit either the short or the long hat mounting screws listed above.
HCP326 OEM alloy-steel, natural finish carb hat mounting screw LOCK WASHER, each:
$ 0.75
HCP326SET4 OEM alloy-steel, natural finish carb hat mounting screw LOCK WASHERS, set of 4:
$ 2.50
HCP326SET16 OEM alloy-steel, natural finish carb hat mounting screw LOCK WASHERS, set of 16:
$ 9.00
HCP922 Aftermarket alloy-steel, natural finish carb hat mounting screw LOCK WASHER, each:
$ 0.50
HCP922SET4 Aftermarket alloy-steel natural finish carb hat mounting screw LOCK WASHERS, set of 4:
$ 1.50
HCP922SET16 Aftermarket alloy-steel natural finish carb hat mounting screw LOCK WASHERS, set of 16:
$ 4.00
HCP336 Aftermarket 18-8 stainless-steel polished finish carb hat mounting screw LOCK WASHER, each:
$ 0.60
HCP336SET4 Aftermarket 18-8 stainless-steel polished finish carb hat mounting screw LOCK WASHERS, set of 4:
$ 2.00
HCP336SET16 Aftermarket 18-8 stainless-steel polished finish carb hat mounting screw LOCK WASHERS, set of 16:
$ 5.00
HCP342 Aftermarket black oxide-coated steel finish carb hat mounting screw LOCK WASHER, each:
$ 0.50
HCP342SET4 Aftermarket black oxide-coated steel finish carb hat mounting screw LOCK WASHERS, set of 4:
$ 1.50
HCP342SET16 Aftermarket black oxide-coated steel finish carb hat mounting screw LOCK WASHERS, set of 16:
$ 4.00
k5) Hitachi carb diaphram cover mounting screw FLAT WASHER.....use 1 per carb rack, on the #2 carb rear position where the vacuum line clip attaches (this position uses both a lock washer and a flat washer). NOTE: originally featured a natural finish.
HCP328 OEM alloy-steel natural finish carb hat mounting screw FLAT WASHER, each:
$ 0.75
HCP924 Aftermarket alloy-steel natural finish carb hat mounting screw FLAT WASHER, each:
$ 0.15
HCP338 Aftermarket 18-8 stainless-steel polished finish carb hat mounting screw FLAT WASHER, each:
$ 0.20
HCP1356 Aftermarket black oxide-coated steel finish carb hat mounting screw FLAT WASHER, each:
$ 1.50
HITACHI CARB STARTER-ENRICHMENT CIRCUIT-CHOKE SYSTEM HARDWARE:
xx4) Aftermarket Hitachi Starter-Enrichment Circuit Arm-to-Shaft SET SCREW. These replacement screws are used to retain the starter lever "finger" bracket to the starter circuit shaft. Use 4 of these screws per rack. NOTE: originally, these screws had a natural finish, with a straight slot (flat) head style drive. All aftermarket screws feature an allen-head drive and are slightly longer (about 1mm) than the original set screws, but that additional length causes no interference problems.
HCP299 Aftermarket Hitachi enrichment circuit lever arm-to-shaft SET SCREW, allen-head, black oxide coated alloy steel, each:
$ 1.00
HCP299SET4 Aftermarket Hitachi enrichment circuit lever arm-to-shaft SET SCREWS, allen-head, black oxide coated alloy steel, set of 4:
$ 2.50
HCP300 Aftermarket Hitachi enrichment circuit lever arm-to-shaft SET SCREW, allen-head, 18-8 stainless steel, each:
$ 1.25
HCP300SET4 Aftermarket Hitachi enrichment circuit lever arm-to-shaft SET SCREWS, allen-head, 18-8 stainless steel, set of 4:
$ 4.00
xx5) Hitachi Starter-Enrichment SHAFT RETAINING SCREW, used to retain the starter shaft bracket to the starter circuit shaft. Use 1 of these screws per rack. NOTE: originally, these screws had a natural finish, with a phillips-head drive system, and a captive lock washer. All OEM and aftermarket screws do not come with the captive lock washer, and a lock washer needs to be ordered separate.
HCP292 OEM Hitachi enrichment circuit SHAFT RETAINING SCREW, panhead phillips-drive, black oxide coated alloy steel, each. Use with the HCP296 or HCP298 lock washer listed further below.
$ 1.50
HCP898 Aftermarket Hitachi enrichment circuit SHAFT RETAINING SCREW, panhead phillips-drive, bright zinc-plated alloy steel, each. Use with the HCP297 lock washer listed further below.
$ 1.00
HCP293 Aftermarket Hitachi enrichment circuit SHAFT RETAINING SCREW, panhead phillips-drive, 18-8 stainless steel, each. Use with the HCP297 lock washer listed further below.
$ 1.80
HCP294 Aftermarket Hitachi enrichment circuit SHAFT RETAINING SCREW, allen-head, 18-8 stainless steel, each. Use with the HCP297 lock washer listed further below.
$ 1.00
HCP295 Aftermarket Hitachi enrichment circuit SHAFT RETAINING SCREW, allen-head, black oxide coated alloy steel, each. Use with the HCP298 lock washer listed further below.
$ 1.00
xx6) Hitachi enrichment shaft retainer screw LOCK WASHER, use with the above retainer screws. Use 1 of these washers per rack. NOTE: originally, the retainer screw came with a captive lock washer; all OEM and aftermarket screws do not come with the captive lock washer, and a lock washer needs to be ordered separate.
HCP296 OEM Hitachi enrichment shaft retainer screw LOCK WASHER, black oxide coated alloy steel, each. Use with the HCP292 retaining screw listed
above.
$ 1.50
HCP297 Aftermarket Hitachi enrichment shaft retainer screw LOCK WASHER, 18-8 stainless steel, each. Use with the HCP293, HCP898, or HCP294 retaining screw listed above.
$ .50
HCP298 Aftermarket Hitachi enrichment shaft retainer screw LOCK WASHER, 18-8 stainless steel, each. Use with the HCP292 or HCP295 retaining screw listed above.
$ .50
HCP25 OEM Hitachi Starter Enrichment Circuit brass jet needle PLUNGER SPRING. Each.
$ 6.00
HITACHI CARB UPPER RACK MOUNTING BRACKET HARDWARE:
a7) Aftermarket Hitachi carb upper rack bracket MOUNTING SCREWS, available in both the short and long versions, and in a variety of original and aftermarket styles and finishes.
The short screws are used in every position EXCEPT the #6 screw hole which also holds the clutch cable routing clip. Use 7 of these screws per rack to mount the carbs.
The long screw is used in the #6 position that has the clutch cable routing clip or bracket associated with it. You will need to use 1 of these long screws per complete carb rack.
NOTE: originally, these screws were a natural finish, panhead phillips-drive style with a captive lock washer. Current OEM screws and all aftermarket screws do NOT have an integral lock washer and the lock washer must be ordered separately from the choices listed further below.
ALSO, these screws were originally installed (and should be re-installed) with a low-strength thread locking fluid applied. Therefore, these screws may be VERY difficult to remove and it is highly recommended that you obtain the correct size JIS style screwdriver (or an impact driver) to remove them without stripping the slots.
- These replacement panhead phillips-drive screws have a natural finish and are made from alloy steel. Use with the HCP913 lock washers listed further below:
HCP60 OEM Hitachi carb upper rack bracket short MOUNTING SCREW, alloy steel, natural finish, panhead phillips-drive. Use with the HCP913 lock washers listed below. Each.
$ 1.00
HCP60SET7 OEM Hitachi carb upper rack bracket short MOUNTING SCREWS. Use with the HCP913 lock washers listed below. Set of 7.
$ 6.00
HCP304 OEM Hitachi carb upper rack bracket long MOUNTING SCREW, alloy steel with a natural finish and phillips head. Use the HCP913 lock washers and HCP914 flat washer listed below. Each.
$ 2.00
HCP4561 OEM Hitachi carb upper rack bracket long MOUNTING SCREW, black oxide-coated steel with a phillips head. For used on XJ650 Midnight Maxima nd XJ750 Midnight Maxim models only. Use the HCP59 lock washers and HCP65 flat washer listed below. Each.
$ 2.00
HCP910 Aftermarket Hitachi carb upper rack bracket short MOUNTING SCREW, alloy steel, natural finish, panhead phillips-drive. Use with the HCP913 lock washers listed below. Each.
$ 1.00
HCP910SET7 Aftermarket Hitachi carb upper rack bracket short MOUNTING SCREWS. Use with the HCP913 lock washers listed below. Set of 7.
$ 4.00
HCP911 Aftermarket Hitachi carb upper rack bracket long MOUNTING SCREW, alloy steel, natural finish, panhead phillips-drive. Use the HCP913 lock washers and HCP914 flat washer listed below. Each.
$ 1.00
- These replacement panhead phillips-drive screws have a polished finish and are made from 18-8 stainless steel. Use with the HCP57 lock washers listed further below:
HCP62 Aftermarket Hitachi carb upper rack bracket short MOUNTING SCREW, 18-8 stainless steel panhead phillips-drive. Use with the HCP57 lock washers listed below. Each.
$ 1.25
HCP62SET7 Aftermarket Hitachi carb upper rack bracket short MOUNTING SCREWS. Use with the HCP57 lock washers listed below. Set of 7.
$ 6.00
HCP307 Aftermarket Hitachi carb upper rack bracket long MOUNTING SCREW, 18-8 stainless steel panhead phillips-drive. Use the HCP57 lock washers and HCP1353 flat washer listed below. Each.
$ 1.25
- These replacement button head hex-drive screws have a polished finish and are made from 18-8 stainless steel. Use with the HCP57 lock washers listed further below:
HCP308 Aftermarket Hitachi carb upper rack bracket short MOUNTING SCREW, 18-8 stainless steel with a button head and hex-drive. Use with the HCP57 lock washers listed below. Each.
$ 1.25
HCP308SET7 Aftermarket Hitachi carb upper rack bracket short MOUNTING SCREWS. Use with the HCP57 lock washers listed below. Set of 7.
$ 6.00
HCP309 Aftermarket Hitachi carb upper rack bracket long MOUNTING SCREW, 18-8 stainless steel with a button head and hex-drive. Use the HCP57 lock washers and HCP1353 flat washer listed below. Each.
$ 1.00
- These replacement allen head hex-drive screws have a polished finish and are made from 18-8 stainless steel. Use with the HCP57 lock washers listed further below:
HCP310 Aftermarket Hitachi carb upper rack bracket short MOUNTING SCREW, 18-8 stainless steel with an allen head and hex-drive. Use with the HCP57 lock washers listed below. Each.
$ 1.25
HCP310SET7 Aftermarket Hitachi carb upper rack bracket short MOUNTING SCREWS. Use with the HCP57 lock washers listed below. Set of 7.
$ 6.00
HCP311 Aftermarket Hitachi carb upper rack bracket long MOUNTING SCREW, 18-8 stainless steel with an allen head and hex-drive. Use the HCP57 lock washers and HCP1353 flat washer listed below. Each.
$ 1.00
- These replacement allen head hex-drive screws have a black oxide-coated finish and are made from alloy steel. Use with the HCP59 lock washers listed further below:
HCP64 Aftermarket Hitachi carb upper rack bracket short MOUNTING SCREW, black-oxide coated alloy steel, allen head with a hex drive. Use with the HCP59 lock washers listed below. Each.
$ 1.00
HCP64SET7 Aftermarket Hitachi carb upper rack bracket short MOUNTING SCREWS. Use with the HCP59 lock washers listed below. Set of 7.
$ 4.00
HCP312 Aftermarket Hitachi carb upper rack bracket long MOUNTING SCREW, black-oxide coated alloy steel with an allen head and hex-drive. Use the HCP59 lock washers and HCP65 flat washer listed below. Each.
$ 1.00
c7) Aftermarket Hitachi carb upper rack bracket mounting screw LOCK WASHER. These replacement lock washers are used in all 8 positions. Use 8 of these lock washers per rack. NOTE: originally, these washers were a natural finish. Current OEM screws and all aftermarket screws do NOT have an integral lock washer and the lock washer must be ordered separately from the choices listed below.
HCP913 Aftermarket Hitachi carb upper rack bracket mounting screw LOCK WASHER, alloy steel with a natural finish. Use with the HCP60, HCP304, HCP910, and HCP911 screws listed above. Each.
$ 1.00
HCP913SET8 Aftermarket Hitachi carb upper rack bracket mounting screw LOCK WASHERS, alloy steel with a natural finish. Use with the HCP60, HCP304, HCP910, and HCP911 screws listed above. Set of 8.
$ 3.00
HCP57 Aftermarket Hitachi carb upper rack bracket mounting screw LOCK WASHER, 18-8 stainless steel. Use with the HCP62, HCP 307, HCP308, HCP309, HCP310, and HCP311 screws listed above. Each.
$ 1.00
HCP57SET8 Aftermarket Hitachi carb upper rack bracket mounting screw LOCK WASHERS, 18-8 stainless steel. Use with the HCP60, HCP304, HCP910, and HCP911 screws listed above. Set of 8.
$ 4.00
HCP59 Aftermarket Hitachi carb upper rack bracket mounting screw LOCK WASHER, black oxide coated alloy steel. Use with the HCP64 and HCP312 screws listed above. Each.
$ 1.50
HCP59SET8 Aftermarket Hitachi carb upper rack bracket mounting screw LOCK WASHERS, black-oxide coated alloy steel. Use with the HCP64 and HCP312 screws listed above. Set of 8.
$ 9.00
d7) Aftermarket Hitachi carb upper rack bracket mounting screw FLAT WASHER. These replacement flat washers are used in only the #6 screw hole which also holds the clutch cable routing clip. Use 1 of these screws per rack. NOTE: originally, these washers were a natural finish.
HCP914 Aftermarket Hitachi carb upper rack bracket mounting screw FLAT WASHER, alloy steel with a natural finish. Use with the HCP304 or HCP911 screws listed above. Each.
$ 1.00
HCP1353 Aftermarket Hitachi carb upper rack bracket mounting screw FLAT WASHER, 18-8 stainless steel. Use with the HCP307, HCP309, or HCP311 screws listed above. Each.
$ 1.00
HCP65 Aftermarket Hitachi carb upper rack bracket mounting screw FLAT WASHER, black oxide coated alloy steel. Use with the HCP312 screw listed above. Each.
$ 1.00
HITACHI CARB LOWER RACK MOUNTING BRACKET HARDWARE:
e7) Aftermarket Hitachi carb lower rack bracket MOUNTING SCREW. These replacement screws are used in every position of the lower rack bar to mount the carbs. Use 8 of these screws per rack.
- These replacement panhead phillips-drive screws have a natural finish and are made from alloy steel. Use with the HCP916 lock washers listed further below:
HCP314 OEM Hitachi carb lower rack bracket MOUNTING SCREW, alloy steel with a natural finish, panhead phillips-drive. Use the HCP916 lock washers listed below. Each.
$ 1.50
HCP314SET8 OEM Hitachi carb lower rack bracket MOUNTING SCREWS, alloy steel with a natural finish, panhead phillips-drive. Use the HCP916 lock washers listed below. Set of 8.
$ 9.00
HCP915 Aftermarket Hitachi carb lower rack bracket MOUNTING SCREW, panhead, alloy steel, phillips drive with a natural finish. Use the HCP916 lock washers listed below. Each.
$ 1.00
HCP915SET8 Aftermarket Hitachi carb lower rack bracket MOUNTING SCREWS, panhead, alloy steel, phillips drive with a natural finish. Use the HCP916 lock washers listed below. Set of 8.
$ 3.00
- These replacement panhead phillips-drive screws have a polished finish and are made from 18-8 stainless steel. Use with the HCP319 lock washers listed further below:
HCP316 Aftermarket Hitachi carb lower rack bracket MOUNTING SCREW, 18-8 stainless steel, panhead phillips-drive. Use the HCP319 lock washers listed below. Each.
$ 1.00
HCP316SET8 Aftermarket Hitachi carb lower rack bracket MOUNTING SCREWS, 18-8 stainless steel, panhead phillips-drive. Use the HCP319 lock washers listed below. Set of 8.
$ 6.00
- These replacement button head hex-drive screws have a polished finish and are made from 18-8 stainless steel. Use with the HCP319 lock washers listed further below:
HCP317 Aftermarket Hitachi carb lower rack bracket MOUNTING SCREW, 18-8 stainless steel with a button head and hex-drive. Use the HCP319 lock washers listed below. Each.
$ 1.25
HCP317SET8 Aftermarket Hitachi carb lower rack bracket MOUNTING SCREWS, 18-8 stainless steel with a button head and hex-drive. Use the HCP319 lock washers listed below. Set of 8.
$ 7.00
- These replacement allen head hex-drive screws have a polished finish and are made from 18-8 stainless steel. Use with the HCP319 lock washers listed further below:
HCP318 Aftermarket Hitachi carb lower rack bracket MOUNTING SCREW, 18-8 stainless steel with an allen head and hex-drive. Use the HCP319 lock washers listed below. Each.
$ 1.25
HCP318SET8 Aftermarket Hitachi carb lower rack bracket MOUNTING SCREWS, 18-8 stainless steel with an allen head and hex-drive. Use the HCP319 lock washers listed below. Set of 8.
$ 7.00
- These replacement allen head hex-drive screws have a black oxide-coated finish and are made from alloy steel. Use with the HCP321 lock washers listed further below:
HCP320 Aftermarket Hitachi carb lower rack bracket MOUNTING SCREW, black-oxide coated alloy steel with an allen head and hex-drive. Use the HCP321 lock washers listed below. Each.
$ 1.00
HCP320SET8 Aftermarket Hitachi carb lower rack bracket MOUNTING SCREWS, black-oxide coated alloy steel with an allen head and hex-drive. Use the HCP321 lock washers listed below. Set of 8.
$ 3.00
e7a) Aftermarket Hitachi carb lower rack bracket mounting screw LOCK WASHER. These replacement lock washers are used in all 8 positions. Use 8 of these lock washers per rack. NOTE: originally, these washers were a natural finish. Current OEM screws and all aftermarket screws do NOT have an integral lock washer and the lock washer must be ordered separately from the choices listed below.
HCP916 Aftermarket Hitachi carb lower rack bracket mounting screw LOCK WASHER,alloy steel with a natural finish. Use with the HCP314 and HCP915 screws listed above. Each.
$ 1.00
HCP916SET8 Aftermarket Hitachi carb lower rack bracket mounting screw LOCK WASHERS,alloy steel with a natural finish. Use with the HCP314 and HCP915 screws listed above. Set of 8.
$ 3.00
HCP319 Aftermarket Hitachi carb lower rack bracket mounting screw LOCK WASHER,18-8 stainless steel. Use with the HCP316, HCP317, and HCP318 screws listed above. Each.
$ 1.00
HCP319SET8 Aftermarket Hitachi carb lower rack bracket mounting screw LOCK WASHERS,18-8 stainless steel. Use with the HCP316, HCP317, and HCP318 screws listed above. Set of 8.
$ 4.00
HCP321 Aftermarket Hitachi carb lower rack bracket mounting screw LOCK WASHER,black oxide coated alloy steel. Use with the HCP320 screws listed above. Each.
$ 1.50
HCP321SET8 Aftermarket Hitachi carb lower rack bracket mounting screw LOCK WASHERS, black-oxide coated alloy steel. Use with the HCP320 screws listed above. Set of 8.
$ 9.00
NOTE: good used carb mounting hardware, brackets, clips, etc. are also available, please inquire.
FREE STANDARD SHIPPING {OR JUST $5.00 FOR PRIORITY MAIL} SHIPPING IN THE USA FOR ALL ORDERS OVER $100 !!!!
$7.50 STANDARD SHIPPING TO CANADA FOR ALL ORDERS OVER $100 !!!!
Paypal accepted. Worldwide shipping available. Shipping prices and insurance costs are NOT included in the prices of items unless specifically listed. Please write with your list of parts needs and I will be glad to quote your shipping costs to you.
You can either PM (Private Message) me through this website, e-mail us via the "email" button on the bottom of this post, or e-mail us directly at:
info @ xj4ever.com
PLEASE NOTE!: our e-mail address does NOT have spaces before or after the "@" symbol........the posting system on this website automatically adds blank spaces before and after that symbol as an anti-spam feature! Make sure you eliminate those blank spaces when sending us an e-mail! Our e-mail address does NOT have any blank spaces in it!!
PLEASE!: on each and every correspondence with us, please tell us what YEAR and MODEL bike you have (example: 1982 XJ650 Maxim) and what your NAME (first name, at least!) is......that information really makes life a bit easier for us, and insures a more timely and ACCURATE response from us back to you!
MORE XJ PARTS IN THE FOLLOWING POST!!
Posted: Mon Dec 15, 2008 2:06 am Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION C:
FUEL SYSTEM ITEMS: Including Airboxes, Carbs, Intakes, Fuel Tanks, Sending Units, Petcocks, Gas Caps, Tank Mounts, Etc.
-- Mikuni Parts
MORE FUEL SYSTEM PARTS:
MIKUNI CARB REBUILD PARTS:
NOTE: Mikuni carbs were originally used on all Yamaha XJ550 models (BS28 series carbs), all XJ650 Turbo models (BS30 series carbs), all XJ700-X and XJ750-X models (BS33 series carbs), XJ900RK model (BS35 series carbs), and XJ1100 models (BS34 series carbs). All other XJ models from this era (XJ650 non-Turbo models, XJ700 non-"X" models, and all XJ750 non-X models) used Hitachi carbs.
NOTE: "OEM" refers to an original Yamaha factory part, whereas "Replacement" or "Aftermarket" refers to a part not made by Yamaha or one of their original suppliers. NOTE THAT AN "OEM" PART may be made by Yamaha's original supplier, even though such part is no longer serviced through the Yamaha factory parts system.
MIKUNI THROTTLE SHAFT REBUILD PARTS:
MIKUNI THROTTLE SHAFT SEALS:
aaa) OEM and aftermarket Mikuni carb THROTTLE SHAFT V-SEALS (sometimes called an "O-Ring", but it's not!)...these are the seals on the outside of the carb body that the throttle shaft passes through. Uses 2 per carb, BUT......without taking the carbs apart from the rack, the only ones you can replace are the outer seals on the #1 and the #4 carbs. Unlike the QR-series "o-rings" that many people recommend using---AND WHICH DO NOT FIT PROPERLY---these "V-Seals" do have the correct O.D., I.D., and thickness to fit both the throttle shaft and the carb shaft seal bore recess correctly. Used on all XJ550, XJ650 Turbo, XJ700-X, XJ750-X, XJ900RK, and XJ1100 models.
HCP6838B OEM Mikuni throttle shaft V-SEAL, single:
$ 5.00
HCP6838BSET2 OEM Mikuni throttle shaft V-SEALS, pair:
$ 9.50
HCP6838BSET8 OEM Mikuni throttle shaft V-SEALS, set of 8:
$ 36.00
HCP38B Aftermarket Mikuni throttle shaft V-SEAL, single:
$ 4.00
HCP38BSET2 Aftermarket Mikuni throttle shaft V-SEALS, pair:
$ 7.75
HCP38BSET8 Aftermarket Mikuni throttle shaft V-SEALS, set of 8:
$ 28.95
We also strongly recommend the purchase of a new set of throttle shaft butterfly retaining screws, as it is very common to strip the heads out of the original screws while removing them. Replacement screws are listed further below.
Also, you are going to find it next-to-impossible to properly remove the original screws without using the proper JIS-style screwdriver. Typical "American" style screwdrivers do not have the proper tip design to engage the slots on JIS-specifications screws (which all screws on Japanese bikes are) and tend to very easily strip out the screw heads. We offer both a complete 4-piece set of various sized JIS screwdrivers, but those people wanting only the correct size screwdriver for these throttle shaft screws should order the HCP5901 (size #2) screwdriver:
HCP5901 Aftermarket size #2 JIS-standards SCREWDRIVER, for m3-m5 sized screws.
$ 11.95
HCP5904 Aftermarket JIS-standards SCREWDRIVER SET. Japanese phillips drive screws have sharper corners than regular phillips screwdrivers so they won't turn out under heavy torque. In order to take advantage of this feature, and to avoid stripping out the JIS screw heads by using US-standard phillips screwdrivers, it's a good idea to invest in a set of quality JIS-standard screwdrivers. This set of 4 contains one each of #1, #2, #3, and #4 sized-tip screwdrivers, and this range of sizes will handle everything down to an M2 sized screw (that's tiny, smaller than the size of the petcock faceplate mounting screws) all the way up to screws bigger than anything I've seen used on these bikes. They all feature sturdy plastic handles, chrome plated steel shafts, and come in a handy vinyl storage pouch.
$ 37.95
bbb) Aftermarket Mikuni carb Throttle Shaft Seal PLASTIC SHIM WASHER...these washers go directly "outside" of the throttle shaft seals listed above. Same notes as listed above about the seals (regarding the ease of replacement) also applies to these shims. NOTE: these shims do NOT "wear out" like the seals do; you only need to replace them if your shim washers are broken or missing. Used on all XJ550, XJ650 Turbo, XJ700-X, XJ750-X, XJ900RK, and XJ1100 models.
HCP39C Aftermarket Mikuni throttle shaft seal SHIM WASHER, single:
$ 2.00
HCP39CSET2 Aftermarket Mikuni throttle shaft seal SHIM WASHERS, pair:
$ 3.75
HCP39CSET8 Aftermarket Mikuni throttle shaft seal SHIM WASHERS, eight shims:
$ 14.00
MIKUNI THROTTLE SHAFT HARDWARE:
ts5) Aftermarket Mikuni throttle shaft BUTTERFLY VALVE MOUNTING SCREW. Each round butterfly "valve" is held to the steel throttle shaft via two tiny phillips head screws. The throttle shaft has self-locking threads which makes the removal of these screws an absolute chore and usually results in a buggered phillips head slot. These replacement screws come in a variety of materials and drive styles. Use 2 per carb, 8 per entire carb rack. Used on all XJ550, XJ650 Turbo, XJ700-X, XJ750-X, XJ900RK, and XJ1100 models.
NOTE: these screws are an absolute BEAST to remove, and it is very easy to destroy the screw heads as well as the throttle shaft threads while trying to remove them---if proper precautions are not taken. You will want to review the information in this forum thread before attempting removal:
www.xjbikes.com/Forums...html#66348
For all of the above reasons, our recommendation is to use the allen-head (hex drive) style screws (HCP7120 or HCP7346 below) to make future removal easier. ALSO, since it is not really feasible to peen or stake the screws once installed (as Mikuni originally did---they must have had a special fixture to perform this task), it is strongly recommended that you use some type of semi-permanent thread-locking fluid (such as our HCP1266 or HCP1267 thread locker fluids) when installing these screws.....as the last thing you want to have happen is having these screws back out during engine operation.....as that would be a sad, sad day for you and your engine!
HCP5899 Aftermarket Mikuni butterfly valve MOUNTING SCREW, oval-head 18-8 stainless steel screw with a phillips-drive, each:
$ 1.00
HCP5899SET2 Aftermarket Mikuni butterfly valve MOUNTING SCREWS, oval-head 18-8 stainless steel screw with a phillips-drive, set of 2:
$ 1.75
HCP5899SET8 Aftermarket Mikuni butterfly valve MOUNTING SCREWS, oval-head 18-8 stainless steel screw with a phillips-drive, set of 8:
$ 5.00
HCP7120 Aftermarket Mikuni butterfly valve MOUNTING SCREW, flat-head 18-8 stainless steel socket head cap screw with a 2mm hex-drive, each:
$ 1.00
HCP7120SET2 Aftermarket Mikuni butterfly valve MOUNTING SCREWS, flat-head 18-8 stainless steel socket head cap screw with a 2mm hex-drive, set of 2:
$ 1.95
HCP7120SET8 Aftermarket Mikuni butterfly valve MOUNTING SCREWS, flat-head 18-8 stainless steel socket head cap screw with a 2mm hex-drive, set of 8:
$ 5.50
HCP7346 Aftermarket Mikuni butterfly valve MOUNTING SCREW, flat-head black-oxide coated alloy steel socket head cap screw with a 2mm hex-drive, each:
$ 1.00
HCP7346SET2 Aftermarket Mikuni butterfly valve MOUNTING SCREWS, flat-head black-oxide coated alloy steel socket head cap screw with a 2mm hex-drive, set of 2:
$ 1.95
HCP7346SET8 Aftermarket Mikuni butterfly valve MOUNTING SCREWS, flat-head black-oxide coated alloy steel socket head cap screw with a 2mm hex-drive, set of 8:
$ 5.50
vv2) Aftermarket small parts NEEDLE FILES SET. This set of 12 miniature swiss files allows you to easily get into those tight spots with precise control. A variety of files----round, flat, triangle---all have easy-grip round knurled handles. Each file is approximately, 6" long. Works great for knocking the peening off the back of the original Mikuni throttle shaft screws before you attempt to remove them.
HCP9802 Aftermarket small parts NEEDLE FILES SET.
$ 14.95
ts5) OEM and aftermarket Mikuni carb throttle shaft retaining E-CLIP...these shaft retainer clips go directly "outside" of the plastic shim washers listed above on the #1 and #4 carbs only. Used on all XJ550, XJ650 Turbo, XJ700-X, XJ750-X, XJ900RK, and XJ1100 models.
HCP6836 OEM throttle shaft end retaining E-CLIP, bright plated spring steel, each:
$ 3.50
HCP6836SET2 OEM throttle shaft end retaining E-CLIPS, set of 2:
$ 6.75
HCP905 Aftermarket throttle shaft end retaining E-CLIP, black-phosphate coated spring steel as original, each:
$ 1.00
HCP905SET2 Aftermarket throttle shaft end retaining E-CLIPS, set of 2:
$ 1.50
HCP2909 Aftermarket throttle shaft end retaining E-CLIP, type 420 stainless spring steel, each:
$ 1.75
HCP2909SET2 Aftermarket throttle shaft end retaining E-CLIPS, set of 2:
$ 3.00
MIKUNI IDLE MIXTURE SCREW PARTS:
NOTE: idle mixture screws are also referred to as "pilot mixture screws" or "pilot screws".
If you've never delved into the guts of your carburetor idle mixture screw port, it can sometimes be confusing. Here's the playbook for this critical area:
If we were looking at a cut-away of the carb body/idle mixture screw bore, the order of parts, from bottom to top, would be:
a) HCP895 o-ring
b) HCP896 spring seat washer
c) HCP6574 tension spring
d) the idle mixture screw
e) the metal anti-tamper cap.
What is mostly confusing is the order of the o-ring versus the spring seat washer....which goes in the hole first? The answer is that the HCP895 O-ring does. The HCP896 washer primarily acts as the lower "seat" for the HCP6574 tension spring, while also keeping the o-ring firmly and securely in place.
ims3) OEM Mikuni IDLE MIXTURE SCREW SET is correct for all original XJ550, XJ650 Turbo, XJ700-X, XJ750-X, and XJ900 carbs.
Each complete set contains one brass slot-headed idle mixture adjustment Screw, the mixture screw Spring, the spring Washer, and the sealing O-Ring. NOTE: the tension spring contained in this kit is not the correct length for the XJ650 Turbo, XJ900RK, or XJ1100 models, but will work.
HCP3745 OEM Mikuni IDLE MIXTURE SCREW SET....contains the brass idle mixture screw, spring, spring washer, and the o-ring. Each:
$ 16.95
HCP3745SET4 OEM Mikuni IDLE MIXTURE SCREW SETS, set of 4:
$ 64.95
ddd) Aftermarket Mikuni IDLE MIXTURE SCREW O-RING.....a "must-replace" item when rebuilding your carbs. Made of long-lasting, fuel-resistant Buna-N material.
HCP895 Aftermarket Mikuni idle mixture screw O-RING, fits all XJ550, XJ650 Turbo, XJ700-X, XJ750-X, XJ900, and XJ1100 carbs, each:
$ 1.50
HCP895SET4 Aftermarket Mikuni idle mixture screw O-RINGS, set of 4:
$ 4.95
eee) Aftermarket Mikuni IDLE MIXTURE SCREW SPRING SEAT WASHER.....also a "must-replace" item when rebuilding your carbs. Made of long-lasting, fuel- and water-resistant 18-8 stainless steel material.
HCP896 Aftermarket Mikuni idle mixture screw spring seat WASHER, fits all XJ550, XJ650 Turbo, XJ700-X, XJ750-X, XJ900, and XJ1100 carbs, each:
$ 1.75
HCP896SET4 Aftermarket Mikuni idle mixture screw spring seat WASHERS, set of 4:
$ 5.95
ims6) Aftermarket carb IDLE MIXTURE SCREW TENSION SPRING, brand new reproductions exactly replace damaged, rusted, or missing originals. High-strength carbon-steel coil springs have a baked yellow-zinc plating as original.
HCP6574 Aftermarket reproduction idle mixture screw TENSION SPRING, fits Mikuni carbs used on all XJ550, XJ700-X, and XJ750-X models, each:
$ 3.50
HCP6574SET4 Aftermarket reproduction idle mixture screw TENSION SPRINGS, set of 4:
$ 10.95
HCP8544 Aftermarket reproduction idle mixture screw TENSION SPRING, fits Mikuni carbs used on all XJ650 Turbo, XJ900RK, and XJ1100 models, each:
$ 4.95
HCP8544SET4 Aftermarket reproduction idle mixture screw TENSION SPRINGS, set of 4:
$ 14.95
ims3) OEM and aftermarket idle mixture screw bore hole TAMPER CAPS, original round aluminum cap exactly replaces the original brass sealing cap and has the small breather hole in the center as original. Aftermarket rubber plug makes installation and removal a breeze, and is highly recommended as a replacement for the original style cap.
HCP3748 OEM Mikuni idle mixture screw bore hole aluminum TAMPER CAP, each:
$ 5.00
HCP3748SET4 OEM Mikuni idle mixture screw bore hole TAMPER CAPS, set of 4:
$ 19.00
HCP7376 Aftermarket Mikuni idle mixture screw bore hole RUBBER PLUG, tapered design with mushroom head allows repeated removal and re-use. NOTE: maybe a slightly loose fit on some models; if so, use a small amount of gasket or rubber adhesive to secure firmly in place (just a thin smear will do). Waterproof and dustproof design keeps the screw away from dirt and moisture, while also allowing for easy removal for tuning purposes. Each:
$ 4.50
HCP7376SET4 Aftermarket Mikuni idle mixture screw bore hole RUBBER PLUGS, set of 4:
$ 14.95
HCP2398 THREAD CHASER AND CLEAN-UP TAP, made from a high-speed uncoated steel. For use on all Mikuni idle mixture screw ports, for models using ultra-fine threaded idle mixture screws. NOTE: these threaded holes almost always need cleaning or re-tapping.
$ 33.00
HCP254 Idle Mixture Screw REMOVAL AND ADJUSTER TOOL, fits all Mikuni idle mixture screws.
$ 17.95
MIKUNI IDLE SPEED SCREW PARTS:
Not to be confused with the idle MIXTURE screw listed above, the IDLE SPEED SCREW is the large knurled-head screw that lives dead center, at the bottom of the carb rack, in-between the #2 and #3 cars, and pointing straight back. This screw is used to adjust the idle speed of the engine, and has no effect on the idle mixture nor the carb (engine) "synch" settings!
HCP5161 OEM idle speed ADJUSTMENT SCREW AND SPRING SET, fits all XJ550, XJ650 Turbo, XJ700-X, XJ750-X, and XJ900RK models.
$ 24.95
HCP9848 Aftermarket Mikuni idle speed screw rubber GROMMET, fits into the lower carb rack bracket opening where the idle speed screw enters the bracket. This replacement grommet is quite a bit larger than the stock grommet, but fits and works properly. Use a little bit of silicone grease on the screw's shaft where it passes through this grommet and it will be silky-smooth in operation. Fits all XJ550, XJ650 Turbo, XJ700-X, XJ750-X, and XJ900RK models
$ 1.95
HCP4024 Aftermarket Mikuni carb idle speed screw WASHER, not an original part, but if you use a set of these thin flat plastic shimming washers in-between the spring and the screw, and between the spring and the bracket (in other words, on either end of the spring), it greatly reduces the friction between the two and makes the idle screw silky-smooth to adjust! Fits all XJ550, XJ650 Turbo, XJ700-X, XJ750-X, XJ900RK, and XJ1100 models Each:
$ 0.75
MIKUNI CARB STARTER-ENRICHMENT CIRCUIT-CHOKE SYSTEM PARTS:
The starter (choke) circuit is prone to a number of problems, from clogged passages in the starter jet (down int he bowl) to worn or fractured plunger valves and their related hardware. We've got some of those hard-to-find parts to properly restore your system.
