 Latest: Docwits
 New Today: 0
 New Yesterday: 0
 Overall: 13244
 Members: 0
 Visitors: 18
 Total: 18
Who Is Where: Visitors:01: Forums
We have received 97138681page views since August 9, 2005
Forums › XJBikes Marketplace › XJ4Ever - Supporting Vendor › XJ MAXIM, SECA, AND TURBO PARTS CATALOG
XJ MAXIM, SECA, AND TURBO PARTS CATALOGYamaha XJ parts and accessories
Go to page Previous 1, 2, 3, 4, 5, 6 Next
chacal Supporting Vendor
Joined: Aug 01, 2006 Posts: 4845 Location: At My Computer
Posted: Sun Dec 21, 2008 3:34 am Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION L:
WHEELS, AXLES, AND TIRES:
-- Front Wheel Bearings, axles, speedometer drive, and related.
-- Rear Wheel Bearings, axles, and related.
-- Bearing Tools.
FRONT WHEEL BEARING, AXLE, AND SPEEDOMETER DRIVE PARTS:
wb2) Original and aftermarket wheel and axle parts, bearings, and seals will restore that like-new ride and feel to your machine.
Our premium quality front and rear WHEEL BEARINGS & SEALS KITS provide you with the highest-performance sealed replacement bearings available. These premium grade, high-speed bearings feature low-drag and double-lip seals on both sides to provide superior exclusion of water and dirt, while also greatly enhancing grease retention. Note that most original wheel bearings were exposed on one or both sides, thus making these bearings are great improvement over stock. All of these bearing kits use fully sealed style bearings which never require grease packing or re-packing.
The type "TC" elastomer wheel seals that come in these kits are designed to keep out dirt and moisture, the killer of bearings. The rubber-coated outside diameter creates an optimum seal at the hub.
Note that if you plan to replace the bearing yourself, that removal of pressed-in bearings such as these can be rather difficult without special tools. We have an 8-piece bearing removal tool kit to help make this job easier listed further below.
Finally, ALWAYS replace at least the wheel axle "castle nut" COTTER PINS whenever they have been removed.
Front Wheel Bearing & Seals Kits:
HCP1915 Aftermarket complete front wheel BEARINGS AND SEALS KIT, for all XJ550, XJ650, XJ700, XJ750, and XJ900RK models. Two bearings and two seals......note that XJ700 models only came with one seal originally, and owners of these models will need to discard the unnecessary left side (small) seal that comes with this kit.
$ 17.95
HCP1916 Aftermarket complete front wheel BEARINGS AND SEALS KIT, for all XJ1100 models. Two bearings and two seals comes with this kit.
$ 19.95
Front Wheel Axle Shaft and Related Hardware:
HCP1781 OEM front wheel AXLE SHAFT, for all XJ700 models. Does not include any accessory parts (washers, spacers, collars, etc.).
$ 24.95
HCP1806 OEM front wheel axle shaft CASTLE NUT, for all XJ550, XJ650, XJ750, and XJ1100 models.
$ 4.25
HCP1807 OEM front wheel axle shaft CASTLE NUT, for all XJ900RK models.
$ 4.95
HCP1805 OEM front wheel axle shaft castle nut WASHER, for all XJ550, XJ650, XJ750, XJ900RK, and XJ1100 models.
$ 2.50
HCP1803 OEM front wheel axle shaft castle nut COTTER PIN, for all XJ550, XJ650, XJ700, XJ750, and XJ1100 models.
$ 1.75
HCP1783 OEM front wheel axle shaft COLLAR, for all XJ550 Maxim models, XJ650 Maxim and Midnight Maxim, and all XJ750 models. This is the approximately 1" long tube that is fitted on the right side of the wheel hub.
$ 5.95
HCP1785 OEM front wheel axle shaft COLLAR, for all XJ550 Seca models, XJ650RJ Seca and XJ650 Turbo models, all XJ700 models, and XJ900RK models. This is the approximately 1" long tube that is fitted on the right side of the wheel hub.
$ 5.95
HCP1791 OEM front wheel axle shaft SPACER TUBE, for all XJ550 models, XJ650 models, all XJ700 models, all XJ750 models, and XJ900RK models. This is the approximately 6" long tube that is fitted through the length of the wheel hub.
$ 6.95
HCP1792 OEM front wheel axle shaft SPACER TUBE, for all XJ1100 models. This is the approximately 6" long tube that is fitted through the length of the wheel hub.
$ 6.95
HCP1794 OEM front wheel axle shaft SPACER FLANGE, for all XJ550 models, XJ650 models, all XJ700 models, all XJ750 models, and XJ900RK models. This is incredibly thin flanged shimming washer on the left side of the wheel, behind the bearing. A necessary part and one that is easily damaged during bearing removal or forgotten during replacement.
$ 2.95
HCP1795 OEM front wheel axle shaft SPACER FLANGE, for all XJ1100 models. This is incredibly thin flanged shimming washer on the left side of the wheel, behind the bearing. A necessary part and one that is easily damaged during bearing removal or forgotten during replacement.
$ 2.95
HCP1788 OEM front wheel right side bearing GREASE SEAL. Fits all XJ550, XJ650, XJ700, XJ750, and XJ900RK models. Use 1 per bike. Each:
$ 7.95
HCP1789 OEM front wheel right side bearing GREASE SEAL. Fits all XJ1100 models. Use 1 per bike. Each:
$ 6.95
HCP1790 OEM front wheel left side bearing GREASE SEAL. Fits all XJ550, XJ650, XJ750, XJ900RK, and XJ1100 models. Use 1 per bike. Each:
$ 7.95
Front Wheel Speedometer Drive Assembly Components:
Your speedometer is driven off a drive unit mounted onto the left outer side of the wheel hub, and consists of the CLUTCH unit, the clutch RETAINER, and the large GEAR DRIVE UNIT. Although most non-functioning speedometers can be traced to more common sources of failure (the speedometer head itself, or more likely the speedometer drive cable), we offer these replacement drive units should the need arise.
HCP1797 OEM speedometer gear drive METER CLUTCH, this is the double-tanged metal washer that rotates along with the wheel and drives the gear unit. For all XJ550, XJ650, XJ750, XJ900RK, and XJ1100 models.
$ 3.00
HCP1798 OEM speedometer gear drive meter clutch RETAINER, flat washer that retains the above meter clutch. For all XJ550, XJ650, XJ750, XJ900RK, and XJ1100 models.
$ 2.50
HCP1799 OEM speedometer gear drive GEAR UNIT, the large driven gear unit which your speedometer drive cable actually plugs into. For all XJ550 Maxim, all XJ650 (except Turbo), and all XJ750 models.
$ 88.95
HCP1802 OEM speedometer gear drive GEAR UNIT, the large driven gear unit which your speedometer drive cable actually plugs into. For all XJ550 Seca and XJ900RK models.
$ 46.00
HCP1801 OEM speedometer gear drive GEAR UNIT, the large driven gear unit which your speedometer drive cable actually plugs into. For all XJ700 models.
$ 74.00
REAR WHEEL BEARINGS, AXLE, AND CLUTCH HUB PARTS:
HCP1917 Aftermarket complete rear wheel BEARINGS AND SEALS KIT, for all XJ550 models. Three bearings and one seal comes with this kit.
$ 19.95
HCP1918 Aftermarket complete rear wheel BEARINGS AND SEALS KIT, for all XJ650, XJ700, and XJ750 models. Three bearings only, as no "bearing seals" were used on these models.
$ 12.95
Complete rear wheel bearings & seals kits are not available for the XJ900RK and XJ1100 models. However we do offer the individual components that you need:
XJ900RK rear wheel bearings and seals:
HCP1787 OEM rear wheel BEARING, use one on the right side of the wheel, for all XJ900RK models.
$ 12.95
HCP1834 OEM rear wheel BEARING, use one on the left OUTER side of the wheel, for all XJ900RK models.
$ 12.95
HCP1838 OEM rear wheel BEARING, use one on the left INNER side of the wheel, for all XJ900RK models.
$ 124.00
HCP4767 OEM rear wheel right side bearing OIL SEAL, use one. This seal goes on the outer face of the HCP1787 wheel bearing listed above.
$ 6.50
XJ1100 rear wheel bearings and seals:
HCP1836 OEM rear wheel BEARING, use one on the right side of the wheel, for all XJ1100 models.
$ 12.95
HCP1837 OEM rear wheel BEARING, use one on the left side of the wheel, for all XJ1100 models.
$ 49.00
HCP4755 OEM rear wheel right side bearing OIL SEAL, use one. This seal goes on the outer face of the HCP1836 wheel bearing listed above. For XJ1100 models.
$ 6.95
HCP4756 OEM rear wheel left side bearing OIL SEAL, use one. This seal goes on the outer face of the HCP1837 wheel bearing listed above. For XJ1100 models.
$ 6.95
HCP4784 OEM rear wheel left side bearing and hub DUST BOOT, use one. For XJ1100 models.
$ 7.95
Clutch Hub O-Rings:
And while you've got the rear wheel off to replace the bearings, it's a great idea to inspect and replace those rear wheel clutch hub O-rings, Oil Seals, and clutch hub rubber Dampers as needed. NOTE: some models used either one, two, or three O-rings.
HCP2327 OEM rear wheel clutch hub O-RING, for all XJ650, XJ700 non-X, XJ750, and XJ900RK models. Use one per bike.
$ 6.50
HCP4935 OEM rear wheel clutch hub O-RING, for all XJ650 Turbo, XJ700-X models, and XJ900RK models. Use one per bike.
$ 4.50
HCP4932 OEM rear wheel clutch hub O-RING, for all XJ650 Turbo, XJ700-X models, and XJ900RK models. Use one per bike.
$ 4.50
HCP4770 OEM rear wheel clutch hub inner O-RING, for all XJ1100 models. Use one per bike.
$ 3.50
HCP4769 OEM rear wheel clutch hub outer O-RING, for all XJ1100 models. Use one per bike.
$ 6.50
HCP4768 OEM rear wheel clutch hub OIL SEAL, for all XJ550 models. Use one per bike.
$ 6.00
HCP4777 OEM rear wheel clutch hub rubber DAMPER, the siamesed triangular rubber wedges used on all XJ550 models and XJ900RK. Use six per bike. Each:
$ 7.95
HCP4777SET6 OEM rear wheel clutch hub rubber DAMPERS, set of 6:
$ 44.95
HCP4776 OEM rear wheel clutch hub rubber DAMPER, the triangular rubber wedges used on all XJ650 Turbo models and all XJ700-X models. Use six per bike. Each:
$ 24.95
HCP4776SET6 OEM rear wheel clutch hub rubber DAMPERS, set of 6:
$ 139.95
Rear Wheel Axle Shafts and Hardware:
HCP4799 OEM rear wheel AXLE SHAFT, for all XJ650, all XJ700, and all XJ750 models. Does not include any accessory parts (washers, spacers, collars, etc.).
$ 84.95
HCP4810 OEM rear wheel AXLE SHAFT, for all XJ900RK models. Does not include any accessory parts (washers, spacers, collars, etc.).
$ 64.95
HCP4801 OEM rear wheel axle shaft CASTLE NUT, for all XJ550, XJ650, XJ700, XJ750, and XJ900RK models.
$ 6.25
HCP4808 OEM rear wheel axle shaft CASTLE NUT, for all XJ1100 models.
$ 12.95
HCP1805 OEM rear wheel axle shaft castle nut WASHER, for all XJ550 models.
$ 2.50
HCP2328 OEM rear wheel axle shaft castle nut WASHER, for all XJ650, all XJ700, all XJ750, and XJ900RK models.
$ 3.50
HCP4807 OEM rear wheel axle shaft castle nut WASHER, for all XJ1100 models.
$ 2.95
HCP1803 OEM rear wheel axle shaft castle nut COTTER PIN, for all XJ550, XJ650, XJ700, XJ750, and XJ900RK models.