The starter circuit PLUNGER VALVES are the solid brass needle-tip valve that actually shuts off or opens the enrichment circuit. Worn tips or fractured heads renders these valves useless. These valves are SPRING-loaded, and retained in the starter valve port in the carb body by a threaded, hollow-center brass SEAT, which is then surrounded by a small rubber DUST CAP. In addition, XJ650 Turbo models used a rubber O-RING to provide an air-tight seal at the cover-to-carb body mating surface.
HCP5197 OEM Mikuni brass PLUNGER VALVE, fits all XJ550 models, each:
$ 17.95
HCP9933 OEM Mikuni brass PLUNGER VALVE, fits all XJ650 Turbo, XJ700-X, and XJ750-X models, each:
$ 27.95
HCP5198 OEM Mikuni brass plunger valve SPRING, fits all XJ550, XJ650 Turbo, XJ700-X and XJ750-X models, each:
$ 7.95
HCP9334 OEM Mikuni brass plunger valve threaded brass SEAT, fits all XJ550, XJ700-X and XJ750-X models, each:
$ 9.95
HCP9846 Aftermarket starter circuit plunger valve seat O-RING, correct for the XJ650 Turbo models (o-rings were only used in this area on Turbo carbs). Fits just under the head of the threaded plunger shaft cap. Each:
$ 1.50
HCP9846SET4 Aftermarket starter circuit plunger seat O-RINGS, correct for the XJ650 Turbo models (o-rings were only used in this area on Turbo carbs), set of 4:
$ 5.00
HCP9335 OEM Mikuni brass plunger valve threaded brass seat DUST CAP, fits all XJ550, XJ650 Turbo, XJ700-X, and XJ750-X models, each:
$ 6.95
HCP9895 OEM Mikuni brass PLUNGER VALVE SET, contains the brass plunger Valve, the Spring, the threaded brass Seat, and the rubber seat Cap. Fits all XJ650 Turbo, XJ700-X, and XJ750-X models. NOTE: the threaded brass seat that comes with this set is not correct and will not fit the XJ650 Turbo models. Each:
$ 44.95
MIKUNI CARB FUEL SUPPLY AND BOWL OVERFLOW T-FITTINGS, CONNECTOR TUBES, AND O-RINGS:
mtz1) OEM Mikuni fuel inlet T-FITTING AND CONNECTOR SUPPLY TUBES. The swivelling plastic t-fitting is used as the intake port from the petcock and "splits" the fuel flow to the left and right sides of the carb banks, while the aluminum fuel connector pipes are used to connect the outer carbs to the center carbs for incoming fuel supply. The inlet T-fitting was plastic, and was equipped with built in anti-leak "ribs" where they enter the carb bodies, while the aluminum connector tubes use separate o-rings (listed further below) to provide a leak-proof connection into the carb bodies.
HCP5166 OEM plastic fuel inlet T-FITTING, use 1 on all XJ550 models, in-between the #2 and #3 carbs.
$ 33.95
HCP9865 OEM plastic fuel inlet T-FITTING, use 1 on all XJ700-X and XJ750-X models, in-between the #2 and #3 carbs.
$ 32.00
HCP5165 OEM aluminum fuel SUPPLY TUBE, use 1 each on all XJ550 models in-between the #1/2 and the #3/4 carbs. O-rings are included. Each:
$ 22.50
HCP5239 OEM aluminum fuel SUPPLY TUBE, use 1 each on all XJ650 Turbo, all XJ700-X, and XJ750-X models in-between the #1/2 and the #3/4 carbs; use 1 on XJ900RK models between the #2/3 carbs, includes the sealing o-rings. Each:
$ 22.95
HCP9866 OEM fuel bowl vent/overflow plastic T-FITTING, use 1 each on all XJ700-X and XJ750-X models in-between the #1/2 and #3/4 carbs.
$ 17.95
HCP9867 OEM fuel bowl vent/overflow plastic T-FITTING, use 1 each on all XJ900RK models in-between the #1/2 and #3/4 carbs.
$ 19.95
HCP9864 OEM fuel bowl vent/overflow aluminum CONNECTOR TUBE, use 1 each on all XJ650 Turbo models in-between the #2/3 carbs, includes the sealing o-rings. Each:
$ 19.95
mmm1) OEM and aftermarket Mikuni fuel rail connector pipe O-RING.....all fours carbs share a common fuel supply, and this fuel supply is distributed to each carb via either plastic, brass or aluminum tubes and T-fittings that connects one carb to another. These tubes fits into a machined bores in the carb base, and the tubes are sealed in their bores with these rubber o-rings. Additionally, XJ650 Turbo and XJ700-X and XJ750-X models also used bowl vent connectors (plastic T-fittings) that also used o-rings. NOTE: original seals were "D-rings" rather than "O-rings", but are now serviced only as o-rings, but are the correct shape and firmness to provide a leak-proof fit. You will only be able to access these seals if you break the carbs out of their rack! (and if you do break the rack, you need to replace these seals).
NOTE: on all Mikuni model carbs, the factory parts diagram show the use of a plastic, ribbed fuel inlet T-fitting that does NOT use any o-rings.....the molded in "ribs" are supposed to take the place of o-rings for sealing the t-fitting to the carb body. To be honest, like many of you have commented, I don't understand either how the ribs on the plastic fitting by themselves could have maintained an effective seal, but......I'm not fuel line engineer! You can always add an extra two o-rings to this t-fitting to provide a more secure connection.
- Use 4 seals per fuel connector pipe in-between carbs 1&2 and 3&4, or a total of 8 seals per entire carb rack, for Mikuni carbs used on all XJ550 models. NOTE: the plastic fuel inlet "T" fitting does not use o-rings.
- Use 4 seals per fuel connector pipe in-between carbs 1&2 and 3&4, and use 4 seals per bowl overflow connector pipes, for a total of 20 seals per entire carb rack, on the Mikuni carbs used on all XJ650 Turbo models. NOTE: the plastic fuel inlet "T" fitting does not use o-rings.
- Use 4 seals per fuel connector pipe in-between carbs 1 & 2 and in-between 3 & 4, and use 2 seals on each bowl overflow "T" connector pipes, or a total of 12 seals per entire carb rack, for Mikuni carbs used on all XJ700-X and XJ750-X models. NOTE: the plastic fuel inlet "T" fitting does not use o-rings, and the bowl overflow plastic T-connectors actually use a slightly larger o-ring. However, these o-rings will fit the bowl-overflow T-fittings, although they will result in a slightly more loose fitting pipe in the carb bores. Since these bowl overflow T-connectors don't actually carry fluid---they normally just vent fuel vapors---the slightly looser fitment is not an issue.
- In case you're wondering, XJ1100 models used two plastic T-fittings for fuel inlet supply, and those fittings do NOT use any o-rings. There are no bowl vent connector tubes on 1100's, so there are no o-rings used at all on 1100 models!
HCP3458 OEM Mikuni fuel line Tube O-RING, each:
$ 3.50
HCP3458SET8 OEM Mikuni fuel line Tube O-RINGS, set of 8:
$ 26.50
HCP3458SET12 OEM Mikuni fuel line Tube O-RINGS, set of 12:
$ 39.00
HCP3458SET20 OEM Mikuni fuel line Tube O-RINGS, set of 20:
$ 62.00
HCP6880 Aftermarket Mikuni fuel line Tube O-RING, made from a durable Buna-N rubber material, fits just like the originals at a much better price. Each:
$ 1.50
HCP6880SET8 Aftermarket Mikuni fuel line Tube O-RINGS, set of 8:
$ 8.50
HCP6880SET12 Aftermarket Mikuni fuel line Tube O-RINGS, set of 12:
$ 11.95
HCP6880SET20 Aftermarket Mikuni fuel line Tube O-RINGS, set of 20:
$ 18.95
MIKUNI FUEL AND AIR JETS:
MIKUNI MAIN FUEL JETS:
NOTE: stock Mikuni XJ series carbs used the following original main fuel jet sizes:
#100 1985 all XJ700-X models*
1991-94 XJ900
#102.5 XJ900RK US & Canada
XJ900RL and XJ900P (31A models)
XJ550L (1984) on cylinders #3 and #4
#105 1986 all XJ700-X models and all XJ750-X
XJ550L (1984) on cylinders #1 and #2
#107.5 XJ900 most 1983-90 except USA or Canada
#112.5 XJ550 all models and XJ1100
#125 XJ650 Turbo carbs for all cylinders**
#127.5 XJ650 Turbo carbs for cylinders #1 and #4**
#132.5 XJ650 Turbo carbs for cylinders #2 and #3**
NOTES:
* there are discrepancies between the parts manuals and the service manual information on the size of the 1985 XJ700-X main fuel jets; one source claims these carbs were equipped with #100 main fuel jets, while other sources claim a #105 size main fuel jet.
** there are discrepancies between the parts manuals and the service manual information on the size of the 1982-83 XJ650 Turbo main fuel jets; one source claims these carbs were equipped with #127.5/#132.5 combination of main fuel jets as described above, while other sources claim #125 size main fuel jets were used in all cylinders. Original carbs that we have explored have the #127.5/#132.5 combination of jets as shown above.
All the other sizes are for "tuning" or re-jetting purposes when changing intakes or exhaust systems.
HCP6900 OEM Mikuni MAIN FUEL JET #105
HCP6901 OEM Mikuni MAIN FUEL JET #107.5
HCP6902 OEM Mikuni MAIN FUEL JET #110
HCP6903 OEM Mikuni MAIN FUEL JET #112.5
HCP6904 OEM Mikuni MAIN FUEL JET #115
HCP6905 OEM Mikuni MAIN FUEL JET #117.5
HCP6906 OEM Mikuni MAIN FUEL JET #120
HCP6908 OEM Mikuni MAIN FUEL JET #125
HCP6909 OEM Mikuni MAIN FUEL JET #127.5
HCP6910 OEM Mikuni MAIN FUEL JET #130
HCP6911 OEM Mikuni MAIN FUEL JET #132.5
HCP6912 OEM Mikuni MAIN FUEL JET #135
HCP6913 OEM Mikuni MAIN FUEL JET #137.5
HCP6914 OEM Mikuni MAIN FUEL JET #140
HCP6915 OEM Mikuni MAIN FUEL JET #142.5
HCP6916 OEM Mikuni MAIN FUEL JET #145
HCP6917 OEM Mikuni MAIN FUEL JET #147.5
HCP6918 OEM Mikuni MAIN FUEL JET #150
All of the above OEM Mikuni Main Fuel Jets are priced as follows:
$ 5.50 each
or
$ 18.00 per set of 4
HCP6919 Aftermarket Mikuni MAIN FUEL JET #90
HCP6920 Aftermarket Mikuni MAIN FUEL JET #95
HCP6921 Aftermarket Mikuni MAIN FUEL JET #100
HCP6922 Aftermarket Mikuni MAIN FUEL JET #102.5
HCP6923 Aftermarket Mikuni MAIN FUEL JET #105
HCP6924 Aftermarket Mikuni MAIN FUEL JET #107.5
HCP6925 Aftermarket Mikuni MAIN FUEL JET #110
HCP6926 Aftermarket Mikuni MAIN FUEL JET #112.5
HCP6927 Aftermarket Mikuni MAIN FUEL JET #115
HCP6928 Aftermarket Mikuni MAIN FUEL JET #117.5
HCP6929 Aftermarket Mikuni MAIN FUEL JET #120
HCP6930 Aftermarket Mikuni MAIN FUEL JET #122.5
HCP6931 Aftermarket Mikuni MAIN FUEL JET #125
HCP6932 Aftermarket Mikuni MAIN FUEL JET #127.5
HCP6933 Aftermarket Mikuni MAIN FUEL JET #130
HCP6934 Aftermarket Mikuni MAIN FUEL JET #135
HCP6936 Aftermarket Mikuni MAIN FUEL JET #140
HCP6937 Aftermarket Mikuni MAIN FUEL JET #142.5
HCP6938 Aftermarket Mikuni MAIN FUEL JET #145
HCP6939 Aftermarket Mikuni MAIN FUEL JET #147.5
HCP6940 Aftermarket Mikuni MAIN FUEL JET #150
HCP6941 Aftermarket Mikuni MAIN FUEL JET #152.5
HCP6942 Aftermarket Mikuni MAIN FUEL JET #155
HCP6943 Aftermarket Mikuni MAIN FUEL JET #157.5
HCP6944 Aftermarket Mikuni MAIN FUEL JET #160
HCP6945 Aftermarket Mikuni MAIN FUEL JET #165
HCP6946 Aftermarket Mikuni MAIN FUEL JET #170
HCP6947 Aftermarket Mikuni MAIN FUEL JET #175
HCP6948 Aftermarket Mikuni MAIN FUEL JET #180
All of the above Aftermarket Mikuni Main Fuel Jets are priced as follows:
$ 2.50 each
or
$ 9.75 per set of 4
HCP5186 OEM Mikuni main jet SHIM WASHER, correct copper shim washer fits under the main fuel jet, in-between the jet and the emulsion tube. Fits all XJ550, XJ650 Turbo, XJ700-X, XJ750-X, XJ900RK, and XJ1100 models. Each:
$ 1.75
MIKUNI MAIN AIR JETS:
Alas, the Mikuni BSxx series carbs used on XJ models---unlike their cousins the Hitachi HSCxx series carbs---did not have replaceable main jets. The main air jets on these models are in the carb throat, facing the airbox, and are a small, brass pressed-in tube that is non replaceable, and which we suggest you do NOT try to modify by drilling or enlarging.
And just in case anyone is wondering, here are the sizes of these non-removable main air jets in the various models:
#45: XJ900 all
#70: XJ550 all models and XJ650 Turbo models.
#120: XJ700-X all models and XJ750-X all models*
#140: XJ1100 models*
NOTE: we believe that the #120 and #140 sizes listed in the service manuals (from where the above information was gathered) may be incorrect, as these are gigantic sizes for main air jets. But since you can't replace them anyway, I suppose that it doesn't really matter........
MIKUNI PILOT FUEL JETS:
ef) OEM and aftermarket Mikuni brass PILOT FUEL JETS, sizes as follows, fits all XJ550, XJ650 Turbo, all XJ700-X and XJ750-X, XJ900RK, and XJ1100 models.
NOTE: stock Mikuni XJ series carbs used the following original pilot fuel jet sizes:
#32.5 XJ650LK Turbo (1983)
#35 XJ550 all 1981-83 models, XJ650LJ Turbo (1982), and XJ700-X** all models
#37.5 XJ750-X and XJ900RK USA & Canada only
#40 XJ660L (1984) model, all XJ900 except USA or Canada
#47.5 XJ1100
NOTES:
** there are discrepancies between the parts manuals and the service manual information on the size of the 1985 XJ700-X pilot fuel jets; one source claims these carbs were equipped with #35 main fuel jets, while other sources claim a #37.5 size main fuel jet.
HCP5223 OEM Mikuni PILOT FUEL JET #32.5
$ 15.00 each
or
$ 55.00 set of 4
HCP5183 OEM Mikuni PILOT FUEL JET #35
$ 15.00 each
or
$ 55.00 set of 4
HCP6890 OEM Mikuni PILOT FUEL JET #37.5
$ 14.00 each
or
$ 51.00 set of 4
HCP6889 OEM Mikuni PILOT FUEL JET #47.5
$ 16.50 each
or
$ 59.00 set of 4
HCP6949 Aftermarket Mikuni PILOT FUEL JET #30
HCP6950 Aftermarket Mikuni PILOT FUEL JET #32.5
HCP6951 Aftermarket Mikuni PILOT FUEL JET #35
HCP6952 Aftermarket Mikuni PILOT FUEL JET #37.5
HCP6953 Aftermarket Mikuni PILOT FUEL JET #40
HCP6954 Aftermarket Mikuni PILOT FUEL JET #42.5
HCP6955 Aftermarket Mikuni PILOT FUEL JET #45
HCP6956 Aftermarket Mikuni PILOT FUEL JET #47.5
HCP6957 Aftermarket Mikuni PILOT FUEL JET #50
HCP6958 Aftermarket Mikuni PILOT FUEL JET #52.5
HCP6959 Aftermarket Mikuni PILOT FUEL JET #55
All of the above Aftermarket Mikuni Pilot Fuel Jets are priced as follows:
$ 4.50 each
or
$ 14.00 per set of 4
MIKUNI PILOT AIR JETS:
Pilot air jets on the Mikuni BSxx series carbs are replaceable and are located under the diaphram cover on all XJ550 models, and XJ650 Turbo models, and in the carb throat, facing the airbox, on all XJ700-X, XJ750-X, XJ900RK, and XJ1100 models.
ef) OEM and aftermarket Mikuni brass PILOT AIR JETS, sizes as follows, fits all XJ550, XJ650 (except Turbo), all XJ700-X and XJ750-X, XJ900RK, and XJ1100 models.
NOTE: stock Mikuni XJ series carbs used the following original pilot air jet sizes:
#140 XJ700-X and XJ750-X models
#155 XJ550L (1984) models, 1983 XJ650 Turbo* models
#160 XJ900 all models
#165 XJ550 Maxim models (1981-83), 1982 XJ650 Turbo* models
#170 XJ550 Seca models, XJ650 Turbo*, and XJ1100
NOTE: *the yamaha parts books reference the use of #165 pilot air jets for the 1982 XJ650 Turbo models, and #155 pilot air jets for the 1983 XJ650 Turbo models. Original carbs that we have explored have the #170 jets as shown above.
HCP5218 OEM Mikuni PILOT AIR JET #155
$ 8.50 each
or
$ 32.00 set of 4
HCP6892 OEM Mikuni PILOT AIR JET #160
$ 8.00 each
or
$ 30.00 set of 4
HCP5206 OEM Mikuni PILOT AIR JET #165
$ 6.50 each
or
$ 24.00 set of 4
HCP5171 OEM Mikuni PILOT AIR JET #170
$ 8.00 each
or
$ 30.00 set of 4
HCP6960 Aftermarket Mikuni PILOT AIR JET #110
HCP6961 Aftermarket Mikuni PILOT AIR JET #112.5
HCP6962 Aftermarket Mikuni PILOT AIR JET #115
HCP6963 Aftermarket Mikuni PILOT AIR JET #117.5
HCP6964 Aftermarket Mikuni PILOT AIR JET #120
HCP6965 Aftermarket Mikuni PILOT AIR JET #122.5
HCP6966 Aftermarket Mikuni PILOT AIR JET #125
HCP6967 Aftermarket Mikuni PILOT AIR JET #130
HCP6968 Aftermarket Mikuni PILOT AIR JET #135
HCP6969 Aftermarket Mikuni PILOT AIR JET #137.5
HCP6970 Aftermarket Mikuni PILOT AIR JET #140
HCP6971 Aftermarket Mikuni PILOT AIR JET #142.5
HCP6972 Aftermarket Mikuni PILOT AIR JET #145
HCP6973 Aftermarket Mikuni PILOT AIR JET #147.5
HCP6974 Aftermarket Mikuni PILOT AIR JET #150
All of the above Aftermarket Mikuni Pilot Air Jets are priced as follows:
$ 2.50 each
or
$ 9.50 per set of 4
WHAT ABOUT RE-JETTING FOR PODS, ETC?:
It's a question we get asked often and unfortunately, one that we cannot answer honestly about your specific bike besides with "it depends".
Which is a nice way of saying "you're about to enter the seventh circle of hell......."!
Carb jet tuning required by aftermarket modifications is somewhat of a black art, part science, part skill, part luck. It depends on the current state of tune of your engine, your altitude, the mix of aftermarket parts on your bike, etc........a lot of variables.
The best advice we can offer is: Just Say No. Don't do it! Leave everything stock!
But, since most people---with good reason, I might add---don't always listen to our well-intentioned advice, then the next best recommendation we can offer is: "if you want more power get a bigger bike!".
And since that doesn't cut it with many owners, either, for the remaining stalwarts out there who insist on "experimenting" with aftermarket intake and exhaust systems, here's the best information that we've come across to give you some GUIDANCE, which you should take as just that, and not as ANSWERS, because it isn't!
MAIN FUEL JET SIZE CHANGES NEEDED PER TYPICAL MODIFICATION:
Typical Exhaust Changes:
+2 main fuel jet size for custom 4-into-2 exhaust
or
+4 main fuel jet sizes for 4-into-1 exhaust
or
+4 main jet sizes for no muffler (open headers)
Typical Intake Changes:
+2 main fuel jet sizes for single K&N filter (inside a stock airbox)
or
+2 main fuel jet size for drilling holes in the airbox with stock filter
or
+4 main fuel jet sizes for individual pod filters (no airbox)
Additional changes:
- Add up all the main fuel jet size increases and subtract 2 sizes.
- Decrease main fuel jet size by 2 sizes per every 2000' above sea level.
- Under a mis-match condition, such as when using pod filters with a 100% stock exhaust, or 4-into-1 header with stock filter and air box, then subtract 2 main fuel jet sizes.
PILOT FUEL JET SIZES CHANGES NEEDED PER TYPICAL MODIFICATION:
Pilot fuel jet size changes are related only to the change in main fuel jet sizes according to the main fuel jet size formula described above. Note that this pilot fuel jet rule is for the main fuel jet size change BEFORE any main fuel jet altitude compensation is factored in:
Increase the pilot fuel jet size +1 for every +3 main fuel jet size increases.
Additional changes:
- Decrease pilot fuel jet size by 1 for every 6000' above sea level.
PRECAUTIONS:
- Make sure your carbs are in perfect working order before making jet changes....meaning fully cleaned internally and rebuilt, operating properly in their stock configuration, proper sized air jets and needles, etc. Otherwise, you'll like find that all of your efforts are going to be a HUGE waste of time.
- Check plug color often and adjust as needed, 2 main fuel jet sizes at a time and 1 pilot fuel jet size at a time. Bright white plug insulators are a sign of an overly lean fuel mixture condition and WILL cause damage to your engine over time, up to and including engine seizure!
- Synch the carbs after each jet change.
- Make sure the floats are set correctly
- Seriously consider purchasing a Colortune Plug Tuning kit.
- You may find it necessary to make changes to the size or shimming of the main jet needle. There are no guidelines on what or how to do these changes, this is true trial-and-error tuning!
EXAMPLE:
A 1982 XJ550RJ Seca using an aftermarket Supertrapp 4-into-1 exhaust and a single K&N air filter in the stock, unmodified airbox. Bike is primarily operated at an altitude of 2600 feet above sea level.
XJ550 Seca Stock Mikuni BS28-series Carb Jetting:
#112.5 Main Fuel Jet
#35 Pilot Fuel Jet
#70 Main Air Jet
#170 Pilot Air Jet
4GZ11 Needle
MAIN FUEL JET SIZE CALCULATIONS:
Changes made:
Exhaust:
4 into 1 with Supertrapp = +4 Sizes Main Fuel Jet
Intake:
K&N Pod Filters = +4 sizes Main Fuel Jet
Equals: +8 main fuel jet sizes above baseline
Subtract: -2 main fuel jet size per formula above
Equals: +6 main fuel jet sizes due to modifications, thus:
Stock main fuel jet size is: #112.5
+ 6 additional sizes
= a #118.5 main fuel jet size
Subtract: -2 main fuel jet sizes for Altitude of 2500' Average
= #118.5 calculated from above
-2 jet sizes for altitude adjustment
= a #116.5 main fuel jet size.
PILOT FUEL JET SIZE CALCULATIONS:
The formula is: +1 pilot jet size increase for every +3 main jet sizes increased.
Stock pilot fuel jet size is: #35
+ 2 additional jet sizes (since we went up +6 main fuel jet sizes before the altitude compensation was factored in):
= a #37 pilot fuel jet size.
Note that no altitude compensation is needed on the pilot fuel jet since our elevation is less than 6000' a-s-l.
RESULT:
A #116.5 Main Fuel Jet and #37 Pilot Fuel Jet is A GOOD STARTING POINT.
Note that the above calculations do NOT take into account any possible changes in the sizes of the air jets nor the main needle size, which are additional variables and opportunities for tuning excellence (or frustration!).
For further insights and understanding, the Holy Grail (meaning: the whole miserable, un-varnished truth of what a real chore carb tuning is going to be, written by people who actually know what they're talking about, rather than by people who are trying to sell you something) can be found at:
www.factorypro.com
and then click on the "Product Support/Technical Support" link at the top of the page, then on the "Motorcycle Tuning Tech" link, and then the "CV Carb Tuning" link........and then read, weep, study, and do....if you still dare to! HINT: if reading through it makes you think to yourself "sheesh, this sounds like an incredible amount of effort!", well, you're right! That's just some of the joys (and pitfalls) of getting to play "tuning engineer", which is what you're going to be doing. Yamaha probably has 10 of those types of guys on staff, and millions of dollars of test equipment, both physical and computer-aided, that allowed them to get the mixture settings just right---from an overall drivability AND power output standpoint----and now, since you're changing the airflow parameters thru the engine, you'll have to figure it all out "from scratch", but WITHOUT the benefit of 10 trained engineers and all that test equipment and experience.
That's why we warn you that setting up a bike for pods can be quite a bit of trial-and-error procedure. You can make the calculations according to what is shown in that guideline and then order the jets that the "formula" recommends, and that should serve as a good STARTING POINT............you may (or may not!) have to do more tuning and trial-and-erroring substitution of different jet sizes, etc. to get it performing to you satisfaction, with the recognition that you may ALWAYS end up with a situation that has some kinds of trade-offs.....lazy at the lower end but runs well at mid/upper-ranges, or runs well at the lower end but a "flat-spot" at some other rpm range, etc. Unfortunately there is no magic formula........you might want to read through the factorypro.com article that I list at the end of that section, and you will get a better understanding of what is involved to get the carbs set-up properly in a non-stock configuration.
MIKUNI MAIN JET NEEDLES:
mjw1) Aftermarket Mikuni main jet needle TUNING WASHERS, these precision ground 18-8 stainless steel shim washers are used to raise the main jet needle height slightly, in order to allow performance tuning modifications when the stock intake or exhaust system has been modified. Tuning washers fit on top of the plastic needle cap and underneath the needle cap clip. Each washer is .025mm thick, and multiple washers can be used to provide the proper tuning desired. Fits all XJ550, 650 Turbo, XJ700-X, XJ750-X, XJ900RK, and XJ1100 models.
HCP7142 aftermarket 18-8 stainless steel TUNING WASHER, each:
$ 1.95
HCP7142SET4 aftermarket 18-8 stainless steel TUNING WASHERS, set of 4:
$ 6.00
HCP7142SET8 aftermarket 18-8 stainless steel TUNING WASHERS, set of 8:
$ 10.00
HCP7142SET12 aftermarket 18-8 stainless steel TUNING WASHERS, set of 12:
$ 12.00
MIKUNI MAIN JET NOZZLE OR EMULSION TUBE:
Called by a variety of names, the main fuel jet tube is technically known as the MAIN NOZZLE, although they also go by the name of "power valves", "emulsion tubes", or some choice four-letter words whie you are trying to remove them from their bore hole in the carb body! These 2-3" long tubes have a series of very precise, very small holes that actually pass the fuel from the main fuel jet around the jet needle, and are what provide the final, precise metering of the fuel mixture through the main jet.
Commonly clogged and dirty-filthy beyond belief, they are easy to damage while removing them or during the cleaner process. If the holes are enlarged, or the threads in the jet end damaged, these nozzles should be replaced, or your bike will never run properly.
HCP5224 OEM Mikuni brass MAIN NOZZLE, fits all XJ650 Turbo models, each:
$ 41.00
HCP5224SET4 OEM Mikuni brass MAIN NOZZLES, fits all XJ650 Turbo models, set of 4:
$ 159.95
HCP9899 OEM Mikuni brass MAIN NOZZLE, fits all XJ900RK models, each:
$ 39.00
HCP9899SET4 OEM Mikuni brass MAIN NOZZLES, fits all XJ900RK models, set of 4:
$ 149.95
MIKUNI CARB BOWL PARTS:
ii) OEM and aftermarket Mikuni FLOAT BOWL GASKETS & O-RINGS:
Die-cut replacement carb bowl-to-carb body gaskets correctly replace your torn or leaking originals. Note that the XJ650 Turbo body used a shape-molded o-ring in place of a standard paper gasket.
For XJ550 models:
HCP5182 OEM Mikuni carb FLOAT BOWL GASKET, each:
$ 4.75
HCP5182SET4 OEM Mikuni carb FLOAT BOWL GASKETS, set of 4:
$ 17.95
HCP863 Aftermarket Mikuni carb FLOAT BOWL GASKET, each:
$ 4.00
HCP863SET4 Aftermarket Mikuni carb FLOAT BOWL GASKETS, set of 4:
$ 13.00
For XJ650 Turbo models:
HCP5222 OEM carb bowl-to-body rubber FLOAT BOWL O-RING, for all XJ650 Turbo models, each:
$ 13.95
HCP5222SET4 OEM carb FLOAT BOWL O-RINGS, set of 4:
$ 54.00
For XJ700 "X", XJ750-X, and XJ900RK models:
HCP8563 OEM Mikuni carb FLOAT BOWL GASKET, each:
$ 7.50
HCP8563SET4 OEM Mikuni carb FLOAT BOWL GASKETS, set of 4:
$ 27.00
HCP1674 Aftermarket Mikuni carb FLOAT BOWL GASKET, each:
$ 4.00
HCP1674SET4 Aftermarket Mikuni carb FLOAT BOWL GASKETS, set of 4:
$ 13.00
For XJ1100 models:
HCP6575 OEM Mikuni carb FLOAT BOWL GASKET, each:
$ 14.95
HCP6575SET4 OEM Mikuni carb FLOAT BOWL GASKETS, set of 4:
$ 57.00
HCP1675 Aftermarket Mikuni carb FLOAT BOWL GASKET, each:
$ 4.00
HCP1675SET4 Aftermarket Mikuni carb FLOAT BOWL GASKETS, set of 4:
$ 13.00
NOTE: if you use any type of sealant on these gaskets, use it on the BOWL side of the gasket (something like Permatex Copper Spray-A-Gasket is a fine choice). On the carb body side of the gasket, use a light oil....like Marvel Mystery Oil or the like....and barely moisten the gasket surface. This will allow the new gasket to soften slightly and allows the gasket to form itself to the raised mounting ridge that is cast onto the carb body mating flange.....and also allows for an easy, no-stick removal of the float bowl in the future!
MIKUNI CARB FLOATS AND FLOAT NEEDLE VALVES:
fs4) Aftermarket Mikuni float valve NEEDLE ONLY...for those who wish to do an extreme-budget rebuild, you can buy the rubber-tipped float valve needle by itself (without its brass seat).
For use on all XJ550 models, all XJ700-X and XJ750-X models, all XJ900RK models with the clipped-to-the-float style seat, and all XJ1100 models:
HCP1670 Aftermarket Mikuni float valve NEEDLE with retainer clip, each:
$ 8.50
HCP1670SET4 Aftermarket Mikuni float valve NEEDLES with retainer clip, set of 4:
$ 29.00
For use on all XJ650 Turbo, and all XJ900RK models with the non-clipped to the float style of needle/seat:
HCP1671 Aftermarket Mikuni float valve NEEDLE only, each:
$ 4.50
HCP1671SET4 Aftermarket Mikuni float valve NEEDLES only, set of 4:
$ 17.00
kk) OEM and Aftermarket Mikuni FLOAT NEEDLE VALVE ASSEMBLY---contains the float needle with retainer clip (if used), float valve brass seat, the seat o-ring, and the seat filter screen.
NOTE: XJ900RK models can use either a valve with a 2.0mm seat opening and which uses a non-clipped-to-the-float needle style, or they can use a valve with a larger 2.3mm seat opening and which uses a clipped-to-the-float style of needle. THE TWO STYLES ARE NOT INTERCHANGEABLE---you cannot use one style seat with the other style needle. You CAN, however, interchange the complete needle/seat units on all XJ900RK (Mikuni BS33 series) carbs. However, you should use all four of the same style in a complete set of carbs. Generally speaking, we've seen the non-clipped needle and seat style valves (with the 2.0mm valve seat orifice) used mostly on North American models, and the clipped needle and seat style valves (with the 2.3mm valve seat orifice) used on the non-North American models.
HCP5191 OEM single FLOAT NEEDLE VALVE ASSEMBLY, fits all XJ550 and XJ1100 carbs, each:
$ 28.00
HCP5191SET4 OEM FLOAT NEEDLE VALVE ASSEMBLIES, set of 4:
$ 99.00
HCP1672 Aftermarket single FLOAT NEEDLE VALVE ASSEMBLY, fits all XJ550 and XJ1100 carbs, each:
$ 29.95
HCP1672SET4 Aftermarket FLOAT NEEDLE VALVE ASSEMBLIES, set of 4:
$ 109.00
HCP5229 OEM single FLOAT NEEDLE VALVE ASSEMBLY, for all XJ650 Turbo models. Includes the seat, needle, and seat o-ring. Seat filter screen is not included and must be ordered separate. Each:
$ 66.00
HCP5229SET4 OEM FLOAT NEEDLE VALVE ASSEMBLIES, set of 4:
$ 239.00
HCP8562 OEM single FLOAT NEEDLE VALVE ASSEMBLY, for all XJ700-X, XJ750-X. Also fits the XJ900RK with the 2.3mm orifice and the clipped-to-the-float style needle. Each:
$ 59.95
HCP8562SET4 OEM FLOAT NEEDLE VALVE ASSEMBLIES, set of 4:
$ 229.00
HCP1673 Aftermarket single FLOAT NEEDLE VALVE ASSEMBLY, for all XJ700-X, XJ750-X. Also fits the XJ900RK with the 2.3mm orifice and the clipped-to-the-float style needle. Each:
$ 16.00
HCP1673SET4 Aftermarket FLOAT NEEDLE VALVE ASSEMBLIES, set of 4:
$ 57.00
HCP8560 OEM single FLOAT NEEDLE VALVE ASSEMBLY, for all XJ900RK models with a 2.0mm seat orifice and non-clipped-to-the-float style needle, each:
$ 65.00
HCP8560SET4 OEM FLOAT NEEDLE VALVE ASSEMBLIES, set of 4:
$ 229.00
fnv1) OEM and aftermarket Mikuni float needle valve SEAT O-RING. These o-rings are included in the replacement float needle valve assemblies listed above; but, if you want to re-use your original valve seats, we still recommend the replacement of the seat-to-carb body o-rings.
HCP5192 OEM Mikuni float needle valve SEAT O-RING, tough and durable buna-N material. Fits all XJ550, XJ650 Turbo, XJ700-X, XJ750-X, XJ900RK, and XJ1100 models. Each:
$ 3.50
HCP5192SET4 OEM Mikuni float needle valve SEAT O-RINGS, tough and durable buna-N material, set of 4:
$ 12.95
HCP7406 Aftermarket Mikuni float needle valve SEAT O-RING, tough and durable buna-N material. Fits all XJ550, XJ650 Turbo, XJ700-X, XJ750-X, XJ900RK, and XJ1100 models. Each:
$ 1.50
HCP7406SET4 Aftermarket Mikuni float needle valve SEAT O-RINGS, tough and durable buna-N material, set of 4:
$ 4.50
fnv2) OEM and aftermarket Mikuni float needle valve SEAT FILTER SCREEN. These small domed mesh screen filters snap onto the top of the float needle valve seat and help to keep crud, junk, and other kinds of cosmic debris out of the carbs. These filter screens are included in the replacement float needle valve assemblies and lower end rebuild kits listed above; but, if you want to re-use your original valve seats, we still recommend the replacement of these screens. Fits all XJ550, XJ650 Turbo, XJ700-X and XJ750-X models, XJ900RK, and XJ1100 models.