$ 1.75
HCP4928 OEM rear wheel axle shaft castle nut COTTER PIN, for all XJ1100 models.
$ 2.50
HCP4815 OEM rear wheel axle shaft COLLAR, for all XJ550 models. This is the 1" long tube that is fitted on the right side of the brake backing plate (all models except XJ900RK) and on the far right end of the axle shaft (XJ900RK models).
$ 8.95
HCP4803 OEM rear wheel axle shaft COLLAR, for all XJ650, all XJ700, all XJ750, and XJ900RK models. This is the 1" long tube that is fitted on the right side of the brake backing plate (all models except XJ900RK) and on the far right end of the axle shaft (XJ900RK models).
$ 4.95
HCP4813 OEM rear wheel axle shaft COLLAR, for all XJ900RK models. This is the 1" long tube that is fitted on the right side of the XJ900RK models, just outside of the oil seal.
$ 6.95
HCP4752 OEM rear wheel axle shaft SPACER TUBE, for all XJ550 Maxim and XJ900RK models. This is the approximately 2-1/2" long tube that is fitted through the length of the wheel hub.
$ 6.95
HCP1795 OEM rear wheel axle shaft SPACER FLANGE, for all XJ550, XJ650, XJ700, XJ750, and XJ900RK models. This is the incredibly thin flanged shimming washer on the right side of the spacer tube, behind the right side wheel bearing. A necessary part and one that is easily damaged during bearing removal or forgotten during replacement.
$ 2.95
HCP4787 OEM rear wheel axle shaft SPACER FLANGE, for all XJ1100 models. This is the incredibly thin flanged shimming washer on the right side of the spacer tube, behind the right side wheel bearing. A necessary part and one that is easily damaged during bearing removal or forgotten during replacement.
$ 2.95
WHEEL BEARING/AXLE TOOLS:
Wheel Bearing Removal Tool Kit
HCP7850 Aftermarket wheel bearing BEARING REMOVAL TOOL SET, heavy-duty set of the proper sized split collar drivers and two drift rods. Very high quality, versatile tool to have in your box, as removing the pressed-in front wheel bearings can be quite a challenge without these tools being available
$ 59.00
Wheel Bearing Grease:
HCP8608 Aftermarket gear and bearing synthetic RED MOLY GREASE.. High temperature, water resistant, extreme pressure and high-load strength synthetic organic moly grease is far superior to black moly disulfide (petroleum-based) products. Use on steering neck bearings, wheel bearings, starter motor gears, and swingarm bearings. 14 oz. tube.
$ 13.95
FREE STANDARD SHIPPING {OR JUST $5.00 FOR PRIORITY MAIL} SHIPPING IN THE USA FOR ALL ORDERS OVER $100 !!!!
$7.50 STANDARD SHIPPING TO CANADA FOR ALL ORDERS OVER $100 !!!!
Paypal accepted. Worldwide shipping available. Shipping prices and insurance costs are NOT included in the prices of items unless specifically listed. Please write with your list of parts needs and I will be glad to quote your shipping costs to you.
You can either PM (Private Message) me through this website, e-mail us via the "email" button on the bottom of this post, or e-mail us directly at:
info @ xj4ever.com
PLEASE NOTE!: our e-mail address does NOT have spaces before or after the "@" symbol........the posting system on this website automatically adds blank spaces before and after that symbol as an anti-spam feature! Make sure you eliminate those blank spaces when sending us an e-mail! Our e-mail address does NOT have any blank spaces in it!!
PLEASE!: on each and every correspondence with us, please tell us what YEAR and MODEL bike you have (example: 1982 XJ650 Maxim) and what your NAME (first name, at least!) is......that information really makes life a bit easier for us, and insures a more timely and ACCURATE response from us back to you!
MORE XJ PARTS IN THE FOLLOWING POST!!
_________________ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Posted: Sun Dec 21, 2008 3:36 am Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION L:
-- Wheels and Tires.
WHEELS AND TIRES:
Unlike with automotive wheels and tires, there's no really good reasons why you can't do as good a job of changing tires and balancing your wheel/tire combo as a shop can. Although all the fancy tire dis-mount - mount machinery and spin-balancers are very impressive looking, they also add quite a bit of cost to the process (call around in your local area for pricing and you'll see what I mean!).
By spending some labor time and effort yourself (for wheel removal and tire dis-mount and re-mounting; those are the big consumer of your time), the money you can save can easily pay for the cost of upgrading to some much nicer, high-quality tires, which is where the true safety and performance gains can be realized. NOTE: If you feel unqualified in performing such actions, then by all means don't attempt these taks yourself; however, if you can follow instructions and are have the patience and skills needed to do things correctly, then these tasks----and savings----are certainly achievable, even if it's your first time.
We offer a complete variety variety of all the tools and products needed for you to perform these jobs. Also, be aware the the best time to inspect and replace your wheel bearings are when the wheels are off the bike for a tire change, so don't forget to review those items, too.
Tire Valves:
HCP1773 OEM wheel rim complete TIRE VALVE, straight style, 1-1/2" stem height is approximately the same length as original. For all XJ-series bikes except the XJ700 models on the rear wheel, which used a 90-degree angle (bent) stem. Complete valve includes the stem, internal valve, black plastic cap, o-ring, special washer, and two mounting nuts. NOTE: some models may have used shorter valve stems. Each:
$ 6.75
HCP1773SET2 OEM wheel rim TIRE VALVES, straight style, set of 2:
$ 12.95
HCP1763 OEM wheel rim complete TIRE VALVE, right-angle bent style, 1-1/2" stem height and 1-3/8" reach is approximately the same length as original. For all XJ700 models on the rear wheel. Complete valve includes the stem, internal valve, black plastic cap, o-ring, special washer, and two mounting nuts. Each:
$ 19.50
HCP1763SET2 OEM wheel rim TIRE VALVES, straight style, set of 2:
$ 37.95
HCP9193 Aftermarket wheel rim complete TIRE VALVE, right-angle bent style, 1-1/2" stem height and 1-3/8" reach is approximately the same length as original. For all XJ700 models on the rear wheel. Complete valve includes the stem, internal valve, black plastic cap, o-ring, special washer, and two mounting nuts. Each:
$ 10.95
HCP9193SET2 Aftermarket wheel rim TIRE VALVES, straight style, set of 2:
$ 19.95
HCP9195 Aftermarket wheel rim VALVE STEM CAP, polished chrome acorn cap is a very close copy of the original metal screw-on cap (but lacks the central dimple). Replaces the plain black plastic caps that come on the replacement valve stems. Each:
$ 1.50
HCP9195SET2 Aftermarket wheel rim VALVE STEM CAPS, set of 2:
$ 2.75
HCP9193 Aftermarket wheel rim VALVE STEM CORE, internal brass valve core exactly replaces leaking and damaged originals on all style (straight and bent) valve stems. If your stem is leaking air, this is the inexpensive way to fix it. Each:
$ 1.25
HCP9193SET2 Aftermarket wheel rim VALVE STEM CORES, set of 2:
$ 1.95
HCP9196 Aftermarket VALVE STEM TOOL, handy 4-in-1 tool allows you to properly remove and insert the stem core, and also clean/chase/re-thread the internal and external stem threads.
$ 4.00
Wheel and Tire Changing Tools:
Here's a variety of tools to make the chore of tire de-mounting and re-moutning of your tires just a wee bit easier (and much less expensive!).
HCP1753 Aftermarket tire BEAD POPPER, this molded plastic wedge, when firmly whacked with a mallet or hammer, gently "pops" stuck tire beads away from the inner rim flange without risking damage to the wheel rim in this critical area.
$ 19.95
HCP9772 Aftermarket CURVED TIRE IRON, 15" cast steel tire "pry bar" helps you lever the wheel bead over the edge of the tire safely and without risking damage to your wheel rims or the tire.
$ 9.95
HCP9772 Aftermarket STRAIGHT TIRE IRON, 16" forged steel tire "pry bar" helps you lever the wheel bead over the edge of the tire safely and without risking damage to your wheel rims or the tire.
$ 8.95
HCP1749 Aftermarket pair of nylon RIM EDGE PROTECTORS, these curved plastic guards, placed under the above tire irons, provide the utmost in protection fromn rim edge damage when changing tires.
$ 9.95
$ 4.00
Wheel Balancing Weights and Tools:
HCP10490 Aftermarket WHEEL BALANCER. Contrary to pupular belief, you don't have to spin-balance motorcycle wheels to achieve satisfactory results. With this simple tool, and a pair of hi-rise common jackstands ("hi-rise" means more than 15" lift off the floor level), you can professionaly balance your own tire/wheel assembly. High quality tool-steel axle, low-drag bearings, and precision-machined wheel holder collets provide you with the means to spin-balance all XJ-series wheels in a matter of minutes. Set-up and balancing directions are included. Properly cared for (meaning: don't drop it or beat on it!), this balance will last a lifetime.
$ 99.95
HCP4834 OEM wheel rim CLIP-ON WEIGHT, 10-gram (.353 ounce). For all XJ-series bikes. Each:
$ 4.00
HCP4834SET4 OEM wheel rim WHEEL WEIGHTS, set of 4:
$ 14.95
HCP9197 Aftermarket wheel rim CLIP-ON WEIGHT, 10-gram (.353 ounce), slightly wider than original. For all XJ-series bikes. Each:
$ 2.75
HCP9197SET4 Aftermarket wheel rim WHEEL WEIGHTS, set of 4:
$ 9.95
HCP4835 OEM wheel rim CLIP-ON WEIGHT, 20-gram (.706 ounce). For all XJ-series bikes. Each:
$ 7.25
HCP4835SET4 OEM wheel rim WHEEL WEIGHTS, set of 4:
$ 27.95
HCP9198 Aftermarket wheel rim CLIP-ON WEIGHT, 20-gram (.706 ounce), slightly wider than original. For all XJ-series bikes. Each:
$ 2.75
HCP9198SET4 Aftermarket wheel rim WHEEL WEIGHTS, set of 4:
$ 9.95
HCP4836 OEM wheel rim CLIP-ON WEIGHT, 30-gram (1.06 ounce). For all XJ-series bikes. Each:
$ 4.25
HCP4836SET4 OEM wheel rim WHEEL WEIGHTS, set of 4:
$ 16.95
HCP9199 Aftermarket wheel rim CLIP-ON WEIGHT, 30-gram (1.06 ounce), slightly wider than original. For all XJ-series bikes. Each:
$ 2.95
HCP9199SET4 Aftermarket wheel rim WHEEL WEIGHTS, set of 4:
$ 10.95
HCP1747 Aftermarket wheel rim STICK-ON WEIGHT, 7.09-gram (.25 ounce), black finish, self-adhesive backing. For all XJ-series bikes. Each:
$ 0.75
HCP1747SET4 OEM wheel rim WHEEL WEIGHTS, set of 4:
$ 2.25
HCP1748SET4 OEM wheel rim WHEEL WEIGHTS, set of 4:
$ 2.95
HCP10546 Aftermarket wheel rim STICK-ON WEIGHT, 7.09-gram (.25 ounce), natural finish, self-adhesive backing. For all XJ-series bikes. Each:
$ 0.75
HCP10546SET4 OEM wheel rim WHEEL WEIGHTS, set of 4:
$ 2.00
info @ xj4ever.com
Posted: Sun Dec 21, 2008 3:37 am Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
This post left empty on purpose!
xjbikes.com/Forums/vie.../f=23.html |
Posted: Sun Dec 21, 2008 9:24 pm Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION M:
CONTROL CABLES & HAND LEVERS:
--Control Cables:
CONTROL CABLES:
The constant flexing and bending of the internal stranded wire cable inside your contol cables weaken those stranded wires, and eventually will snap it at the primary bend point....hopefully when you're close to home, but why take the risk?
The most-used cables are obviously at the greatest risk, and the pecking order goes like this:
a) tach/speedo cable
b) clutch cable
c) throttle cable
d) brake cable---750 Seca models
e) choke cable
Throttle and clutch cables will leave you basically stranded, while the others you can continue on down the road even if they fail........but why take that risk? Inspect your cable regularly, and lubricate them religously! And don't be afraid to have a spare set of those critical cables on-hand as "cheap insurance" for that time when the inevitable happens!
NOTE: we strongly suggest that you throroughly LUBRICATE your new cables before installation!
Brake Lever-to-Master Cylinder Cables:
gc1) OEM front master cylinder BRAKE CABLE, brand new coil-wound black-sheathed housings, inner nylon sleeve, and correct ends to correctly replace snapped, frayed, or stiff originals.
HCP591 OEM front BRAKE CABLE, for all XJ750 Seca models.
$ 17.00
Choke/Starter/Enrichment Circuit Cables:
cac1) OEM and aftermarket CHOKE CABLES, brand new with coil-wound black-sheathed housings, inner nylon sleeve, and correct ends to correctly replace snapped, frayed, or noisy originals. NOTE: the overall length of aftermarket cables may differ by 1-2" (total overall length) from original, but this can easily be compensated for in the routing and final adjustment of the cable once installed.....this is why there are fewer aftermarket cables than original cables (cables that were very close in all other aspects, but within 2-3" of overall length, have been consolidated into one part number on aftermarket cables).
HCP2709 OEM original CHOKE CABLE, for all XJ550 models and all XJ750 (except Seca) models.
$ 16.00
HCP2710 OEM original CHOKE CABLE, for all XJ650 Maxim and Midnight Maxim models.
$ 15.00
HCP2712 OEM original CHOKE CABLE, for all XJ650 Seca and XJ750 Seca models. NOTE: experimental testing has shown that this cable is an excellent replacement cable to use on XJ550 Seca models if you substitute "euro" or "clubman" style handlebars for the stock handlebars.
$ 14.00
HCP2713 OEM original CHOKE CABLE, for all XJ650 Turbo models.
$ 14.00
HCP2715 OEM original CHOKE CABLE, for all XJ700-X models.
$ 13.00
HCP2716 OEM original CHOKE CABLE, for all XJ900RK models.
$ 12.00
HCP2717 OEM original CHOKE CABLE, for all XJ1100 models.
$ 12.00
HCP2645 Aftermarket replacement CHOKE CABLE, for all XJ650 Maxim and Midnight Maxim models.
$ 12.00
HCP2660 Aftermarket replacement CHOKE CABLE, for all XJ650 Turbo models and all XJ700 models.
$ 12.00
Choke/Starter/Enrichment Circuit Control Levers & Hardware:
Mounted onto the left side handlebar control switch, this black plastic choke cable control LEVER allows you to control the choke system, and if it's missing or broken, here's your chance to replace them with brand new parts and restore their proper function and appearance.
HCP2687 OEM choke LEVER, round plastic lever unit with finger knob, does not include any mounting hardware. Fits all XJ550 models, all XJ650 (except Turbo) models, and all XJ750 Seca models:
$ 12.50
HCP268 OEM choke LEVER, round plastic lever unit with finger knob, does not include any mounting hardware. Fits all XJ650 Turbo models, all XJ700, XJ750 Maxim and Midnight Maxim, and XJ1100 models:
$ 8.50
HCP3567 OEM choke lever HOUSING, round plastic bracket attaches to the bottom of the control switch housing and holds the actual choke lever and routes the starter cable. Fits all XJ700 models:
$ 14.00
HCP3565 OEM choke lever RING, round plastic lever unit with finger knob, does not include any mounting hardware. Fits all XJ900RK models:
$ 21.00
HCP3568 OEM choke lever SPRING WASHER, special flat washer that mounts underneath the choke lever (between the lever and the control switch housing). Used on all XJ550, XJ650, XJ750, and XJ1100 models.
$ 2.95
HCP3571 OEM choke lever MOUNTING SCREW, holds the lever to the control switch housing. Used on all XJ550, all XJ700, and all XJ750 Seca models.
$ 1.50
HCP3572 OEM choke lever MOUNTING SCREW, holds the lever to the control switch housing. Used on all XJ650 models.
$ 1.75
HCP3570 OEM choke lever MOUNTING SCREW, holds the lever to the control switch housing. Used on all XJ750 Maxim and Midnight Maxim models, and XJ1100 models.
$ 2.25
HCP3575 OEM choke lever mounting screw FLAT WASHER, used under the HCP3571 screw listed above. Used on all XJ550, XJ650, XJ700, XJ750, and XJ1100 models.
$ 1.00
HCP3576 OEM choke lever mounting screw LOCK WASHER, used under the HCP3571 screw listed above on all XJ700 models.
$ 1.50
Speedometer Drive Cables:
cac3) OEM and aftermarket SPEEDOMETER DRIVE CABLES, brand new with coil-wound black-sheathed housings, inner nylon sleeve, and correct ends to correctly replace snapped, frayed, or noisy originals.
NOTE: the overall length of aftermarket cables may differ by 1-2" (total overall length) from original, but this can easily be compensated for in the routing and final adjustment of the cable once installed.......this is why there are fewer aftermarket cables than original cables (cables that were very close in all other aspects, but within 2-3" of overall length, have been consolidated into one part number on aftermarket cables).
HCP2719 OEM original SPEEDOMETER DRIVE CABLE, includes the bright plated metal sleeve nut on both ends as original, for all XJ550 Seca models.
$ 18.00
HCP2718 OEM original SPEEDOMETER DRIVE CABLE, includes the bright plated metal sleeve nut on meter end and the metal clip-bracket on the gear end as original, for all XJ550 Maxim models, XJ650 Maxim and Midnight Maxims, and all XJ750 models.
$ 27.00
HCP2725 OEM original SPEEDOMETER DRIVE CABLE, includes the bright plated metal sleeve nut on both ends as original, for all XJ650 Seca models. Service replacement OEM parts differs slightly in length from original.
$ 17.00
HCP2721 OEM original SPEEDOMETER DRIVE CABLE, includes the bright plated metal sleeve nut on both ends as original, for all XJ650 Turbo models.
$ 15.00
HCP2722 OEM original SPEEDOMETER DRIVE CABLE, includes the bright plated metal sleeve nut on both ends as original, for all XJ700 models.
$ 14.00
HCP2723 OEM original SPEEDOMETER DRIVE CABLE, includes the bright plated metal sleeve nut on both ends as original, for all XJ900RK models.
$ 14.00
HCP2724 OEM original SPEEDOMETER DRIVE CABLE, includes the bright plated metal sleeve nut on meter end and the metal clip-bracket on the gear end as original, for all XJ1100 models.
$ 25.00
HCP2647 Aftermarket replacement SPEEDOMETER DRIVE CABLE, includes the bright plated metal sleeve nut on meter end and the metal clip-bracket on the gear end as original, for all XJ550 Maxim models, all 1980-83 XJ650 Maxim and Midnight Maxim models, and all XJ750 models.
$ 16.00
HCP2662 Aftermarket replacement SPEEDOMETER DRIVE CABLE, includes the bright plated metal sleeve nut on both ends as original, for all 1982 XJ650 Seca and all XJ650 Turbo models.
$ 14.00
HCP2659 Aftermarket replacement SPEEDOMETER DRIVE CABLE, includes the bright plated metal sleeve nut on both ends as original, for all XJ700 models.
$ 16.00
HCP2653 Aftermarket replacement SPEEDOMETER DRIVE CABLE, includes the bright plated metal sleeve nut on both ends as original, for all XJ550 Seca models, and all XJ900 models.
$ 14.00
HCP2658 Aftermarket replacement SPEEDOMETER DRIVE CABLE, includes the bright plated metal sleeve nut on meter end and the metal clip-bracket on the gear end as original, for all XJ1100 models.
$ 17.00
HCP2207 OEM speedometer drive cable CABLE GUIDE, flexible black plastic loop mounts to the front fender and keeps the speedo cable properly routed out of harm's way. Fits: all XJ550 models, all XJ650 (except Turbo) models, all XJ750 models, and XJ1100 models.
$ 4.50
HCP2208 OEM speedometer drive cable CABLE GUIDE, flexible black plastic loop mounts to the front fender and keeps the speedo cable properly routed out of harm's way. Fits: all XJ650 Turbo models and XJ900RK models.
$ 4.50
Tachometer Cables:
cac2) OEM and aftermarket TACHOMETER DRIVE CABLE, brand new with coil-wound black-sheathed housings, inner nylon sleeve, and correct ends to correctly replace snapped, frayed, or noisy originals.
NOTE: the overall length of aftermarket cables may differ by 1-2" (total overall length) from original, but this can easily be compensated for in the routing and final adjustment of the cable once installed......this is why there are fewer aftermarket cables than original cables (cables that were very close in all other aspects, but within 2-3" of overall length, have been consolidated into one part number on aftermarket cables).
HCP2726 OEM TACHOMETER DRIVE CABLE, for all XJ550 Maxim models and all 1980-81 XJ650 Maxim and Midnight Maxim models.
$ 21.95
HCP2648 Aftermarket replacement TACHOMETER DRIVE CABLE, includes the bright plated metal sleeve nut on both ends as original, for all XJ550 Maxim models and all 1980-81 XJ650 Maxim and Midnight Maxim models.
$ 14.00
HCP2727 OEM TACHOMETER DRIVE CABLE, fits all XJ550 Seca and 1982 XJ650 Seca models.
$ 19.95
HCP3539 OEM tachometer cable drive gear (on cylinder head) OIL SEAL. If you're leaking oil where the tach cable attaches to the drive housing on the drive adapter housing, it's because this oil seal (and/or the drive gear O-ring) is bad and need to be replaced. Fits all XJ550 models, 1980-81 XJ650 Maxim and Midnight Maxim models, and 1982 XJ650 Seca model.
$ 5.95
HCP3537 OEM tachometer cable drive gear O-RING. If you're leaking oil where the tach cable attaches to the drive housing on the drive adapter housing, it's because this o-ring (and/or the housing oil seal) is bad and need to be replaced. Fits all XJ550 models, 1980-81 XJ650 Maxim and Midnight Maxim models, and 1982 XJ650 Seca model.
$ 4.95
HCP3540 OEM tachometer cable drive gear CABLE ADAPTER. This is the threaded hollow stud that screws into both the drive gear housing and into the tach cable. Fits all XJ550 models, 1980-81 XJ650 Maxim and Midnight Maxim models, and 1982 XJ650 Seca model.
$ 11.50
HCP3541 OEM tachometer cable drive gear HOUSING RETAINER BRACKET. The entire tach cable adapter housing unit is retained to the engine via this "open-C" bracket. Fits all XJ550 models, 1980-81 XJ650 Maxim and Midnight Maxim models, and 1982 XJ650 Seca model. Natural finish, some models used a black-painted version of this same bracket.
$ 3.95
HCP3542 OEM tachometer cable drive gear housing retaining bracket BOLT. Use with the above housing retainer bracket. Fits all XJ550 models, 1980-81 XJ650 Maxim and Midnight Maxim models, and 1982 XJ650 Seca model. Black plated.
$ 1.00
HCP3546 OEM tachometer cable drive gear housing retaining bracket BOLT. Use with the above housing retainer bracket. Fits all XJ550 models, 1980-81 XJ650 Maxim and Midnight Maxim models, and 1982 XJ650 Seca model. Bright plated.
$ 1.50
HCP7521 OEM tachometer cable drive gear housing BLOCK OFF CAP. If you decide to replace your cable-driven tach with something else, this block-off cap screws onto to the cable adapter in places of the tach cable, and prevents grit and grime from getting into the engine. Fits all XJ550 models, 1980-81 XJ650 Maxim and Midnight Maxim models, and 1982 XJ650 Seca model. Bright plated.