HCP5193 OEM Mikuni float valve needle SEAT FILTER SCREEN, use one per carb, each:
$ 8.50
HCP5193SET4 OEM Mikuni float valve needle SEAT FILTER SCREENS, use one per carb, set of 4:
$ 32.00
HCP2735 Aftermarket Mikuni float valve needle SEAT FILTER SCREEN, use one per carb, each:
$ 8.00
HCP2735SET4 Aftermarket Mikuni float valve needle SEAT FILTER SCREENS, use one per carb, set of 4:
$ 28.00
fh4) OEM and Aftermarket Mikuni float valve mounting bracket RETAINING SCREW. Original screws are panhead, phillips drive alloy steel and strip out easily. Our original and aftermarket replacement screws prevent future problems....it's a good idea to replace these whenever you remove your float needle valve seats. Fits all XJ550, XJ650 Turbo, XJ700-X, XJ750-X, XJ900RK, and XJ1100 models. Use 1 per carb.
HCP5187 OEM Mikuni float valve mounting bracket RETAINING SCREW, panhead phillips-drive alloy steel, each:
$ 1.00
HCP5187SET4 OEM Mikuni float valve mounting bracket RETAINING SCREWS, set of 4:
$ 2.75
HCP6708 Aftermarket Mikuni float valve mounting bracket RETAINING SCREW, panhead phillips-drive zinc-plated alloy steel, each:
$ 0.50
HCP6708SET4 Aftermarket Mikuni float valve mounting bracket RETAINING SCREWS, set of 4:
$ 1.75
HCP6709 Aftermarket Mikuni float valve mounting bracket RETAINING SCREW, panhead phillips-drive 18-8 stainless steel, bright finish, each:
$ 1.00
HCP6709SET4 Aftermarket Mikuni float valve mounting bracket RETAINING SCREWS, set of 4:
$ 3.00
HCP6710 Aftermarket Mikuni float valve mounting bracket RETAINING SCREW, panhead phillips-drive 18-8 stainless steel, black-oxide coated finish, each:
$ 1.25
HCP6710SET4 Aftermarket Mikuni float valve mounting bracket RETAINING SCREWS, set of 4:
$ 3.50
HCP6712 Aftermarket Mikuni float valve mounting bracket RETAINING SCREW, socket head cap screw, hex-drive, 18-8 stainless steel, bright finish, each:
$ 1.00
HCP6712SET4 Aftermarket Mikuni float valve mounting bracket RETAINING SCREWS, set of 4:
$ 2.50
HCP6711 Aftermarket Mikuni float valve mounting bracket RETAINING SCREW, socket head cap screw, hex-drive, 18-8 stainless steel, black-oxide coated finish, each:
$ 1.00
HCP6711SET4 Aftermarket Mikuni float valve mounting bracket RETAINING SCREWS, set of 4:
$ 2.50
fs8) OEM and aftermarket Mikuni carb fuel bowl FLOAT and FLOAT PIN, brand new replacement units.
HCP5188 OEM Mikuni FLOAT, float only (pin is not included and must be ordered separate), fits all XJ550 and XJ650 Turbo models, each:
$ 27.95
HCP5188SET4 OEM Mikuni FLOATS, set of 4:
$ 104.95
HCP9940 Aftermarket Mikuni FLOAT and FLOAT PIN SET, fits all XJ550 and XJ650 Turbo models, each:
$ 21.00
HCP9940SET4 Aftermarket Mikuni FLOAT and FLOAT PIN SETS, set of 4:
$ 79.95
HCP9944 OEM Mikuni FLOAT, float only (pin is not included and must be ordered separate), fits all XJ700-X, XJ750-X, XJ900RK, and all XJ1100 models, each:
$ 27.95
HCP9944SET4 OEM Mikuni FLOATS, set of 4:
$ 104.95
HCP1668 Aftermarket Mikuni FLOAT and FLOAT PIN SET, fits all XJ700-X, XJ750-X, XJ900RK, and all XJ1100 models, each:
$ 27.00
HCP1668SET4 Aftermarket Mikuni FLOAT and FLOAT PIN SETS, set of 4:
$ 102.00
HCP5190 OEM Mikuni FLOAT PIN, fits all XJ550, XJ650 Turbo, XJ700-X, XJ750-X, XJ900RK, and all XJ1100 models, each:
$ 2.95
HCP5190SET4 OEM Mikuni FLOAT PINS, set of 4:
$ 10.95
oo) Aftermarket Mikuni carb LOWER END REBUILD KIT---contains the float needle with retainer clip, float valve brass seat with the filter screen, the seat o-ring, the idle mixture screw block-off cap, the idle mixture screw o-ring (which is the wrong size----it's way too fat, but it's in there anyway!), a bowl drain screw o-ring, and a reproduction bowl gasket.
XJ550 models:
HCP1669 Aftermarket Mikuni carb LOWER END REBUILD KIT, each:
$ 19.00
HCP1669SET4 Aftermarket Mikuni carb LOWER END REBUILD KITS, set of 4:
$ 69.00
MIKUNI CARB VACUUM DIAPHRAM AND PISTON UNITS:
fs6) OEM and aftermarket Mikuni carb VACUUM DIAPHRAM AND PISTON ASSEMBLY, the slide piston with the non-detachable rubber vacuum diaphram seal. Although it is possible to repair TINY pin-holes that occur in original diaphrams, anything greater than that will require replacement, as these diaphram are under a lot of pressure and stress and the continued flexing of the rubber will eventually lead to failure.
The long slinky SPRING provides the proper pressure and resistance to the movement of the piston unit under a variety of vacuum signal conditions, and stretched or damaged springs should be replaced. Ideally, all fours springs should be replaced all at once to insure equal response from each vacuum piston.
HCP5174 OEM Mikuni VACUUM DIAPHRAM AND PISTON ASSEMBLY, fits all XJ550 models, each:
$ 259.95
HCP5174SET4 OEM Mikuni VACUUM DIAPHRAM AND PISTON ASSEMBLIES, set of 4:
$ 959.95
HCP5173 OEM Mikuni vacuum piston SPRING,fits all XJ550 models, each:
$ 18.95
HCP5173SET4 OEM Mikuni vacuum piston SPRINGS,fits all XJ550 models, set of 4:
$ 69.95
HCP7118 OEM Mikuni VACUUM DIAPHRAM AND PISTON ASSEMBLY, fits all XJ700-X and XJ750-X models, each:
$ 259.95
HCP7118SET4 OEM Mikuni VACUUM DIAPHRAM AND PISTON ASSEMBLIES, set of 4:
$ 959.95
HCP9888 OEM Mikuni vacuum piston SPRING, fits all XJ700-X and XJ750-X models, each:
$ 17.95
HCP9888SET4 OEM Mikuni vacuum piston SPRINGS, fits all XJ700-X and XJ750-X models, set of 4:
$ 69.95
HCP7117 OEM Mikuni VACUUM DIAPHRAM AND PISTON ASSEMBLY, fits all XJ900RK, XJ900RL, XJ900N with BS35 or BS36 series carbs, and all XJ1100 models. NOTE: the piston no longer has the brass plating on it as original (this does not affect its performance or operation). Each:
$ 174.95
HCP7117SET4 OEM Mikuni VACUUM DIAPHRAM AND PISTON ASSEMBLIES, set of 4:
$ 679.95
HCP9889 OEM Mikuni vacuum piston SPRING, fits all XJ900RK models, each:
$ 24.95
HCP9889SET4 OEM Mikuni vacuum piston SPRINGS, fits all XJ900RK models, set of 4:
$ 94.95
HCP1667 Aftermarket Mikuni VACUUM DIAPHRAM AND PISTON ASSEMBLY, fits all XJ900RK and XJ1100 models, each:
$ 99.00
HCP1667SET4 Aftermarket Mikuni VACUUM DIAPHRAM AND PISTON ASSEMBLIES, set of 4:
$ 339.00
bb3) HCP8540 Aftermarket carb diaphram rubber RnR FLUID. Dissolved and chlorinated paraffin wax is the best (and perhaps the only) way to safely bring some life back into stiff, worn rubber material... such as that found in those all-important carb piston diaphrams. Years of hard life inside of your carb take their toll, and whenever your carb is apart for service, and generous application of this product will help to clean, maintain, and restore the flexibility, while prolonging their usable service life. 10cc dripper bottle contains enough fluid to do about eight diaphrams. Simple to use, spread on, wait a few seconds, wipe off, repeat and you're done!
$ 9.95
fms16) OEM and aftermarket Mikuni carb vacuum diaphram-piston assembly MOUNTING SCREWS, This flat metal disc fits into the bottom of the vacuum diaphram and serves as a lower seat for the diaphram spring, and also retains the main jet needle within the diaphram piston unit.
HCP9906 OEM vacuum diaphram MOUNTING SCREWS, fits all XJ1100 models.
$ 6.96
fms7) OEM and aftermarket Mikuni carb vacuum diaphram-piston assembly spring seat MOUNTING SCREWS, panhead phillips-drive screws secures the round spring seat plate to the bottom of the diaphram assembly. Fits all XJ550, XJ650 Turbo, XJ700-X, XJ750-X, XJ900RK, and XJ1100 models. NOTE: the original screws on XJ550 and XJ650 Turbo models did NOT use a lockwasher; all others did use integral lock washers. Replacement screws listed below do not have integral lockwashers, and they can be ordered separate below. Use 2 per carb.
HCP5175 OEM Mikuni carb vacuum piston spring seat MOUNTING SCREW, yellow zinc-plated alloy steel, panhead, phillips-drive screw, each:
$ 1.00
HCP5175SET2 OEM Mikuni carb vacuum piston spring seat MOUNTING SCREWS, yellow zinc-plated alloy steel, panhead, phillips-drive screw, set of 2:
$ 1.90
HCP5175SET8 OEM Mikuni carb vacuum piston spring seat MOUNTING SCREWS, yellow zinc-plated alloy steel, panhead, phillips-drive screw, set of 8:
$ 6.00
HCP2907 Aftermarket Mikuni carb vacuum piston spring seat MOUNTING SCREW, zinc-plated alloy steel, panhead, phillips-drive screw, each:
$ 0.75
HCP2907SET2 Aftermarket Mikuni carb vacuum piston spring seat MOUNTING SCREWS, zinc-plated alloy steel, panhead, phillips-drive screw, set of 2:
$ 1.25
HCP2907SET8 Aftermarket Mikuni carb vacuum piston spring seat MOUNTING SCREWS, zinc-plated alloy steel, panhead, phillips-drive screw, set of 8:
$ 3.50
HCP105 Aftermarket Mikuni carb vacuum piston spring seat MOUNTING SCREW, 18-8 bright stainless steel, panhead, phillips-drive screw, each:
$ 1.50
HCP105SET2 Aftermarket Mikuni carb vacuum piston spring seat MOUNTING SCREWS, 18-8 bright stainless steel, panhead, phillips-drive screw, set of 2:
$ 2.50
HCP105SET8 Aftermarket Mikuni carb vacuum piston spring seat MOUNTING SCREWS, 18-8 bright stainless steel, panhead, phillips-drive screw, set of 8:
$ 7.50
HCP2908 Aftermarket Mikuni carb vacuum piston spring seat MOUNTING SCREW, black oxide coated alloy steel, panhead, phillips-drive screw, each:
$ 1.50
HCP2908SET2 Aftermarket Mikuni carb vacuum piston spring seat MOUNTING SCREWS, black oxide coated alloy steel, panhead, phillips-drive screw, set of 2:
$ 2.50
HCP2908SET8 Aftermarket Mikuni carb vacuum piston spring seat MOUNTING SCREWS, black oxide coated alloy steel, panhead, phillips-drive screw, set of 8:
$ 7.50
HCP7119 Aftermarket Mikuni carb vacuum piston spring seat screw LOCK WASHER, 18-8 stainless steel, each:
$ 0.50
HCP7119SET2 Aftermarket Mikuni carb vacuum piston spring seat screw LOCK WASHERS, 18-8 stainless steel, set of 2:
$ 0.75
HCP7119SET8 Aftermarket Mikuni carb vacuum piston spring seat screw LOCK WASHERS, 18-8 stainless steel, set of 8:
$ 1.50
MIKUNI CARBS HATS:
Mikuni Carb Hats:
Reproduction Mikuni CARB DIAPHRAM COVERS, commonly called carb "hats", are the bright upper covers with the "round dome" shape. Brand new stampings perfectly replace rusted and pitted originals, add a final "crowning" touch to your carb restoration project.
HCP9160 Aftermarket Mikuni POLISHED SILVER CHROME CARB HAT, mirror finish as used on the outboard carbs (#1 and #4) on all XJ550 models. NOTE: can be used on all fours carbs for a more decorative appearance. Each:
$ 32.95
HCP9160SET2 Aftermarket Mikuni POLISHED SILVER CHROME CARB HATS, set of 2:
$ 54.95
HCP9160SET4 Aftermarket Mikuni POLISHED SILVER CHROME CARB HATS, set of 4:
$ 89.95
HCP10010 Aftermarket Mikuni POLISHED GOLDEN CHROME CARB HAT, golden mirror finish. Fits all XJ550 models. NOTE: golden-chrome hats were never used originally on these models, but these are an attractive upgrade that have the same finish as was used on many of the "Midnight Maxim" models. Each:
$ 39.95
HCP10010SET2 Aftermarket Mikuni POLISHED GOLDEN CHROME CARB HATS, set of 2:
$ 59.95
HCP10010SET4 Aftermarket Mikuni POLISHED GOLDEN CHROME CARB HATS, set of 4:
$ 99.95
HCP9161 Aftermarket Mikuni NATURAL ZINC-CAD PLATED CARB HAT, dull silver finish as used on the inner carbs only (#2 and #3) on all XJ550 models. Each:
$ 27.95
HCP9161SET2 Aftermarket Mikuni NATURAL ZINC-CAD PLATED CARB HAT, set of 2:
$ 47.95
info @ xj4ever.com
_________________ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
chacal Supporting Vendor
Joined: Aug 01, 2006 Posts: 4845 Location: At My Computer
Posted: Mon Dec 15, 2008 2:12 am Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION C:
FUEL SYSTEM ITEMS: Including Airboxes, Carbs, Intakes, Fuel Tanks, Petcocks, Gas Caps, Tank Mounts, Etc.
--Mikuni Parts Continued
MIKUNI FUEL SYSTEM HARDWARE:
A variety of different style fasteners and finishes are available, ranging from original OEM grade and finish to stainless steel, polished, or black-oxide coated fasteners. This is the easiest way to replace your missing or damaged original hardware or to upgrade the appearance or durability of your hardware! Many different styles are available for most fasteners, so please review your choices carefully.
MIKUNI CARB BOWL HARDWARE:
bds2) OEM and aftermarket Mikuni carb bowl-to-body MOUNTING SCREW. All Mikuni model carbs originally used a panhead, phillips-drive bowl mounting screw that had an integral lockwasher. Current OEM and most of the replacement screws do not have the integral lockwasher, and a separate lockwasher must be ordered from the selection listed below. NOTE: original screws were plated alloy steel with a natural finish.
For XJ550 models:
HCP3696 OEM Mikuni BS28 series carb bowl-to-body MOUNTING SCREW, phillips-drive panhead screw with natural finish. Use 4 per bowl, each:
$ 2.50
HCP3696SET4 OEM Mikuni BS28 series carb bowl-to-body MOUNTING SCREWS, set of 4:
$ 9.50
HCP3696SET16 OEM Mikuni BS28 series carb bowl-to-body MOUNTING SCREWS, set of 16:
$ 34.00
HCP5482 Aftermarket Mikuni BS28 series carb bowl-to-body MOUNTING SCREW, phillips-drive panhead screw with natural finish. Use 4 per bowl, each:
$ 1.00
HCP5482SET4 Aftermarket Mikuni BS28 series carb bowl-to-body MOUNTING SCREWS, set of 4:
$ 3.00
HCP5482SET16 Aftermarket Mikuni BS28 series carb bowl-to-body MOUNTING SCREWS, set of 16:
$ 9.00
HCP5486 Aftermarket Mikuni BS28 series carb bowl-to-body MOUNTING SCREW, phillips-drive panhead screw with gold chromate finish. Has an integral lockwasher. Use 4 per bowl, each:
$ 1.00
HCP5486SET4 Aftermarket Mikuni BS28 series carb bowl-to-body MOUNTING SCREWS, set of 4:
$ 3.50
HCP5486SET16 Aftermarket Mikuni BS28 series carb bowl-to-body MOUNTING SCREWS, set of 16:
$ 13.00
HCP5483 Aftermarket Mikuni BS28 series carb bowl-to-body MOUNTING SCREW, socket head cap screw (allen headed hex-drive), 18-8 stainless steel with a bright polished finish. Use 4 per bowl, each:
$ 1.00
HCP5483SET4 Aftermarket Mikuni BS28 series carb bowl-to-body MOUNTING SCREWS, set of 4:
$ 3.00
HCP5483SET16 Aftermarket Mikuni BS28 series carb bowl-to-body MOUNTING SCREWS, set of 16:
$ 9.50
HCP5484 Aftermarket Mikuni BS28 series carb bowl-to-body MOUNTING SCREW, socket head cap screw (allen headed hex-drive), black-oxide coated steel finish. Use 4 per bowl, each:
$ 1.00
HCP5484SET4 Aftermarket Mikuni BS28 series carb bowl-to-body MOUNTING SCREWS, set of 4:
$ 3.00
HCP5484SET16 Aftermarket Mikuni BS28 series carb bowl-to-body MOUNTING SCREWS, set of 16:
$ 9.50
HCP5485 Aftermarket Mikuni BS28 series carb bowl-to-body MOUNTING SCREW, button head cap screw (rounded head hex-drive), 18-8 stainless steel with a bright polished finish. Use 4 per bowl, each:
$ 1.50
HCP5485SET4 Aftermarket Mikuni BS28 series carb bowl-to-body MOUNTING SCREWS, set of 4:
$ 3.50
HCP5485SET16 Aftermarket Mikuni BS28 series carb bowl-to-body MOUNTING SCREWS, set of 16:
$ 12.50
For XJ650 Turbo, XJ700-X, XJ750-X, XJ900RK, and XJ1100 models:
HCP2940 OEM Mikuni BS30, BS33, BS34, and BS35 carb bowl-to-body MOUNTING SCREWS. Note: these screws now have a dark gray coated finish, and are approximately 2mm longer than stock, panhead phillips drive. Use 4 per bowl, each:
$ 1.50
HCP2940SET4 OEM Mikuni carb bowl-to-body black oxide MOUNTING SCREWS, set of 4:
$ 5.00
HCP2940SET16 OEM Mikuni carb bowl-to-body black oxide MOUNTING SCREWS, set of 16:
$ 18.00
HCP2643 aftermarket Mikuni BS30, BS33, BS34, and BS35 carb bowl-to-body MOUNTING SCREW, zinc-plated alloy steel, natural finish, approximately 2mm longer than stock, panhead phillips drive. Use 4 per bowl, each:
$ 0.75
HCP2643SET4 aftermarket Mikuni carb bowl-to-body natural finish MOUNTING SCREWS, set of 4:
$ 2.50
HCP2643SET16 aftermarket Mikuni carb bowl-to-body natural MOUNTING SCREWS, set of 16:
$ 9.00
HCP1358 aftermarket Mikuni BS30, BS33, BS34, and BS35 carb bowl-to-body gold chromate MOUNTING SCREW, with an integral lock washer as original, panhead phillips drive. Use 4 per bowl, each:
$ 1.00
HCP1358SET4 aftermarket Mikuni carb bowl-to-body gold chromate MOUNTING SCREWS, with lock washers, set of 4:
$ 3.50
HCP1358SET16 aftermarket Mikuni carb bowl-to-body gold chromate MOUNTING SCREWS, with lock washers, set of 16:
$ 13.00
HCP302 aftermarket Mikuni BS30, BS33, BS34, and BS35 carb bowl-to-body 18-8 stainless steel MOUNTING SCREW, panhead phillips-drive, approximately 2mm longer than stock. Use 4 per bowl, each:
$ 1.00
HCP302SET4 aftermarket Mikuni carb bowl-to-body 18-8 stainless steel MOUNTING SCREWS, phillips head, set of 4:
$ 3.50
HCP302SET16 aftermarket Mikuni carb bowl-to-body 18-8 stainless steel MOUNTING SCREWS, phillips head, set of 16:
$ 12.00
HCP303 aftermarket Mikuni BS30, BS33, BS34, and BS35 carb bowl-to-body MOUNTING SCREW, button head cap screw (rounded head hex-drive), 18-8 stainless steel with a bright polished finish, approximately 2mm longer than stock. Use 4 per bowl, each:
$ 1.50
HCP303SET4 aftermarket Mikuni carb bowl-to-body stainless button-head MOUNTING SCREWS, set of 4:
$ 5.00
HCP303SET16 Replacement Mikuni carb bowl-to-body stainless button-head MOUNTING SCREWS, set of 16:
$ 16.00
HCP56 aftermarket Mikuni BS30, BS33, BS34, and BS35 carb bowl-to-body MOUNTING SCREW, allen head hex-drive, 18-8 stainless steel with a bright polished finish, approximately 2mm longer than stock. Use 4 per bowl, each:
$ 1.50
HCP56SET4 aftermarket Mikuni carb bowl-to-body stainless MOUNTING SCREWS, set of 4:
$ 4.50
HCP56SET16 aftermarket Mikuni carb bowl-to-body stainless MOUNTING SCREWS, set of 16:
$ 15.00
HCP58 aftermarket Mikuni BS30, BS33, BS34, and BS35 carb bowl-to-body MOUNTING SCREW, allen headed hex-drive, black-oxide coated steel finish, approximately 2mm longer than stock. Use 4 per bowl, each:
$ 1.00
HCP58SET4 aftermarket Mikuni carb bowl-to-body black-oxide MOUNTING SCREWS, set of 4:
$ 3.50
HCP58SET16 aftermarket Mikuni carb bowl-to-body black-oxide MOUNTING SCREWS, set of 16:
$ 12.00
bds3) OEM and aftermarket Mikuni carb bowl-to-body mounting screw LOCK WASHER. All Mikuni model carbs originally used a panhead, phillips-drive bowl mounting screw that had an integral lockwasher. Current OEM and many of the replacement screws do not have the integral lockwasher, and a separate lockwasher must be ordered from the selection listed below:
For XJ550 models:
HCP326 OEM alloy-steel natural finish carb bowl mounting screw LOCK WASHER, each:
$ 0.75
HCP326SET4 OEM alloy-steel natural finish bowl mounting screw LOCK WASHERS, set of 4:
$ 2.50
HCP326SET16 OEM alloy-steel natural finish bowl mounting screw LOCK WASHERS, set of 16:
$ 9.00
HCP922 aftermarket alloy-steel natural finish carb bowl mounting screw LOCK WASHER, each:
$ 0.50
HCP922SET4 aftermarket alloy-steel natural finish carb bowl mounting screw LOCK WASHERS, set of 4:
$ 1.50
HCP922SET16 aftermarket alloy-steel natural finish carb bowl mounting screw LOCK WASHERS, set of 16:
$ 4.00
HCP336 aftermarket 18-8 stainless-steel polished finish carb bowl mounting screw LOCK WASHER, each:
$ 0.60
HCP336SET4 aftermarket 18-8 stainless-steel polished finish carb bowl mounting screw LOCK WASHERS, set of 4:
$ 2.00
HCP336SET16 aftermarket 18-8 stainless-steel polished finish carb bowl mounting screw LOCK WASHERS, set of 16:
$ 5.00
HCP342 aftermarket black oxide-coated steel finish carb bowl mounting screw LOCK WASHER, each:
$ 0.50
HCP342SET4 aftermarket black oxide-coated steel finish carb bowl mounting screw LOCK WASHERS, set of 4:
$ 1.50
HCP342SET16 aftermarket black oxide-coated steel finish carb bowl mounting screw LOCK WASHERS, set of 16:
$ 4.00
HCP913 aftermarket Mikuni BS30, BS33, BS34, and BS35 carb bowl-to-body zinc-plated alloy steel, natural finish LOCK WASHER, each:
$ .20
HCP913SET4 aftermarket Mikuni carb bowl-to-body natural finish LOCK WASHERS, set of 4:
$ .75
HCP913SET16 aftermarket Mikuni carb bowl-to-body natural finish LOCK WASHERS, set of 16:
$ 2.50
HCP57 aftermarket Mikuni BS30, BS33, BS34, and BS35 carb bowl-to-body 18-8 stainless steel LOCK WASHER, each:
$ 1.00
HCP57SET4 aftermarket Mikuni carb bowl-to-body stainless LOCK WASHERS, set of 4:
$ 3.00
HCP57SET16 aftermarket Mikuni carb bowl-to-body stainless LOCK WASHERS, set of 16:
$ 9.00
HCP59 aftermarket Mikuni BS30, BS33, BS34, and BS35 carb bowl-to-body black-oxide coated LOCK WASHER, each:
$ 1.00
HCP59SET4 aftermarket Mikuni carb bowl-to-body black oxide LOCK WASHERS, set of 4:
$ 3.00
HCP59SET16 aftermarket Mikuni carb bowl-to-body black oxide LOCK WASHERS, set of 16:
$ 9.00
MIKUNI CARB BOWL DRAIN SCREWS:
g5m) OEM and aftermarket Mikuni carb BOWL DRAIN SCREW....the ones that are always such a bear to remove. OEM screws are bright-plated alloy steel with a panhead, phillips-drive design, and come in both the version WITH the o-ring under the screw head (all XJ550, XJ650 Turbo, XJ900RK, and XJ1100 models) and the style WITHOUT the o-ring under the screw head (all XJ700-X and XJ750-X models).
NOTE: If you plan on using the HCP865 screws WITHOUT any o-rings, I very STRONGLY suggest you use the HCP4399 drain screws instead, and here's why: for whatever reason that Mikuni/Yamaha decided to use the o-rings on these bowl drain screws, the fact is that in order to make the o-ring land or "groove" (where the o-ring sits), they turned down the shaft of the screw by almost 2mm total, thus turning an M6 sized screw (that's the nominal size of both the HCP865 and the HCP4399 drain screws) into an M4 sized screw......kind of a "chain only as strong as it's weakest link" kinda thing......since the "skinniest" part of the HCP865 screw shaft is now just a hair over 4mm diameter, and in effect this is now a M4 (4mm diameter shaft) screw.
Since these screws tend to get stuck in the bowls after a few years of non-use, I believe what Yamaha discovered very quickly was that these o-ringed type screws---the HCP865's with an "in reality" size of just M4---were getting stuck and shearing off right at that "weakest link" portion of the shaft....the o-ring land.....and that is why they did away with the o-ring land on the later model versions of the Mikuni carbs, and started using an unmodified version of the same screw (which is the HCP4399 screw), which is a "true" M6 screw.
In fact, the HCP865 screw and the HCP4399 screw are identical, it's just that the HCP4399 screw is not machined for a ring land.
Aftermarket socket head cap screws are an improved "never-get-stuck-again" version that are made as an 18-8 stainless steel allen head (a/k/a hex-drive socket head cap). This style works much better than the original Yamaha screw; not only is it made of stainless steel, but the larger allen-head design allows for more torque to be applied to the screw, forever ending the stripped/stuck/ruined drain screw problem that has plagued Yamaha owners forever! Note that by their design, the large allen head portion of this drain screw will be located OUTSIDE of the drain screw bore hole in the bowl, and sticks out about 1/4" from the bowl body.
It is HIGHLY recommended that anti-seize compound be used on the screw threads when fitting any bowl drain screws into the carb bowl passage.
OEM Mikuni carb bowl drain screws:
HCP865 OEM Mikuni carb BOWL DRAIN SCREW, correct bright plated, alloy steel, panhead phillips drive drain screw features the machined land just below the head for the acceptance of the HCP4400 o-ring listed below. This style drain screw is used on all XJ550, XJ650 Turbo, XJ900, and XJ1100 models, although it will also fit all XJ700-X and XJ750-X models also. Each:
$ 6.00
HCP865SET4 OEM Mikuni carb BOWL DRAIN SCREWS, correct bright plated, alloy steel, panhead phillips drive drain screw features the machined land just below the head for the acceptance of the HCP4400 o-ring listed below, set of 4:
$ 22.00
HCP4400 OEM Mikuni carb bowl drain screw O-RING, for the HCP865 drain screw listed above. Each:
$ 2.00
HCP4400SET4 OEM Mikuni carb bowl drain screw O-RINGS, for the HCP865 drain screw listed above, set of 4:
$ 7.50
HCP4399 OEM Mikuni carb BOWL DRAIN SCREW, correct bright plated, alloy steel, panhead phillips drive drain screw. This style drain screw does NOT use an o-ring and is correct for all XJ700-X and XJ750-X models, but can also be used successfully on all XJ550, XJ650 Turbo, XJ900, and XJ1100 models, each:
$ 6.20
HCP4399SET4 OEM Mikuni carb BOWL DRAIN SCREWS, correct bright plated, alloy steel, panhead phillips drive drain screw features the machined land just below the head for the acceptance of the HCP4400 o-ring listed below, set of 4:
$ 23.00
Aftermarket Mikuni carb bowl drain screws:
The HCP6279 screw is correct for all XJ700-X and XJ750-X models with Mikuni carbs. This screw will also work just fine in all XJ550, XJ650 Turbo, XJ900RK, and XJ1100 carb bowls. The original drain screws on those models had an integral o-ring, which is not present on this replacement screw. The lack of the o-ring on this replacement screw presents absolutely no fit or sealing/leakage issues on those models originally equipped with a bowl drain screw that used an o-ring. Note that by their design, the large allen head portion of this drain screw will be located OUTSIDE of the drain screw bore hole in the bowl, and sticks out about 1/4" from the bowl body. This additional length does not cause any problems, and after looking at them (installed) on the carb bowls, at first glance they might look "odd" the way the stick out, but after the third or fourth look, they appear normal and oddly interesting with that extended length.
NOTE: do NOT "bottom" the heads of these screws against the bowl! Tighten them to 4-5 foot-pounds of torque, just enough to seat them snugly.
It is recommended that anti-seize compound be used on the screw threads when fitting them into the carb bowl passage.
HCP6279 aftermarket allen-head stainless-steel carb BOWL DRAIN SCREW, large socket-head cap screw (a/k/a allen-head or hex-key drive), 18-8 stainless steel, each:
$ 6.50
HCP6279SET4 aftermarket allen-head stainless-steel carb BOWL DRAIN SCREWS, set of 4:
$ 24.00
MIKUNI CARB HAT HARDWARE:
NOTE: the following carb hat (technically known as a diaphram cover) SCREWS fit all XJ550, XJ650 Turbo, XJ700-X, XJ750-X, XJ900RK, and XJ1100 models. Original hat screws were panhead phillips drive alloy steel with a natural finish, and did not use any washers. Use 4 per carb, 16 per rack.
HCP60 OEM Mikuni carb "Hat" SCREW, alloy steel, natural finish, panhead phillips-drive, each:
$ 1.00
HCP60SET4 OEM Mikuni carb "Hat" SCREWS, set of 4:
$ 3.50
HCP60SET16 OEM Mikuni carb "Hat" SCREWS, set of 16:
$ 13.00
HCP910 Aftermarket Mikuni carb "Hat" SCREW, alloy steel, natural finish, panhead phillips-drive, each:
$ 1.00
HCP910SET4 Aftermarket Mikuni carb "Hat" SCREWS, set of 4:
$ 3.00
HCP910SET16 Aftermarket Mikuni carb "Hat" SCREWS, set of 16:
$ 9.00
HCP62 Aftermarket Mikuni carb "Hat" SCREW, 18-8 stainless steel panhead phillips-drive, each:
$ 1.25
HCP62SET4 Aftermarket Mikuni carb "Hat" SCREWS, set of 4:
$ 4.50
HCP62SET16 Aftermarket Mikuni carb "Hat" SCREWS, set of 16:
$ 14.00
HCP2749 Aftermarket Mikuni carb "Hat" SCREW, black-oxide coated stainless steel panhead phillips-drive, each:
$ 1.50
HCP2749SET4 Aftermarket Mikuni carb "Hat" SCREWS, set of 4:
$ 5.50
HCP2749SET16 Aftermarket Mikuni carb "Hat" SCREWS, set of 16:
$ 18.00
HCP308 Aftermarket Mikuni carb "Hat" SCREW, 18-8 stainless steel, button head with a hex-drive, each:
$ 1.25
HCP308SET4 Aftermarket Mikuni carb "Hat" SCREWS, set of 4:
$ 4.50
HCP308SET16 Aftermarket Mikuni carb "Hat" SCREWS, set of 16:
$ 14.00
HCP310 Aftermarket Mikuni carb "Hat" SCREW, 18-8 stainless steel socket-head cap screw (allen head) with a hex-drive, each:
$ 1.25
HCP310SET4 Aftermarket Mikuni carb "Hat" SCREWS, set of 4:
$ 4.50
HCP310SET16 Aftermarket Mikuni carb "Hat" SCREWS, set of 16:
$ 14.00
HCP64 Aftermarket Mikuni carb "Hat" SCREW, black-oxide coated alloy steel socket head cap screw (a/ka allen head) with a hex drive, each:
$ 1.00
HCP64SET4 Aftermarket Mikuni carb "Hat" SCREWS, set of 4:
$ 3.50
HCP64SET16 Aftermarket Mikuni carb "Hat" SCREWS, set of 16:
$ 12.00
MIKUNI CARB UPPER RACK BRACKET HARDWARE:
a7) OEM and aftermarket Mikuni carb upper rack bracket MOUNTING SCREWS[/b], available in both the short and long versions, in a variety of original and aftermarket styles and finishes. Correct fit for all XJ550, XJ650 Turbo, XJ700-X, XJ750-X, XJ900RK, and XJ1100 models.
The short screws are used in all eight positions EXCEPT for the outer screws hole on all XJ700-X and XJ750-X models. Use 6 of these screws per rack to mount the carbs on those models.
The long screw is used in the two outer positions that has the L-bracket used to hold the carb covers associated with it. You will need to use 2 of these long screws per complete carb rack on those models.
NOTE: originally, these screws were a natural finish, panhead phillips-drive style and did not use a lock washer.
ALSO, these screws were originally installed (and should be re-installed) with a low-strength thread locking fluid applied.
Therefore, these screws may be VERY difficult to remove and it is highly recommended that you obtain the correct size JIS style screwdriver (or an impact driver) to remove them without stripping the slots.
These screws require the use of a semi-permanent thread-locker fluid during installation.
- These replacement panhead phillips-drive screws have a natural finish and are made from alloy steel:
HCP60 OEM Mikuni carb upper rack bracket short MOUNTING SCREW, alloy steel, natural finish, panhead phillips-drive, each:
$ 1.00
HCP60SET6 OEM Mikuni carb upper rack bracket short MOUNTING SCREWS, set of 6:
$ 5.50
HCP60SET8 OEM Mikuni carb upper rack bracket short MOUNTING SCREWS, set of 8:
$ 7.25
HCP2940 OEM Mikuni carb upper rack bracket long MOUNTING SCREW, end screws for XJ700-X and XJ750-X models only. Note: these screws now have a dark gray coated finish, and are approximately 2mm longer than stock, panhead phillips drive, each:
$ 1.50
HCP2940SET2 OEM Mikuni carb upper rack bracket long MOUNTING SCREWS, set of 2:
$ 2.75
HCP910 Aftermarket Mikuni carb upper rack bracket short MOUNTING SCREW, alloy steel, natural finish, panhead phillips-drive, each:
$ 1.00
HCP910SET6 Aftermarket Mikuni carb upper rack bracket short MOUNTING SCREWS, set of 6:
$ 5.00
HCP910SET8 Aftermarket Mikuni carb upper rack bracket short MOUNTING SCREWS, set of 8:
$ 6.50
HCP2643 Aftermarket Mikuni carb upper rack bracket long MOUNTING SCREW, end screws for XJ700-X and XJ750-X models only, zinc-plated alloy steel, natural finish, panhead phillips-drive, approximately 2mm longer than stock, panhead phillips drive. Use 4 per bowl, each:
$ 0.75
HCP2643SET2 Aftermarket Mikuni carb upper rack bracket long MOUNTING SCREWS, set of 2:
$ 1.40
- These replacement panhead phillips-drive screws have a polished finish and are made from 18-8 stainless steel:
HCP62 Aftermarket Mikuni carb upper rack bracket short MOUNTING SCREW, 18-8 stainless steel panhead phillips-drive, each:
$ 1.25
HCP62SET6 Aftermarket Mikuni carb upper rack bracket short MOUNTING SCREWS, set of 6:
$ 6.50
HCP62SET8 Aftermarket Mikuni carb upper rack bracket short MOUNTING SCREWS, set of 8:
$ 7.25
HCP302 Aftermarket Mikuni carb upper rack bracket long MOUNTING SCREW, end screws for XJ700-X and XJ750-X models only, 18-8 stainless steel panhead phillips-drive, approximately 2mm longer than stock, each:
$ 1.00
HCP302SET2 Aftermarket Mikuni carb upper rack bracket long MOUNTING SCREWS, phillips head, set of 2:
$ 1.75
- These replacement button head hex-drive screws have a polished finish and are made from 18-8 stainless steel:
HCP308 Aftermarket Mikuni carb upper rack bracket short MOUNTING SCREW, 18-8 stainless steel, button head with a hex-drive, each:
$ 1.25
HCP308SET6 Aftermarket Mikuni carb upper rack bracket short MOUNTING SCREWS, set of 6:
$ 6.50
HCP308SET8 Aftermarket Mikuni carb upper rack bracket short MOUNTING SCREWS, set of 8:
$ 7.25
HCP303 Aftermarket Mikuni carb upper rack bracket long MOUNTING SCREW, end screws for XJ700-X and XJ750-X models only, 18-8 stainless steel, button head with a hex-drive, approximately 2mm longer than stock, each:
$ 1.50
HCP303SET2 Aftermarket Mikuni carb upper rack bracket long MOUNTING SCREWS, set of 2:
$ 2.75
- These replacement allen head hex-drive screws have a polished finish and are made from 18-8 stainless steel:
HCP310 Aftermarket Mikuni carb upper rack bracket short MOUNTING SCREW, 18-8 stainless steel allen head hex-drive, each:
$ 1.25
HCP310SET6 Aftermarket Mikuni carb upper rack bracket short MOUNTING SCREWS, set of 6:
$ 6.50
HCP310SET8 Aftermarket Mikuni carb upper rack bracket short MOUNTING SCREWS, set of 8:
$ 7.25
HCP56 Aftermarket Mikuni carb upper rack bracket long MOUNTING SCREW, end screws for XJ700-X and XJ750-X models only, 18-8 stainless steel allen head hex-drive, approximately 2mm longer than stock, each:
$ 1.50
HCP56SET2 Aftermarket Mikuni carb upper rack bracket long MOUNTING SCREWS, set of 2:
$ 2.75
- These replacement allen head hex-drive screws have a black oxide-coated finish and are made from alloy steel:
HCP64 Aftermarket Mikuni carb upper rack bracket short MOUNTING SCREW, black-oxide coated alloy steel allen head screw with a hex drive, each:
$ 1.00
HCP64SET6 Aftermarket Mikuni carb upper rack bracket short MOUNTING SCREWS, set of 6:
$ 5.00
HCP64SET8 Aftermarket Mikuni carb upper rack bracket short MOUNTING SCREWS, set of 8:
$ 6.50
HCP58 Aftermarket Mikuni carb upper rack bracket long MOUNTING SCREW, end screws for XJ700-X and XJ750-X models only, black-oxide coated alloy steel allen head screw with a hex drive, approximately 2mm longer than stock, each:
$ 1.00
HCP58SET2 Aftermarket Mikuni carb upper rack bracket long MOUNTING SCREWS, set of 2:
$ 1.75
MIKUNI CARB LOWER RACK MOUNTING BRACKET HARDWARE:
e7) Aftermarket Mikuni carb lower rack bracket MOUNTING SCREWS. available in both the short and long versions, in a variety of original and aftermarket styles and finishes. Correct fit for all XJ550, XJ650 Turbo, XJ700-X, XJ750-X, XJ900RK, and XJ1100 models.
HCP1030 OEM Mikuni carb lower rack bracket short MOUNTING SCREW, alloy steel, dark grey finish, panhead phillips-drive, each:
$ 1.25
HCP1030SET6 OEM Mikuni carb lower rack bracket short MOUNTING SCREWS, set of 6:
$ 7.25
HCP1030SET8 OEM Mikuni carb lower rack bracket short MOUNTING SCREWS, set of 8:
$ 9.50
HCP2940 OEM Mikuni carb lower rack bracket long MOUNTING SCREW, alloy steel, dark grey finish, panhead phillips-drive, for end holes only on "X" models, each:
$ 1.50
HCP2940SET2 OEM Mikuni carb lower rack bracket long MOUNTING SCREWS, set of 2:
$ 2.75
HCP2922 Aftermarket Mikuni carb lower rack bracket short MOUNTING SCREW, zinc-plated alloy steel, natural finish, panhead phillips-drive, each:
$ 1.00
HCP2922SET6 Aftermarket Mikuni carb lower rack bracket short MOUNTING SCREWS, set of 6:
$ 4.00
HCP2922SET8 Aftermarket Mikuni carb lower rack bracket short MOUNTING SCREWS, set of 8:
$ 5.50
HCP2923 Aftermarket Mikuni carb lower rack bracket long MOUNTING SCREW, 18-8 stainless steel, bright finish, panhead phillips-drive, for end holes only on "X" models, each.
$ 1.50
HCP2923SET2 Aftermarket Mikuni carb lower rack bracket long MOUNTING SCREWS, set of 2:
$ 2.50
HCP2924 Aftermarket Mikuni carb lower rack bracket long MOUNTING SCREW, 18-8 stainless steel, black-oxide coated finish, panhead phillips-drive, for end holes only on "X" models, each.
$ 1.50
HCP2924SET2 Aftermarket Mikuni carb lower rack bracket long MOUNTING SCREWS, set of 2:
$ 2.50
HCP6714 Aftermarket Mikuni carb lower rack bracket short MOUNTING SCREW, button head hex-drive, 18-8 stainless steel, bright finish, each:
$ 1.50
HCP6714SET6 Aftermarket Mikuni carb lower rack bracket short MOUNTING SCREWS, set of 6:
$ 8.50
HCP6714SET8 Aftermarket Mikuni carb lower rack bracket short MOUNTING SCREWS, set of 8:
$ 11.00
HCP6713 Aftermarket Mikuni carb lower rack bracket long MOUNTING SCREW, button head hex-drive, 18-8 stainless steel, bright finish, for end holes only on "X" models, each:
$ 1.50
HCP6713SET2 Aftermarket Mikuni carb lower rack bracket long MOUNTING SCREWS, set of 2:
$ 2.75
HCP6716 Aftermarket Mikuni carb lower rack bracket short MOUNTING SCREW, allen head hex-drive, 18-8 stainless steel, bright finish, each:
$ 1.00
HCP6716SET6 Aftermarket Mikuni carb lower rack bracket short MOUNTING SCREWS, set of 6:
$ 4.00
HCP6716SET8 Aftermarket Mikuni carb lower rack bracket short MOUNTING SCREWS, set of 8:
$ 5.00
HCP6639 Aftermarket Mikuni carb lower rack bracket long MOUNTING SCREW, allen head hex-drive, 18-8 stainless steel, bright finish, for end holes only on "X" models, each:
$ 1.00
HCP6639SET2 Aftermarket Mikuni carb lower rack bracket long MOUNTING SCREWS, set of 2:
$ 1.75
HCP6715 Aftermarket Mikuni carb lower rack bracket short MOUNTING SCREW, allen head hex-drive, black-oxide coated alloy steel, bright finish, each:
$ 1.00
HCP6715SET6 Aftermarket Mikuni carb lower rack bracket short MOUNTING SCREWS, set of 6:
$ 4.50
HCP6715SET8 Aftermarket Mikuni carb lower rack bracket short MOUNTING SCREWS, set of 8:
$ 6.00
HCP6640 Aftermarket Mikuni carb lower rack bracket long MOUNTING SCREW, allen head hex-drive, black-oxide coated alloy steel, for end holes only on "X" models, each:
$ 1.00
HCP6640SET2 Aftermarket Mikuni carb lower rack bracket long MOUNTING SCREWS, set of 2:
$ 1.50
MIKUNI CARB STARTER-ENRICHMENT CIRCUIT-CHOKE SYSTEM HARDWARE:
xx4) Aftermarket Mikuni Starter-Enrichment Circuit Arm-to-Shaft SET SCREW. These replacement screws are used to retain the starter lever "finger" bracket to the starter circuit shaft. Use 1 per carb, 4 of these screws per rack on all XJ550, XJ650 Turbo, XJ700-X, XJ750-X, and XJ900RK models. XJ1100 models use 1 per carb, and a total of 5 screws per rack.
NOTE: originally, these screws had a natural finish, and were configured as follows:
XJ550 all models used a panhead, phillips drive cone (pointed) tip set screw. This style screw is not currently available, and the HCP299 or HCP300 screws listed below are the recommended replacements.
XJ650 Turbo and XJ1100 models used a straight slot, cone (pointed) tip set screw. This style screw is similar to the HCP299 and HCP300 screws listed below, with the main difference being that original screws used a straight blade slot, while the replacement screws below employ a hex-drive.
XJ700-X and XJ750-X models used a panhead, phillips drive dog-point (blunt tip) set screw. This style screw is not currently available, although the HCP6828 screw below is very similar, with the main difference being that original screws used a phillips-drive head, while the replacement screws below employ a hex-drive.
HCP299 Aftermarket Mikuni enrichment circuit lever arm-to-shaft cone-point SET SCREW, allen-head, black oxide coated alloy steel, each:
$ 1.00
HCP299SET4 Aftermarket Mikuni enrichment circuit lever arm-to-shaft SET SCREWS, set of 4:
$ 2.50
HCP299SET5 Aftermarket Mikuni enrichment circuit lever arm-to-shaft SET SCREWS, set of 5:
$ 3.00
HCP300 Aftermarket Mikuni enrichment circuit lever arm-to-shaft cone-point SET SCREW, allen-head, 18-8 stainless steel, bright finish,each:
$ 1.25
HCP300SET4 Aftermarket Mikuni enrichment circuit lever arm-to-shaft SET SCREWS, set of 4:
$ 4.00
HCP300SET5 Aftermarket Mikuni enrichment circuit lever arm-to-shaft SET SCREWS, set of 5:
$ 4.50
HCP6828 Aftermarket Mikuni enrichment circuit lever arm-to-shaft blunt point SET SCREW, allen-head, 18-8 stainless steel, bright finish, each:
$ 1.25
HCP6828SET4 Aftermarket Mikuni enrichment circuit lever arm-to-shaft SET SCREWS, set of 4:
$ 4.00
FREE STANDARD SHIPPING {OR JUST $5.00 FOR PRIORITY MAIL} SHIPPING IN THE USA FOR ALL ORDERS OVER $100 !!!!
$7.50 STANDARD SHIPPING TO CANADA FOR ALL ORDERS OVER $100 !!!!
Paypal accepted. Worldwide shipping available. Shipping prices and insurance costs are NOT included in the prices of items unless specifically listed. Please write with your list of parts needs and I will be glad to quote your shipping costs to you.
You can either PM (Private Message) me through this website, e-mail us via the "email" button on the bottom of this post, or e-mail us directly at:
info @ xj4ever.com
PLEASE NOTE!: our e-mail address does NOT have spaces before or after the "@" symbol........the posting system on this website automatically adds blank spaces before and after that symbol as an anti-spam feature! Make sure you eliminate those blank spaces when sending us an e-mail! Our e-mail address does NOT have any blank spaces in it!!
PLEASE!: on each and every correspondence with us, please tell us what YEAR and MODEL bike you have (example: 1982 XJ650 Maxim) and what your NAME (first name, at least!) is......that information really makes life a bit easier for us, and insures a more timely and ACCURATE response from us back to you!
MORE XJ PARTS IN THE FOLLOWING POST!!
Posted: Mon Dec 15, 2008 2:17 am Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION C:
FUEL SYSTEM ITEMS: Including Airboxes, Carbs, Intakes, Fuel Tanks, Sending Units, Petcocks, Gas Caps, Tank Mounts, Etc.
-- General Fuel System Tools & Parts
FUEL SYSTEM TOOLS:
Carb Chemicals:
xx1) Fastener ANTI-SEIZE PASTE. Yeah, it's smelly and makes a slippery mess on your fingers, but this stuff is a life-saver for any true wrencher, because it prevents problems down the road. Use it on any metal fastener that does not require a "loctite" thread-locker material to be used. This means on just about every fastener that is carb, engine case, or suspension-related! (except for carb upper and lower rack-mount screws and butterfly valve screws, which do require the use of a thread-lock fluid). If you think that it might, sometime, in the future, need to come off: use anti-seize compound!
HCP1264 fastener ANTI-SEIZE PASTE, standard grade aluminum-based formula in a 1-ounce squeeze tube, for smaller jobs.
$ 2.95
HCP1265 fastener ANTI-SEIZE PASTE, standard grade aluminum-based formula in a 4-ounce tub with a brush-lid, for larger jobs.
$ 5.95
HCP9784 fastener ANTI-SEIZE PASTE, standard grade aluminum-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
$ 9.95
HCP9763 fastener ANTI-SEIZE PASTE, standard-grade copper-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
$ 9.95
HCP9764 fastener ANTI-SEIZE PASTE, premium-grade nickel-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
$ 17.95
xx2) The next most important tool: fastener THREAD LOCKER FLUIDS. Use on any fastener that you don't normally ever remove, to make sure that it stays that way. Comes in a variety of formulas, each one designed for a specific use as explained below.
HCP1266 Low Strength THREAD LOCKER FLUID, 6-ounce squeeze tube. This is a semi-permanent formula that provides moderate vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for upper and lower carb rack mount screws and the butterfly valve-to-throttle shaft retaining screws. A little bit goes a long way.......
$ 5.95
HCP1267 Semi-Permanent THREAD LOCKER FLUID, 6-ounce squeeze tube. This is semi-permanent formula that provides good vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for use with 6-20mm fasteners.
$ 5.95
HCP1268 Permanent THREAD LOCKER FLUID, 6-ounce squeeze tube. This is a high-strength formula that provides superior vibration-loosening resistance, and requires the use of heat or special tools to break loose the fastener for disassembly.
$ 5.95
HCP1269 Permanent THREAD LOCKER FLUID, 6-ounce squeeze tube. This is both a high-strength AND high-heat formula that provides superior vibration-loosening resistance, and requires the use of heat or special tools to break loose the fastener for disassembly.
$ 6.95
b4) Aftermarket 1/2 ounce tub of pure SILICONE GREASE----this is the proper product to use when installing any rubber-based o-ring or seal. Petroleum-based grease will attack rubber, resulting in the deterioration and early failure of the rubber compound. Silicone doesn't affect rubber, provides good seal lubrication, can also be used as a "glue" to hold seals in place during installation, and to aid in the re-assembly of components. Use on throttle shaft o-rings or v-seals, fuel connector pipe o-rings, petcock o-rings and seals, fork tube seals and o-rings, and as an installation "edge glue" for the carb vacuum piston diaphram assembly. 1/2 oz tub goes a long way, because just like Brylcreem, "just a little dab will do ya'!"
HCP1714 o-ring installation pure SILICONE GREASE:
$ 6.95
$ 9.95
Carb Tuning Tools:
v) IDLE MIXTURE SCREW TOOL is sized and designed for the proper removal and adjustment of the idle mixture screw, preventing the destruction of the fragile straight slot head on these screws. An exact-fit blade is recessed up into a shrouded cover that sits down over the screw, completely and properly capturing the screw head slot....this design not only eliminates stripping out the idle mixture screw slot, but also allows for very fine adjustment of the screw when fine-tuning the carbs (when using a colortune plug, etc.). Knurled top handle provides for a positive grip and 1/4-turn increments are marked for a visual indication of turns. A very neat little tool and it'll last a lifetime or two. Fits: XJ550 all, XJ650 all including Turbo, XJ700 all, XJ750 all, XJ900RK, and XJ1100 carbs.
HCP254 Idle Mixture Screw REMOVAL AND ADJUSTER TOOL, fits all Hitachi models and all Mikuni idle mixture screws.
$ 17.95
The following two tools are used only in "YICS" ("Yamaha Induction Control System") equipped engines. YICS was used on all XJ550 models, 1982-up XJ650 Maxim and XJ650 Turbo models, all XJ700 non-X models, all XJ750 models, 1983 XJ900RK, and 1982 XJ1100 models. The 1980-81 XJ650 Maxim and 650 Midnight Maxim models, as well as the 1982 XJ650 Seca models, did NOT use the YICS system. It has also been reported by some owners that some very early model 1982 XJ650 Maxim models did not use the YICS system.
YICS bikes have front lower (oil pump) covers on both sides that have a rectangular "YICS" emblem in them below the cast-in YAMAHA wording. These bikes also use a valve cover that has the word YICS cast into the top surface, while non-YICS models are blank or are cast with the name only ("YAMAHA" or "YAMAHA 5VALVE on 700-X/750-X models) on the valve cover.
c5) Yamaha YICS PORT CLEAN-OUT TOOL----the YICS chamber runs side-to-side in the back of the cylinder head, and is accessed via a 12mm bolt on either end (this is the same chamber that the HCP93 synch passage-block-off tool fits into). This chamber has four tiny passages in the top, one for each cylinder. These passages can accumulate soot and other material over time, effectively clogging or reducing their capability to pass the fuel-air mixture through them, and thus compromising their function. This YICS port probe & clean-out tool has a spear point that can punch through the toughest accumulation of carbon build-up, and has marked notches on the extension rod to indicate exactly how deep into the chamber the tool must be inserted to easily locate the passages. Convenient dowel handle allows for ease of use. A very handle tool to have around! For use on all XJ650 - XJ1100 YICS-equipped engines (not needed on XJ550 engines).
HCP1282 Aftermarket YICS chamber PORT CLEAN-OUT TOOL:
$ 14.95
vv7) Reproduction YICS PORT BLANKING TOOL---this is the tool you'll need to perform a proper carb synchronization on any YICS motor......without it, you're just wasting time. This block-off tool is used to isolate each cylinder from the others while performing a carb synch. Updated version of the factory #90890-04068-00 tool. Some people claim that this tool is NOT needed to perform a proper synch; we disagree, and so do the Yamaha engineers who designed the YICS system. Quality aluminum tool features a snap-open and shut trunnion handle design like the original. This is NOT a cheap home-made tool and has all the proper seals, dimensions, and high-temp insulators as an original factory tool. IN STOCK!
HCP93 Reproduction YICS PORT BLANKING TOOL:
$ 39.95
HCP6380 Replacement insulator SEALS SET for the HCP93 tool,
set of 3 seals.
$ 4.95
HCP1410SS Aftermarket STAINLESS STEEL WIRE-BRISTLE CLEANING BRUSH, 11.0mm diameter, perfect size for cleaning out the YICS passage in the cylinder head of all the built-up baked carbon before using the YICS tool. We recommend the use of an aggressive solvent when cleaning this passage, such as Hoppes #9 gun-cleaning fluid (available at gun shops) or similar.
$ 4.50
HCP3735 OEM cylinder head YICS passage BOLT, used on all 1981 XJ550 models, 1981 XJ750 Seca, and all XJ700 non-X engines. Fits either side. Each:
$ 4.25
HCP3733 OEM cylinder head YICS passage BOLT, used on all 1982-3 XJ550 models, 1982-3 all XJ650 and XJ750 models, XJ900RK, and XJ1100 engines. Fits either side. Each:
$ 1.75
HCP3734 OEM cylinder head YICS passage bolt WASHER, used on all XJ550 models, 1982-3 all XJ650 and XJ750 models, all XJ700 non-X, XJ900RK, and XJ1100 engines. Fits either side. Each:
$ 2.75
j2) Aftermarket Morgan CARBTUNE PRO 4-COLUMN SYNCH GAUGE TOOL.......brand new, no display box, includes all accessories and instructions. This is the one that professionals use and recommend, and is superior in design, ease of use, and accuracy versus vacuum gauges and all other versions, whether fluid-filled or otherwise. Uses damped stainless steel sliding dowel rods instead of mercury or the "blue mystery fluid", giving accurate, safe, and easy-to-read measurements. More expensive than other synch tools and worth it. Use it even once and you'll wonder how you lived without it.
NOTE: this tool is used on all XJ engines, regardless of whether it is a "YICS" engine or not.
Also, please note! you can sometimes find these same sticks selling at a discount at various places, but most of these places are offering a much older, now-discontinued Carbtune II version, rather than the latest, much-improved Carbtune PRO version that is offered here. The PRO version is much more durable, accurate, and easier to clean and service than the older version.
HCP96Q Aftermarket Morgan CARBTUNE PRO 4-COLUMN SYNCH GAUGE TOOL.
$ 114.00
j3) Aftermarket Carbtune Pro STORAGE AND TRANSPORT CASE for the above carbtune pro synch stick......a heavy duty, nicely made zippered and clasp-closure storage case to hold the gauge and all the accessories neatly and safely. You REALLY want to have this to safely store and transport the (somewhat fragile) synch gauges!
HCP1287 Aftermarket Carbtune Pro STORAGE AND TRANSPORT CASE.
$ 19.00
j5) Aftermarket Gunson COLORTUNE TUNING SPARK PLUG KIT....brand new, no display box, includes all accessories and instructions. If you really want to tune your multi-carbs to perfection, you'll have to use this unique "see-through" spark plug that allows you to view the combustion chamber flame color in real-time, thus allowing accurate (rather than guesswork) adjustments to your idle mixture screws. Use it once and you won't believe how you ever got by without it, and will pity those who don't have one of their own. Beware: you'll find that a lot of people now want to be your "friend" and have you come and tune on their bikes, once they find out you have a Colortune!
Also, please note! you can find quite a few of these plugs at a discount at various places, but most of these places are selling an older, now-discontinued "automotive" version of the Gunson colortune plug. While there are no fitment differences between the automotive and "motorcycle" versions of these plugs, just be aware that the automotive versions were designed to be used in a water-cooled engine, and thus have a significantly lower heat tolerance----and if these plugs overheat, the "clear" window either goes cloudy or just simply fractures.
The following two video presentations show a Colortune Plug in action:
www.gadgetjq.com/Vulca...e_Test.wmv
and
Please remember, though, that a Colortune is NOT used to set your carbs at anything other than idle rpm's!!
NOTE: 12mm plugs are used on all XJ550 and XJ700-X models. 14mm plugs are used on all XJ650, XJ700 non-X, XJ750, XJ900RK, and XJ1100 models. No XJ-bikes from this era used 10mm plugs!
HCP95A Aftermarket Gunson COLORTUNE TUNING SPARK PLUG KIT, for 10mm spark plugs. NOTE: NGK plugs that begin with the letter "C" are 10mm. No XJ-series bikes from this era used 10mm plugs!
$ 54.95
HCP95B Aftermarket Gunson COLORTUNE TUNING SPARK PLUG KIT, for 12mm spark plugs. NOTE: NGK plugs that begin with the letter "D" are 12mm, and are used on all XJ550 models and all XJ700 "X" model bikes.
$ 49.95
HCP95C Aftermarket Gunson COLORTUNE TUNING SPARK PLUG KIT, for 14mm spark plus. NOTE: NGK plugs that begin with the letter "B" are 14mm, and are used on all XJ650, XJ700 non-X models, all XJ750, XJ900RK, and XJ1100 models.
$ 49.95
j77) Aftermarket carb tuning and synchronization AUXILIARY FUEL TANK. This handy plastic mini-tank allows you to conveniently and safely store the small amount of fuel you'll need when operating the engine when the main fuel tank is removed....such as during synch procedures and colortuning efforts. Tank comes with hanger wire, 4' of the proper 1/4" fuel hose, and an in-line on-off valve.
HCP159 Aftermarket plastic AUXILIARY FUEL TANK, half-gallon capacity. Gravity feed design, not suitable for fuel-injected bikes, but perfect for all XJ models. XJ1100 models will have to use a fuel "T-fitting" to split the outlet hose to the two carb fuel inlet.
$ 44.95
af12) OEM and aftermarket carb fuel bowl FLOAT LEVEL GAUGES......let's face it, setting the float level heights on carbs is a real pain in the butt (and that's being as nice as I can be about it!). You normally have to take the carbs on-and-off the bike two or three times to get the settings right, rig up some special leveling fixtures, etc. etc. If you've done it before, you know what I mean. These special tools can help lessen this nightmare (but not eliminate it, sorry!).
Yamaha service manuals define the float-height be set via the "clear tube" method, whereby you instll a clear piece of tubing into the carb bowl drain outlet, open the drain screw, and then hold the tube upwards against the edge of the carb bowl and see how high up the fuel rises in the tube, and then compare this level to a specified distance below the carb bowl-carb body interface. Although this method IS a correct method of determining whether the fuel level int he bowl is correct, it's a rather cumbersome (meaning: after the fact) procedure for setting the float height.....as it invariably leads to a repetitive cycle of measure > adjust > measure > adjust > etc.......time-consuming, messy, and frustrating. A much better way is to set the float heights the way the factory did, using a pre-determined float height measurement, and then using the clear-tube measure to simply check the results.
These gauges will allow you to do just that.
HCP9798 We offer this inexpensive FLOAT HEIGHT RULER that comes with a sliding "pocket clip" (which doubles as a fixed position pointer), allowing you to duplicate your float setting measurements from one carb to the next. Ultra-thin and only a 1/4" wide, this 150mm (6") measuring stainless steel ruler has black etched rulings and is a valuable addition to your carb tool arsenal.
$ 8.95
HCP4 Professional quality sliding-arm FLOAT LEVEL GAUGE is specifically designed for measuring float heights and features a sliding arm that allows you to accurately measure the distance from the carb body base to any point on the float itself (normally to the top or bottom edge of the float, when the needle is in its "just-barely-closed" position) and then apply this exact same setting to the other carbs. A great time saver for this technically simple, but very time-consuming task.
$ 42.00
HCP1592 OEM clear-tube FUEL LEVEL TUBE GAUGE, used to check the fuel level in the bowls when the bowls are installed by attaching the end of the clear rubber tube to the float bowl drain nipple, and then holding the graduated fuel gauge up agaist the side of the fuel bowl. Black millimeter markings on the measurement tube allow you to easily determine the fuel level with respect to the bowl-to-body reference point. For use on all XJ models with fuel bowl drain nipples (all models with Hitachi carbs and XJ1100 models with Mikuni carbs).
$ 24.95
HCP4926x2 Aftermarket clear-tube FUEL LEVEL TUBE GAUGE, used to check the fuel level in the bowls when the bowls are installed by attaching the end of the clear rubber tube to the float bowl drain nipple, and then holding the graduated fuel gauge up agaist the side of the fuel bowl. Unlike the original gauge HCP1592 listed above, this is just a clear section of fuel line and does NOT have the upper tube end with any graduated markings (at all). For use on all XJ models with fuel bowl drain nipples (all models with Hitachi carbs and XJ1100 models with Mikuni carbs).
$ 3.50
Carb Rack Assembly Alignment Plate:
j77) Aftermarket carb rack ALIGNMENT PLATE. When you break the individual carbs out of the rack, one of the crucial re-assembly procedures is to make sure that all the carb bodies are in "perfect" alignment with each within the rack. This is critical, as mis-alignment of one carb body to another will result in different throttle valve opening positions between differing (adjacent) carbs that no amount of synch screw adjusting will ever remedy.
As you start installing the screws into the individual carb bodies (mounting them into the upper and lower carb rack bracket bars), the carb bodies will try to twist and "walk" from each other due to the torsional forces being applied to the screws and the precise alignement of the screw mounting holes.
Yamaha specifies the use of a flat piece of plate glass to perform this procedure.....the idea being, if you set the carb throats down against a perfectly flat surface, you can apply downward pressure onto the carb bodies to insure that the throats stay perfectly flat against the glass plate during re-assmebly and tightening of the rack bracket screws, insuring accurate carb body alignements within the assembled rack.
This flat plate of 1/2" thick clear acrylic serves this purpose, and also has a relief slot cut into the center of it to allow clearance for the thorttle cable bracket linkage or the idle speed screw head, so that those items do not interfere with the re-assembly procedure (an inconvenient issue to deal with when using plate glass). Non-slip foot pads prevents the plate from trying to slide around while you're fiddling with the screws and the carb rack. Works for all XJ-series carbs.
HCP9997 Aftermarket carb rack re-assembly ALIGNMENT PLATE.
$ 17.95
Carb Cleaning Tools:
p1) Aftermarket CARB PASSAGES CLEANING WIRES KITS: these sets of small wire tip cleaners come in a handy aluminum flip-open case, and arae essential for probing and cleaning some of the smallest internal passages within the carb bodies to push out and free up solidified fuel "gunk" and other obstructions before blasting the passages with cleaner and compressed air. The #6 and #7 size wires are the only sizes small enough to fit into the tiny jet passages and emulsion tube holes and clean them properly (without the risk of "re-sizing" the hole by mistake). NOTE: even the smallest #6 wire is too large to clean the starter jet down in the bowl! For that task, you'll need to order the correct bowl starter jet drill bits listed further below.
HCP950 Carb Passages MINI CLEANING WIRES TOOL SET, contains 13 wires (sizes #6 - 26) and a small flat file.
$ 7.95
HCP951 Carb Passages MINI-PLUS CLEANING WIRES TOOL SET. Same as the MINI set above, but contains an extra 3 (each) of the #6, #7, and #8 size wires (the smallest ones) so even if you ruin one, you'll have lots of spares (being so thin, they're very easy to break!). The miniature file---which you don't really need---is not included in this set.
$ 9.95
HCP953 Carb Passages MAN-SIZE CLEANING WIRES TOOL SET contains 22 small wire tip cleaners, sizes #6-45, in a handy aluminum flip-open case.
$ 9.95
z7) Aftermarket wire gauge BOWL STARTER JET DRILL BIT. As you will quickly discover if you ever try to clean or rebuild your Hitachi carbs, the tiny, non-removable starter jet that is stuck wa-a-a-y down at the bottom of a drilled passage in the carb bowl is next to impossible to clean. For one, did we mention that the jet opening is TINY? And did I also mention that it's stuck way down at the bottom of a small passageway, and basically unreachable? AND THEREFORE, NO ONE EVER REALLY EVEN ATTEMPTS TO CLEAN IT OUT? And that a clogged starter jet not only means trouble starting and idling, but that starter circuit is actually also involved in idle and off-idle performance? Well, how do you actually clean it? Even the tiniest cleaning rod in our carb passage cleaning wire sets (above) aren't small enough to fit through this starter jet (it is THE smallest jet-passage in the entire carb)...
Well, here's how you clean it: with this tiny drill bit. Just big enough to get through the jet, but not big enough to ENLARGE the jet (that's a huge no-no), this high-speed steel bit can be gently rotated (but never "pushed", as it will break) through the toughest of crud. This is the only way to properly clean these starter jets.
NOTE: this is a TINY drill bit, and will not chuck into a standard drill chuck. You have to use a mini pin-vise attachment or do it carefully by hand...... ALSO: this drill bit is a mere 1-1/2" long, and as such, will disappear below the top "plane" of the bowl as it goes down into the jet. You will have to use a pair of very slim needle-nose pliers to grip the tip of this drill bit and rotate it!
HCP2296 Aftermarket BOWL STARTER JET DRILL BIT, for Hitachi carb bowls used on all XJ650 (except Turbo) models, all XJ700 non-X models, and all XJ750 models.
$ 11.95
HCP2293 Aftermarket BOWL STARTER JET DRILL BIT, for Mikuni carb bowls used on all XJ550 models, and all XJ700-X models.
$ 11.95
P.S. how do you know when your starter jet is really, truly, zestfully clean? One of two ways:
a) shine a strong penlight or mini flashlight into the bottom of the bowl, where this jet passage "intake" is located. Look through the top of the bowl down into the jet passage "outflow" passage (this is the passage that the brass suction tube in the bottom of the carb body actually fits down into). Focus your eye carefully on the jet opening and make sure it's clean. P.S. it helps to do all this while in a darkened area....
www.xjbikes.com/Forums...rt=15.html
b) put the spray tip (you may have to gently shape the end of it to a fine point) of a can of carb or brake cleaner into the intake opening of the starter jet and let rip a spray. A STEADY, FINE, POWERFUL STREAM OF FLUID WILL COME OUT OF THE OUTFLOW PASSAGE ON THE TOP OF THE CARB BOWL IF THE JET IS PERFECTLY CLEAN AND OPEN. I mean this stream will absolutely spit out a good 5-10 feet. If the stream isn't powerful and laser-like precise coming out of the jet, then the jet isn't zestfully clean.....
BTW, when using the spray-stream method of checking the jet, don't even THINK of putting your eye or face anywhere even NEAR the jet outflow path, unless you like a painful and potentially serious trip to the emergency room.
ft2) Aftermarket twisted-stem WIRE-BRISTLE CLEANING BRUSHES. The greatest tool ever invented for cleaning bored and threaded holes, such as in carb bodies, float bowls, even master cylinder piston bores. Available in either 18-8 stainless steel or brass, these brushes not only help make the job of cleaning parts so much easier, but also insure that threaded passages are clean, clean, clean and less likely to strip or deform when fasteners are inserted once again. All brushes have a "finger-loop" in the end to make twisting action easier. Stainless brushes will last longer and can clean more aggressively, so be gentle when using them on aluminum carb bodies and bowls. Brass brushes are gentle on soft metals like carb bodies, but require more effort to produce a cleaner surface and wear out more quickly.
Stainless Steel Wire Bristle Brushes:
HCP1288SS Aftermarket 18-8 STAINLESS STEEL WIRE BRISTLE BRUSH, 3mm diameter, great for the fuel/air passage galley in the carb body and the carb bowl starter jet passage.
$ 3.00
HCP1406SS Aftermarket 18-8 STAINLESS STEEL WIRE BRISTLE BRUSH, 4.5mm diameter, great for the emulsion tube inner passage in the carb body and the pilot fuel jet passage.
$ 3.20
HCP1407SS Aftermarket 18-8 STAINLESS STEEL WIRE BRISTLE BRUSH, 5.5mm diameter, great for the idle mixture screw port, the air jet passages, and the emulsion tube bore in the carb body, and the carb bowl drain screw passage.
$ 3.50
HCP1408SS Aftermarket 18-8 STAINLESS STEEL WIRE BRISTLE BRUSH, 8.0mm diameter, great for the throttle shaft bore, the emulsion tube bore, and the air/fuel pipe bore in the carb body.
$ 4.50
HCP1409SS Aftermarket 18-8 STAINLESS STEEL WIRE BRISTLE BRUSH, 9.5mm diameter, great for the float valve seat threaded bore in the carb body.
$ 3.50
HCP1410SS Aftermarket 18-8 STAINLESS STEEL WIRE BRISTLE BRUSH, 11.0mm diameter, great for the YICS passage in the cylinder head, and the starter/enrichment circuit seat bore in the carb body.
$ 4.50
HCP2762SS Aftermarket 18-8 STAINLESS STEEL WIRE BRISTLE BRUSH, 12.5mm diameter, great for the YICS passage in the cylinder head, and the starter/enrichment circuit seat bore in the carb body, and can also be used for the master cylinder bore in XJ550 master cylinders.
$ 4.50
HCP2912SS Aftermarket 18-8 STAINLESS STEEL WIRE BRISTLE BRUSH, 14.5mm diameter, great for the YICS passage in the cylinder head, and can also be used for the master cylinder bore in XJ550, XJ650 Maxim, and XJ1100 master cylinders.
$ 5.00
HCP2764SS Aftermarket 18-8 STAINLESS STEEL WIRE BRISTLE BRUSH, 15.8mm diameter, great for the fuel/air passage bore in the carb body, and the master cylinder bore in XJ650 Seca and Turbo, XJ700, XJ750, and XJ900 master cylinders.