$ 7.50
Throttle Cables:
cac4) OEM and aftermarket THROTTLE CABLE, brand new with coil-wound black-sheathed housings, inner nylon sleeve, and correct ends to correctly replace snapped, frayed, or noisy originals. NOTE: the overall length of aftermarket cables may differ by 1-2" (total overall length) from original, but this can easily be compensated for in the routing and final adjustment of the cable once installed........this is why there are fewer aftermarket cables than original cables (cables that were very close in all other aspects, but within 2-3" of overall length, have been consolidated into one part number on aftermarket cables).
HCP5196 OEM original THROTTLE "STUB" CABLE, short 3" long adapter cable that actually attaches to the #3 carb body throttle shaft bracket, and has the metal adapter that the main throttle cable (HCP2690 or HCP2649 listed below) hooks into, used on all XJ550 models only.
$ 36.95
HCP2690 OEM original THROTTLE CABLE, with bright plated curved metal tube, adjuster nut, and thumb-wheel on the throttle end of the cable, for all XJ550 models.
$ 24.00
HCP2691 OEM original THROTTLE CABLE, with bright plated curved metal tube, adjuster nut, and thumb-wheel on the throttle end of the cable, for all XJ650 Maxim and Midnight Maxim models.
$ 25.00
HCP2698 OEM original THROTTLE CABLE, with bright plated curved metal tube, adjuster nut, and thumb-wheel on the throttle end of the cable, for all XJ650RJ Seca models.
$ 24.00
HCP2692 OEM original THROTTLE CABLE, with bright plated curved metal tube, adjuster nut, and thumb-wheel on the throttle end of the cable, for all XJ650 Turbo models.
$ 25.00
HCP2693 OEM original THROTTLE CABLE, with bright plated curved metal tube, adjuster nut, and thumb-wheel on the throttle end of the cable, for all XJ700 non-X models.
$ 19.00
HCP2694 OEM original THROTTLE CABLE, with bright plated curved metal tube, adjuster nut, and thumb-wheel on the throttle end of the cable, for all XJ700-X models.
$ 21.00
HCP2695 OEM original THROTTLE CABLE, with bright plated curved metal tube, adjuster nut, and thumb-wheel on the throttle end of the cable, for all XJ750 Maxim and Midnight Maxim models.
$ 25.00
HCP2696 OEM original THROTTLE CABLE, with bright plated curved metal tube, adjuster nut, and thumb-wheel on the throttle end of the cable, for all XJ750 Seca models.
$ 25.00
HCP2699 OEM original THROTTLE CABLE, with bright plated curved metal tube, adjuster nut, and thumb-wheel on the throttle end of the cable, for all XJ900RK Seca models.
$ 25.00
HCP2700 OEM original THROTTLE CABLE, with bright plated curved metal tube, adjuster nut, and thumb-wheel on the throttle end of the cable, for all XJ1100 models.
$ 26.00
HCP2649 Aftermarket replacement THROTTLE CABLE, with bright plated curved metal tube, adjuster nut, and thumb-wheel on the throttle end of the cable, for all XJ550 models, and all XJ650 Maxim and 650 Midnight Maxim models.
$ 17.00
HCP2661 Aftermarket replacement THROTTLE CABLE, with bright plated curved metal tube, adjuster nut, and thumb-wheel on the throttle end of the cable, for all XJ650RJ Seca models.
$ 18.00
HCP2651 Aftermarket replacement THROTTLE CABLE, with bright plated curved metal tube, adjuster nut, and thumb-wheel on the throttle end of the cable, curved tube on carb end; for all XJ700-X models.
$ 19.00
HCP2656 Aftermarket replacement THROTTLE CABLE, with bright plated curved metal tube, adjuster nut, and thumb-wheel on the throttle end of the cable, for all XJ750 Maxim and 750 Midnight Maxim models.
$ 17.00
HCP2655 Aftermarket replacement THROTTLE CABLE, with bright plated curved metal tube, adjuster nut, and thumb-wheel on the throttle end of the cable, for all XJ750 Seca models.
$ 17.00
HCP9182 OEM throttle cable HOLDER BRACKET, this is the small metal bracket that retains the throttle cable flange to the control switch housing. Fits all XJ550 models and all XJ650 (except Turbo) models. This bracket is retained by the control switch housing screw.
$ 2.95
HCP9180 OEM throttle cable holder bracket SCREW, used on XJ650 Turbo models, all XJ750 Maxim and Midnight Maxim models, and XJ1100 models.
$ 0.95
Clutch Cables:
cac5) OEM and aftermarket CLUTCH CABLE, brand new with coil-wound black-sheathed housings, inner nylon sleeve, and correct ends to correctly replace snapped, frayed, or noisy originals. NOTE: the overall length of aftermarket cables may differ by 1-2" (total overall length) from original, but this can easily be compensated for in the routing and final adjustment of the cable once installed.
NOTE: All original OEM cables come with a non-removable, non-replacable nylon or teflon bushing installed on the clutch cable lever end barrel or "bullet"........and this bushing is installed BEFORE the barrel (or bullet) is crimped onto the cable and although it is slotted, the slots do not go to the outer edge of the bushing, and thus there is no way to remove the bushing (nor install a new one).
All aftermarket cables use a larger diameter barrel (or "bullet") on the clutch cables that matches the the O.D. size of the original sleeved bullet.....and thus no nylon sleeve is necessary nor used. We've never heard of a problem with these aftermarket cable ends binding or seizing up, although I suppose that without periodic lubrication, that is a possibility.
NOTE: your clutch lever should have 2-3mm of free play (at the lever) when the clutch cable is properly adjusted.
HCP2701 OEM CLUTCH CABLE, for all XJ550 Maxim models.
$ 24.95
HCP2702 OEM CLUTCH CABLE, for all XJ550 Seca models.
$ 26.95
HCP2703 OEM CLUTCH CABLE, for all XJ650 Maxim and Midnight Maxim models, and all XJ750 Maxim and Midnight Maxim models.
$ 24.95
HCP2704 OEM CLUTCH CABLE, for all XJ650RJ Seca models.
$ 21.95
HCP2705 OEM CLUTCH CABLE, for all XJ700 models.
$ 22.95
HCP2706 OEM CLUTCH CABLE, for all XJ750 Seca models.
$ 26.95
HCP2707 OEM CLUTCH CABLE, for all XJ900RK Seca models.
$ 22.95
HCP2708 OEM CLUTCH CABLE, for all XJ1100 models.
$ 24.95
HCP2650 Aftermarket replacement CLUTCH CABLE, triple adjusting nuts and black plastic end cap as original on clutch end, for all XJ550 Maxim models.
$ 16.00
HCP2652 Aftermarket replacement CLUTCH CABLE, triple adjusting nuts and black plastic end cap as original on clutch end, for all XJ550 Seca models.
$ 16.00
HCP2646 Aftermarket replacement CLUTCH CABLE, triple adjusting nuts and black plastic end cap as original on clutch end, for all XJ650 Maxim and Midnight Maxim models, and all XJ750 Maxim and Midnight Maxim models.
$ 16.00
HCP2663 Aftermarket replacement CLUTCH CABLE, triple adjusting nuts and black plastic end cap as original on clutch end, for all XJ650 Seca and XJ650 Turbo models.
$ 16.00
HCP2654 Aftermarket replacement CLUTCH CABLE, triple adjusting nuts and black plastic end cap as original on clutch end, for all XJ750 Seca and all XJ700 models.
$ 16.00
HCP2657 Aftermarket replacement CLUTCH CABLE, featuring the correct stepped collar on the lever end, for XJ1100 models.
$ 16.00
Clutch Cable Boot:
hl7) Pleated accordion style small BOOT fits over the clutch cable where it meets the lever.
HCP603 OEM clutch cable at lever adjuster black rubber BOOT, use 1 per bike. Fits all XJ550 models, all XJ650 models, all XJ700 models, all XJ750 (except Seca) models, and all XJ1100 models.
$ 10.50
Clutch Cable Adjuster Hardware:
hl14) The precise length and tension adjustment of the clutch cable is accomplished both at the clutch case end of the cable and via a clutch cable special ADJUSTMENT BOLT AND NUT located at the lever end of the cable. This hollow, split bolt and nut allow you to take up cable slack in small, precise amounts are necessary for proper cable adjustment and clutch operation.
HCP7859 OEM clutch cable ADJUSTER BOLT, a special slotted, hollow, "split" bolt that the cable runs through. Fits all of the following models: all XJ550, XJ650, XJ700, XJ750 (except Seca), XJ900RK, and XJ1100 models.
$ 5.95
HCP7860 OEM clutch cable ADJUSTER NUT, a special slotted, "split" nut with a ball-detent that the cable runs through. Fits all of the following models: all XJ550, XJ650, XJ700, XJ750 (except Seca), XJ900RK, and XJ1100 models.
$ 4.95
Cable Lube Tool & Cable Lubricant:
cm1) Aftermarket CABLE LUBRICATION TOOL, this hand-held, easy-to-use cable clamp tool makes it easy to properly lubricate your cables. For the longest cable life and less drag, cables should be lubed at least once a year.
HCP255 Aftermarket CABLE LUBRICATION TOOL.
$ 9.50
cm2) Aftermarket CABLE LUBRICANT. makes it easy to properly lubricate your cables with this easy to use cable luber. For the longest cable life and less drag, cables should be lubed at least once a year.
NOTE: cable lube cannot (and will not----don't even ask!) be shipped via any air transport delivery service-level nor outside of the USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
HCP256 Aftermarket CABLE LUBE, 6-ounce spray can.
$ 13.95
info @ xj4ever.com
Posted: Sun Dec 21, 2008 9:28 pm Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION M:
--Brake and Clutch Hand Levers:
HAND LEVERS AND PARTS:
Brake Hand Levers:
hl9) OEM and aftermarket BRAKE HAND LEVERS perfectly replace the factory original aluminum handles. Although most handle levers LOOK the same, they actually are different bike-to-bike, as the bend angle and offsets to clear other handlebar features, control switches, etc. take into account such things.
OEM replacement levers normally have a rough-texture finish to promote hand grip (originals were smooth) and come in either the correct low-gloss-black or polished finish (depending on model).
Aftermarket levers faithfully reproduce the designs of the originals, and are available in a variety of finishes.
NOTE: the brake hand levers used on all XJ550 Maxim, 1982-83 XJ550 Seca, and all XJ650 Maxim and Midnight Maxim models originally used a plastic spacer bushing to take up the large difference between the lever hole inside diameter and the pivot bolt shoulder outer diameter (all other models have a lever hole ID and pivot bolt shoulder OD that is a close enough tolerance so that no bushing was ever used nor required). Both the original OEM replacement and the aftermarket levers listed below will also require the use of a spacer bearing for proper fit and operation.
HCP2681 OEM BRAKE HAND LEVER, proper fit for all XJ550 Maxim and 1982-83 XJ550 Seca models, and all XJ650 Maxim and Midnight Maxim models. Surface texture differs from original; flat black finish. NOTE: these levers require the use of spacer bearing HCP9853 for proper fit and operation.
$ 15.95
HCP2666 Aftermarket BRAKE HAND LEVER, proper fit for all XJ550 Maxim and 1982-83 XJ550 Seca models, and all XJ650 Maxim and Midnight Maxim models. Smooth surface texture and low gloss black finish as original. NOTE: these levers require the use of spacer bearing HCP9854 for proper fit and operation.
$ 11.95
HCP9853 Aftermarket brake lever pivot bolt hole SPACER BUSHING. Original hand levers used a plastic spacer bushing to create a close tolerance between brake lever hole ID and the pivot bolt should OD. These replacement bronze bushings work better and will last longer than the original bushing. Use this bearing with all original factory hand levers or the HCP2681 hand lever above.