$ 5.00
HCP2766SS Aftermarket 18-8 STAINLESS STEEL WIRE BRISTLE BRUSH, 19.0mm diameter, not really useful for anything carb related, but a really big, beefy, meaty, bouncy brush that looks really impressive in your toolbox!
$ 5.00
HCPSS-SET Complete set of nine different 18-8 STAINLESS STEEL WIRE BRISTLE BRUSH (all sizes except the 19.0mm), gives you all the sizes needed to clean your carbs, YICS port, and master cylinder bore (when that time comes).
$ 32.00
Brass-Wire Bristle Brushes:
HCP1288BR Aftermarket BRASS WIRE BRISTLE BRUSH, 3mm diameter, great for the fuel/air passage galley in the carb body and the carb bowl starter jet passage.
$ 3.00
HCP1406BR Aftermarket BRASS WIRE BRISTLE BRUSH, 4.5mm diameter, great for the emulsion tube inner passage in the carb body and the pilot fuel jet passage.
$ 3.20
HCP1407BR Aftermarket BRASS WIRE BRISTLE BRUSH, 5.5mm diameter, great for the idle mixture screw port, the air jet passages, and the emulsion tube bore in the carb body, and the carb bowl drain screw passage.
$ 3.50
HCP1408BR Aftermarket BRASS WIRE BRISTLE BRUSH, 8.0mm diameter, great for the throttle shaft bore, the emulsion tube bore, and the air/fuel pipe bore in the carb body.
$ 4.50
HCP1409BR Aftermarket BRASS WIRE BRISTLE BRUSH, 9.5mm diameter, great for the float valve seat threaded bore in the carb body.
$ 3.50
HCP1410BR Aftermarket BRASS WIRE BRISTLE BRUSH, 11.0mm diameter, great for the YICS passage in the cylinder head, and the starter/enrichment circuit seat bore in the carb body.
$ 4.50
HCP2762BR Aftermarket BRASS WIRE BRISTLE BRUSH, 12.5mm diameter, great for the YICS passage in the cylinder head, and the starter/enrichment circuit seat bore in the carb body, and can also be used for the master cylinder bore in XJ550 master cylinders.
$ 4.50
HCP2912BR Aftermarket BRASS WIRE BRISTLE BRUSH, 14.5mm diameter, great for the YICS passage in the cylinder head, and can also be used for the master cylinder bore in XJ550, XJ650 Maxim, and XJ1100 master cylinders.
$ 5.00
HCP2764BR Aftermarket BRASS WIRE BRISTLE BRUSH, 15.8mm diameter, great for the fuel/air passage bore in the carb body, and the master cylinder bore in XJ650 Seca and Turbo, XJ700, XJ750, and XJ900 master cylinders.
$ 5.00
HCP2766BR Aftermarket BRASS WIRE BRISTLE BRUSH, 19.0mm diameter, not really useful for anything carb related, but a really big, beefy, meaty, bouncy brush that looks really impressive in your toolbox!
$ 5.00
HCPBR-SET Complete set of nine different BRASS WIRE BRISTLE BRUSHES (all sizes except the 19.0mm), gives you all the sizes needed to clean your carbs, YICS port, and master cylinder bore (when that time comes).
$ 30.00
ft2) Aftermarket plastic-handled CLEANING TOOTHBRUSHES are great for general cleaning and grunge removal, very handy to keep a few of these around.
HCP9971 Aftermarket nylon-bristle CLEANING TOOTHBRUSH.
$ 1.00
HCP9970 Aftermarket brass-wire CLEANING TOOTHBRUSH.
$ 1.00
HCP9969 Aftermarket stainless steel-wire CLEANING TOOTHBRUSH.
$ 1.00
fh14) Aftermarket VACUUM PISTON BORE HONE. In order to refinish the vacuum piston bore correctly, you'll need to restore and refinish the bore with a small-bore hone. This adjustable, 3-shoe cylinder bore hone adjusts all the way down in size to 7/8" (and all the way up to 2" in diameter, so it can also be used for your brake calipers, too!) and come with a set of 240-grit (medium) stones.
Replacement shoe sets are available in both medium (240) and fine-grit (400) finishes. IT IS RECOMMENDED THAT YOU PURCHASE A SET OF 400-GRIT STONES WHEN YOU BUY THE HONE, as you really need the super-fine stones to put the proper finish on this piston bore: you can first "clean-up" the bore with the provided 240-grit stones, and then change the shoes to the "polishing" 400-grit stones for a truly professional job.
NOTE: hones have a standard 1/4" round shank and can be operated manually or attached to a very low speed (less than 100 rpms) drill. ALWAYS KEEP THE HONE MOVING WITHIN THE BORE IF OPERATING WITH A DRILL, AND KEEP THE STONES FULLY LUBRICATED WHEN IN USE! (brake fluid is a great lubricant).
Having the carb piston bore fully polished is an incredibly important task when rebuilding a set of carbs, as any restriction to the free and almost friction-less movement of the vacuum piston will create a variety of performance-related problems. You can review this issue (the vacuum piston "CLUNK TEST") at:
www.xjbikes.com/Forums...=1640.html
and see a nice video of a clunking piston at:
xjmadness.myphotoalbum...clunk_test
You can further polish the bores with 600-, 800-, 1000-, 1200-, and 1500-grit FINISHING PAPERS listed below for a "blueprinted" mirror-finish. You can cut the finishing paper(s) into approximately 2" tall x 3-1/2" rectangular strips and "wrap" the finishing paper around the hone shoes to make the final polishing steps simple and consistent.
NOTE: do not EVER attempt to polish away any discoloration on the vacuum pistons! The pistons are actually aluminum with a brass-like anondized coating. A brief and gentle "wipe" with 1500- or 2000-grit finsihing paper is all that is needed on the pistons themselves.
HCP9955 Aftermarket 3-shoe CYLINDER HONE, comes with a set of 240-grit stones. Works on all XJ-series front or rear brake calipers.
$ 17.95
HCP9957 Aftermarket replacement set of three HONE SHOES, 240-grit. Includes a set of retaining cotter pins.
$ 5.95
HCP9958 Aftermarket replacement set of three HONE SHOES, 400-grit. Includes a set of retaining cotter pins.
$ 5.95
cps2) Aftermarket high-quality WET-OR-DRY FINISHING SHEETS. Since these don't contain "sand", we really can't call them "sandpaper", but you get the idea. A large assortment of ultra-fine finishing paper is just the trick to polish the vacuum pistons and piston bores in your carbs, or master cylinder and brake caliper bores, ridding them of any surface oxidation and minor imperfections that will create interference or friction and prevent the pistons from moving freely---causing all sorts of high-idle (and other problems) in your carbs, or dragging brakes in your calipers. Our recommendation is to start with the 400- or 600-grit paper and move up 200 grit at a time until you get the bores micro-polished to an incredible smooth finish. One 9.5" x 11" sheet of each size will be enough to do four carbs or one pair of calipers; use two sheets of the 5-1/2" x 11" super-fine grit paper.
Of course, this premium finishing paper is just the thing you'll need for prepping any painted surface for painting,
HCP8594 Aftermarket premium grade 400-grit FINISHING PAPER, single sheet, 9.5" x 11". Each:
$ 1.95
HCP8594SET10 Aftermarket premium grade 400-grit FINISHING PAPER, single sheet, 9.5" x 11". Set of 10 sheets:
$ 14.95
HCP8596 Aftermarket premium grade 600-grit FINISHING PAPER, single sheet, 9.5" x 11". Each:
$ 1.95
HCP8596SET10 Aftermarket premium grade 600-grit FINISHING PAPER, single sheet, 9.5" x 11". Set of 10 sheets:
$ 14.95
HCP8597 Aftermarket premium grade 800-grit FINISHING PAPER, single sheet, 9.5" x 11". Each:
$ 1.95
HCP8597SET10 Aftermarket premium grade 800-grit FINISHING PAPER, single sheet, 9.5" x 11". Set of 10 sheets:
$ 14.95
HCP8598 Aftermarket premium grade 1000-grit FINISHING PAPER, single sheet, 5.5" x 11". Each:
$ 1.50
HCP8598SET10 Aftermarket premium grade 1000-grit FINISHING PAPER, single sheet, 5.5" x 11". Set of 10 sheets:
$ 10.95
HCP8599 Aftermarket premium grade 1200-grit FINISHING PAPER, single sheet, 5.5" x 11". Each:
$ 1.50
HCP8599SET10 Aftermarket premium grade 1200-grit FINISHING PAPER, single sheet, 5.5" x 11". Set of 10 sheets:
$ 10.95
HCP8600 Aftermarket premium grade 1500-grit FINISHING PAPER, single sheet, 5.5" x 11". Each:
$ 1.50
HCP8600SET10 Aftermarket premium grade 1500-grit FINISHING PAPER, single sheet, 5.5" x 11". Set of 10 sheets:
$ 10.95
HCP8601 Aftermarket premium grade 2000-grit FINISHING PAPER, single sheet, 5.5" x 11". Each:
$ 1.50
HCP8601SET10 Aftermarket premium grade 2000-grit FINISHING PAPER, single sheet, 5.5" x 11". Set of 10 sheets:
$ 10.95
HCPSANDSET1 Your choice, mix-and-match, any 5 full-size sheets of 400-800 grit paper grades listed above.
$ 8.75
HCPSANDSET2 Your choice, mix-and-match, any 5 half-size sheets of 1000-2000 grit paper grades listed above.
$ 6.50
Other Carb Tools:
mt1) Almost every screw on these bikes are "JIS" design screws, JIS standing for Japanese Industrial Standards, and both the depth and design on the phillips-head "slot" is different than typical US slots. In a nutshell, JIS screws (which can be easily identified by the small punched single "dot" on the screw head, in between two of the screw slots) have both deeper and "squarer" slots and thus can hold more torque than their rest-of-the-world counterparts. They also require a JIS screwdriver to take full advantage of, and to prevent rounding out the slots as typical phillips-slot screwdrivers will do. The more "rounded" edges of a standard phillips-head screwdriver cannot exert as much torque on the screw head (by design, actually) and will "cam-out" of the slots, taking some of the slot material with it unfortunately!
So it might be a good idea to also invest in a set of quality JIS screwdrivers, trust me, they make a difference (yes, they can be used on standard phillips head screws, too):
HCP5904 Aftermarket JIS-standards SCREWDRIVER SET. Japanese phillips drive screws have sharper corners than regular phillips screwdrivers so they won't turn out under heavy torque. In order to take advantage of this feature, and to avoid stripping out the JIS screw heads by using US-standard phillips screwdrivers, it's a good idea to invest in a set of quality JIS-standard screwdrivers. This set of 4 contains one each of #1, #2, #3, and #4 sized-tip screwdrivers, and this range of sizes will handle everything down to an M2 sized screw (that's tiny, smaller than the size of the petcock faceplate mounting screws) all the way up to screws bigger than anything I've seen used on these bikes. They all feature sturdy plastic handles, chrome plated steel shafts, and come in a handy vinyl storage pouch.
$ 37.95
Individual JIS Screwdrivers:
The #2 and #3 fit the most commonly used size screws on the carbs, gauge clusters, etc.
HCP5900 Aftermarket size #1 JIS-standards SCREWDRIVER, for m2-m4 sized screws.
$ 9.95
HCP5901 Aftermarket size #2 JIS-standards SCREWDRIVER, for m3-m5 sized screws.
$ 11.95
HCP5902 Aftermarket size #3 JIS-standards SCREWDRIVER, for m6-m8 sized screws.
$ 13.95
HCP5903 Aftermarket size #3 JIS-standards SCREWDRIVER, for m8-up sized screws.
$ 16.95
v) Aftermarket small parts TWEEZER. These 5" long, nickel-plated jewelers tweezers are small enough to reach into tight passages and have pointed tips to grab items easily and securely.
HCP1413 Aftermarket small parts TWEEZER.
$ 5.00
u) Aftermarket o-ring and seal PICK TOOL SET. A very handy set of 4 different o-ring removal - dental-pick set, in a variety of pick angles and styles, all in a handy plastic storage pouch. The HCP1411 picks are a high-quality, professional use style that feature individual pick shafts that interchange into a 5" long, knurled, easy-grip handle, and are small enough to fit easily into the tiny idle mixture screw bores and other such passages. The HC9974 style feature four different individual picks, each secured into their own impact-resistant, sure-grip plastic handle.
HCP1411 Aftermarket set of 4 o-ring and seal PICKS.
$ 14.95
HCP9974 Aftermarket set of 4 o-ring and seal PICKS, plastic handles, good inexpensive set.
$ 7.95
vv2) Aftermarket small parts NEEDLE FILES SET. This set of 12 miniature swiss files allows you to easily get into those tight spots with precise control. A variety of files----round, flat, triangle---all have easy-grip round knurled handles. Each file is approximately, 6" long. Works great for knocking the peening off the back of the original Mikuni throttle shaft screws before you attempt to remove them.
HCP9802 Aftermarket small parts NEEDLE FILES SET.
$ 14.95
c9) Hitachi & Mikuni carbs THREAD CHASER AND CLEAN-UP TAPS. The soft aluminum bodies of the carbs can take a severe beating over the years, especially as it concerns their threaded holes. Steel is harder than aluminum, so you know what's going to distort, deform, or strip first...the threaded bore holes. The following professional quality tool-steel metric cutting taps will allow you to either "clean-up" or re-thread distorted or stripped threads in all metals, soft (aluminum) to hard (steel). THE TINY VERY FINE THREADS OF THE IDLE MIXTURE SCREW PORT ARE ESPECIALLY PRONE TO DAMAGE AND SHOULD BE "CLEANED" UP WITH A PASS OF A THREADING TAP.
HCP2398 THREAD CHASER AND CLEAN-UP TAP, made from a high-speed uncoated steel. For use on all Hitachi idle mixture screw ports, for models using ultra-fine threaded idle mixture screws. NOTE: these threaded holes almost always need cleaning or re-tapping.
$ 33.00
HCP6335 THREAD CHASER AND CLEAN-UP TAP, made from a high-speed uncoated steel. For use on all Hitachi idle mixture screw ports, for models using coarse threaded idle mixture screws, and on all Mikuni carb bowl fuel drain screw ports. NOTE: these threaded holes almost always need cleaning or re-tapping.
$ 24.00
HCP2396 THREAD CHASER AND CLEAN-UP TAP, made from a high-speed titanium nitride coated steel. For the following holes:
- Hitachi air jet cover plate hold-down screw hole
- Hitachi carb chrome "hat" hold-down holes
- XJ550 and XJ650 gas tank emblem screw holes.
- Mikuni XJ550 carb bowl-to-body
NOTE: the carb hat threaded holes almost always need cleaning or re-tapping.
$ 20.00
HCP2397 THREAD CHASER AND CLEAN-UP TAP, made from a high-speed titanium nitride coated steel. For the following holes:
- Hitachi upper rack mount screw holes
- Hitachi float bowl mount holes in carb body
- Hitachi pilot fuel jet hole in carb body
- All models: gas cap mounting screw hole in all XJ-series gas tanks
- Mikuni 550 carb hat
- Mikuni 550 carb choke bracket clamp
- Mikuni 550 upper rack mounts
- Mikuni 550 lower rack idle thumb screw bracket to lower rack bar
NOTE: because of the large size of these threads, many of these threaded holes rarely need cleaning or re-tapping....except for the gas tank cap mounting hole, which almost always needs cleaning or tapping (be careful about this when buying a used gas tank!).
$ 13.00
HCP2399 THREAD CHASER AND CLEAN-UP TAP, made from a high-speed titanium nitride coated steel. For the following holes:
- Hitachi HSC32 air compensator jet holes
- Hitachi lower carb rack mount screw holes
- Hitachi pilot and main air jets port holes (in carb throat, below vacuum piston)
- Hitachi carb bowl drain screw hole
- All models: gas tank mounting holes for the petcock
- All models: gas tank fuel sending unit mounting holes
- Mikuni XJ550 lower carb rack bracket screw holes
NOTE: because of the large size of these threads, many of these threaded holes rarely need cleaning or re-tapping....except for the carb bowl drain screw holes, especially if the drain screw was "frozen"; and the gas tank petcock and sending unit mounting holes, which almost always needs cleaning or tapping (be careful about this when buying a used gas tank!).
$ 20.00
HCP2400 THREAD CHASER AND CLEAN-UP TAP, made from a high-speed titanium nitride coated steel. For the following holes:
- float valve needle seat screw hole.
NOTE: because of the large size of these threads, and the fact that the seat is made of brass, these threaded holes rarely need cleaning or re-tapping.
$ 20.00
HCP2401 THREAD CHASER AND CLEAN-UP TAP, made from a high-speed titanium nitride coated steel. For the following holes:
- starter enrichment circuit bore hole.
$ 33.00
FINALLY: always use a proper thread-cutting oil or lubricant before using thread taps! Thin motor oils work fine when merely doing a "clean-up" thread chase; real cutting fluid should be obtained if a threaded bore needs to be truly cut.
info @ xj4ever.com
_________________ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
chacal Supporting Vendor
Joined: Aug 01, 2006 Posts: 4845 Location: At My Computer
Posted: Mon Dec 15, 2008 2:36 am Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION C:
FUEL SYSTEM ITEMS:
--Airboxes, Air Filters, Rubber Boots, & Parts
AIRBOX PARTS:
HCP4176 OEM airbox MOUNTING BOLT, secures the airbox to the frame. Fits all the following models and locations, each:
$ 1.75
XJ550 all models (use 3, all positions)
XJ650 all models (except Turbo) (use 1, top center)
XJ700 all models (use 2, all positions)
XJ750 all models (use 1, top center)
XJ900RK models (use 3, all positions)
HCP2533 OEM airbox MOUNTING BOLT, secures the airbox to the frame. Fits all XJ650 models (except Turbo) and all XJ750 models on the left side of the airbox, use 1 per box.
$ 1.00
HCP315 OEM airbox LOCK WASHER, for use with the HCP9949 bolt above. Fits all XJ650 models (except Turbo) and all XJ750 models on the left side of the airbox, use 1 per box.
$ 0.95
HCP2174 OEM airbox FLAT WASHER, for use with the HCP9949 bolt above. Fits all XJ650 models (except Turbo) and all XJ750 models on the left side of the airbox, use 1 per box.
$ 1.50
HCP4175 OEM airbox CAPTURED NUT, use with the HCP9949 bolt above. Fits all XJ650 models (except Turbo) and all XJ750 models on the left side of the airbox, use 1 per box.
$ 5.50
HCP848 OEM airbox side end covers RETAINING SCREW, secures the chrome end cap covers to the airbox. Fits all XJ650 Maxim and Midnight Maxim models, use 2 per cover, each:
$ 1.75
HCP4168 OEM airbox side end covers RETAINING SCREW, secures the end cap covers to the airbox. Fits all XJ700 models, use 2 per cover, each:
$ 1.95
HCP4167 OEM airbox side end covers RETAINING SCREW, secures the end cap covers to the airbox. Fits all XJ750 models, use 3 per cover, each:
$ 0.95
HCP3625 OEM airbox side end covers retaining screw FLAT WASHER. Fits all XJ700 models, use 2 per cover, each:
$ 3.50
HCP2512 OEM airbox side end covers retaining screw FLAT WASHER. Fits 1983 XJ750 Maxim and Midnight Maxim models, and all XJ750 Seca models, use 3 per cover, each:
$ 0.50
HCP1949 OEM rectangular rubber AIRBOX CUSHION, use 2 per side on all XJ550 Seca models, attaches to the frame tabs on the rear upper, outer sides of the airbox, and cushions the airbox against vibrations. Each:
$ 2.25
HCP4147 OEM airbox filter black plastic LID, fits all XJ900RK models.
$ 19.95
HCP4149 OEM airbox filter lid FOAM SEAL, attaches to the bottom of the airbox filter lid and forms an air-tight seal to the airbox. Fits all XJ700 and XJ900RK models.
$ 5.50
HCP4172 OEM airbox filter lid RETAINING SCREW, secures the filter lid to the airbox. Fits all XJ550 models, use 4 per lid, each:
$ 0.95
HCP314 OEM airbox filter lid RETAINING SCREW, secures the filter lid to the airbox. Fits all XJ650 (except Turbo) and all XJ750 models, use 3 per lid, each:
$ 1.50
HCP4173 OEM airbox filter lid RETAINING SCREW, secures the filter lid to the airbox. Fits all XJ700 models, use 3 per lid, each:
$ 1.25
HCP2152 OEM airbox filter lid retaining screw FLAT WASHER, secures the filter lid to the airbox. Fits all XJ550 models, use 4 per lid, each:
$ 0.75
HCP2173 OEM airbox filter lid retaining screw FLAT WASHER, secures the filter lid to the airbox. Fits all XJ650 (except Turbo) and all XJ750 models, use 3 per lid, each:
$ 1.00
HCP306 OEM airbox filter lid retaining screw FLAT WASHER, secures the filter lid to the airbox. Fits all XJ700 models, use 3 per lid, each:
$ 0.50
AIR FILTER ELEMENTS:
af1) OEM and aftermarket stock PLEATED PAPER AIR FILTER ELEMENT. Original factory and reproduction air filter elements lets your engine breathe all the good, clean air it deserves. Dirty, oil or fuel soaked elements dramatically reduce the flow of air into the engine, thus resulting in a very rich fuel mixture to the carbs. Aftermarket stock type elements look, fit, and perform just like the factory filters, although some versions may have molded plastic end cases rather than the thin stamped sheetmetal caps as on OEM filters.
HCP689 OEM pleated-paper stock AIR FILTER, fits all XJ550 models.
$ 33.00
HCP1218 Aftermarket pleated-paper stock style AIR FILTER, fits all XJ550 models.
$ 17.95
HCP690 OEM pleated-paper stock AIR FILTER, fits all XJ650 (except Turbo) and all XJ750 models.
$ 36.00
HCP1219 Aftermarket pleated-paper stock style AIR FILTER, fits all XJ650 (except Turbo) and all XJ750 models.
$ 17.95
HCP691 OEM pleated-paper stock AIR FILTER, fits all XJ650 Turbo models.
$ 34.00
HCP692 OEM pleated-paper stock AIR FILTER, fits all XJ700 models.
$ 47.00
HCP693 OEM pleated-paper stock AIR FILTER, fits all XJ900RK models.
$ 26.00
HCP1222 Aftermarket pleated-paper stock style AIR FILTER, fits all XJ900RK models.
$ 15.95
HCP694 OEM pleated-paper stock AIR FILTER, fits all XJ1100 models.
$ 34.00
af2) Aftermarket K&N high-flow, re-usable HIGH-PERFORMANCE AIR FILTER ELEMENT. Made from 4-6 layers of a tough cotton gauze material bonded between aluminum retainer screens, K&N air filters flow more air than stock pleated paper filters, and can be cleaned, re-oiled, and re-used almost indefinitely, while also fitting inside your stock airbox. Each filter contains two 15ml tubes of filter oil and cleaning/re-oiling instructions. Spray cans of re-oiling fluid and filter cleaner are also available below. You normally DO have to re-jet your carbs when replacing a stock paper element with a K&N filter, but individual situations will vary. Always check your plug insulator colors after installing any intake or exhaust modifications to insure proper mixture conditions and settings!
HCP1212 Aftermarket K&N HIGH FLOW AIR FILTER, for all XJ550 models:
$ 43.00
NOTE: on the following two K&N filters----for the XJ650 (except Turbo) and XJ750 models---we offer two different size K&N filters:
a) the "standard" K&N filter designated for these models, part HCP1213. This filter is tiny compared to the size of the stock Yamaha paper filter element and airbox for these models....about 40% of the original size, at most. We're not really sure why K&N specifies such a small filter for these models, but they do!
b) an "oem-sized" Super K&N filter, part HCP6478. This is actually a larger K&N filter (which is the same size and shape as the stock Yamaha paper filter) that has been modified to properly fit into the stock 650/750 airbox. This filter will give you the absolute maximum airflow possible while still using a stock filtered airbox intake system.
HCP1213 Aftermarket K&N HIGH FLOW AIR FILTER, for all XJ650 (except Turbo) and all 1981-83 XJ750 models, small size.
$ 40.00
HCP6478 Aftermarket K&N HIGH FLOW AIR FILTER, for all XJ650 (except Turbo) and all 1981-83 XJ750 models, oem size.
$ 57.00
HCP5786 Aftermarket K&N HIGH FLOW AIR FILTER, for all 1985-86 XJ700 and XJ750-X models:
$ 40.00
HCP5740 Aftermarket K&N HIGH FLOW AIR FILTER, for all 1983 XJ900RK Seca models:
$ 42.00
af2) Aftermarket UNI re-usable FOAM AIR FILTER ELEMENT. Made from an open-cell polyurethane foam material, these filters flow more air than stock pleated paper filters, can be cleaned, re-oiled, and re-used almost indefinitely, and fit inside your stock airbox. Spray cans of re-oiling fluid and filter cleaner are also available below. As contrasted with K&N filters, you normally will NOT have to re-jet your carbs when replacing a stock paper element with a UNI foam filter, but individual situations will vary. Always check your plug insulator colors after installing any intake or exhaust modifications to insure proper mixture conditions and settings!
HCP6474 Aftermarket UNI washable foam HIGH FLOW AIR FILTER, for all XJ550 models:
$ 27.00
HCP6475 Aftermarket UNI washable foam HIGH FLOW AIR FILTER, for all XJ650 (except Turbo) and all 1981-83 XJ750 model:
$ 27.00
HCP6476 Aftermarket UNI washable foam HIGH FLOW AIR FILTER, for all 1985-86 XJ700 and XJ750-X models:
$ 27.00
HIGH-FLOW POD AIR FILTERS:
NOTE: although free-flow air filters sound like a great idea at first glance, just be aware that increasing the amount of airflow through an engine is going to cause you to spend quite a bit of "trial and error" time in re-jetting your carbs to get the engine to perform correctly. And by "quite a bit", we mean A LOT OF TIME.
In addition, there are a few other drawbacks to pod air filters: they are susceptible to odd wind conditions. Crosswinds, or even the normal airflow around your engine can disturb the airflow going into the carbs. Some bikes don't have the problem, other bikes have lots of problems with this issue. And one other significant consideration is rain----if you ride in rainy weather, the water can soak your pod filter elements and leave you on the side of the road!
af32) Aftermarket K&N brand high-flow, re-usable HIGH PERFORMANCE POD AIR FILTER ELEMENTS. Made from 4-6 layers of a tough cotton gauze material bonded between aluminum retainer screens, K&N individual "pod" air filters flow much more air than almost any other style air filter or media available, and can be cleaned, re-oiled, and re-used almost indefinitely. Each set of 4 pod filters comes with a tube of filter oil and cleaning/re-oiling instructions. Spray cans of re-oiling fluid and filter cleaner are also available below. You absolutely will have to re-jet your carbs when replacing a stock paper element with pod filters! Always check your plug insulator colors after installing any intake or exhaust modifications to insure proper mixture conditions and settings!
HCP1665 Aftermarket K&N brand high-flow, re-usable HIGH PERFORMANCE POD AIR FILTER ELEMENTS. with polished chrome end caps. Fits all XJ550, XJ650 (except Turbo), XJ700 non-X, and 1981-83 XJ750 models. Will also fit XJ700-X and XJ750-X models very tightly (those models can use either this set or the larger HCP1666 pod filter set listed below). Complete set of 4 pods:
$ 124.00
HCP1666 Aftermarket K&N brand high-flow, re-usable HIGH PERFORMANCE POD AIR FILTER ELEMENTS. with polished chrome end caps. Fits all XJ700-X and XJ750-X models, XJ900RK, and XJ1100 models (XJ700-X and XJ750-X models can use either this set or the smaller HCP1665 pod filter set listed above). Complete set of 4 pods:
$ 124.00
af34) Aftermarket UNI brand high-flow, re-usable FOAM HIGH PERFORMANCE POD AIR FILTER ELEMENTS. Made from a special high density open-cell polyurethane foam material, UNI filters feature a higher air flow rate than stock paper filters, and can be cleaned, re-oiled, and re-used almost indefinitely. Each set of 2 pod filters comes with cleaning/re-oiling instructions. Spray cans of re-oiling fluid and filter cleaner are also available below. You absolutely will have to re-jet your carbs when replacing a stock paper element with pod filters! Always check your plug insulator colors after installing any intake or exhaust modifications to insure proper mixture conditions and settings!
HCP7547 Aftermarket UNI brand high-flow, re-usable FOAM HIGH PERFORMANCE POD AIR FILTER ELEMENTS.with polished chrome end caps. Fits all XJ550 (tightly; the top chrome caps will rub against each other when installed), all XJ650 (except Turbo), all XJ700 non-X, and all XJ750 models. One set of 2 pods:
$ 37.95
HCP7547SET2 Aftermarket UNI brand high-flow, re-usable FOAM HIGH PERFORMANCE POD AIR FILTER ELEMENTS.with polished chrome end caps. Two sets of 2 pods each does one complete carb rack:
$ 72.00
HCP6510 Aftermarket UNI brand high-flow, re-usable FOAM HIGH PERFORMANCE POD AIR FILTER ELEMENTS.with polished chrome end caps. Fits all XJ900RK Seca and XJ1100 models. One set of 2 pods:
$ 37.95
HCP6510SET2 Aftermarket UNI brand high-flow, re-usable FOAM HIGH PERFORMANCE POD AIR FILTER ELEMENTS.with polished chrome end caps. Two sets of 2 pods each does one complete carb rack:
$ 72.00
af33) Aftermarket Emgo brand high-flow HIGH PERFORMANCE POD AIR FILTER ELEMENTS. Made with a tough wire-mesh outer screen over a paper filter material, Emgo individual "pod" air filters flow much more air than the stock air filter/airbox units. Short, tapered design features chrome lids and bases. You absolutely will have to re-jet your carbs when replacing a stock paper element with these pod filters! Always check your plug insulator colors after installing any intake or exhaust modifications to insure proper mixture conditions and settings!
NOTE1: Emgo filters do not appear to be washable, so once they get dirty, you must replace them. Their "filtering" ability is marginal at best.
NOTE2: Emgo filters will not fit XJ550 models, as the Mikuni carbs used on these models have such a small carb throat center-to-center spacing that the wide base flanges on Emgo filters will interfere with each other.
HCP1738 Aftermarket Emgo brand high-flow HIGH PERFORMANCE POD AIR FILTER ELEMENTS. fits all XJ650, XJ700, and XJ750 models with HITACHI carbs and all XJ700-X models with the MIKUNI carbs. One filter does one carb. Each:
$ 9.50
HCP1738SET4 Aftermarket Emgo brand high-flow HIGH PERFORMANCE POD AIR FILTER ELEMENTS. fits all XJ650, XJ700, and XJ750 models with HITACHI carbs and all XJ700-X models with the MIKUNI carbs. One filter does one carb. Set of 4:
$ 29.50
HCP5739 Aftermarket Emgo brand high-flow HIGH PERFORMANCE POD AIR FILTER ELEMENTS. fits all XJ900 and XJ1100 models with the MIKUNI carbs. One filter does one carb. Each:
$ 9.50
HCP5739SET4 Aftermarket Emgo brand high-flow HIGH PERFORMANCE POD AIR FILTER ELEMENTS. fits all XJ900 and XJ1100 models with the MIKUNI carbs. One filter does one carb. Set of 4:
$ 29.50
NOTE: all of the pod filters listed above come with a bright-plated "worm screw" flange clamping ring that is used to secure the pod to the carb intake throat. For an upgraded look, you can use this stock style "screw cinching" type of clamping ring for a more "factory" look!
HCP566 OEM pod air filter flange CLAMPING RING, fits all of the pod air filters listed above, each:
$ 6.00
HCP566SET4 OEM pod air filter flange CLAMPING RINGS, set of 4:
$ 22.00
af73) Aftermarket crankcase oil breather FILTER ELEMENTS. When you replace your stock air filter box system with "pod" filters, you also lose your stock crankcase oil breather system (since it normally vents oil vapors back into the stock filter airbox). The stock vent system runs from a breather nipple on the engine block (XJ550 and XJ1100 models) on the back upper corner of the shifter side cover (all others) via a rubber hose to a plastic nipple on the airbox.
Rather than just allow these vents to blow off into the atmosphere,
these aftermarket washable and re-usable VENT FILTERS--- available in either a push-in (to the existing rubber hose) or a clamp-on (to the existing vent nipple) style---solve this problem in an attractive and simple way. Spray cans of re-oiling fluid and filter cleaner are also available below.
The clamp-on breather fits directly onto the engine case or shifter cover vent nipple, and thus can be used on all XJ-series bikes. It comes with a worm-screw type clamp.
The push-in style breather fits onto the original rubber breather hose, and has a mounting "tab" flange to allow it to be fastened to some fixed object (to prevent it from bouncing around).
HCP9795 Aftermarket crankcase breather VENT FILTER, push-in style fits into the stock breather rubber vent hose.
$ 14.95
HCP9796 Aftermarket crankcase breather VENT FILTER, clamp-on style fits onto the stock breather rubber vent nipple.
$ 14.95
AFTERMARKET RE-USABLE AIR FILTER ELEMENT CLEANER AND OILS:
af33) All of the aftermarket fabric (K&N) or foam filter elements need to be periodically cleaned and re-oiled. Our AIR FILTER CLEANER and AIR FILTER OIL products help keep your filter flowing freely and promote not only their proper filtering ability, but are also necessary to assure the longest filter life.
NOTE: these products can only be shipped via ground transportation and cannot cannot (and will not----don't even ask!) be shipped via any air transport delivery service-level nor outside of the USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
HCP10377 AftermarketAIR FILTER CLEANER, large 19-oz. aerosol spray can can be used with both foam or fabric filter elements.
$ 12.50
HCP10375 Aftermarket FABRIC AIR FILTER ELEMENT OIL, large 15-oz. aerosol spray can, for K&N filters.
$ 10.50
HCP10376 Aftermarket FOAM AIR FILTER ELEMENT OIL, large 20-oz. aerosol spray can, for UNI filters.
$ 12.50
RUBBER AIR CLEANER BOX-TO-CARB BOOTS & RELATED:
af3) OEM and reproduction airbox-to-carb rubber JOINT or BOOT, both original and reproduction individual boots and complete sets are offered to allow you to replace cracked, dry-rotted, melted or stiff-as-a-proverbial-board originals. If these boots aren't flexible, you're going to have a fight on your hands when you go to re-install your carbs! And if they're leaking, they will upset the air flow into your carb(s), not only making carb-tuning efforts difficult or impossible, but also allowing dirty, unfiltered air into your carbs and cylinders. These are the boots that run from the air cleaner box to the rear of the carbs!
ALSO---it's never a bad idea to use some of our 100% Silicone Grease as an "assembly lube" when installing any of these airbox boots (around the inside of the lip where the carbs enter the boots, as well as the outer edge of the boot where it fits into the airbox opening):
$ 6.95
HCP558 OEM Air Cleaner Box-to-Carb Rubber BOOT, for all XJ550 models, each:
$ 14.50
HCP558SET4 OEM Air Cleaner Box-to-Carb Rubber BOOTS, set of 4:
$ 53.00
HCP559 OEM Air Cleaner Box-to-Carb Rubber BOOT, for all XJ650 (except Turbo) models, each:
$ 13.50
HCP559SET4 OEM Air Cleaner Box-to-Carb Rubber BOOTS, set of 4:
$ 52.00
HCP561 OEM Air Cleaner Box-to-Carb Rubber BOOT, for all XJ700-X models, each:
$ 10.50
HCP561SET4 OEM Air Cleaner Box-to-Carb Rubber BOOTS, set of 4:
$ 39.50
HCP563 OEM Air Cleaner Box-to-Carb Rubber BOOT, for all XJ900 models, each:
$ 14.00
HCP563SET4 OEM Air Cleaner Box-to-Carb Rubber BOOTs, set of 4:
$ 54.00
af4) OEM air cleaner-to-carb boot metal CLAMP RING, includes the cinching screw. These are used on the carb end of the boot only.