$ 6.95
HCP9854 Aftermarket brake lever pivot bolt hole SPACER BUSHING. Original hand levers used a plastic spacer bushing to create a close tolerance between brake lever hole ID and the pivot bolt should OD. These replacement bronze bushings work better and will last longer than the original bushing. Use this bearing only with the aftermarket replacement HCP2666 brake hand lever above.
$ 6.95
NOTE: for all of the following levers, XJ750RL and XJ900RK owners can use either these levers or the HCP2686 style lever below, there is only a minimal difference between the two versions.
HCP2682 OEM BRAKE HAND LEVER, proper fit for all 1981 XJ550 Seca models, and all XJ650 Turbo and XJ650RJ Seca models, all XJ750 (except Seca) models, XJ900RK and XJ1100. Surface texture differs from original; flat black finish.
$ 14.95
HCP2669 Aftermarket BRAKE HAND LEVER, proper fit for all 1981 XJ550 Seca models, and all XJ650 Turbo models and XJ650RJ Seca models, all XJ750 (except Seca) models, XJ900RK and XJ1100 models. Smooth surface texture and low gloss black finish as original.
$ 11.95
HCP9698 Aftermarket BRAKE HAND LEVER, proper fit for all 1981 XJ550 Seca models, and all XJ650 Turbo models and XJ650RJ Seca models, all XJ750 (except Seca) models, XJ900RK and XJ1100 models. Smooth surface texture and low gloss black finish as original. Cast aluminum, low cost replacement for the original.
$ 6.95
HCP9692 Aftermarket BRAKE HAND LEVER, proper fit for all 1981 XJ550 Seca models, and all XJ650 Turbo models and XJ650RJ Seca models, all XJ750 (except Seca) models, XJ900RK and XJ1100 models. Smooth surface texture with a shiny gloss black finish. Cast aluminum, low cost replacement for the original.
$ 6.95
HCP2664 Aftermarket BRAKE HAND LEVER, proper fit for all 1981 XJ550 Seca models, all XJ650 Turbo models and XJ650RJ Seca models, all XJ750 (except Seca) models, XJ900RK and XJ1100 models. Has a beautiful mirror-polished CHROME PLATED FINISH, unlike the original, and also features a wider blade design than original for better grip and control.
$ 18.00
HCP9695 Aftermarket BRAKE HAND LEVER, proper fit for all 1981 XJ550 Seca models, and all XJ650 Turbo models and XJ650RJ Seca models, all XJ750 (except Seca) models, XJ900RK and XJ1100 models. Has a smooth surface texture with a beautiful mirror-polished CHROME PLATED FINISH, unlike the original. Cast aluminum, low cost replacement for the original.
$ 7.95
HCP2684 OEM BRAKE HAND LEVER, proper fit for all XJ700 non-X models. Bright semi-polished finish as original. NOTE: this lever is the same lever as used on XJ700-X models except it is not as highly polished (to a mirror-like finish) as used originally on "X" models.
$ 13.95
HCP2668 Aftermarket BRAKE HAND LEVER, proper fit for all XJ700 non-X models. Bright semi-polished finish as original. NOTE: this lever is the same lever as used on XJ700-X models except it is not as highly polished (to a mirror-like finish) as used originally on "X" models.
$ 11.95
HCP2686 OEM BRAKE HAND LEVER, proper fit for all XJ750 Seca models. Surface texture differs from original; flat black finish.
$ 19.95
HCP2688 OEM BRAKE HAND LEVER, proper fit for all XJ750RL and XJ900RK Seca models. Surface texture differs from original; flat black finish. NOTE: XJ750RL and XJ900RK owners can use either this lever or the HCP2682 style lever above, there is only a minimal difference between the two versions.
$ 16.95
Brake Hand Lever Hardware:
hl6) Brake levers are retained to the master cylinder (or, for XJ750 Seca models, to the control switch housing) via a smooth-shanked PIVOT BOLT and a NUT. There was also a small rubber O-RING that fit under the lever where the pivot bolt passes through, in-between the lever and the retaining nut, on certain models.
Additionally, brake levers are equipped with a master cylinder piston-stroke ADJUSTER SCREW, NUT, and SPRING.
HCP3046 OEM brake lever mounting PIVOT BOLT, used to attach the hand lever to the master cylinder housing perch. Use 1 per lever. Fits: all XJ550 models, all XJ650 models, all XJ700 models, all XJ750 (except Seca) models, all XJ900RK, and XJ1100 models.
$ 4.00
HCP3049 OEM brake lever mounting PIVOT BOLT, used to attach the hand lever to the master cylinder housing perch. Use 1 per lever. Fits: all XJ750 Seca models.
$ 4.50
HCP3560 OEM brake lever mounting pivot bolt O-RING, fits onto the pivot bolt after it passes through the hand lever. Use 1 per lever. Fits all XJ750 Seca models.
$ 3.50
HCP3047 OEM brake lever mounting pivot bolt NUT, fits onto the bottom of the pivot bolt after it passes through the hand lever. Use 1 per lever. Fits all XJ550 models, all XJ650 models, all XJ700 models, all XJ750 models, all XJ900RK and all XJ1100 models.
$ 1.25
HCP4948 OEM brake lever master cylinder actuating ADJUSTER SCREW, fits into the hand lever and controls the amount of piston stroke and lever free play. Use 1 per lever. Fits all XJ550 models, all XJ650 models, all XJ700 models, all XJ750 (except Seca) models, all XJ900RK and all XJ1100 models.
$ 1.95
HCP4949 OEM brake lever master cylinder actuating screw NUT. Use 1 per lever. Fits all XJ550 models, all XJ650 models, all XJ700 models, all XJ900RK and all XJ1100 models.
$ 2.50
HCP3047 OEM brake lever master cylinder actuating screw NUT. Use 1 per lever. Fits all XJ750 models.
$ 1.50
HCP4951 OEM brake lever return SPRING. Use 1 per lever. Fits all XJ550 models, all XJ700 models, all XJ750 Maxim and Midnight Maxim models, and all XJ900RK models.
$ 2.50
HCP4950 OEM brake lever return SPRING. Use 1 per lever. Fits all XJ650 models and all XJ1100 models.
$ 1.50
Brake Lever Cover/Boot:
hl11) Original flexible rubber accordion brake lever BOOTS protect the hinge mechanism and switch from excess moisture and dirt.
HCP608 OEM black accordion-pleated BRAKE LEVER BOOT, correct fit and appearance as original. Fit all XJ550 models, all XJ650 models, all XJ750 (except Seca) models, and XJ1100 models.
$ 8.00
HCP609 OEM black accordion-pleated BRAKE LEVER BOOT, correct fit and appearance as original. Fit all XJ900RK Seca models.
$ 14.00
Clutch Hand Levers:
hl1) OEM and aftermarket CLUTCH HAND LEVERS perfectly replace the factory original aluminum handles. Although most handle levers LOOK the same, they actually are different bike-to-bike, as the bend angle and offsets to clear other handlebar features, control switches, etc. take into account such things.
Aftermarket levers faithfully reproduce the designs of the originals, and are available in a variety of finishes, as well as having more pronounced "finger grip" scallops on the front side of the lever than the original levers do.
HCP2674 OEM CLUTCH HAND LEVER, proper fit for all XJ550 models and all XJ650 models (except Turbo). Surface texture differs from original; flat black finish.
$ 15.00
HCP2667 Aftermarket CLUTCH HAND LEVER, proper fit for all XJ550 models and all XJ650 models (except Turbo). Smooth surface texture and low gloss black color is the same as original.
$ 12.50
HCP9693 Aftermarket CLUTCH HAND LEVER, proper fit for all XJ550 models and all XJ650 models (except Turbo). Smooth surface texture and shiny gloss black color. Cast aluminum, low cost replacement for the original lever.
$ 6.95
HCP9694 Aftermarket CLUTCH HAND LEVER, proper fit for all XJ550 models and all XJ650 models (except Turbo). Smooth, bright polished chrome finish. Cast aluminum, low cost replacement for the original lever.
$ 7.95
HCP2676 OEM CLUTCH HAND LEVER, proper fit for all XJ650 Turbo, XJ750 Maxim and Midnight Maxim, and XJ1100 models. Surface texture differs from original; flat black finish.
$ 18.00
HCP2665 Aftermarket CLUTCH HAND LEVER, proper fit for all XJ650 Turbo, XJ750 Maxim and Midnight Maxim, and XJ1100 models. Has a beautiful mirror-polished CHROME PLATED FINISH, unlike the original, and also features a wider blade design than original for better grip and control.
$ 18.00
HCP2677 OEM CLUTCH HAND LEVER, proper fit for all XJ700 non-X models. Bright semi-polished finish as original. NOTE: the HCP2678 lever below, for the XJ700-X models, is the same lever, and can be used by owners desiring a mirror-polished finish.
$ 24.50
HCP2678 OEM CLUTCH HAND LEVER, proper fit for all XJ700-X models. Bright mirror-polished finish as original.
$ 27.50
HCP2679 OEM CLUTCH HAND LEVER, proper fit for all XJ750 Seca models. Surface texture differs from original; flat black finish.
$ 19.50
HCP9696 Aftermarket CLUTCH HAND LEVER, proper fit for all XJ750 Seca models. Smooth surface texture and low gloss black color is the same as original. Cast aluminum, low cost replacement for the original lever, no "fengers grips" on front face of the lever.
$ 7.50
HCP2680 OEM CLUTCH HAND LEVER, proper fit for all XJ750RL and XJ900RK Seca models. Surface texture differs from original; flat black finish.
$ 17.00
HCP2670 Aftermarket CLUTCH HAND LEVER, proper fit for all XJ750RL and XJ900RK Seca models. Smooth surface texture and low gloss black color is the same as original.
$ 11.50
HCP9697 Aftermarket CLUTCH HAND LEVER, proper fit for all XJ750RL and XJ900RK Seca models. Smooth surface texture and low gloss black color is the same as original. Cast aluminum, low cost replacement for the original lever.
$ 7.50
Clutch Hand Lever Hardware:
hl6) Clutch levers were retained to the mounting bracket via a smooth-shanked PIVOT BOLT, WASHER, and NUT. There was also a small rubber O-RING that fit under the lever where the pivot bolt passes through, in-between the lever and the retaining nut.
HCP3286 OEM clutch lever mounting PIVOT BOLT, used to attach the hand lever to the lever mounting perch. Use 1 per lever. Fits all XJ550 models, all XJ650 models except Turbo, and all XJ700 models. Black finish may differ slightly from original.
$ 4.50
HCP3293 OEM clutch lever mounting PIVOT BOLT, used to attach the hand lever to the lever mounting perch. Use 1 per lever. Fits all XJ650 Turbo models, all XJ750 models, and all XJ1100 models.
$ 4.50
HCP3407 OEM clutch lever mounting PIVOT BOLT, used to attach the hand lever to the lever mounting perch. Use 1 per lever. Fits all XJ750RL and XJ900RK Seca models.
$ 5.50
HCP3564 OEM clutch lever mounting pivot bolt COLLAR, fits into the mounting bracket where the pivot bolt passes through it. Use 1 per lever. Fits all XJ750RL and XJ900RK models.
$ 6.25
HCP3559 OEM clutch lever mounting pivot bolt WASHER, fits under the head of the pivot bolt before it passes through the hand lever. Use 1 per lever. Fits all XJ550 models and all XJ650 (except Turbo) models.
$ 1.50
HCP3558 OEM clutch lever mounting pivot bolt WASHER, fits under the head of the pivot bolt before it passes through the hand lever. Use 1 per lever. Fits all XJ650 Turbo models, all XJ750 Maxim and Midnight Maxim models, and XJ1100 models.
$ 1.50
HCP3560 OEM clutch lever mounting pivot bolt O-RING, fits onto the pivot bolt after it passes through the hand lever. Use 1 per lever. Fits all XJ550 models, all XJ650 models, all XJ700 models, all XJ750 models, and all XJ1100 models.
$ 3.50
HCP3047 OEM clutch lever mounting pivot bolt NUT, fits onto the bottom of the pivot bolt after it passes through the hand lever. Use 1 per lever. Fits all XJ550 models, all XJ650 models, all XJ700 models, all XJ750 models, all XJ900RK and all XJ1100 models.
$ 1.25
Clutch Lever Boots:
hl3) Original flexible rubber accordion Clutch Lever BOOTS protect the hinge mechanism and switch from excess moisture and dirt.
HCP606 OEM black accordion-pleated CLUTCH LEVER BOOT, correct fit and appearance as original. Fit all XJ550 models and all XJ650 (except Turbo) models.
$ 8.00
HCP604 OEM black accordion-pleated CLUTCH LEVER BOOT, correct fit and appearance as original. Fit all XJ650 Turbo, XJ750 Maxim and Midnight Maxim, and XJ1100 models.
$ 16.00
HCP607 OEM black accordion-pleated CLUTCH LEVER BOOT, correct fit and appearance as original. Fit all XJ750RL and XJ900RK Seca models.
$ 17.00
Clutch Lever Mounting Bracket:
hl4) Original black cast clutch lever MOUNTING BRACKET ("Perch") also has the drilled hole for mirror mount.
HCP3284 OEM black CLUTCH LEVER BRACKET, correct fit and appearance as original. Fit all XJ550 models and XJ650 Seca models.
$ 21.00
HCP3285 OEM black CLUTCH LEVER BRACKET, correct fit and appearance as original. Fit all XJ650 Maxim and Midnight Maxim models.
$ 49.00
HCP3283 OEM black CLUTCH LEVER BRACKET, correct fit and appearance as original. Fit all XJ650 Turbo and 1982 XJ750 Maxim models.
$ 31.00
HCP3281 OEM black CLUTCH LEVER BRACKET, correct fit and appearance as original. Fit all XJ700 models.
$ 37.00
HCP3282 OEM black CLUTCH LEVER BRACKET, correct fit and appearance as original. Fit all 1983 XJ750 Maxim and Midnight Maxim models, and XJ1100 models.
$ 25.00
HCP3280 OEM black CLUTCH LEVER BRACKET, correct fit and appearance as original. Fit all XJ750RL and XJ900RK Seca models.
$ 29.95
Clutch Lever Holder Bracket Hardware:
HCP4404 OEM clutch lever holder bracket mount BOLT, used to attach the bracket to the handlebars. Use 1 per bracket. Fits all XJ550 models, all XJ650 models, all XJ700 models, all XJ750 models except Seca, and all XJ1100 models. Finish may differ slightly from original.
$ 1.50
HCP3029 OEM clutch lever holder bracket mount BOLT, used to attach the bracket to the handlebars. Use 1 per bracket. Fits all XJ750RL and XJ900RK Seca models. Finish may differ slightly from original.
$ 1.50
HCP1902 OEM clutch lever holder bracket mount bolt LOCK WASHER, used with the above attaching bolts. Use 1 per bracket. Fits all XJ550 models, all XJ650 models, all XJ700 models, all XJ750 models except Seca, XJ750RL and XJ900RK Seca, and all XJ1100 models. Finish may differ slightly from original.
$ 1.00
Clutch Hand Lever Safety Switch:
hl18) OEM clutch lever SAFETY SWITCH pops into the clutch lever holder bracket and comes with the correctly colored wire harness leads and connector.
NOTE: except on the XJ750 Seca and XJ900RK models, the removal of these switches from the housing seems like a trick Chinese puzzle, until you figure it out.....there is small, round hole (about 2mm diameter) on the forward side of the housing where this switch plugs in. Using a small screwdriver or other such object, gently push in through this hole onto the plastic "tooth" that is part of the switch housing, while also pulling back on the switch. Releasing this ratchet tooth will release the switch from the housing, and out it comes!
HCP452 OEM clutch hand lever SAFETY SWITCH, complete with lead harness. Fits all of the following models: XJ550 all models, XJ650 all models, XJ700 all models, XJ750 Maxim and Midnight Maxim models, and XJ1100 models.
$ 15.00
HCP454 OEM clutch hand lever SAFETY SWITCH. Fits all XJ750RL and XJ900RK Seca models.
$ 16.00
HCP3556 OEM clutch lever safety switch RETAINING SCREW. Holds the switch to the bracket. Use 1 per switch on all XJ750 Seca and XJ900RK models.
$ 1.25
info @ xj4ever.com
Posted: Sun Dec 21, 2008 9:30 pm Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
this post left empty on purpose!
Posted: Sun Dec 21, 2008 10:08 pm Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION N:
BODY & FRAME:
-- Front Fairings and Windscreens.
-- Fenders.
FRONT FAIRING:
HCP1883-63 OEM front SPORT FAIRING, brilliant red, correct for all 1983 XJ900RK Seca (USA) models.
$ 279.00
Front Fairing Mounting Hardware:
HCP5787 OEM front fairing MAIN MOUNTING BRACKET, attaches the fairing to the frame, used on XJ900RK Seca models.
$ 109.95
HCP6812 OEM front fairing main mounting bracket UPPER BOLT, attaches the fairing to the frame, used on XJ900RK Seca models, use 2 per bike, each:
$ 1.25
HCP3933 OEM front fairing main mounting bracket LOWER BOLT, attaches the fairing to the frame, used on XJ650 Turbo and XJ900RK Seca models, use 2 per bike, each:
$ 1.00
HCP1902 OEM front fairing main mounting bracket bolt LOCK WASHER, attaches the fairing to the frame on both the upper and lower positions, used on XJ900RK Seca models, use 4 per bike, each:
$ 1.00
HCP7607 OEM front fairing main mounting bracket bolt FLAT WASHER, attaches the fairing to the frame on the upper positions, used on XJ900RK Seca models, use 2 per bike, each:
$ 1.00
HCP7365 OEM front fairing main mounting bracket bolt COLLAR - SPACER, attaches the fairing to the frame on the upper positions, used on XJ900RK Seca models, use 2 per bike, each:
$ 3.00
HCP7366 OEM front fairing main mounting bracket bolt COLLAR - SPACER, attaches the fairing to the frame on the lower positions, used on XJ900RK Seca models, use 2 per bike, each:
$ 3.00
HCP7363 OEM front fairing main mounting bracket bolt GROMMET, attaches the fairing to the frame on both the upper and lower positions, used on XJ900RK Seca models, use 8 per bike, each:
$ 2.75
Front Fairing Windscreen and Trim:
HCP1888 OEM front fairing windscreen black RUBBER TRIM, wraps along the outer edge or the windscreen and fairing body, correct for all 1981-82 XJ550 Seca and 1983 XJ900RK Seca (USA) models.
$ 17.00
HCP1890 OEM front fairing windscreen black RUBBER TRIM, fits in-between the base of the windscreen and the fairing body, correct for 1983 XJ900RK Seca (USA) models.
$ 12.00
HCP7362 OEM front fairing RUBBER DAMPER PAD, attaches inside the fairing, used on XJ900RK Seca models, 2 per fairing, each:
$ 4.75
HCP6747 OEM front fairing windscreen MOUNTING SCREW, attaches the windscreen to the fairing body, used on the following models, each:
$ 4.00
- XJ650 Turbo models, use 6
- 1983 XJ900RK Seca (USA) models, use 8
HCP6747SET6 OEM front fairing windscreen MOUNTING SCREWS, set of 6:
$ 22.95
HCP6747SET8 OEM front fairing windscreen MOUNTING SCREWS, set of 8:
$ 29.95
HCP3635 OEM front fairing windscreen mounting screw NUT, attaches the windscreen to the fairing body, used on XJ900RK Seca models, use 8 per windscreen, each:
$ 0.95
HCP7367 OEM front fairing windscreen mounting screw nut CAP, attaches over the HCP3635 nut listed above and provides a decorative cover, used on XJ900RK Seca models, use 8 per windscreen, each:
$ 8.95
FRONT FENDERS AND MOUNTING HARDWARE:
Front Fender:
HCP2190-6G OEM front FENDER, brand new. Fits all XJ550 Seca, 1980-82 XJ650 Euro and U.K. models, and all XJ650RJ Seca or XJ650RJC models. Painted in the original New Yamaha Black color, which is the correct color for 1983 XJ550 Seca models. NOTE: the above fender will also correctly fit all XJ750 Seca models, but it is missing the thinner, long oval "slot" opening that is directly below the large triangular openings on the fender side skirting. They look almost identical to each other once installed, and only someone with intimate knowledge of the small differences between the different flavors and models of XJ bikes of this era will ever notice the difference.
$ 109.95
HCP2194-1U OEM front FENDER, brand new. Fits all XJ550 Seca, 1980-82 XJ650 Euro and U.K. models, and all XJ650RJ Seca or XJ650RJC models. Painted in the original Crystal Silver color, which is the correct color for 1980-81 XJ650 Euro and U.K. models, and is basically identical to the XJ650RJ Seca (USA) models Quartz Silver color. NOTE: the above fender will also correctly fit all XJ750 Seca models, but it is missing the thinner, long oval "slot" opening that is directly below the large triangular openings on the fender side skirting. They look almost identical to each other once installed, and only someone with intimate knowledge of the small differences between the different flavors and models of XJ bikes of this era will ever notice the difference.
$ 199.95
HCP2214-20 OEM front FENDER, brand new. Fits all XJ650 Turbo models. Painted in the original Crystal Silver color, which is the correct color for both the1982-3 models, but is styled slightly differently between the two years (this is actually a 1982 version fender).
$ 159.95
HCP2198-6G OEM front FENDER, brand new, painted in the correct glossy New Yamaha Black color. For all XJ700 models. NOTE: 1985 models used a slightly narrower fender than the 1986 models, but are otherwise identical in shape and fit. This is a 1986 style fender.
$ 129.95
HCP2195-63 OEM front FENDER, brand new, painted in the correct Brilliant Red metallic color. For all XJ900RK Seca (US) models. Same fender design and fit as the XJ900 (Canada) models, but is a different color.
$ 134.95
Front Fender Mounting Hardware:
HCP2181 OEM front fender-to-fork tube mounting BOLT, correct polished finish hex bolt, grade 8. For all XJ550 models, all XJ650 models (except Midnight Maxim), all XJ750 models, and XJ1100 models. Use 2 per side, 4 per fender. Each:
$ 2.00
HCP2181SET4 OEM front fender-to-fork tube mounting BOLTS, set of 4:
$ 7.00
HCP3927 OEM front fender-to-fork tube mounting BOLT, correct dark grey hex bolt, grade 8. For all XJ650 Midnight Maxim models. Use 2 per side, 4 per fender. Each:
$ 2.00
HCP3927SET4 OEM front fender-to-fork tube mounting BOLTS, set of 4:
$ 7.00
HCP2182 OEM front fender-to-fork tube mounting BOLT, correct polished finish hex bolt, grade 8. For all XJ700 models. Use 2 per side, 4 per fender. Each:
$ 2.50
HCP2182SET4 OEM front fender-to-fork tube mounting BOLTS, set of 4:
$ 8.50
HCP2171 OEM front fender-to-fork tube mounting BOLT, correct polished finish hex bolt, grade 8. For all XJ900RK models. Use 2 per side, 4 per fender. Each:
$ 1.50
HCP2171SET4 OEM front fender-to-fork tube mounting BOLTS, set of 4:
$ 5.50
HCP2185 OEM front fender-to-fork tube mounting bolt LOCK WASHER, correct bright finish. For all XJ550 models, all XJ650 models, all XJ750 models, XJ900RK, and XJ1100 models. Use 2 per side, 4 per fender. Each:
$ 1.00
HCP2185SET4 OEM front fender-to-fork tube mounting LOCK WASHERS, set of 4:
$ 3.00
HCP315 OEM front fender-to-fork tube mounting bolt LOCK WASHER, correct bright finish. For all XJ700 models. Use 2 per side, 4 per fender. Each:
$ 0.95
HCP315SET4 OEM front fender-to-fork tube mounting LOCK WASHERS, set of 4:
$ 3.00
LICENSE PLATE FRAME AND HARDWARE:
Aftermarket decorative license plate FRAMES and MOUNTING HARDWARE add a little spice and flair to this area. These frames will fit all factory XJ-series bikes rear fender-mounted license plate brackets.