HCP565 OEM air cleaner boot metal CLAMP RING, for all XJ550, XJ650 (except Turbo), XJ700 non-X, and XJ750 models, each:
$ 11.00
HCP565SET4 OEM air cleaner boot metal CLAMP RINGS, set of 4:
$ 39.00
HCP566 OEM air cleaner boot metal CLAMP RING, for all XJ700 -X, XJ900, and XJ1100 models, each:
$ 6.00
HCP566SET4 OEM air cleaner boot metal CLAMP RINGS, set of 4:
$ 22.00
AIRBOX DRAIN AND BREATHER HOSES, PINCH CLAMPS:
Your airbox DRAIN HOSE come off a small plastic fixed nipple port on the bottom side of the airbox or air cleaner housing, and the hose normally runs straight down, towards the ground.....serving to provide a "lowest point" exit for any water or overflow fuel (in case of leaking or stock float needle valves in the carbs).
The crankcase-to-airbox BREATHER HOSE normally runs from a pivoting, large plastic nipple port that is centrally located on the front of the airbox, and runs either to a crankcase breather port (XJ550 and XJ1100 models) or to a port on the upper rear of the shifter cover (XJ650, XJ700, XJ750, and XJ900RK models). This hose carries the unburned fuel and oil vapors from the crankcase, back to the air filter housing, allowing introduction of such fumes into the intake air stream to be burned rather than vented to the atmosphere.
Owners of bikes who have added "pod" air filters will require the use of either a custom fabricated crankcase vent system to move these fumes to the pod filters, or a exit vent/filter system to capture such fumes.
Airbox Drain Hoses and Clamps:
HCP5458 OEM airbox fluid DRAIN HOSE, for all XJ550 model and 1980-81 XJ650 Maxim and Midnight Maxim models, 9" section.
$ 3.95
HCP4910 Aftermarket airbox fluid DRAIN HOSE, for all XJ550 model and 1980-81 XJ650 Maxim and Midnight Maxim models, translucent red color as original, 12" section, cut to length.
$ 1.75
HCP7347 OEM airbox fluid DRAIN HOSE, for all 1982-84 XJ650 Maxim models, and all XJ700, XJ750, XJ900RK, and XJ1100 models, black, 15" long, cut to length.
$ 10.95
HCP4924B Aftermarket airbox fluid DRAIN HOSE, for all 1982-84 XJ650 Maxim models, and all XJ700, XJ750, XJ900RK, and XJ1100 models, black, 18" length, cut to length.
$ 4.75
HCP122 OEM airbox fluid drain hose PINCH CLAMP, correct fit for the HCP4910 and HCP4924B drain hoses, use 1 per hose. Each:
$ 1.50
HCP2945 OEM airbox fluid drain hose PINCH CLAMP, correct fit for the HCP5458 and HC7347 drain hoses, use 1 per hose.
$ 1.50
Crankcase-to-Airbox Breather Hose and Clamps:
HCP8046 OEM crankcase vapor breather hose PORT, black plastic swivelling port fits into the airbox housing face. Fits all XJ700 and XJ900RK models.
$ 3.50
HCP9792 OEM crankcase vapor breather hose port rubber GROMMET, for where the plastic port fits into the airbox housing face. Fits all XJ650 (except Turbo models) and all XJ750 models.
$ 1.50
HCP9793 OEM crankcase vapor breather hose port rubber GROMMET, for where the plastic port fits into the airbox housing face. Fits all XJ700 and XJ900RK models.
$ 4.50
HCP9790 OEM crankcase vapor BREATHER HOSE, for all XJ550 models.
$ 15.50
HCP979 OEM crankcase vapor BREATHER HOSE, for all XJ700 models.
$ 14.50
HCP980 OEM crankcase vapor BREATHER HOSE, for all XJ750 and XJ900RK models.
$ 14.95
HCP9789 OEM crankcase vapor BREATHER HOSE, for all XJ1100 models, attaches to the breather valve in the crankcase.
$ 4.95
HCP9787 OEM crankcase vapor BREATHER HOSE, for all XJ1100 models, attaches to the intake nipple port at the airbox.
$ 18.95
HCP983 OEM crankcase breather hose PINCH CLAMP, used with the above breather hoses as follows: all XJ550, XJ700, and XJ1100 models, use 1 at both the breather pipe fitting end of the hose and the airbox fitting end of the hose; all XJ650, XJ750, and XJ900RK models use 1 at the shifter cover breather pipe fitting end of the hose only. Each:
$ 1.50
HCP3107 Aftermarket crankcase breather hose PINCH CLAMP, used with the above breather hoses as follows: all XJ550 and XJ700 models, use 1 at both the breather pipe fitting end of the hose and the airbox fitting end of the hose; all XJ650, XJ750, and XJ900RK models use 1 at the shifter cover breather pipe fitting end of the hose only. Each:
$ 0.90
HCP984 OEM crankcase breather hose PINCH CLAMP, used with the above breather hoses as follows: all XJ650, XJ750, and XJ900RK models use 1 at the airbox breather fitting end of the hose only.
$ 1.00
HCP982 OEM crankcase vapor breather hose PIPE FITTING, the barbed metal fitting that either presses into the crankcase (XJ550 models) or the top rear edge of the shifter side cover (all XJ650, XJ700, XJ750, and XJ900RK models).
$ 8.50
HCP9788 OEM crankcase vapor BREATHER VALVE, presses into the crankcase.
$ 13.00
FREE STANDARD SHIPPING {OR JUST $5.00 FOR PRIORITY MAIL} SHIPPING IN THE USA FOR ALL ORDERS OVER $100 !!!!
$7.50 STANDARD SHIPPING TO CANADA FOR ALL ORDERS OVER $100 !!!!
Paypal accepted. Worldwide shipping available. Shipping prices and insurance costs are NOT included in the prices of items unless specifically listed. Please write with your list of parts needs and I will be glad to quote your shipping costs to you.
You can either PM (Private Message) me through this website, e-mail us via the "email" button on the bottom of this post, or e-mail us directly at:
info @ xj4ever.com
PLEASE NOTE!: our e-mail address does NOT have spaces before or after the "@" symbol........the posting system on this website automatically adds blank spaces before and after that symbol as an anti-spam feature! Make sure you eliminate those blank spaces when sending us an e-mail! Our e-mail address does NOT have any blank spaces in it!!
PLEASE!: on each and every correspondence with us, please tell us what YEAR and MODEL bike you have (example: 1982 XJ650 Maxim) and what your NAME (first name, at least!) is......that information really makes life a bit easier for us, and insures a more timely and ACCURATE response from us back to you!
MORE XJ PARTS IN THE FOLLOWING POST!!
Posted: Mon Dec 15, 2008 2:38 am Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION C:
FUEL SYSTEM ITEMS:
--Intake Manifolds and Related.
RUBBER INTAKE MANIFOLDS & RELATED:
Intake Manifolds, Gaskets, and Clamp Rings:
ww7) OEM and reproduction INTAKE MANIFOLDS, both original and reproduction individual manifolds and complete sets are offered to allow you to replace cracked, dry-rotted, vacuum-leaking (making carb tuning impossible......) originals. These are the vulcanized rubber-over-aluminum tubes that run from the front of the carbs to the cylinder heads!
NOTE: the reproduction manifolds are excellent quality, basically indistinguishable from the originals. However, the gaskets that come with them are a very thin paper style, much less substantial than the originals, although they probably will work okay. You might want to consider buying some of the original manifold-to-head gaskets when ordering a reproduction kit.......
ALSO---it's never a bad idea to use some of our 100% Silicone Grease as an "assembly lube" when installing any of these intake manifolds (around the inside of the lip where the carbs enter the manifold):
HCP1714 Aftermarket o-ring and gasket installation pure SILICONE GREASE:
$ 6.95
The intake manifold-to-head GASKETS or O-RINGS seals the intake manifold to the cylinder head mating surface. A "must-replace" item whenever the intake manifolds are removed for any reason.
Finally, we also carry the original OEM intake manifold metal CLAMP RINGS, which include the cinching screw. These are used on the carb end of the manifold only.
NOTE: all intake manifolds differ between the left side and the right side versions in two critical manners:
* intake manifolds, when installed on the engines, "curve" inwards towards the centerline of the bike.
* they also curve "upwards" (as well as inwards).
This combination of both upward and inward curvatures of the intake manifolds is why it is not possible to simple swap left side (cylinders #1 and #2) and right side (cylinders #3 and #4) intake manifolds.....some people think that you can just "flip upside down" a right side manifold and it will become a left side manifold (or vice-versa). This would be true is there were only the "inward" curvature to the manifolds; however, the "upward" curvature prevents such swapping from occuring (as the swapped-side manifold would be curving "inwards and downward")...........and you'll never get the carbs to fit correctly into such mis-aligned manifolds, and on the slim chance that you do get them to fit, you'll end up with major vacuum leaks at that joint.
550 engines:
HCP534LH OEM Yamaha rubber INTAKE MANIFOLD, used on the two left cylinders (#1 and #2). Manifold only; you must order all accessory pieces (manifold-to-head gaskets, nipple plug caps, bolts, etc.) separate. Fits all XJ550 models. Each:
$ 64.95
HCP534RH OEM Yamaha rubber INTAKE MANIFOLD, used on the two right cylinders (#3 and #4). Manifold only; you must order all accessory pieces (manifold-to-head gaskets, nipple plug caps, bolts, etc.) separate. Fits all XJ550 models. Each:
$ 64.95
HCP534SET4 OEM Yamaha rubber INTAKE MANIFOLDS, complete set of 4 intake manifolds (2 left and 2 right). Fits all XJ550 models. Set of 4:
$ 249.00
HCP76 Reproduction Yamaha rubber INTAKE MANIFOLDS, complete set of 4 intake manifolds (2 left and 2 right). OEM quality at a better price! Includes a set of 4 manifold-to-head gaskets. Fits all XJ550 models. Set of 4:
$ 119.00
HCP543 OEM intake manifold-to-head GASKET, used on all XJ550 models. Each:
$ 5.50
HCP543SET4 OEM intake manifold-to-head GASKETS, used on all XJ550 models. Set of 4:
$ 19.95
HCP2889 OEM intake manifold metal CLAMP RING, used on all XJ550 models only, black finish, each:
$ 8.95
HCP2889SET4 OEM intake manifold metal CLAMP RINGS, set of 4:
$ 32.95
XJ650, XJ700, and XJ750 engines:
NOTE: the non-YICS (1980-81 and 1982 XJ650RJ Seca) left side (cylinders #1 and #2) manifolds differ from the YICS (1982-84) manifolds in the orientation of their mounting:
* non-YICS engines have the intake manifold mounting bolt holes in the cylinder head aligned in this manner:
<#1 \ \ \ \ #4>
* YICS engines have the intake manifold mounting bolt holes in the cylinder head aligned in this manner:
<#1 / / \ \ #4>
This is why the left side (cylinders #1 and #2) intakes differ between the YICS and non-YICS engines, and why they are the same for the right side (cylinders #3 and #4) in-between all 650 engines!
HCP535LH OEM Yamaha rubber INTAKE MANIFOLD, used on the two left cylinders (#1 and #2). Manifold only; you must order all accessory pieces (manifold-to-head gaskets, nipple plug caps, bolts, etc.) separate. Fits all 1980-81 XJ650 Maxim, XJ650 Midnight Maxim, and 1982 XJ650RJ Seca models. Each:
$ 60.95
HCP536RH OEM Yamaha rubber INTAKE MANIFOLD, used on the two right cylinders (#3 and #4). Manifold only; you must order all accessory pieces (manifold-to-head gaskets, nipple plug caps, bolts, etc.) separate. Fits all 1980-81 XJ650 Maxim, XJ650 Midnight Maxim, and 1982 XJ650RJ Seca models. Each:
$ 62.95
HCP535SET4 OEM Yamaha rubber INTAKE MANIFOLDS, complete set of 4 intake manifolds (2 left and 2 right). Manifolds only; you must order all accessory pieces (manifold-to-head gaskets, nipple plug caps, bolts, etc.) separate. Fits all 1980-81 XJ650 Maxim, XJ650 Midnight Maxim, and 1982 XJ650RJ Seca models. Set of 4:
$ 229.95
HCP536LH OEM Yamaha rubber INTAKE MANIFOLD, used on the two left cylinders (#1 and #2). Manifold only; you must order all accessory pieces (manifold-to-head gaskets, nipple plug caps, bolts, etc.) separate. Fits all 1982-3 XJ650 Maxim (except Turbo), and all 1981-83 XJ750 models. Each:
$ 54.95
HCP536RH OEM Yamaha rubber INTAKE MANIFOLD, used on the two right cylinders (#3 and #4). Manifold only; you must order all accessory pieces (manifold-to-head gaskets, nipple plug caps, bolts, etc.) separate. Fits all 1980-83 XJ650 Maxim, XJ650 Midnight Maxim, 1982 XJ650 Seca (not turbo), and all 1981-83 XJ750 models. Each:
$ 62.95
HCP536SET4 OEM Yamaha rubber INTAKE MANIFOLDS, complete set of 4 intake manifolds (2 left and 2 right). Manifolds only; you must order all accessory pieces (manifold-to-head gaskets, nipple plug caps, bolts, etc.) separate. Fits all 1982-3 XJ650 Maxim (except turbo) and all 1981-83 XJ750 models. Set of 4:
$ 219.95
NOTE: the above intake manifolds can also be fitted to the 1985-86 XJ700 non-X (air-cooled engines) cylinder heads and will work as long as the XJ650 or XJ750 Hitachi HSC32 series carbs are also used. The original carbs for the XJ700 non-x models were Hitachi HSC33 series carbs, which have larger diameter intake throats and have a wider carb spacing than those of the HSC32 series, and thus used their own unique set of (no longer available) intake manifolds. Of course, you would need to re-tune the HSC32 series carbs to perform properly on an XJ700 engine, but at least method opens up another opportunity for XJ700 owners.
HCP544 OEM intake manifold-to-head GASKET, used on all XJ650 (except Turbo), all XJ700 non-X, all 1981-83 XJ750 models, and XJ750RL models. Each:
$ 8.00
HCP544SET4 OEM intake manifold-to-head GASKETS, set of 4:
$ 29.95
HCP545 OEM intake manifold-to-head O-RING, used on all XJ650 Turbo models only.
Each:
$ 5.00
HCP545SET4 OEM intake manifold-to-head O-RINGS, set of 4:
$ 18.95
HCP546 OEM intake manifold-to-head O-RING, used on all XJ700-X, XJ750-X and all XJ900RK, RL, N/FN, and F models. NOTE: XJ900 models used both a gasket AND this rubber o-ring to seal each intake manifold to the head. XJ700-X and XJ750-X models are specified to use this o-ring only, but can also use the HC547 gasket in addition to this o-ring. Each:
$ 7.00
HCP546SET4 OEM intake manifold-to-head O-RINGS, set of 4:
$ 26.95
HCP2893 OEM intake manifold metal CLAMP RING, used on all XJ650 (except Turbo) models, all XJ700 non-X models, all 1981-83 XJ750 models, and XJ750RL models, black finish as original, each:
$ 9.95
HCP2893SET4 OEM intake manifold metal CLAMP RINGS, set of 4:
$ 37.95
HCP2891 OEM intake manifold metal CLAMP RING, used on all XJ650 Turbo models only, black finish as original, each:
$ 9.95
HCP2891SET4 OEM intake manifold metal CLAMP RINGS, set of 4:
$ 37.95
HCP2892 OEM intake manifold metal CLAMP RING, used on all XJ700-X, XJ750-X, and all Fits all XJ900RK, RL, N/FN, and F models, black finish as original, each:
$ 9.95
HCP2892SET4 OEM intake manifold metal CLAMP RINGS, set of 4:
$ 37.95
900RK engines:
HCP540LH OEM Yamaha rubber INTAKE MANIFOLD, used on the two left cylinders (#1 and #2). Manifold only; you must order all accessory pieces (manifold-to-head gaskets, nipple plug caps, bolts, etc.) separate. Fits all XJ900RK, RL, N/FN, and F models. Each:
$ 62.95
HCP540RH OEM Yamaha rubber INTAKE MANIFOLD, used on the two right cylinders (#3 and #4). Manifold only; you must order all accessory pieces (manifold-to-head gaskets, nipple plug caps, bolts, etc.) separate. Fits all XJ900RK, RL, N/FN, and F models. Each:
$ 78.95
HCP540SET4 OEM Yamaha rubber INTAKE MANIFOLDS, a complete set of 4 intake manifolds (2 left and 2 right). Manifolds only; you must order all accessory pieces (manifold-to-head gaskets, nipple plug caps, bolts, etc.) separate. Fits all XJ900RK, RL, N/FN, and F models. Set of 4:
$ 279.95
HCP547 OEM intake manifold-to-head GASKET, used on all XJ900RK, RL, N/FN, and F models. NOTE: XJ900 models used both this gasket AND a rubber o-ring to seal each intake manifold to the head. This gasket will also fit the XJ700-X and XJ750-X intake manifolds, although it was not originally specified for use with those models. Each:
$ 9.00
HCP547SET4 OEM intake manifold-to-head GASKETS, set of 4:
$ 33.95
$ 7.00
$ 26.95
$ 9.95
$ 37.95
1100 engines:
NOTE: the following intake manifolds and related parts will also fit the 1978-81 XS1100E - F - G - H models, the 1980-81 XS1100LG or LH Midnight Special models, and the 1979-81 XS1100SF - SG - SH Special models.
However, the manifold gaskets that come with the HCP1230 reproduction manifolds kit will only fit the XJ1100 models, and we do not have the correct manifold gaskets for any of the XS models.
HCP1229LH OEM Yamaha rubber INTAKE MANIFOLD, used on the two left cylinders (#1 and #2). Manifold only; you must order all accessory pieces (manifold-to-head gaskets, nipple plug caps, bolts, etc.) separate. Fits all XJ1100 models. Each:
$ 74.95
HCP1229RH OEM Yamaha rubber INTAKE MANIFOLD, used on the two right cylinders (#3 and #4). Manifold only; you must order all accessory pieces (manifold-to-head gaskets, nipple plug caps, bolts, etc.) separate. Fits all XJ1100 models. Each:
$ 74.95
HCP1229SET4 OEM Yamaha rubber INTAKE MANIFOLDS, a complete set of 4 intake manifolds (2 left and 2 right). Manifolds only; you must order all accessory pieces (manifold-to-head gaskets, nipple plug caps, bolts, etc.) separate. Fits all XJ1100 models. Set of 4:
$ 289.95
HCP1230 Reproduction Yamaha rubber INTAKE MANIFOLDS, complete set of 4 intake manifolds (2 left and 2 right). OEM quality at a better price! Includes a set of 4 manifold-to-head gaskets. Fits all XJ1100 models. Set of 4:
$ 149.00
HCP6324 OEM intake manifold-to-head GASKET, used on all XJ1100 models only. Each:
$ 12.95
HCP6324SET4 OEM intake manifold-to-head GASKETS, set of 4:
$ 48.95
HCP2894 OEM intake manifold metal CLAMP RING, used on all XJ1100 models, bright plated finish, each:
$ 9.95
HCP2894SET4 OEM intake manifold metal CLAMP RINGS, set of 4:
$ 38.95
Intake Manifold Mounting Bolts:
ww7) OEM and reproduction INTAKE MANIFOLD MOUNTING BOLTS, both original and reproduction mounting bolts perfectly replace your originals. It's not a bad idea, at all, to replace these bolts whenever you change your manifolds. Use 2 bolts per manifold; fits all XJ-series engines 550 - 1100cc. Torque specification is 7.5 foot-pounds. And please be sure to use anti-seize fluid when installing these bolts!!!!
NOTE: these bolts are very easy to "snap off" when attempting their removal; please take all precautions necessary to prevent that from happening! If you do break one off, we offer the following Stud Extractor Tools that may "save the day" for you (if the stud did not snap off flush, in which case you need an ez-out, or more likely, you'll need to pull the head and enlist the services of a local machine shop):
it33) Aftermarket handheld EZ-OUT AND LEFT-HAND DRILL BITS SET. Perhaps one of the most important tools you can own when working with older vehicles, as you WILL eventually shear off the head of a screw or bolt and will have to "drill it out". EZ-Outs, of course, are hardened steel spiral extractors that dig into a drilled hole through the center of a fastener for removal, while left-hand (reverse rotation) drill bits "bite" in the opposite direction from a standard drill bit, therefore applying a counter-clockwise (loosening) force to a fastener. These tools can save you a lot of frustration when "the inevitable" happens to you!
HCP9967 Aftermarket EZ-OUT & LEFT-HAND DRILL BITS SET, contains 5 different sizes of extractors (sizes #1 - 5) and 5 different sizes of high-speed, cobalt-coated steel left-hand drill bits (5/64, 7/64, 5/32, 1/4, and 19/64" sizes). Metal storage case included.
$ 21.95
it54) Aftermarket broken stud EXTRACTOR TOOL KIT. Common problem: you snap or shear off the head of a fastener, now what do you do? This happens quite a bit on your exhuast manifold studs and also with the intake manifold bolts. As long as you have a bit of the broken stud remaining outside of the cylinder head threaded hole (in other words, the fastener has not broken off "flush"), then a stud extractor tool is what's going to save your day. Similar in concept to a "ez-out", but these tools have their "biting" surfaces on the inside of a socket-type housing, so that the hardened steel ridges bite into the stud and allow you to extract it. Also works great on screw or bolt heads that have had the drive slot ruined or the bolt head rounded off.
HCP10302 Aftermarket 6mm STUD EXTRACTOR......this is the correct size for both the exhaust headpipe studs and the intake manifold bolts in the cylinder head, which are the most common fasteners that you'll need to use these extractot tools on. You simply pound this extractor onto the stud, and then use an open-end wrench to twist it out.
$ 39.95
HCP10301 Aftermarket complete STUD EXTRACTOR TOOLS SET. Complete set of 4 different size extractors, and these can be used with ratchet wrenches for ease of removal. Contains one each of a 6mm and 8mm extractors (which can be used with 3/8" drive ratchets) and one each of a 10mm and 12mm extractors (which can be used with 1/2" drive ratchets). You simply pound the extractor onto the stud, and then use an appropriate sized ratchet wrench to twist it out. Comes in a molded storage case.
$ 59.95
- All models: cylinder head intake manifold bolt holes.
$ 20.00
Prevent any of the above situations from happening to you by using one of our anti-sieze products when installing your new bolts!
HCP548 OEM intake manifold-to-head INTAKE MANIFOLD MOUNTING BOLT, black oxide coated alloy steel socket head, allen-drive. Use 2 per manifold, 8 per engine. Each:
$ 1.50
HCP548SET8 OEM intake manifold-to-head INTAKE MANIFOLD MOUNTING BOLTS, black oxide coated alloy steel socket head, allen-drive. Use 2 per manifold, 8 per engine. Set of 8:
$ 10.95
HCP2424 Aftermarket intake manifold-to-head INTAKE MANIFOLD MOUNTING BOLT, black oxide coated alloy steel socket head, allen-drive. Use 2 per manifold, 8 per engine. Each:
$ 1.00
HCP2424SET8 Aftermarket intake manifold-to-head INTAKE MANIFOLD MOUNTING BOLTS, black oxide coated alloy steel socket head, allen-drive. Use 2 per manifold, 8 per engine. Set of 8:
$ 5.50
HCP80 Aftermarket intake manifold-to-head INTAKE MANIFOLD MOUNTING BOLT, black oxide coated alloy steel socket head, allen-drive. Features a small nylon thread patch, making this a self-locking bolt. Use 2 per manifold, 8 per engine. Each:
$ 1.50
HCP80SET8 Aftermarket intake manifold-to-head INTAKE MANIFOLD MOUNTING BOLTS, black oxide coated alloy steel socket head, allen-drive. Features a small nylon thread patch, making this a self-locking bolt. Use 2 per manifold, 8 per engine. Set of 8:
$ 10.50
HCP2423 Aftermarket intake manifold-to-head INTAKE MANIFOLD MOUNTING BOLT, bright 18-8 stainless steel socket head, allen-drive. Use 2 per manifold, 8 per engine. Each:
$ 1.20
HCP2423SET8 Aftermarket intake manifold-to-head INTAKE MANIFOLD MOUNTING BOLTS, bright 18-8 stainless steel socket head, allen-drive. Use 2 per manifold, 8 per engine. Set of 8:
$ 8.50
Intake Manifold Vacuum Port Rubber Caps & Clamps:
im2) OEM and aftermarket intake manifold VACUUM PORT PLUG CAPS & PINCH CLAMPS: these are the EPDM rubber caps and their associated spring pinch-clamps that fit over the brass vacuum nipple port on each intake manifold.
Stock configurations use three (3) caps per bike, on the #1, #2, and #4 intake manifolds (the #3 intake manifold vacuum port has a rubber line on it that goes to the petcock). If you substitute a non-vacuum operated petcock like the HCP630 fuel valve below, then you'll also need an extra cap for the #3 intake manifold.
- The following original and aftermarket vacuum port plug caps fit all XJ-series models in all intake manifolds positions EXCEPT for the XJ700-X models, which uses these plugs only on the #2 intake manifold:
HCP541 OEM intake manifold vacuum port PLUG CAP, requires the use of the HCP542 spring-clamp listed below. Each:
$ 3.50
HCP541SET3 OEM intake manifold vacuum port PLUG CAPS, set of 3:
$ 9.95
HCP541SET4 OEM intake manifold vacuum port PLUG CAPS, set of 4:
$ 12.95
HCP81 Aftermarket intake manifold vacuum port PLUG CAP, requires the use of the HCP542 spring-clamp listed below. Each:
$ 3.00
HCP81SET3 Aftermarket intake manifold vacuum port PLUG CAPS, set of 3:
$ 8.00
HCP81SET4 Aftermarket intake manifold vacuum port PLUG CAPS, set of 4:
$ 10.00
HCP2731 Aftermarket intake manifold vacuum port PLUG CAP, does NOT require the use of the HCP542 spring-clamp listed below, as this plug is much tighter than the original and is self-sealing. NOTE: it is recommended that these caps be lubricated with silicone grease before installation, as they are so tight that removal becomes quite difficult without it, and you will likely break the head off the cap when trying to remove them from the vacuum port! Each:
$ 2.00
HCP2731SET3 Aftermarket intake manifold vacuum port PLUG CAPS, set of 3:
$ 5.00
HCP2731SET4 Aftermarket intake manifold vacuum port PLUG CAPS, set of 4:
$ 6.00
- The following original vacuum port plug cap fits all XJ700-X models, on the #1 and #4 intake manifolds only:
HCP8545 OEM intake manifold vacuum port PLUG CAP, requires the use of the HCP542 spring-clamp listed below. Each:
$ 8.50
HCP542 Aftermarket intake manifold vacuum port plug cap PINCH CLAMP, 3-prong rubber-fingered spring clamp used to retain either the HCP541, HCP8545, or the HCP81 port plugs to the brass port nipple. NOTE: not needed and does not fit the aftermarket HCP2731 port plug! Each:
$ 2.50
HCP542SET3 Aftermarket intake manifold vacuum port plug cap PINCH CLAMPS, set of 3:
$ 5.50
HCP542SET4 Aftermarket intake manifold vacuum port plug cap PINCH CLAMPS, set of 4:
$ 8.95
af45) Aftermarket intake manifold metal clamp ring CINCH SCREWS, correct size and length cinch screws are available in a variety of styles and finishes to replace your rusty or destroyed originals. All of the new clamp rings that we sell are already furnished with standard, phillips-drive cinch screws.
HCP6655 Aftermarket intake manifold clamp ring CINCH SCREW, standard phillips drive, zinc-plated bright alloy steel. Use 1 per intake clamp on all XJ550 models. Each:
$ 1.25
HCP6655SET4 Aftermarket intake manifold clamp ring CINCH SCREWS, set of 4:
$ 3.75
HCP6656 Aftermarket intake manifold clamp ring CINCH SCREW, standard phillips drive, bright 18-8 stainless steel. Use 1 per intake clamp on all XJ550 models. Each:
$ 1.50
HCP6656SET4 Aftermarket intake manifold clamp ring CINCH SCREWS, set of 4:
$ 4.25
HCP6657 Aftermarket intake manifold clamp ring CINCH SCREW, allen key drive black-oxide coated alloy steel. Use 1 per intake clamp on all XJ550 models. Each:
$ 1.20
HCP6657SET4 Aftermarket intake manifold clamp ring CINCH SCREWS, set of 4:
$ 3.95
HCP6658 Aftermarket intake manifold clamp ring CINCH SCREW, allen key drive bright 18-8 stainless steel. Use 1 per intake clamp on all XJ550 models. Each:
$ 1.40
HCP6658SET4 Aftermarket intake manifold clamp ring CINCH SCREWS, set of 4:
$ 4.95
HCP6649 Aftermarket intake manifold clamp ring CINCH SCREW, standard phillips drive, zinc-plated bright alloy steel. Use 1 per intake clamp on all XJ650, XJ700, XJ750, and XJ900RK models. Each:
$ 1.25
HCP6649SET4 Aftermarket intake manifold clamp ring CINCH SCREWS, set of 4:
$ 3.75
HCP6650 Aftermarket intake manifold clamp ring CINCH SCREW, standard phillips drive, bright 18-8 stainless steel. Use 1 per intake clamp on all XJ650, XJ700, XJ750, and XJ900RK models. Each:
$ 1.50
HCP6650SET4 Aftermarket intake manifold clamp ring CINCH SCREWS, set of 4:
$ 4.25
HCP6652 Aftermarket intake manifold clamp ring CINCH SCREW, allen key drive black-oxide coated alloy steel. Use 1 per intake clamp on all XJ650, XJ700, XJ750, and XJ900RK models. Each:
$ 1.20
HCP6652SET4 Aftermarket intake manifold clamp ring CINCH SCREWS, set of 4:
$ 3.95
HCP6653 Aftermarket intake manifold clamp ring CINCH SCREW, allen key drive bright 18-8 stainless steel. Use 1 per intake clamp on all XJ650, XJ700, XJ750, and XJ900RK models. Each:
$ 1.40
HCP6653SET4 Aftermarket intake manifold clamp ring CINCH SCREWS, set of 4:
$ 4.95
HCP6062 Aftermarket intake manifold clamp ring CINCH SCREW, standard phillips drive, zinc-plated bright alloy steel. Use 1 per intake clamp on all XJ1100 models. Each:
$ 1.25
HCP6062SET4 Aftermarket intake manifold clamp ring CINCH SCREWS, set of 4:
$ 3.75
HCP6063 Aftermarket intake manifold clamp ring CINCH SCREW, standard phillips drive, bright 18-8 stainless steel. Use 1 per intake clamp on all XJ1100 models. Each:
$ 1.50
HCP6063SET4 Aftermarket intake manifold clamp ring CINCH SCREWS, set of 4:
$ 4.25
HCP6658 Aftermarket intake manifold clamp ring CINCH SCREW, allen key drive bright 18-8 stainless steel. Use 1 per intake clamp on all XJ1100 models. Each:
$ 1.40
$ 4.95
info @ xj4ever.com
Posted: Mon Dec 15, 2008 2:51 am Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION C:
FUEL SYSTEM ITEMS:
--Fuel Tanks, Caps, Filters, Fuel Line and Vacuum Lines
FUEL TANKS, FUEL TANK MOUNTS, & TANK TRIM:
GAS TANKS:
h12) OEM original steel GAS TANK, brand new originals exactly replace your originals.
NOTE on tank interchange: all XJ650 (except Turbo) and 750 tanks will swap between those models and fit, but may experience some minor interference issues with the front of the seat/seat pans. Many XJ650 Maxim and Midnight Maxim owners like to upgrade to the larger XJ750 Maxim tanks, and that is basically a bolt-on swap.
XJ550 tanks (Maxim and Seca models) will interchange with each other, but will NOT swap with XJ650 or above models (the tank mounting dimensions are different). XJ700 tanks will NOT interchange with any other models. XJ650 Turbo tanks will NOT interchange with any other models. XJ900RK tanks will NOT interchange with any other models.
Due to the size of these items, the "over $100" freight discounts do not apply to this product.
HCP127-6G OEM original steel GAS TANK, factory gloss black color, fits all XJ650 Maxim and Midnight Maxim models. NOTE: the gloss black finish on this tank is correct for 1980 XJ650 Maxim and 1981 XJ650 Midnight Maxim models only. All other years of XJ650 Maxims that used a "black" paint color actually used a gloss black with a very subtle metallic "star" flake coloration inserted. Bare tank does not include the front trim, gas cap, petcock, or any mounting hardware or bushings. New.
$ 359.00
HCP9911-33 OEM original steel GAS TANK, factory low gloss black color, fits all XJ650 Turbo models. NOTE: this tank is the larger capacity 1983 5.0-gallon tank, and will fit all 1982 models correctly. New.
$ 499.00
HCP3116-6G OEM original steel GAS TANK, factory gloss black color, fits all XJ700 non-California models. NOTE: the gloss black finish on this tank is correct for the 1985 XJ700N and 1986 XJ700XS models. Bare tank does not include the gas cap, petcock, or any mounting hardware or bushings. NOTE: can be used on California models, but do not have the port for the use of the rollover valve..
$ 599.00
HCP3117-KU OEM original steel GAS TANK, fits all XJ700 models. NOTE: these tanks normally come to us painted in the original 1985 "Scarlet Red" color. These tanks are for California model bikes as they have the port for the use of the rollover valve.
Also, due to the size of this item, the "over $100" freight discounts do not apply to this product.
$ 499.00
FUEL TANK MOUNTING PADS AND HARDWARE:
h22) OEM and aftermarket rubber fuel tank MOUNTING PADS AND HARDWARE insure both the proper fit and eliminates those annoying squeeks and vibration.
HCP1504 OEM fuel tank FRONT MOUNTING DAMPER, round "doughnut" style insulator fits on both the left and right sides of the tank and frame mounts. For all XJ550 Seca models. Each:
$ 5.75
HCP150 OEM fuel tank FRONT MOUNTING DAMPER, round "doughnut" style insulator fits on both the left and right sides of the tank and frame mounts. For all XJ550 Maxim, all XJ650 models, all XJ750 models, and all XJ900RK Seca models. Each:
$ 4.75
HCP1505 OEM fuel tank FRONT MOUNTING DAMPER, round "doughnut" style insulator fits on both the left and right sides of the tank and frame mounts. For all XJ700 models. Each:
$ 4.95
HCP1506 OEM fuel tank FRONT MOUNTING DAMPER, round "doughnut" style insulator fits on both the left and right sides of the tank and frame mounts. For all XJ1100 models. Each:
$ 8.95
HCP151 OEM fuel tank REAR LOWER (on frame) MOUNTING CUSHION, large flat pad fits on the frame pad, and the rear tank mounting crossbrace sets down onto this pad. For all XJ550 models. Use 1 per tank.
$ 36.95
HCP1512 OEM fuel tank REAR LOWER (on frame) MOUNTING CUSHION, large flat pad fits on the frame pad, and the rear tank mounting crossbrace sets down onto this pad. For all XJ650 models and all XJ750 Seca models. Use 1 per tank.
$ 14.95
HCP671 OEM fuel tank REAR UPPER (on tank) MOUNTING CUSHION, small oval pad fits on the top of the rear tank mounting crossbrace and accepts the pad Plate Washer listed below. For all XJ550 models, all XJ650 models, all XJ750 models, XJ900RK and XJ1100 models. Use 1 per tank.
$ 4.95
HCP672 OEM fuel tank REAR UPPER (on tank) MOUNTING CUSHION, small oval pad fits on the top of the rear tank mounting crossbrace and accepts the pad Plate Washer listed below. For all XJ700 models. Use 1 per tank.
$ 3.95
HCP152 OEM fuel tank rear upper mounting cushion oval PLATE WASHER, fits on the top of the rear tank upper mounting cushions listed above. For all XJ550 models, all XJ650 models (except XJ650RJ Seca), all XJ750 Maxim and Midnight Maxim models, and XJ1100 models. Use 1 per tank.
$ 4.95
HCP673 OEM fuel tank rear upper mounting cushion oval PLATE WASHER, fits on the top of the rear tank upper mounting cushions listed above. For all XJ650RJ Seca, all XJ750 Seca models, and XJ900RK Seca models. Use 1 per tank.
$ 7.95
HCP1514 OEM fuel tank rear upper mounting cushion oval PLATE WASHER, fits on the top of the rear tank upper mounting cushions listed above. For all XJ700 models. Use 1 per tank.
$ 3.95
HCP1515 OEM fuel tank rear MOUNTING BOLT. For all XJ550 Maxims, all XJ650 models (except XJ650RJ Seca), all XJ750 Maxim and Midnight Maxim models, and XJ1100 models. Use 1 per tank.
$ 1.00
HCP1516 OEM fuel tank rear MOUNTING BOLT. For all XJ550 Seca, all XJ650RJ Seca, all XJ750 Seca, and XJ900RK Seca models. Use 1 per tank.
$ 6.75
HCP674 OEM fuel tank rear MOUNTING BOLT. For all XJ700 models. Use 1 per tank.
$ 1.50
HCP1517 OEM fuel tank rear SPRING CLIP. For all XJ550 Seca, all XJ650RJ Seca, all XJ750 Seca, and XJ900RK Seca models. This special clips retains the rear of the tank and captures it to the head of the cushion mounting bolt. Use 1 per tank.
$ 16.00
FUEL TANK SEAM EDGE TRIM:
h9) Aftermarket fuel tank SEAM EDGE TRIM. Originally used on XJ650 Maxim and XJ1100 models only, the welded edge "lip" of the tank was covered with a bright chrome decorative metal trim band. The original metal pieces are no longer available. These flexible, plastic u-channel sections of decorative trim are very similar in overall shape and profile to the original metal trim, and will perfectly replace the originals. Many people like to add this trim to other model tanks, as it not only hides and finishes the sharp edge of this lip, but adds a very nice distinctive appearance to your tank! All replacement trim moldings have an internal glue strip for a semi-permanent installation, and it easily pushes-on to the metal lip. Sold per foot or in longer lengths, it can be easily cut to exact-fit size with a sharp razor blade.
NOTE: the original seam edge trim on XJ650 models was a total of only 34" long, and only extended about halfway down the length of the tank (front-to-back) and around the u-bend by the steering stem tube. The ENTIRE length of the welded lip on XJ tanks.....end-to-end.....is 54" on XJ550 tanks, 60" on XJ650 (except turbo models) tanks, and 65" on XJ750 tanks (don't currently have measurements for 700/900/1100 tanks). This entire-length measurement does include the u-bend at the front of the tank, up by the steering stem tube, and the entire side lengths all the way to the back of the tank (where the rear tank mount is). In my opinion, the tanks look better with the full length trim added, rather than the "halfway-down-the-sides length" trim as originally used.
HCP678 Aftermarket fuel tank SEAM EDGE TRIM, gloss black finish. Will fit all XJ series tanks. Per foot.
$ 1.90 per foot
HCP678SET5 Aftermarket fuel tank SEAM EDGE TRIM, gloss black finish. Will fit all XJ series tanks. A 5-foot length. Enough to do the entire lip edge on all XJ550 and all XJ650 (except turbo models) tanks.
$ 9.00 per 5-foot length
HCP678SET6 Aftermarket fuel tank SEAM EDGE TRIM, gloss black finish. Will fit all XJ series tanks. A 6-foot length. Enough to do the entire lip edge on all XJ750 tanks.
$ 10.50 per 6-foot length
HCP677 Aftermarket fuel tank SEAM EDGE TRIM, gloss gold finish. Will fit all XJ series tanks. Looks outstanding on black tanks! Per foot.
$ 2.00 per foot
HCP677SET5 Aftermarket fuel tank SEAM EDGE TRIM, gloss gold finish. Will fit all XJ series tanks. A 5-foot length. Enough to do the entire lip edge on all XJ550 and all XJ650 (except turbo models) tanks. Looks outstanding on black tanks!
$ 9.50 per 5-foot length
HCP677SET6 Aftermarket fuel tank SEAM EDGE TRIM, gloss gold finish. Will fit all XJ series tanks. A 6-foot length. Enough to do the entire lip edge on all XJ750 tanks. Looks outstanding on black tanks!
$ 11.00 per 6-foot length
HCP676 Aftermarket fuel tank SEAM EDGE TRIM, chrome silver finish. Will fit all XJ series tanks. Per foot.
$ 2.00 per foot
HCP676SET5 Aftermarket fuel tank SEAM EDGE TRIM, chrome silver finish. Will fit all XJ series tanks. A 5-foot length. Enough to do the entire lip edge on all XJ550 and XJ650 (except turbo models) tanks.
HCP676SET6 Aftermarket fuel tank SEAM EDGE TRIM, chrome silver finish. Will fit all XJ series tanks. A 6-foot length. Enough to do the entire lip edge on all XJ750 tanks.
FUEL TANK GAS CAPS:
gc2) OEM fuel tank complete GAS CAP, with lock and 2 keys. Brand new, original chrome-plated, flip-open style gas caps or black screw-on design caps are just like original.
HCP2904 OEM complete GAS CAP with lock and a pair of keys. Fits all XJ550 models, all XJ650 models (except Turbo), all XJ700 non-California models, all XJ750 models, and XJ1100 models. Includes the HCP170 cap-to-tank sealing gasket. Mounting screw to tank is not included.
$ 54.00
HCP2905 OEM complete GAS CAP with lock and a pair of keys. Fits all XJ700 California models (SC/XSC/NC/XNC). Includes the HCP170 cap-to-tank sealing gasket. Mounting screw to tank is not included.
$ 64.00
HCP2906 OEM complete GAS CAP with lock and a pair of keys. Fits all XJ650 Turbo and XJ900 models. Black finish, screw-on design as original.
$ 47.00
Fuel Cap Rebuild Parts:
c6) OEM and aftermarket gas cap-to-tank CAP MOUNTING SCREW, original fit and function. Original mounting screws were made of a plain alloy steel, and did not use a lock washer; these replacement screws are available in a variety of styles. Fits all XJ550, XJ650 (except Turbo models), all XJ750, and XJ1100 models.
HCP168 OEM gas tank fuel cap MOUNTING SCREW, dark gray coated alloy steel with correct pan head size and using a phillips drive slot.
$ 1.00
HCP910 aftermarket gas tank fuel cap MOUNTING SCREW, zinc-plated alloy steel with correct pan head size and using a phillips drive slot.
$ 1.00
HCP2748 aftermarket gas tank fuel cap MOUNTING SCREW, 18-8 stainless steel with correct pan head size and using a phillips drive slot.
$ 2.50
HCP2749 aftermarket gas tank fuel cap MOUNTING SCREW, 18-8 stainless steel with a black-oxide coating, featuring the correct pan head size and using a phillips drive slot.
$ 1.50
HCP2750 aftermarket gas tank fuel cap MOUNTING SCREW, 18-8 stainless steel with correct pan head size and using a phillips drive slot. Has an integral externally-toothed captive "star" (sems) lock washer.
$ 2.50
xx6) OEM fuel tank gas cap SEALING GASKET, large round rubber ring gasket molded onto a stamped metal base, with a cinch spring surrounding it. Fits all the flip-open style gas caps that have a metal body. The black-plastic bodied flip-open caps use a different style sealing ring that is not currently available. Fits all XJ550, XJ650 (except Turbo), XJ700, XJ750, and XJ1100 models. If you smell gas when your cap is closed, or if it leaks gas when full, this sealing gasket probably needs replacing!
NOTE: during installation, the "concave" side of this ring faces AWAY from the filler neck on the tank.
HCP170 OEM gas cap SEALING GASKET, each:
$ 16.00
xx26) OEM fuel cap lock cylinder O-RINGS, there is a small (at the base of the cylinder) and a large (at the top of the cylinder) rubber o-ring that seal the lock cylinder inside the gas cap housing. Fits all the flip-open style gas caps that have a metal body. The black-plastic bodied flip-open caps use a different style o-ring that is not currently available. Fits all XJ550, XJ650 (except Turbo), XJ700, XJ750, and XJ1100 models. If you smell gas when your cap is closed, or if it leaks gas when full, these o-rings may need replacing.
HCP186 Aftermarket gas cap lock cylinder upper (top) O-RING, each:
$ 2.95
HCP187 Aftermarket gas cap lock cylinder lower (bottom) O-RING, each:
$ 2.75
xx26) OEM fuel cap locking-ears housing SCREWS & WASHERS. The cast metal housing that holds the cap catch hooks or ears is mounted to the cap body via two small phillips-drive screws which are normally very corroded after years of exposure to fuel. Fits all the flip-open style gas caps that have a metal body. The black-plastic bodied flip-open caps use a different style o-ring that is not currently available. Fits all XJ550, XJ650 (except Turbo), XJ700, XJ750, and XJ1100 models. If you're going to be dis-assembling your cap for rebuild or lubrication, you'll probably want to replace these screws while you've got everything apart. Available in a variety of original phillips-drive or replacement socket head allen-wrench drive styles and materials. Lockwashers should be also ordered separately below.
HCP6418 Aftermarket gas cap lock housing retaining SCREW, panhead phillips-drive zinc-plated alloy steel screw has the correct small-diameter head needed for this close-fit application. Use 2 per cap. Each:
$ 0.70
HCP6421 Aftermarket gas cap lock housing retaining SCREW, panhead phillips-drive natural finish 18-8 stainless steel screw has the correct small-diameter head needed for this close-fit application. Use 2 per cap. Each:
$ 2.00
HCP6423 Aftermarket gas cap lock housing retaining SCREW, socket head cap screw allen (3mm hex-key) drive black-oxide coated finish alloy steel screw has the correct small-diameter head needed for this close-fit application. Use 2 per cap. Each:
$ 0.75
HCP6424 Aftermarket gas cap lock housing retaining SCREW, socket head cap screw allen (3mm hex-key) drive 18-8 stainless steel screw has the correct small-diameter head needed for this close-fit application. Use 2 per cap. Each:
$ 0.75
HCP6425 Aftermarket gas cap lock housing retaining screw LOCK WASHER, 18-8 stainless steel finish has the correct small-diameter profile needed for this close-fit application. Use 2 per cap. Each:
$ 0.20
HCP6426 Aftermarket gas cap lock housing retaining screw LOCK WASHER, black-oxide coated alloy steel has the correct small-diameter profile needed for this close-fit application. Use 2 per cap. Each:
$ 0.25
xx28) OEM fuel cap pressure and fluid control BALL VALVE. The cast metal fuel cap housing has a drilled cross-passage in it that allows air pressure to escape from the inside of the tank, while preventing fuel spillage if the tank or bike becomes horizontal. Looks like a standard ball bearing but is quite a bit smaller. Fits all the flip-open style gas caps that have a metal body. The black-plastic bodied flip-open caps use a different style ball that is not currently available. Fits all XJ550, all XJ650 (except Turbo), all XJ700 non-California models. all XJ750 and XJ1100 models. If you're going to be dis-assembling your cap for rebuild or lubrication, you'll probably want to replace this small ball while you've got everything apart.
HCP6415 Aftermarket fuel cap pressure and fluid control BALL VALVE, made from standard alloy steel. Use 1 per cap.
$ 0.75
HCP6414 Aftermarket fuel cap pressure and fluid control BALL VALVE, made from corrosion-resistant 440C stainless steel. Use 1 per cap.
$ 1.95
FUEL SENDING UNITS:
fsu3) OEM fuel tank FUEL SENDING UNIT, brand new sender comes with the wiring harness leads.
HCP685 OEM in-tank FUEL SENDING UNIT, for all XJ700 models.
$ 44.95
HCP684 OEM in-tank FUEL SENDING UNIT, for all XJ900RK models.
$ 57.95
f1) Fuel tank SENDING UNIT MOUNTING GASKET. Molded rubber gasket fits between the sending unit mounting plate and the tank, preventing leaks. A great idea to replace this gasket whenever you pull the sending unit out.
HCP687 OEM fuel tank sending mounting GASKET. Fits all XJ550 Seca, XJ650 Turbo, 1982 XJ750 Maxim, all XJ750 Seca models, and XJ1100 models.
$ 7.00
HCP688 OEM fuel tank sending unit mounting GASKET. Fits all XJ700 models.
$ 6.00
HCP3081 OEM fuel tank sending unit mounting GASKET. Fits all XJ900RK models.
$ 6.50
f3) Fuel tank Sending Unit mounting BOLT. Flanged shoulder hex-head bolts attach the fuel sending unit to the tank.
HCP1241 OEM fuel tank sending unit mounting BOLTS. Fits all XJ550 Seca, XJ650 Turbo, 1982 XJ750 Maxim, and all XJ750 Seca models. Each:
$ 1.00
HCP1241SET4 OEM fuel tank sending unit mounting BOLTS. Fits all XJ550 Seca, XJ650 Turbo, 1982 XJ750 Maxim, and all XJ750 Seca models. Set of four:
$ 3.50 set
HCP2745 Aftermarket fuel tank sending unit mounting BOLT, black-oxide coated alloy steel 10mm hex-head bolt has a serrated flange that acts as a lock washer (OEM bolts do not have a serrated flange nor do they use a lock washer). Fits all XJ550 Seca, XJ650 Turbo, 1982 XJ750 Maxim, and all XJ750 Seca models. Each:
$ 1.50
HCP2745SET4 Aftermarket fuel tank sending unit mounting BOLTS, black-oxide coated alloy steel 10mm hex-head bolt has a serrated flange that acts as a lock washer (OEM bolts do not have a serrated flange nor do they use a lock washer). Fits all XJ550 Seca, XJ650 Turbo, 1982 XJ750 Maxim, and all XJ750 Seca models. Set of four:
$ 4.95 set
HCP118 OEM fuel tank sending unit mounting BOLT. Fits all XJ700 models. Each:
$ 1.50
HCP118SET2 OEM fuel tank sending unit mounting BOLTS. Fits all XJ700 models. Set of two.
$ 2.50 set
HCP3082 OEM fuel tank sending unit mounting BOLT. Fits all XJ900RK models. Use 4 per tank. Each:
$ 1.95
HCP3082SET4 OEM fuel tank sending unit mounting BOLTS. Fits all XJ900RK models. Set of four:
$ 6.50 set
f4) Fuel tank sending unit-to-tank mounting bolt WASHER. These washers are made from a fuel-resistant hard fiber material and need to be replaced every so often, and certainly every time you remove the fuel sender from the tank.
HCP2743 OEM fuel tank sending unit-to-tank mounting bolt WASHER. Fits all XJ550, XJ650, XJ700, XJ750, XJ900RK, and XJ1100 models. Each.
$ 1.00
HCP2743SET2 OEM fuel tank sending unit-to-tank mounting bolt WASHERS. Fits all XJ700 models. Set of two (700 models only used two washers).
$ 1.75 pair
HCP2743SET4 OEM fuel tank sending unit-to-tank mounting bolt WASHERS. Fits all XJ550, XJ650, XJ700, XJ750, XJ900RK, and XJ1100 models. All models EXCEPT 700's used 4 washers. Set of four:
$ 3.00 set
FUEL LINES, FUEL LINE PINCH CLAMPS:
NOTE: All Yamaha XJ models use 1/4" main fuel line from the petcock fuel outlet to the carb inlet(s). Yamaha XJ700 non-X Hitachi HSC33 carbs also use 1/4" fuel line for the upper vent lines (one on each carb) just under and to the side of the idle mixture screw bore. In addition, XJ700 non-X Hitachi HSC33 carbs and some Mikuni model carbs use a bowl vent/overflow tube that runs between the #1 and #2 carb, and separate bowl vent/overflow tube between carbs #3 and #4. These bowl vent tubes require the use of a larger 5/16" fuel line. Be aware that both the upper vent lines and the lower bowl vent lines run from to carb body to "nowhere"; that is, their other ends do not attach to any component, and are merely vented to the atmosphere. Those lines just "hang free" and point downward, exiting below the bottom of the carb rack, each line being anywhere from 8-12" long. Yes---for those carbs, there is a virtual rats-nest of fuel lines going everywhere!
ALSO NOTE: everyone likes to be special, right? Well, Yamaha did, and that specialness goes all the way down to the fuel and vacuum lines, too. They used a special "thinwall" design hose that is just that: very thin walls of the hose. This makes the hose very flexible, and easy to manuever into the sometimes tight bends and squeezes that are found in the fuel plumbing on these bikes, yet still resist kinking or collapsing or bursting. Aftermarket fuel and vacuum lines tends to be "automotive" grade and have thick, rigid walls, and is fairly non-flexible. THIS CAN PRESENT REAL PROBLEMS ON YOUR ROUTING YOUR FUEL LINES. Our OEM and Premium Aftermarket Fuel Lines are both thinwall design to make routing of the hose easy.
fl2) OEM Petcock-to-Carb and Carb Vent ORIGINAL FUEL LINE. Original thinwall, flexible rubber fuel line is black with a green or red tracer stripe. NOTE: do not use fuel line as vacuum line, and vice-versa. Fuel line is designed to withstand expansion pressures, while vacuum line is made to resist collapsing! This fuel line is NOT for use in fuel-injection systems.
HCP120A OEM 14" straight 1/4" ORIGINAL FUEL LINE, more than enough to reach from the petcock to the fuel rail inlet nipple on the carbs on models that have a rear-facing fuel outlet nipple on the petcock. Correct black fuel hose with green tracer stripe is used on all XJ650 models (except Turbo) and all XJ900RK models. NOTE: use the HCP122, HCP542, or HCP2945 hose clamps with this fuel line. Although this hose is not correct for XJ550 and XJ750 models, it can be used as a lower-cost substitute for those models "dog-leg" molded style fuel lines.
$ 7.00
HCP120B OEM 8" dogleg (90-degree bend) molded 1/4" ORIGINAL FUEL LINE, more than enough to reach from the petcock to the fuel rail inlet nipple on the carbs on models that have an in-ward pointing fuel outlet nipple (towards the center of the bike) on the petcock. Correct black fuel hose with red tracer stripe is used on all XJ750 models. NOTE: use the HCP122, HCP3106, or HCP2945 hose clamps with this fuel line.
$ 11.00
HCP120C OEM 9" dogleg (90-degree bend) molded 1/4" ORIGINAL FUEL LINE, more than enough to reach from the petcock to the fuel rail inlet nipple on the carbs on models that have an in-ward pointing fuel outlet nipple (towards the center of the bike) on the petcock. Correct black fuel hose with red tracer stripe is used on all XJ550 models. NOTE: use the HCP122, HCP3106, or HCP2945 hose clamps with this fuel line.
$ 14.00
HCP5366 OEM 17" straight 1/4" ORIGINAL FUEL LINE. Correct black fuel hose, no tracer stripe, as used on all XJ1100 models. Each:
$ 4.50
NOTE: XJ1100 models require a total length of fuel hose of approximately 50", therefore you will need to order a total of three (3) of these hoses to do the entire carb rack on these models, and cut them into the following lengths:
1 piece each: 2", 3-1/2", 4", 5-1/4", and 8"
3 pieces each: 9"
and to accomplish the above you will cut each of the three HCP5366 pieces as follows:
1 of the HCP5366 pieces, cut into a 9" and 8" pieces
1 of the HCP5366 pieces, cut into 9", 4", and 3-1/2" pieces
1 of the HCP5366 pieces, cut into 9", 5-1/4", and 2" pieces.
NOTE: as an alternative to using this original solid black fuel line, you can use any of our aftermarket fuel lines listed below, or for a creative solution to the "which hose runs where?" issue that arises with these carbs, you can order three different colors of your choice (call them colors "A", "B", and "C") of fuel line to color-code each fuel path. You'll need the following total lengths:
- one foot of color "A" to run from petcocks to the fuel line T-Splitters.
- two feet of color "B" to run from the petcocks to the vacuum pod inlet.
- three feet of color "C" to run from the vacuum pod outlet to the T-splitter input, and then also from the T-splitter output to the carb bank input.
The pinch clamps to use AT THE PETCOCK PORTS is the HCP542, and you'll need 4 of those, while all other fittings (at the vacuum pod and at the fuel line T-splitters) should will require the use of 12 of the HCP2945 hose clamps. Note that if you choose to add any of our in-line fuel filters, you will need order and additional two of HCP2945 hose clamps for each filter ordered.
HCP5364 OEM fuel line T-SPLITTER, used on XJ1100 models only, use two per carb rack. Each:
$ 4.95
fl12) Aftermarket Petcock-to-Carb STANDARD FUEL LINE, better than OE quality, this black line resists collapse and is a low-cost, durable replacement DOT approved automotive and marine grade line. Black thin-wall design is very flexible and has no tracer stripe. Suitable for use with both gasoline and alcohol-blended fuels. This fuel line is NOT for use in fuel-injection systems.
NOTE1: for the 1/4" fuel line from the petcock to the carb inlet, order an 18" section for all XJ650 (except Turbo) and XJ900RK models. Order a 12" section for all XJ550 models, all XJ700 models, and all XJ750 models. Order a 60" section for all XJ1100 models.
NOTE2: use the HCP122 or the HCP542 fuel line clamps with the 1/4" hose. Use the HCP3106 clamps with the 5/16" line.
HCP4924A aftermarket 1/4" STANDARD FUEL LINE, sold per 12" (foot) section.
$ 3.25
HCP4924B aftermarket 1/4" STANDARD FUEL LINE, sold per 18" (foot and a half) section.
$ 4.75
HCP4924C aftermarket 1/4" STANDARD FUEL LINE, sold per 24" (two feet) section.
$ 5.95
HCP9424D aftermarket 1/4" STANDARD FUEL LINE, sold per 60" (five feet) section.
$ 14.00
HCP4925A aftermarket 5/16" STANDARD FUEL LINE, sold per 12" (foot) section.
$ 3.95
HCP4925B aftermarket 5/16" STANDARD FUEL LINE, sold per 18" (foot and a half) section.
$ 5.50
HCP4925C aftermarket 5/16" STANDARD FUEL LINE, sold per 24" (two feet) section.
$ 6.95
fl3) Aftermarket Petcock-to-Carb PREMIUM FUEL LINE, better than OE quality, featuring a two-layer design with a fuel-resistant inner core and a chemical, heat, and ozone resistant outer sheath, DOT approved. The best of both worlds. Light grey thin-wall design line has a blue tracer stripe. Suitable for use with both gasoline and alcohol-blended fuels. This fuel line is NOT for use in fuel-injection systems.
NOTE2: use either the HCP3106 or the HCP122 hose clamp with the 1/4" hose.
HCP948A aftermarket 1/4" PREMIUM FUEL LINE, sold per 12" (foot) section.
$ 3.50
HCP948B aftermarket 1/4" PREMIUM FUEL LINE, sold per 18" (foot and a half) section.
$ 5.50
HCP948C aftermarket 1/4" PREMIUM FUEL LINE, sold per 24" (two feet) section.
$ 6.50
HCP948D aftermarket 1/4" PREMIUM FUEL LINE, sold per 60" (five feet) section.
$ 15.00
HCP1663A aftermarket 5/16" PREMIUM FUEL LINE, sold per 12" (foot) section.
$ 3.95
HCP1663B aftermarket 5/16" PREMIUM FUEL LINE, sold per 18" (foot and a half) section.
$ 5.95
HCP1663C aftermarket 5/16" PREMIUM FUEL LINE, sold per 24" (two feet) section.
$ 7.00
fl23) Aftermarket Petcock-to-Carb COLORED FUEL LINE, high quality 1/4" polyethylene alcohol and petroleum-compatible transparent fuel line allows you to both view fuel flow AND obtain a certain measure of "XJ-bling"! Really dresses up---in a subtle way, of course---your engine area, especially if used with colored spark plug wires and vacuum lines! Thinwall design is very flexible, as original; and has excellent abrasion resistance. Note that these are lines are not "eye-blinding" bright colors, but rather soft pastel tints necessary to allow the "see-through" feature. Suitable for use with both gasoline and alcohol-blended fuels. This fuel line is NOT for use in fuel-injection systems.
NOTE2: use the HCP122, HCP542, or HCP2945 hose clamps with this fuel line.
All clear and colored fuel line is priced and sold at $ 1.75 PER FOOT and only in one-foot increments (i.e. 1-foot, 2-feet, 3-feet, etc.).
HCP4909 aftermarket 1/4" Transparent BLUE FUEL LINE
HCP4910 aftermarket 1/4" Transparent RED FUEL LINE
HCP4911 aftermarket 1/4" Transparent YELLOW FUEL LINE
HCP4912 aftermarket 1/4" Transparent GREEN FUEL LINE
HCP4926 aftermarket 1/4" Transparent CLEAR FUEL LINE...use with the HCP122 hose clamps only on this non-tinted, clear fuel line.
fl8) OEM Yamaha and Aftermarket Fuel Line PINCH CLAMPS, genuine scissors-type tension clamp. Use 2 per fuel hose for non-aftermarket filter application, or 4 per fuel hose when you add an aftermarket in-line fuel filter.
HCP122 OEM Fuel Line 1/4" Hose PINCH CLAMP, correct fit for the HCP120B and HCP948 fuel lines, and a slightly looser fit for the HCP120A. Each:
$ 1.50
HCP2945 OEM Fuel Line 1/4" Hose PINCH CLAMP, correct fit for the HCP120B and HCP948 fuel lines, each.
$ 1.50
HCP3106 Aftermarket Fuel Line 5/16" Hose PINCH CLAMP, correct fit for the HCP120B and HCP948 fuel lines, and a slightly loose fit on the HCP120A fuel line. Each:
$ 0.80
HCP542 OEM Fuel Line 1/4" Hose PINCH CLAMP, correct fit for the HCP120A, and a very tight fit on the HCP120B fuel line. This is actually the "3-finger" spring clamp used on the intake manifold block-off caps, and is much wider than a standard (stock) fuel line scissors clamp, but it provides better clamping action and is easier to install and remove due to the wider spread of the release grips. Each.
$ 2.00
HCP542SET2 OEM Fuel Line 1/4" Hose PINCH CLAMPS, set of 2:
$ 3.75
HCP542SET4 OEM Fuel Line 1/4" Hose PINCH CLAMPS, set of 4:
$ 7.00
FUEL FILTERS:
fl4) OEM Yamaha petcock IN-TANK FUEL FILTER. This is the tall, white filter unit (yours may have turned brown after all these years) that fits onto the petcock and goes up into the tank. 94mm (about 3-3/4") tall, which may differ slightly from the stock filter height, but it doesn't interfere with anything and doesn't change the performance. It's a swell idea to replace this filter whenever you have the petcock out! Fits: all XJ550, XJ650 (except Turbo models), all XJ700, XJ750, XJ900RK, and XJ1100 models. NOTE: some original petcocks used a shorter 2" tall filter, which is no longer available, and this taller filter will work just fine in place of it, but may change the determination point of when the "reserve" supply level is reached. SOME MINOR SLIMMING AND TRIMMING OF THE OVAL BASE OF THE FILTER MAY BE NECESSARY TO INSURE PROPER FIT, AS THE FILTER BASE IS VERY SLIGHTLY "OVERSIZE" FOR SOME ORIGINAL PETCOCKS. Also please note: this filter can, on some petcocks, fit "either way" into the petcock body, so that the ON and RES locations could become reversed! Make sure you install in the proper orientation!!
HCP116 OEM petcock in-tank FUEL FILTER.
$ 14.00
fl5) Aftermarket IN-LINE FUEL FILTERS. This is the cheapest and best investment you can make for a long, clean life for your carbs. Available as either round or cone-shaped clear plastic filter units, they go a long way towards preventing contaminants from your fuel tank ever getting into your carbs.
NOTE: As far as the differnce in suitability of the various in-line filters listed below, there's not much, but just as with engines, the "bigger the better". The 2" sized filter will flow plenty and filter the fuel just fine. However, please bear in mind that fuel filters DO become clogged over time (reducing both their fuel flow
capacity and filtration ability) and as such you should plan to inspect and replace them periodically (once a year would be appropriate).
HCP763 Aftermarket IN-LINE FUEL FILTER, round, 1/3" diameter filter has a clear, see-through 1-3/4" long housing with a metal screen filter. This is a straight-thru design, with inlet and outlet tubes 180-degrees opposite each other. For 1/4" fuel lines.
$ 3.00
HCP2733 Aftermarket IN-LINE FUEL FILTER, cone-shaped 2" long filter has a clear, see-through housing with a bronze mesh filter. This is a straight-thru design, with inlet and outlet tubes 180-degrees opposite each other. NOTE: the sintered bronze filter element goes TOWARDS the tank.
$ 3.00
HCP3591 Aftermarket IN-LINE FUEL FILTER, cone-shaped 3" long filter has a clear, see-through housing with a bronze mesh filter. This is a straight-thru design, with inlet and outlet tubes 180-degrees opposite each other. Longer length results in a higher fuel flow and filtering capacity. NOTE: the sintered bronze filter element goes TOWARDS the tank.
$ 3.50
HCP2734 Aftermarket IN-LINE FUEL FILTER, cone-shaped 2" long housing has a clear, see-through housing with a bronze mesh filter. This unit has 90-degree angled inlet and outlet tubes (pointed 90-degrees opposite of each other), which is useful in the "tight-squeeze" conditions that exist under some models! NOTE: the sintered bronze filter element goes TOWARDS the tank....meaning the 90-degree rotated (from the centerline) INPUT nipple (from the tank) is approximately 1" off the centerline of the housing. The entire housing---including the inlet nipple, is about 2" wide, and---including the outlet nipple---is about 2-1/4" long. THIS IS THE MOST POPULAR STYLE TO USE FOR MOST XJ-SERIES BIKES, as the 90-degree turn that the filter inlet/outlet orientation provides serves to minimize the amount of fuel line bends that are necessary to route the fuel line from the petcock to the carb fuel inlet!
$ 3.50
VACUUM LINES, VACUUM LINE PINCH CLAMPS:
fl6) OEM and aftermarket Yamaha Petcock-to-#3 Intake Manifold Nipple VACUUM HOSE. OEM black rubber vacuum line has the green or red tracer stripe. The aftermarket line is black rubber with no tracer stripe.
HCP121 OEM 15" black rubber VACUUM HOSE, with tracer stripe, for use on all XJ550, XJ650 (except Turbo), XJ700, XJ750, and XJ900RK models. Can also be used on the XJ1100 models but is actually too long. Use with the HCP123 pinch clamps.
$ 6.00
HCP5349 OEM 30" black rubber VACUUM HOSE, with tracer stripe, for use on all XJ700 California-only models with the vapor recovery system. Use with the HCP123 pinch clamps.
$ 6.00
HCP5365C OEM 8" black rubber VACUUM HOSE, for all XJ1100 models, from the vacuum control pod to the intake manifold nipple. This vacuum line does NOT have a tracer stripe on it. Use with the HCP3951 or the HCP3102 pinch clamps
$ 3.00
HCP5357 OEM 16" long 1/8" diameter (smaller than standard) VACUUM HOSE, from the brass nipple on the #2 carb body to the pressure sensor device. Use with the HCP3951 or the HCP3102 pinch clamps. NOTE: this hose is smaller than the aftermarket HCP2949 vacuum hose listed below.
$ 5.95
HCP2949 Aftermarket black rubber VACUUM HOSE, per foot. Use as a lower-cost, high-quality substitute in place of the HCP121, HCP5349, or HCP5365C original vacuum hoses listed above.
$ 1.50
fl26) Aftermarket petcock-to-Intake Manifold Nipple COLORED VACUUM HOSE, high quality thick-walled alcohol and petroleum-compatible fuel line is more than tough enough to be used as vacuum line (without collapsing) AND obtain a certain measure of "XJ-bling"! Really dresses up---in a bright, loud way---your engine area, especially if used with colored spark plug wires and fuel lines. Thick-wall design is not very flexible like original vacuum hose, but can easily bend to accomodate the path from the petcock to the intake manifold nipple. Note that these are lines are "eye-blinding" bright colors. NOTE: this line is too small in its internal diameter to be used as fuel line.
NOTE: line is small enough in ID to seal tightly against the vacuum port nipples without any hose clamps being used, but if so desired, the HCP3104 hose clamps are the closest that come to fitting this hose.
All colored vacuum line sold in a 12" length and is priced at $ 4.95.
HCP4913 aftermarket 7/32" DARK BLUE VACUUM HOSE
HCP4914 aftermarket 7/32" NEON GREEN VACUUM HOSE
HCP4915 aftermarket 7/32" NEON PINK VACUUM HOSE
HCP4916 aftermarket 7/32" NEON YELLOW VACUUM HOSE
HCP4917 aftermarket 7/32" NEON PURPLE VACUUM HOSE
HCP4918 aftermarket 7/32" NEON ORANGE VACUUM HOSE
HCP4919 aftermarket 7/32" NEON RED VACUUM HOSE
NOTE: except for the colored vacuum lines above, do not use fuel line as vacuum line, and vice-versa. Fuel line is designed to withstand expansion pressures, while vacuum line is made to resist collapsing!
fl7) OEM Yamaha and Aftermarket vacuum hose PINCH CLAMPS, genuine spring-type tension clamp. Use 2 per hose for vacuum line.
HCP123 OEM vacuum hose PINCH CLAMP, fits the HCP121 vacuum line correctly, and just a little bit loose on the HCP2949 vacuum line. Each:
$ 1.50
HCP3104 Aftermarket vacuum hose PINCH CLAMP, fits the HCP2949 vacuum line, and just a little tight on the HCP121 vacuum line. Each:
$ 0.80
HCP3951 OEM vacuum hose PINCH CLAMP, fits the HCP5365C vacuum line. Each:
$ 1.95
HCP3102 Aftermarket vacuum hose PINCH CLAMP, fits the HCP5365C vacuum line. Each:
$ 0.90
info @ xj4ever.com
_________________ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
chacal Supporting Vendor
Joined: Aug 01, 2006 Posts: 4845 Location: At My Computer
Posted: Mon Dec 15, 2008 2:55 am Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION C:
FUEL SYSTEM ITEMS:
--Petcocks & Parts
PETCOCKS, REBUILD PARTS & KITS:
Original fuel petcocks: note that although these will physically bolt up to your tank, some versions are completely different from your original petcock in every way imaginable!
fp16) OEM Yamaha replacement fuel PETCOCKS. Brand new unit comes complete with the internal filter. This unit fits and looks "somewhat" the same as an original XJ-series petcock, but it is a completely new unit and no component (internal) parts will interchange between an original petcock and these units. Surprisingly, these units are still made by the Taiyo Giken Company, who supplied the original petcocks on the XJ era bikes....
HCP626 OEM fuel PETCOCK. The vacuum and fuel outlet port nipples point straight out towards the back of the bike (parallel to the front-to-back centerline of the bike). This is the most useful orientation for these outlet pipes, and the same as on original XJ petcocks. Includes the in-tank filters and the petcock-to-tank sealing o-ring. Fits all XJ550, XJ650 (except Turbo), and all XJ750 models. HOWEVER, this petcock is a bit "taller" than the original Yamaha petcocks, and on some models the dropped location of the vacuum port nipple on this petcock may cause clearance problems with the top of the carb hats (particularly on Seca model gas tanks, which tend to have a deeper "drop" on their bottom edge than the Maxim tanks). NOTE: petcock mounting screws and their washers are NOT included!
$ 117.00
HCP625 OEM fuel PETCOCK. The vacuum outlet port nipple points directly out towards the back of the bike, while the fuel outlet port nipple faces backwards and at a 45-degree angle outwards. This is a slightly odd orientation, but it does allow for slightly more space for the fuel line to be routed clear of obstructions, especially when using an aftermarket in-line fuel filter. Includes the in-tank filter and the petcock-to-tank sealing o-ring. Fits all XJ550, XJ650 (except Turbo), and XJ750 models. This style replacement petcock has plenty of vacuum nipple clearance for all replacement tanks, Seca and Maxim, for the models listed above. NOTE: petcock mounting screws and their washers are NOT included!