License Plate Frames:
HCP9702 Aftermarket rear LICENSE PLATE FRAME, polished bright chrome rectangular frame has proper bolt hole spacing for mounting of all 50-state standard size license plates.
$ 6.95
HCP9704 Aftermarket rear LICENSE PLATE FRAME, brilliant polished golden chrome rectangular frame has proper bolt hole spacing for mounting of all 50-state standard size license plates. Looks great on Midnight Maxim models or any black bike!
$ 8.95
HCP9705 Aftermarket rear LICENSE PLATE FRAME, smooth low gloss, flat-black rectangular frame has proper bolt hole spacing for mounting of all 50-state standard size license plates.
$ 6.95
HCP9703 Aftermarket rear LICENSE PLATE FRAME, smooth carbon-fiber look rectangular frame has proper bolt hole spacing for mounting of all 50-state standard size license plates.
$ 9.95
License Plate Mounting Hardware:
Aftermarket license plate mounting SCREWS and [/b]NUTS[/b] are the correct size and length to properly fit all original tag brackets, US standard-issue tags, and the above tag frames.
Screws are available in a variety of both phillips- and hex-drive head styles, and use a serrated flange (locking) nut to hold things together tightly. Get rid of those nasty, ugly, rusty original fasteners!
Use 2 screws and nuts per bike if you are not using a decorative frame, and 4 screws and nuts per tag if you are using a frame.
HCP9931 Aftermarket rear license plate mounting SCREW, made from a bright 18/8 stainless steel material, phillips-drive panhead screw. Use with the HCP9932 mounting nut listed further below. Each:
$ 0.95
HCP9930 Aftermarket rear license plate mounting SCREW, made from a black nylon (plastic) material, phillips-drive panhead screw. Looks great with the black license plate frames. Use with the HCP9932 mounting nut listed further below. Each:
$ 0.50
HCP9929 Aftermarket rear license plate mounting SCREW, made from bright polished golden brass, phillips-drive panhead screw. Looks great with the black license plate frames. Use with the HCP9932 mounting nut listed further below. Each:
$ 1.25
HCP9928 Aftermarket rear license plate mounting SCREW, made from a bright 18/8 stainless steel material, low-crown socket head cap screw with a 1/8" hex-key drive. Use with the HCP9932 mounting nut listed further below. Each:
$ 1.50
HCP9927 Aftermarket rear license plate mounting SCREW, made from black-oxide coated steel, low-crown socket head cap screw with a 1/8" hex-key drive. Use with the HCP9932 mounting nut listed further below. Each:
$ 0.75
HCP9932 Aftermarket rear license plate mounting NUT, made from a bright 18/8 stainless steel material, serrated locking flange style elminates the need for a separate lockwasher. Use with any of the mounting screws listed above. Each:
$ 0.50
info @ xj4ever.com
chacal Supporting Vendor
Joined: Aug 01, 2006 Posts: 4845 Location: At My Computer
Posted: Sun Dec 21, 2008 10:14 pm Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION N:
BODY & FRAME:
-- Side Covers, Side Cowling, Rear Cowling.
FRAME SIDE COVERS:
HCP1527-6G OEM right hand SIDE COVER, black, correct for 1983 XJ550 Seca models, but is the same physical panel as the 1982-83 XJ550 Seca models (just the wrong color).
$ 95.00
HCP1528-6G OEM left hand SIDE COVER, black, correct for 1983 XJ550 Seca models, but is the same physical panel as the 1982-83 XJ550 Seca models (just the wrong color).
$ 79.00
HCP1880-6G OEM right hand SIDE COVER, black, correct for 1981 XJ750 Seca models, but is the same physical panel as the 1982-83 XJ750 Seca models (just the wrong color).
$ 89.00
HCP1880-63 OEM right hand SIDE COVER, brilliant red, correct for 1981-82 XJ750 Seca models, but is the same physical panel as the 1983 XJ750 Seca models (just the wrong color).
$ 89.00
HCP1880-6M OEM right hand SIDE COVER, 1982 star silver, correct for 1982 XJ750 Seca models, but is the same physical panel as the 1981 and 1983 XJ750 Seca models (just the wrong color).
$ 89.00
HCP1880-1U OEM right hand SIDE COVER, 1983 quartz silver, correct for 1983 XJ750 Seca models, but is the same physical panel as the 1981-82 XJ750 Seca models (just the wrong color).
$ 89.00
HCP1893-1X OEM left hand SIDE COVER, brilliant red with low gloss black front ribs, correct for 1983 XJ900RK Seca models, but is the same physical panel for all XJ900 models made through the years, but would be the wrong color for other years.
$ 84.00
Side Cover Mounting Hardware:
bp2) OEM body side cover panel rubber MOUNTING GROMMETS, BUMPERS, and PADS. These come in a variety of sizes and shapes for different models, and all of them allow the side cover panels to be properly mounted to the bike frame or prevent vibration. GROMMETS normally fit into an open, c-shaped mounting "ear" on the side panel, or onto the bike frame via a double-lip and accept a pointed mounting "peg" molded into the side panel. BUMPERS normally push into a round hole in the side cover, and have a small "tail" that cinches tight once pushed through the hole. PADS are thin, flat insulators that are attached onto the side panel. NOTE: some grommets also have a small, mushroom-shaped metal collar that fits within the grommet and provides extra stability and rigidity to the grommet once installed.
HCP1946 OEM round rubber mounting BUMPER, used on all XJ550 Seca models, use 1 per cover, slips into the hole in the rear lower mounting flange. Each:
$ 2.00
HCP1946SET2 OEM round rubber mounting BUMPERS, set of 2:
$ 3.50
HCP1943 OEM round rubber mounting GROMMET, used on all the following models and positions:
- XJ550 all models, use 2 per cover, slips into the molded mounting ears.
- XJ650 all models (except Turbo), use 2 per cover, slips into the molded mounting ears.
- XJ700 all models, use 2 per cover, slips into the molded mounting ears.
- XJ750 Seca models, use 1 per cover, on the rear upper mounting ear.
- XJ900 model, use 2 per cover, on the rear upper and front lower mounting ears.
Each:
$ 1.50
HCP1943SET4 OEM round rubber Mounting GROMMETS, set of 4:
$ 5.00
HCP1945 OEM round rubber mounting GROMMET, used on all the following models and positions:
- XJ550 Maxim models, use 1 per cover, accepts the rear molded mounting peg.
- XJ650 all models (except Turbo), use 1 per cover, accepts the rear molded mounting peg.
- XJ700 all models, use 1 per cover, accepts the rear molded mounting peg.
- XJ900 model, use 1 per side cover, accepts the front upper molded mounting peg.
- XJ900 model, use 2 per lower body "air scoop", accepts the upper molded mounting pegs.
Each:
$ 2.50
HCP1945SET2 OEM round rubber mounting GROMMETS, set of 2:
$ 3.50
HCP1945SET4 OEM round rubber mounting GROMMETS, set of 4:
$ 6.50
HCP1951 OEM round rubber mounting GROMMET, used on all the following models and positions:
- XJ750 Maxim models, use 1 per cover, slips into the molded rear upper mounting tabs.
- XJ1100 all models, use 1 per cover, slips into the molded rear lower mounting tabs.
Each:
$ 1.50
HCP1951SET2 OEM round rubber mounting GROMMETS, set of 2:
$ 2.50
HCP1952 OEM round rubber mounting GROMMET, used on all the following models and positions:
- XJ750 Maxim and Midnight Maxim models, use 1 on the left side cover only, slips into the molded front lower mounting tab.
- XJ750 Seca models, use 2 per cover, slips into the molded front lower mounting tabs.
Each:
$ 2.50
HCP1952SET2 OEM round rubber mounting GROMMETS, set of 2:
$ 4.50
HCP1953 OEM round rubber mounting GROMMET, used on all XJ750 Maxim and Midnight Maxim models, use 1 on the right side cover only, slips into the molded front upper mounting tab. Each:
$ 2.50
HCP1953SET2 OEM round rubber mounting GROMMETS, set of 2:
$ 4.50
HCP1950 OEM round rubber mounting GROMMET, used on all the following models and positions:
- XJ750 Maxim and Midnight Maxim models, use 1 on the left side cover only, slips into the molded front upper mounting tab.
- XJ1100 models, use 1 per cover, slips into the upper center mounting tab.
NOTE: this grommet is designed to be used along with the HCP1956 metal mounting collar listed below.
Each:
$ 2.00
HCP1950SET2 OEM round rubber mounting GROMMETS, set of 2:
$ 3.50
HCP1956 OEM round rubber mounting grommet metal COLLAR, used on all the following models and positions:
- XJ750 Maxim and Midnight Maxim models, use 1 on the left side cover only, slips into the HCP1950 mounting grommet listed above.
- XJ1100 models, use 1 per cover, slips into the HCP1950 mounting grommet listed above.
Each:
$ 4.50
HCP1956SET2 OEM round rubber mounting COLLARS, set of 2:
$ 8.50
HCP2264 OEM round rubber mounting grommet mounting SCREW, used on all the following models and positions:
- XJ750 Maxim and Midnight Maxim models, use 1 on the left side cover only, retains the HCP1950/HCP1956 mounting grommet & collar listed above.
- XJ1100 models, use 1 per cover, retains the HCP1950/HCP1956 mounting grommet & collar listed above.
Each:
$ 1.50
HCP2264SET2 OEM round rubber mounting grommet SCREWS, set of 2:
$ 2.75
HCP1957 OEM round rubber mounting GROMMET, use 1 per cover in the front lower mounting tab position on all XJ1100 models. Each:
$ 3.50
HCP1957SET2 OEM round rubber Mounting GROMMETS, set of 2:
$ 6.50
TAIL LIGHT COWLING:
HCP1526-Y9 OEM rear tail light COWLING - COVER, pearl white, correct for 1981 XJ550 Seca models, but is the same physical panel as the 1982-83 XJ550 Seca models (just the wrong color). Stripe is not included.
$ 109.95
FREE STANDARD SHIPPING {OR JUST $5.00 FOR PRIORITY MAIL} SHIPPING IN THE USA FOR ALL ORDERS OVER $100 !!!!
$7.50 STANDARD SHIPPING TO CANADA FOR ALL ORDERS OVER $100 !!!!
Paypal accepted. Worldwide shipping available. Shipping prices and insurance costs are NOT included in the prices of items unless specifically listed. Please write with your list of parts needs and I will be glad to quote your shipping costs to you.
You can either PM (Private Message) me through this website, e-mail us via the "email" button on the bottom of this post, or e-mail us directly at:
info @ xj4ever.com
PLEASE NOTE!: our e-mail address does NOT have spaces before or after the "@" symbol........the posting system on this website automatically adds blank spaces before and after that symbol as an anti-spam feature! Make sure you eliminate those blank spaces when sending us an e-mail! Our e-mail address does NOT have any blank spaces in it!!
PLEASE!: on each and every correspondence with us, please tell us what YEAR and MODEL bike you have (example: 1982 XJ650 Maxim) and what your NAME (first name, at least!) is......that information really makes life a bit easier for us, and insures a more timely and ACCURATE response from us back to you!
MORE XJ PARTS IN THE FOLLOWING POST!!