$ 89.95
HCP627 OEM fuel PETCOCK. The fuel inlet and outlet port nipples point directly out towards the back of the bike and tilted upwards at a 45-degree angle. Includes the in-tank filters and the petcock-to-tank sealing o-ring. Fits all XJ650 Turbo models. NOTE: petcock mounting screws and their washers are NOT included!
$ 121.95
HCP628 OEM fuel PETCOCK. The vacuum port nipple points directly out towards the back of the bike (rather than being angled as the original) and the fuel inlet port nipple is tilted upwards at about a 45-degree angle and is NOT angled towards the center of the bike (as original), nor is the fuel inlet nipple as long as on an original petcock. Surprisingly, besides these minor differences, these petcocks look exactly the originals. Also, the changed inlet pipe orientation results in being able to install the rear petcock-to-tank mounting screw easily---on original petcocks, you basically have to almost hacksaw the screw off to remove/replace it or the fiber sealing washer! (a wonderful feat of factory engineering!). Includes the in-tank filter and the petcock-to-tank sealing o-ring. Fits all XJ700 and XJ900RK models. NOTE: petcock mounting screws and their washers are NOT included!
$ 114.95
Aftermarket ON-OFF Fuel Valves:
fp17) Aftermarket complete ON-OFF-RESERVE FUEL VALVE KITS. Not really a "petcock" in the XJ sense of the word. Yamaha designed their petcocks to be a very clever "automatic" fuel supply valve, meaning it has to have engine vacuum for it to function. Great idea (when it works) because it allows us to basically "set it and forget it". Bad news is that when the seals go bad, or as age wears the internal components, it can become a really bad idea, since it will leak fuel into the carbs when it's not supposed to, leading to flooded carbs, fuel in the crankcase, spun bearings, etc.
A true fuel VALVE is either ON (in either the standard "ON" or the "RES"erve positions) or it's OFF. And it doesn't depend on engine vacuum, just gravity. So it won't ever leak or pass fuel in the OFF position. That's the good news. The bad news is that you have to remember to turn it on or off manually (as in every time you start your bike up or shut it down) or, instead of blaming a faulty petcock for your resultant problems, you'll have to blame yourself!
Once installed, this unit fits and looks somewhat the same as an original XJ-series petcock, what with the chrome faceplate and selector lever. It obviously has no vacuum nipple, only a rear-ward facing fuel outlet, which means you will need to remove your petcock vacuum line from the #3 intake manifold boot nipple and replace it with a rubber block-off cap plug. These fuel valves use the same size fuel line as original.
Available in two versions:
Our STANDARD VERSION requires the use a adapter plate on the bottom of your fuel tank that this fuel valve screws into, and has a cylindrical, brass-mesh, in-tank fuel filter (included with this valve) which is larger than the opening in the bottom of the gas tank, and thus you'll have to grind the tank opening with a dremel tool or steel file to allow the filter to go into the opening. Our complete HCP630KIT34 and HCP630KIT46 kits (below) includes a bolt-on grinding template so you'll know exactly how much metal to remove.
The downside to this standard version is that it requires you to modify your original gas tank (and somehow keep the metal shavings/filings out of your tank, or use of a telescoping magnet to retrieve such metal particles out of the tank after the enlargement procedure is completed), and, once you modify your opening, an original petcock cannot be used on such tank again, as it will leak around this enlarged opening.
Our DELUXE VERSION still requires the use a adapter plate on the bottom of your fuel tank that this fuel valve screws into, but has been modified to fit into the stock, original fuel opening on the bottom of your tank, and has stock-style "straw" fuel filters included. Our complete HCP10336KIT34 and HCP10336KIT46 kits (below) requires no tank modification at all, being truly bolt-on.
All-in-all, either of these fuel valve kits are a great value and a fine idea. It forever eliminates the dreaded "leaking petcock" problems associated with 20+ year old factory petcocks for a price just slightly more than what it costs to rebuild a factory petcock. On the downside, you will have to remember to turn this unit off or on every single time!
XJ550, XJ650 (except Turbo), XJ750, and XJ1100 models:
HCP630KIT34 Aftermarket complete STANDARD VERSION ON-OFF FUEL VALVE KIT, contain everything you'll need to replace a factory all XJ550, XJ650 (except Turbo), XJ750, and XJ1100 models. Includes the fuel valve, the HCP99 adapter plate, the HCP632 mesh in-tank fuel filter, the HCP1281 tank grinding template, a single HCP81 intake manifold nipple CAP PLUG, and a single HCP542 cap plug PINCH CLAMP. Reguires fuel tank opening enlargement!
$ 54.95
HCP632 Aftermarket replacement brass-mesh FUEL FILTER for the HCP630 fuel valve, filter only.
$ 11.00
HCP99 Aftermarket fuel valve-to-tank ADAPTER PLATE, includes the plate, plate-to-tank mounting screws, screw washers, die-cut plate-to-tank gasket, and a packet of gasket sealer/thread sealant. This adapter plate fits all XJ550, XJ650 (except Turbo), XJ750, and XJ1100 models.
$ 24.95
HCP1281 Aftermarket tank opening RE-SIZING TEMPLATE....a bolt-on thin aluminum plate that has a hole the exact size and placement needed to enlarge the petcock opening hole in the tank to accept the HCP630 fuel valve listed above. Takes the guesswork out of this critical task! This grinding template fits all XJ550, XJ650 (except Turbo), XJ750, and XJ1100 models.
$ 7.00
HCP10336KIT34 Aftermarket complete DELUXE VERSION ON-OFF FUEL VALVE KIT, contain everything you'll need to replace a factory all XJ550, XJ650 (except Turbo), XJ750, and XJ1100 models. Includes the fuel valve, the HCP99 adapter plate, a pair of the HCP10180 mesh in-tank fuel filters, a single HCP81 intake manifold nipple CAP PLUG, and a single HCP542 cap plug PINCH CLAMP. Does NOT reguire fuel tank opening enlargement!
$ 69.95
HCP10180SET2 Aftermarket replacement mesh FUEL FILTERS for the HCP10336KIT34 fuel valve, includes two "straw" filters only.
$ 9.95
XJ700 and XJ900RK models:
HCP630KIT46 Aftermarket complete STANDARD VERSION ON-OFF FUEL VALVE KIT, contain everything you'll need to replace a factory XJ700 or XJ900 petcock. Includes the fuel valve, the HCP2981 adapter plate, the HCP632 mesh in-tank fuel filter, the HCP3013 tank grinding template, a single HCP81 intake manifold nipple CAP PLUG, and a single HCP542 cap plug PINCH CLAMP. Reguires fuel tank opening enlargement!
$ 54.95
HCP632 Aftermarket brass-mesh FUEL FILTER for the HCP630 fuel valve, filter only.
$ 11.00
HCP2981 Aftermarket fuel valve-to-tank ADAPTER PLATE, includes the plate, plate-to-tank mounting screws, screw washers, die-cut plate-to-tank gasket, and a packet of gasket sealer/thread sealant. This adapter plate fits all XJ700 and XJ900RK models.
$ 24.95
HCP3013 Aftermarket tank opening RE-SIZING TEMPLATE....a bolt-on thin aluminum plate that has a hole the exact size and placement needed to enlarge the petcock opening hole in the tank to accept the HCP630 fuel valve listed above. Takes the guesswork out of this critical task! This grinding template fits all XJ700 and XJ900RK models.
$ 7.00
HCP10336KIT46 Aftermarket complete DELUXE VERSION ON-OFF FUEL VALVE KIT, contain everything you'll need to replace a factory all XJ700 and XJ900RK models. Includes the fuel valve, the HCP2981 adapter plate, a pair of the HCP10180 mesh in-tank fuel filters, a single HCP81 intake manifold nipple CAP PLUG, and a single HCP542 cap plug PINCH CLAMP. Does NOT reguire fuel tank opening enlargement!
$ 69.95
HCP10180SET2 Aftermarket replacement mesh FUEL FILTERS for the HCP10336KIT46 fuel valve, includes two "straw" filters only.
$ 9.95
rp3) Aftermarket mini in-line FUEL ON-OFF VALVE. This 1/4" inlet/outlet fuel shutoff valve provides a fail-safe solution for leaky petcocks. Small size allows it to easily fit under the gas tank, within the petcock-to-carb fuel line. Lever handle can be set to full on or full off position. Best solution is to repair or replace a leaky petcock, but for a quick and easy solution, this valve will do the job.
HCP764 Aftermarket mini in-line FUEL ON-OFF VALVE:
$ 16.95
Petcock Block-Off Plates:
t1) Aftermarket petcock tank opening painting BLOCK-OFF PLATE AND GASKET----a die-cut thin aluminum plate and matching rubber gasket, exactly the same size as the petcock-to-tank top mounting flange (or "face").
Before tank paint stripping or during actual tank painting, you'll remove your petcock and replace it with this plate, and therefore won't paint the oval petcock mounting area on the tank (which you definitely don't want to do---it should be bare metal for a proper seal). Includes a pair of mounting screws also, so you don't have to paint over your original or new petcock-to-tank mounting screws, either.
Of course, these block-off plates also works great when performing an electrolytic cleaning of the tank, since you really DON'T want to leave your petcock in the tank when performing such a process!
HCP634SET Aftermarket petcock BLOCK-OFF PLATE AND GASKET. Fits all XJ550 models, all XJ650 (except Turbo) models, all XJ750 tanks, and all XJ1100 models.
$ 8.95
HCP3010SET Aftermarket petcock BLOCK-OFF PLATE AND GASKET. Fits all XJ650 Turbo models, all XJ700 models, and all XJ900RK Seca tanks.
$ 8.95
Fuel Sender Block-Off Plates:
t2) Aftermarket tank fuel sender opening tank painting BLOCK-OFF PLATE AND GASKET----a die-cut thin plastic plate and matching rubber gasket, exactly the same size as the petcock-to-tank top mounting flange (or "face").
Before tank paint stripping or during actual tank painting, you'll remove your fuel sending unit and replace it with this plate, and therefore won't paint the sender mounting area on the tank (which you definitely don't want to do---it should be bare metal for a proper seal). Includes a set of four mounting screws also, so you don't have to paint over your original or new sender-to-tank mounting screws, either.
Of course, these block-off plate also works great when performing an electrolytic cleaning of the tank, since you really DON'T want to leave your sending unit in the tank when performing such a process!
HCP2738SET Aftermarket fuel sending unit BLOCK-OFF PLATE AND GASKET. Fits all XJ550 Seca, XJ650 Turbo, XJ750 Seca, 1982 XJ750 Maxim, and XJ1100 tanks.
$ 8.95
HCP6371SET Aftermarket fuel sending unit BLOCK-OFF PLATE AND GASKET. Fits all XJ700 tanks.
$ 8.95
HCP6373SET Aftermarket fuel sending unit BLOCK-OFF PLATE AND GASKET. Fits all XJ900RK tanks.
$ 9.95
INDIVIDUAL PETCOCK REPAIR PARTS AND KITS:
Petcock Selector Lever & Distribution Valve Parts:
fp13) Petcock fuel position SELECTOR LEVER O-RING. These are usually worn out and need to be replaced whenever you go into the petcock. This o-ring found into the groove along the outside of the selector lever.
HCP108 OEM petcock SELECTOR LEVER O-RING. Fits all XJ550, XJ650 (except Turbo models), XJ750, and XJ1100 models using the original petcock.
$ 5.00
HCP1383 Aftermarket petcock SELECTOR LEVER O-RING, made from a soft, long-lasting Buna-N material. Fits all XJ550, XJ650 (except Turbo models), XJ750, and XJ1100 models using the original petcock.
$ 2.95
HCP5884 Aftermarket petcock SELECTOR LEVER O-RING, made from a harder, better-sealing Viton material. Fits all XJ550, XJ650 (except Turbo models), XJ750, and XJ1100 models using the original petcock.
$ 3.95
HCP2339 OEM petcock SELECTOR LEVER O-RING. Fits all XJ650 Turbo, and all XJ700 and XJ900RK models using the original petcock.
$ 5.00
HCP5869 Aftermarket petcock SELECTOR LEVER O-RING, made from a soft, long-lasting Buna-N material. Fits all XJ650 Turbo, and all XJ700 and XJ900RK models using the original petcock.
$ 2.95
HCP5885 Aftermarket petcock SELECTOR LEVER O-RING, made from a harder, better-sealing Viton material. Fits all XJ650 Turbo, and all XJ700 and XJ900RK models using the original petcock.
$ 3.95
fp12) Petcock fuel position selector lever DISTRIBUTION VALVE. This is the hard plastic molded disc with the 4 holes in it that fits below the selector lever. These are usually worn out and need to be replaced whenever you go into the petcock. A worn valve will cause your petcock to leak fuel while in the RUN position.
HCP109 OEM selector lever DISTRIBUTION VALVE. Fits all XJ550, all XJ650 (except Turbo models), all XJ750, and all XJ1100 models.
$ 9.00
HCP1384 Aftermarket selector lever DISTRIBUTION VALVE. Fits all XJ550, all XJ650 (except Turbo models), all XJ750, and all XJ1100 models. Same as the HCP109 above but at a better price!
$ 5.00
HCP2338 OEM selector lever DISTRIBUTION VALVE. Fits all XJ650 Turbo models, and all XJ700 and XJ900RK models.
$ 9.00
HCP2930 Aftermarket selector lever DISTRIBUTION VALVE. Fits all XJ650 Turbo models, all XJ700 and XJ900RK models. Same as the HCP2338 above but at a better price!
$ 5.00
fp11) Petcock fuel position selector lever WAVE WASHER. These are usually worn out and need to be replaced whenever you go into the petcock. This spring washer fits in-between the selector lever and the outer faceplate, and provides the proper spring-pressure against the selector lever to properly engage the distribution valve.
HCP107 OEM selector lever WAVE WASHER. Fits all XJ550, all XJ650 (except Turbo), and all XJ750 models.
$ 2.00
HCP2918 OEM selector lever WAVE WASHER. Fits all XJ650 Turbo, all XJ700 models, and XJ900RK models.
$ 1.50
fp4) OEM petcock LEVER REBUILD KIT. These kits contain the plastic distribution "valve", the fuel position lever o-ring, and the fuel selector lever wave (spring) washer.
HCP945 petcock LEVER REBUILD KIT, fits all XJ550, all XJ650 (except turbo), and all XJ750 original petcocks.
$13.00
Petcock Mounting O-Ring:
fp10) Petcock fuel position PETCOCK-TO-TANK O-RING. These are usually worn out and need to be replaced whenever you remove the petcock. This rubber o-ring fits onto the top of the petcock.
HCP117 OEM PETCOCK-TO-TANK O-RING. Fits all XJ550, all XJ650 (except turbo), all XJ750, and XJ1100 original petcocks. Molded into a oval shape as original. Each:
$ 3.50
HCP1385 Aftermarket PETCOCK-TO-TANK O-RING. This is a large o-ring and is NOT molded like original; however, it will fit and seal correctly. Fits all XJ550, all XJ650 (except turbo), all XJ750, and XJ1100 original petcocks. Each:
$ 2.50
HCP2340 OEM PETCOCK-TO-TANK O-RING. Fits all XJ650 Turbo models, all XJ700 and XJ900RK models. Molded into a oval shape as original.
$ 3.50
HCP1659 Aftermarket PETCOCK-TO-TANK O-RING. This is a large o-ring and is NOT molded like original; however, it will fit and seal correctly. Fits all XJ650 Turbo models, all XJ700 and XJ900RK models.
$ 2.50
HCP6190 Aftermarket PETCOCK-TO-TANK O-RING. This molded oem replacement sealing ring is correct for the HCP625 and HCP626 replacement petcocks only, Correct molded oval seal with cross-bars fits and seals correctly. Fits the replacement HCP625 and HCP626 petcock only!
$ 3.95
Petcock Fuel Outlet Plate Gasket:
fp19a) Petcock fuel outlet plate GASKET. These are usually worn out and need to be replaced whenever you remove the petcock. This rubber o-ring fits onto the top of the petcock.
HCP114 Aftermarket petcock fuel outlet cover plate GASKET, die cut reproduction of the original. Fits all original XJ550, XJ650 (except Turbo), and XJ750 petcocks that use a detachable fuel outlet port cover plate.
$ 5.95
Petcock Hardware and Fasteners:
fp8) Petcock-to-Tank MOUNTING SCREW. The heads on these are usually stripped and need to be replaced whenever you remove the petcock. NOTE: original Yamaha screws feature a small, integral shoulder flange. All aftermarket screws have an overall head diameter that is similar to the original screws, but do NOT have a flange.
HCP118 OEM petcock-to-tank MOUNTING SCREW, grey-phosphate coated alloy steel. Fits all XJ550, XJ650, XJ750, and XJ1100 models. Each.
$ 1.50
HCP118SET2 OEM petcock-to-tank MOUNTING SCREWS, set of two.
$ 2.50 pair
HCP2922 Aftermarket petcock-to-tank MOUNTING SCREW, bright zinc-plated steel with phillips drive, pan-headed design. Fits all XJ550, XJ650, XJ750, and XJ1100 models. Each.
$ 1.00
HCP2922SET2 Aftermarket petcock-to-tank MOUNTING SCREWS, set of two.
$ 1.50 pair
HCP2923 Aftermarket petcock-to-tank MOUNTING SCREW, bright 18-8 stainless steel with phillips drive, pan-headed design. Fits all XJ550, XJ650, XJ750, and XJ1100 models. NOTE: these screws are slightly longer (2mm) than stock but it makes no difference in fit and function. Each.
$ 1.50
HCP2923SET2 Aftermarket petcock-to-tank MOUNTING SCREWS, set of two.
$ 2.50 pair
HCP2924 Aftermarket petcock-to-tank MOUNTING SCREW, black-oxide coated 18-8 stainless steel with phillips drive, pan-headed design. Fits all XJ550, XJ650, XJ750, and XJ1100 models. NOTE: these screws are slightly longer (2mm) than stock but it makes no difference in fit and function. Each:
$ 1.50
HCP2924SET2 Aftermarket petcock-to-tank MOUNTING SCREWS, set of two.
$ 2.50 pair
HCP2341 OEM petcock-to-tank MOUNTING SCREW. Fits all XJ700 and XJ900RK models. NOTE: the original petcock screw has an integral flanged washer under the head, and this flanged head makes is VERY hard to remove, as the petcock body and the fuel outlet port "traps" the flanged washer when trying to remove the screw. These replacement tank screws HAVE NO FLANGED WASHER ATTACHED, so it "fits" onto the petcock body much easier, while still providing the sealing surface necessary. Each.
$ 1.50
HCP2341SET2 OEM petcock-to-tank MOUNTING SCREWS, set of two.
$ 2.50 pair
fp7) Petcock-to-Tank mounting screw WASHER. These washers are made from a fuel-resistant hard fiber material and need to be replaced every so often, and certainly every time you remove the petcock from the tank.
HCP2743 OEM Petcock-to-Tank Mounting Screw WASHER. Fits all XJ550, XJ650, XJ700, XJ750, XJ900RK, and XJ1100 models. Each.
$ 1.00
HCP2743SET2 OEM Petcock-to-Tank Mounting Screw WASHERS, set of two.
$ 1.75 pair
fp19) Petcock chrome selector lever FACEPLATE MOUNTING SCREW, the tiny phillips-headed screws that secure the chrome ON-FUEL-RES-PRI faceplate to the petcock body. Originals normally have stripped heads after one or two on-and-off sessions. Fits all XJ550, XJ650, XJ700, XJ750, XJ900RK, and XJ1100 petcocks. Use 2 per petcock.
HCP104 OEM petcock FACEPLATE MOUNTING SCREW, each:
$ 1.25
HCP104SET2 OEM petcock FACEPLATE MOUNTING SCREWS, set of 2:
$ 2.00
HCP2907 Aftermarket petcock FACEPLATE MOUNTING SCREW, zinc-plated alloy steel, each:
$ .75
HCP2907SET2 OEM petcock FACEPLATE MOUNTING SCREWS, set of 2:
$ 1.25
HCP105 Aftermarket petcock FACEPLATE MOUNTING SCREW, 18-8 stainless steel, each:
$ 1.50
HCP105SET2 OEM petcock FACEPLATE MOUNTING SCREWS, set of 2:
$ 2.50
HCP2908 Aftermarket petcock FACEPLATE MOUNTING SCREW, black-oxide coated steel, each:
$ 1.00
HCP2908SET2 OEM petcock FACEPLATE MOUNTING SCREWS, set of 2:
$ 1.75
fp29) Petcock vacuum diaphram COVER PLATE SCREW, flathead phillips-headed screws that secure the vacuum diaphram cover plate to the petcock body. Fits all XJ550, XJ650 except Turbo, all XJ700 models, all XJ750 petcocks, XJ900RK, and the XJ1100 vacuum diaphram unit. Use 4 per petcock or vacuum unit.
HCP5895 Aftermarket vacuum diaphram COVER PLATE SCREW, zinc-plated alloy steel, flathead phillips-drive, with a natural finish, each:
$ 1.00
HCP5895SET4 Aftermarket vacuum diaphram COVER PLATE SCREWS, zinc-plated alloy steel, flathead phillips-drive, with a natural finish, set of 4:
$ 2.50
HCP5897 Aftermarket vacuum diaphram COVER PLATE SCREW, 18-8 stainless steel, flathead phillips-drive, with a bright finish, each:
$ 1.50
HCP5897SET4 Aftermarket vacuum diaphram COVER PLATE SCREWS, 18-8 stainless steel, flathead phillips-drive, with a bright finish, set of 4:
$ 5.00
fp31) Petcock fuel outlet COVER PLATE SCREW, flathead phillips-headed screws that secure the fuel outlet cover plate to the petcock body. Fits all XJ550, XJ650 except Turbo, and all XJ750 petcocks. Use 2 per petcock or vacuum unit.
HCP5891 Aftermarket fuel outlet COVER PLATE SCREW, zinc-plated alloy steel, flathead phillips-drive, with a natural finish, each:
$ 1.00
HCP5891SET2 Aftermarket fuel outlet COVER PLATE SCREWS, zinc-plated alloy steel, flathead phillips-drive, with a natural finish, set of 2:
$ 1.50
HCP5893 Aftermarket fuel outlet COVER PLATE SCREW, 18-8 stainless steel, flathead phillips-drive, with a bright finish, each:
$ 1.50
HCP5893SET2 Aftermarket fuel outlet COVER PLATE SCREWS, 18-8 stainless steel, flathead phillips-drive, with a bright finish, set of 2:
$ 2.75
Petcock Fuel Drain:
fp32) Petcock front FUEL DRAIN SCREW, panhead phillips-drive screw fits to the lower front of the petcock and allows it to be drained.
HCP1478 OEM petcock fuel drain FUEL DRAIN SCREW, zinc-plated alloy steel, flathead phillips-drive, with a natural finish. Fits all XJ650 Turbo, all original XJ750 Maxim and Midnight Maxim models, and XJ700 and XJ900RK models that used a bottom drain screw (note: some XJ700 and XJ900RK model original petcocks did NOT use a drain screw) petcocks.
$ 1.25
HCP60 OEM petcock FUEL DRAIN SCREW, zinc-plated alloy steel, flathead phillips-drive, with a natural finish. NOTE: these screws are approx. 2mm longer than stock, but will still fit correctly. Fits all XJ1100 models, use 2 per petcock. Each:
$ 1.00
HCP60SET2 OEM petcock FUEL DRAIN SCREWS, zinc-plated alloy steel, flathead phillips-drive, with a natural finish, set of 2:
$ 1.75
HCP60SET4 OEM petcock FUEL DRAIN SCREW, zinc-plated alloy steel, flathead phillips-drive, with a natural finish, set of 4:
$ 3.50
HCP5887 Aftermarket petcock FUEL DRAIN SCREW, zinc-plated alloy steel, flathead phillips-drive, with a natural finish, fits all XJ1100 models, use 2 per petcock.each:
$ 1.00
HCP5887SET2 Aftermarket petcock FUEL DRAIN SCREWS, zinc-plated alloy steel, flathead phillips-drive, with a natural finish, set of 2:
$ 1.50
HCP5887SET4 Aftermarket petcock FUEL DRAIN SCREWS, zinc-plated alloy steel, flathead phillips-drive, with a natural finish, set of 4:
$ 2.75
HCP5888 Aftermarket petcock FUEL DRAIN SCREW, 18-8 stainless steel, flathead phillips-drive, with a bright finish, fits all XJ1100 models, use 2 per petcock, each:
$ 2.00
HCP5888SET2 Aftermarket petcock FUEL DRAIN SCREWS, 18-8 stainless steel, flathead phillips-drive, with a bright finish, set of 2:
$ 3.75
HCP5888SET4 Aftermarket petcock FUEL DRAIN SCREWS, 18-8 stainless steel, flathead phillips-drive, with a bright finish, set of 4:
$ 6.75
fp33) Petcock fuel drain screw GASKET, translucent plastic fuel drain screw gasket fits behind the drain screw. A common source of leaks on these petcocks.
HCP7446 OEM petcock fuel drain screw GASKET, clear plastic gasket used on all XJ650 Turbo, all original XJ750 Maxim and Midnight Maxim models, and XJ700 and XJ900RK models that used a bottom drain screw (note: some XJ700 and XJ900RK model original petcocks did NOT use a drain screw) petcocks.
$ 1.50
HCP5374 OEM petcock fuel drain screw GASKET, clear plastic gasket used on all XJ1100 models, use 1 per screw, 2 per petcock. Each:
$ 3.00
HCP5374SET2 OEM petcock fuel drain screw GASKETS, set of 2:
$ 5.00
HCP5374SET4 OEM petcock fuel drain screw GASKETS, set of 4:
$ 9.00
Petcock Vacuum Diaphram Parts:
fp3) Aftermarket petcock STANDARD VACUUM DIAPHRAM REPAIR KITS. This is the part that, when worn, torn, or ruptured, allows fuel to leak into the carbs all the time. Double-gasketed plunger assembly has the o-ringed plunger tip. You must save and re-use your original plastic spacer plate!
HCP110 Aftermarket petcock STANDARD VACUUM DIAPHRAM REPAIR KIT. Fits all XJ550, XJ650 (except turbo), and XJ750 models with an original o-ringed plunger tip. Order the HCP663 washer listed below if using this repair kit to repair a petcock that originally used a "d"-ring on the plunger tip.
$ 12.00
HCP1657 Aftermarket petcock STANDARD VACUUM DIAPHRAM REPAIR KIT. Fits all XJ700, XJ900, and XJ1100 models. Order the HCP663 washer listed below if using this repair kit to repair a petcock that originally used a "d"-ring on the plunger tip.
$ 14.00
fp14) Aftermarket petcock DELUXE VACUUM DIAPHRAM REPAIR KITS. This is the part that, when worn, torn, or ruptured, allows fuel to leak into the carbs all the time. Double-gasketed plunger assembly has the o-ringed plunger tip, and comes complete with the plastic spacer plate!
HCP2282 Aftermarket petcock DELUXE VACUUM DIAPHRAM REPAIR KIT, complete with the plastic spacer plate. Fits all XJ550, XJ650 (except turbo), and XJ750 models with an original o-ringed plunger tip. Order the HCP663 washer listed below if using this repair kit to repair a petcock that originally used a "d"-ring on the plunger tip.
$ 19.00
fp5) Aftermarket petcock complete STANDARD REBUILD KITS. These kits contain either the HCP110 or HCP1657 vacuum diaphram repair kit (above), plus the plastic distribution "valve", the fuel position lever o-ring, and the petcock-to-tank mounting o-ring. NOTE: petcock mounting screws, mounting screw washers, faceplate screws, and selector lever wave washer is NOT included in this kit and must be ordered separately if desired.
HCP124 Aftermarket petcock standard Complete STANDARD REBUILD KIT. Fits all XJ550, all XJ650 (except Turbo models), and all XJ750 models with an original o-ringed plunger tip. Order the HCP663 washer listed below if using this repair kit to repair a petcock that originally used a "d"-ring on the plunger tip.
$ 26.00
HCP1661 Aftermarket petcock standard Complete STANDARD REBUILD KIT. Fits all XJ700/900 models with an original o-ringed plunger tip. Order the HCP663 washer listed below if using this repair kit to repair a petcock that originally used a "d"-ring on the plunger tip.
$ 27.00
HCP1662 Aftermarket petcock standard Complete STANDARD REBUILD KITS. Fits all XJ1100 models. Includes 2 each of the selector lever o-ring, the petcock-to-tank mounting o-ring, and the fuel distribution valve. Also comes with the vacuum diaphram used in the external fuel distribution unit. One kit does both petcocks and the external unit. Order the HCP663 washer listed below if using this repair kit to repair a distribution unit that originally used a "d"-ring on the vacuum plunger tip.
$ 27.00
fp22) Aftermarket petcock complete DELUXE REBUILD KITS. These kits contain everything you'll need to do a complete rebuild and replacement of your factory petcock, including mounting screws and washers and a fuel filter!
HCP6060 Aftermarket petcock Complete DELUXE REBUILD KIT: contains everything you'll need to repair an original petcock: the HCP2282 deluxe diaphram repair kit (with the plastic spacer plate); the selector lever o-ring, wave washer, and distribution valve; the petcock-to-tank o-ring, two stainless faceplate screws, two petcock-to-tank mounting screws and their sealing washers, the fuel outlet plate gasket, and the in-tank filter! Fits all XJ550, all XJ650 (except Turbo models), and all XJ750 models with an original o-ringed plunger tip. Order the HCP663 washer listed below if using this repair kit to repair a petcock that originally used a "d"-ring on the plunger tip.
$ 52.00
HCP5870 Aftermarket petcock Complete DELUXE REBUILD KIT: contains everything you'll need to repair an original petcock: the diaphram repair kit; the selector lever o-ring, wave washer, and distribution valve; the petcock-to-tank o-ring, two stainless faceplate screws, and two petcock-to-tank mounting screws and their sealing washers, and the in-tank filter! Fits all XJ700 and XJ900RK models with an original o-ringed plunger tip.
$ 52.00
HCP5871 Aftermarket petcock Complete DELUXE REBUILD KIT: contains everything you'll need to repair both original petcocks and the vacuum pod control unit: the HCP2282 deluxe diaphram repair kit (with the plastic spacer plate); two each of the selector lever o-ring, wave washer, and distribution valve; two of the petcock-to-tank o-ring, four stainless faceplate screws, four petcock-to-tank mounting screws and their sealing washers, two of the petcock drain screws and their sealing washers, two each of the vacuum diaphram pod short and long screws with lockwashers, and two of the in-tank filters! For all XJ1100 models with the original dual petcocks and separate vacuum control unit.
$ 99.00
fp6) HCP663 petcock vacuum diaphram spring SHIM WASHER. Order this washer to be able to use any of the diaphram repair kits on a petcock that originally used a "d"-shaped rubber ring on the plunger tip. This washer goes behind the plunger spring and acts as a tension shim to allow the spring to put more pressure on the replacement-style o-ringed plunger tip, and thus allowing it to seat and seal properly. The key is this: if you are using an "o-ring" vacuum diaphram repair kit (NOTE: all of the replacement vacuum diaphram repair kits are only available with an o-ring tipped seat plunger!) to replace an original "d-ringed" plunger, then you'll need to use this shim! Used on all XJ550, XJ650 except Turbo, XJ700, XJ750, XJ900, and XJ1100 petcocks (or vacuum module for 1100's).
$ 1.00
fp311) OEM fuel distribution and vacuum control VALVE ASSEMBLY,, complete unit as used on XJ1100 models only. Attaches to the C-shaped bracket that is located on top of the #1 carb hat.
HCP5375 OEM fuel distribution complete VALVE ASSEMBLY, with the small mounting bracket, for all XJ1100 models. Does NOT include the c-shaped carb hat bracket. Each:
$ 72.00
HCP5376 OEM fuel distribution valve assembly MOUNTING BOLT, use 1 per assembly, for all XJ1100 models. Each:
$ 4.00
HCP2185 OEM fuel distribution valve assembly mounting bolt LOCK WASHER, use 1 per assembly, for all XJ1100 models. Each:
$ 1.00
HCP6066 Aftermarket vacuum diaphram cover plate SCREW, zinc-plated alloy steel, panhead phillips-drive, with a natural finish, for the upper (short) position that do not go through the mounting bracket. NOTE: these screws are approximately 2mm longer than original, but still fit and function correctly. Original screws had integral lock washers, which these replacement screws do not. Order the lockwashers separately below. For all XJ1100 models. Each:
$ 1.00
HCP6066SET2 Aftermarket vacuum diaphram cover plate SCREW, zinc-plated alloy steel, panhead phillips-drive, with a natural finish, set of 2:
$ 1.50
HCP6068 Aftermarket vacuum diaphram cover plate SCREW, 18-8 stainless steel, panhead phillips-drive, with a bright finish, for the upper (short) position that do not go through the mounting bracket. NOTE: these screws are approximately 2mm longer than original, but still fit and function correctly. Original screws had integral lock washers, which these replacement screws do not. Order the lockwashers separately below. For all XJ1100 models. Each:
$ 1.90
HCP6068SET2 Aftermarket vacuum diaphram cover plate SCREW, zinc-plated alloy steel, panhead phillips-drive, with a natural finish, set of 2:
$ 3.50
HCP6062 Aftermarket vacuum diaphram cover plate SCREW, zinc-plated alloy steel, panhead phillips-drive, with a natural finish, for the lower (long) position that do go through the mounting bracket. NOTE: these screws are approximately 2mm longer than original, but still fit and function correctly. Original screws had integral lock washers, which these replacement screws do not. Order the lockwashers separately below. For all XJ1100 models. Each:
$ 1.00
HCP6062SET2 Aftermarket vacuum diaphram cover plate SCREW, zinc-plated alloy steel, panhead phillips-drive, with a natural finish, set of 2:
$ 1.50
HCP6064 Aftermarket vacuum diaphram cover plate SCREW, 18-8 stainless steel, panhead phillips-drive, with a bright finish, for the lower (long) position that do go through the mounting bracket. NOTE: these screws are approximately 2mm longer than original, but still fit and function correctly. Original screws had integral lock washers, which these replacement screws do not. Order the lockwashers separately below. For all XJ1100 models. Each:
$ 1.90
HCP6064SET2 Aftermarket vacuum diaphram cover plate SCREW, 18-8 stainless steel, panhead phillips-drive, with a bright finish, set of 2:
$ 3.50
HCP922 Aftermarket zinc-plated alloy steel, natural finish diaphram cover plate screw LOCK WASHER, use 4 per control unit, for all XJ1100 models. Each:
$ 0.50
HCP922SET4 Aftermarket zinc-plated alloy steel natural finish diaphram cover plate screw LOCK WASHERS. set of 4:
$ 1.50
HCP336 Aftermarket 18-8 stainless-steel polished finish diaphram cover plate screw LOCK WASHER, for all XJ1100 models, each:
$ 0.60
HCP336SET4 Aftermarket 18-8 stainless-steel polished finish diaphram cover plate mounting screw LOCK WASHERS, set of 4:
$ 2.00
FREE STANDARD SHIPPING {OR JUST $5.00 FOR PRIORITY MAIL} SHIPPING IN THE USA FOR ALL ORDERS OVER $100 !!!!
$7.50 STANDARD SHIPPING TO CANADA FOR ALL ORDERS OVER $100 !!!!
Paypal accepted. Worldwide shipping available. Shipping prices and insurance costs are NOT included in the prices of items unless specifically listed. Please write with your list of parts needs and I will be glad to quote your shipping costs to you.
You can either PM (Private Message) me through this website, e-mail us via the "email" button on the bottom of this post, or e-mail us directly at:
info @ xj4ever.com
PLEASE NOTE!: our e-mail address does NOT have spaces before or after the "@" symbol........the posting system on this website automatically adds blank spaces before and after that symbol as an anti-spam feature! Make sure you eliminate those blank spaces when sending us an e-mail! Our e-mail address does NOT have any blank spaces in it!!
PLEASE!: on each and every correspondence with us, please tell us what YEAR and MODEL bike you have (example: 1982 XJ650 Maxim) and what your NAME (first name, at least!) is......that information really makes life a bit easier for us, and insures a more timely and ACCURATE response from us back to you!
MORE XJ PARTS IN THE FOLLOWING POST!!