_________________ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Posted: Sun Dec 21, 2008 10:16 pm Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
Posted: Sun Dec 21, 2008 10:20 pm Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION N:
BODY & FRAME:
-- Seats, Seat Locks, Helmet Locks.
SEATS AND SEAT COVERS:
Original and reproduction seat parts allow you to restore one of the most important parts of your entire bike: where your butt is placed! There's nothing worse than a worn, torn, faded, destroyed, ill-fitting seat to inspire ridicule amongst friends and to make your bike look old.
Although the replacement of a SEAT COVER is not a mechanically difficult task, the proper building or rebuilding of the underlying foam support IS an important factor in terms of comfort, fit, support, and durability of finished product. For this reason, unless you have experience in this area, we suggest you allow an experienced upholstery shop perform the installation for you.
By thw way, since many people are curious, our experience shows us that without a LOT of effort, neither seat covers nor seat pans are interchangable between different XJ model (for example, neither an XJ650 Maxim seat cover nor the complete seat will fit onto an XJ750 Maxim model). The seat panes are too different and have very different attaching points, brackets, and shapes to make interchange between models anything even approcahing "a simple swap".
HCP4331 OEM original COMPLETE SEAT ASSEMBLY, cover, foam, and pan, ready to install. Seat under-brackets and insulating pads are not included and should be transferred from your original seat. Fits all XJ550 Seca models.
$ 229.00
HCP516 OEM original SEAT COVER, with original heat-pressed seams and padded backing, ready to install. The main shaped and sculpted seat foam is NOT included with the seat cover. Fits all XJ650RJ Seca models.
$ 129.00
HCP6674B OEM original COMPLETE REAR SEAT ASSEMBLY, cover, foam, and pan, ready to install. Seat under-brackets and insulating pads are not included and should be transferred from your original seat. Fits 1985 XJ700-X and all 1986 XJ700 models. NOTE: this seat uses the "leather-look", wrinkled black vinyl fabric material with the 2-button pattern, and does NOT have the "YAMAHA" stencilled wording on the back of it as was original on the 1985 model seats.
$ 209.00
HCP522 OEM original SEAT COVER, with original heat-pressed seams and padded backing, ready to install. The main shaped and sculpted seat foam is NOT included with the seat cover. Fits all XJ900RK Seca models.
$ 209.00
HCP4344 OEM original COMPLETE SEAT ASSEMBLY, cover, foam, and pan, ready to install. Seat underbrakcets and insulating pads are not included and should be transferred from your original seat. Fits all XJ900RK Seca models.
$ 279.00
Soft Vinyl Seat Cover Dye:
All XJ models used black vinyl seats, and they sure can take a licking over the years. If your seat is showing it's age through fading and sun-bleaching, our SOFT VINYL PARTS DYE has a flat black finish and can restore that like-new appearance (sorry, it does nothing to fix those ripped or saggy sreas........!).
Typical Coverage: one can will re-color one very faded seat.
NOTE: this product can only be shipped via ground transportation and cannot cannot (and will not----don't even ask!) be shipped via any air transport delivery service-level nor outside of the USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
HCP10349 Aftermarket soft vinyl SEAT DYE produces a semi-flat black finish. Requires special surface preparation and curing procedures. Each aerosol can contains 16 ounces. Each can:
$ 12.95
SEAT PAN RUBBER PADS AND BUMPERS:
HCP4301 OEM round rubber SEAT BUMPER, use 1 per seat on 550 Seca models.
$ 3.95
HCP4303 OEM round rubber SEAT BUMPER, use 2 per seat on all XJ650 models (except 650RJ Seca), and on XJ900RK models. Each:
$ 3.95
HCP2640 OEM round rubber SEAT BUMPER, use 2 per seat on all XJ650RJ Seca models, use 3 per seat on all XJ650 Turbo models, and 1 each on all XJ700 models and XJ750 Seca models. Each:
$ 4.00
HCP4300 OEM round rubber SEAT BUMPER, use 6 per seat on all XJ650 Turbo models. Each:
$ 4.00
HCP4311 OEM round rubber SEAT BUMPER, use 1 per seat on all XJ650 Turbo models. Each:
$ 7.50
HCP4302 OEM round rubber SEAT BUMPER, use 9 per seat on all XJ750 Maxim models, and 4 per seat on XJ900RK models. Each:
$ 4.00
HCP4299 OEM round rubber SEAT BUMPER, use 1 per rear seat on all XJ700 models, and 6 per seat on XJ750 Seca models. Each:
$ 4.00
HCP4298 OEM round rubber SEAT BUMPER, use 2 per front seat on all XJ700 models. Each:
$ 3.25
SEAT AND HELMET LOCKS, LEVERS, LATCHES, AND HARDWARE:
Seat Release Locks, Levers, and Helmet Lock Assemblies:
HCP4309 OEM seat HOOK LATCH ASSEMBLY, for all XJ550 Maxim models. Use 1 per seat.
$ 19.95
HCP4263 OEM seat RELEASE ASSEMBLY, with lever, fits the left side on all XJ750 Maxim and Midnight Maxims, and all XJ1100 models.
$ 42.95
HCP530 OEM seat LOCK ASSEMBLY, fits all XJ750 Seca models. This unit also includes the helmet-holder hook.
$ 67.95
HCP531 OEM seat RELEASE ASSEMBLY, with lever, fits the left side on all XJ900RK models.
$ 64.95
HCP4264 OEM seat RELEASE ASSEMBLY, with lever, fits the right side on all XJ900RK models.
$ 44.95
HCP533 OEM HELMET LOCK ASSEMBLY, with keys, fits all XJ550 Maxim, XJ650 Turbo, XJ700 all models, and XJ900RK models.
$ 39.95
Mounting Hardware for Seat Release Locks, Levers, and Helmet Lock Assemblies:
HCP4326 OEM rear seat-to-frame mounting BOLT, for all XJ700 models, use 2 per seat, each:
$ 1.75
HCP4321 OEM front seat release lever mounting bracket assembly mounting BOLT, for all XJ700 models, use 2 per bracket, each:
$ 1.50
HCP4348 OEM helmet lock assembly mounting SCREW, for all XJ550 Maxim (use 1), special torx-drive head requires the use of our HCP10236 torx drive bit for installation or removal. Each:
$ 1.25
HCP4349 OEM seat/helmet lock assembly mounting SCREW, for all XJ650 Maxim (use 2), each:
$ 1.00
HCP4350 OEM seat/helmet lock assembly mounting SCREW, for all XJ650 Midnight Maxim (use 2), each:
$ 1.00
HCP4353 OEM seat/helmet lock assembly mounting SCREW, for all XJ650 Turbo models (use 2), each:
$ 1.25
HCP4352 OEM seat/helmet lock assembly mounting SCREW, for all XJ750 Seca models (use 3), each:
$ 1.25
HCP4355 OEM helmet lock assembly mounting SCREW, for all XJ700 models (use 1) and XJ900RK models (use 2), special torx-drive head requires the use of our HCP10236 torx drive bit for installation or removal. Each:
$ 1.75
HCP314 OEM seat lever assembly mounting SCREW, for all XJ750 Maxim and Midnight Maxim models (use 2 per lever assembly), each:
$ 1.50
HCP2264 OEM seat lever assembly mounting SCREW, for all XJ900RK models (use 2 per lever assembly), each:
$ 1.50
HCP4348 OEM seat lock assembly mounting SCREW, for all XJ650 Turbo models (use 2), special torx-drive head requires the use of our HCP10236 torx drive bit for installation or removal. Each:
$ 1.25
HCP4353 OEM seat/helmet lock assembly mounting SCREW, for all XJ650RJ Seca models (use 2), each:
$ 1.25
HCP1869 OEM seat lock assembly mounting screw FLAT WASHER, used on all XJ700 models, use 2 per bike, each:
$ 1.00
HCP3575 OEM seat hinge bracket mounting screw FLAT WASHER, used on all XJ700 models, use 2 per bracket, 4 per bike, each:
$ 1.00
HCP2173 OEM seat lever assembly mounting screw FLAT WASHER, used on all XJ900RK models, use 2 per lever assembly, 4 per bike, each:
$ 1.00
HCP315 OEM seat lever bracket mounting screw LOCK WASHER, used on all the following models, each:
$ 0.95
HCP315SET4 OEM seat lever bracket mounting screw LOCK WASHERS, used on all the following models, set of 4:
$ 3.00
* XJ650 Maxim and Midnight Maxim seat release lever mounting brackets, use 2 per bracket, 4 per seat.
* XJ650RJ Seca seat brackets, seat release lever mounting brackets, and seat hinge brackets, use as required.
* XJ650 Turbo seat brackets, seat release lever mounting brackets, and seat hinge brackets, use as required.
* XJ750 Maxim and Midnight Maxim models, seat release levers assemblies, use 2 per side, 4 per seat.
* XJ750 Seca models, seat hinge brackets, seat release levers, and seat brackets, use as required.
* XJ900RK models, seat release levers/lock assemblies, use 2 per side, 4 per seat.
* XJ1100 models, seat release levers/lock assemblies, use 2 per side, 4 per seat.
HCP4292 OEM seat hinge bracket mounting screw COLLAR, used on all XJ750 Seca models, use 2 per bracket, 4 per bike, each:
$ 1.50
HCP3703 OEM seat bracket mounting NUT, used on all the following models, each:
$ 1.25
* XJ550 Maxim seat bracket, use 2.
* XJ550 Seca seat brackets, seat release lever mounting brackets, and seat hinge brackets, use as required.
* XJ750 Maxim models seat brackets, use 2 per bracket.
* XJ900RK Maxim models seat brackets, use 2 per bracket.
* XJ1100 Maxim models seat brackets, use 2 per bracket.
HCP2176 OEM seat bracket mounting NUT, used on all the following models, each:
$ 1.50
info @ xj4ever.com
Posted: Sun Dec 21, 2008 10:28 pm Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION N:
BODY & FRAME:
-- Grab Bars, Grab Rails, Standing Handles, and Hardware.
REAR GRAB BARS AND HARDWARE:
Rear Grab Bar Mounting Hardware:
gbh2) Original passenger GRAB BARS MOUNTING HARDWARE replaces missing, damaged, or incorrect pieces.
HCP3936 OEM passenger rear grab bar MOUNTING BOLT, use 1 per side. For all XJ700 models. Each:
$ 3.95
HCP2149 OEM passenger rear grab bar MOUNTING BOLT, use 2 per side. Fits all of the following models: XJ750 Seca and XJ900RK Seca models. Each:
$ 1.00
HCP6155 OEM passenger rear grab bar mounting bolt DAMPER, use 1 per bolt. For the following models: all XJ750 Seca models. Each:
$ 3.25
HCP4956 OEM passenger rear grab bar FRONT MOUNTING BOLT, use 1 per side. For the following models: all XJ650 Maxim and Midnight Maxim models. Each:
$ 1.95
HCP7273 OEM passenger rear grab bar FRONT MOUNTING BOLT, use 1 per side. For the following models: all XJ750 Maxim and Midnight Maxim models. Each:
$ 1.95
HCP2149 OEM passenger rear grab bar FRONT MOUNTING BOLT, use 1 per side. For the following models: XJ1100 models, at the front of side rails. Each:
$ 1.00
HCP4962 OEM passenger rear grab bar front mounting bolt DECORATIVE CAP, use 1 per bolt. For the following models: all XJ750 Maxim and Midnight Maxim models. Each:
$ 2.95
HCP2148 OEM passenger rear grab bar REAR MOUNTING BOLT, use 1 per side. For the following models: all XJ550 Maxim models. Each:
$ 1.75
HCP8407 OEM passenger rear grab bar REAR MOUNTING BOLT, use 1 per side. For the following models: all XJ650 Maxim and Midnight Maxim models. Each:
$ 1.95
HCP2149 OEM passenger rear grab bar REAR MOUNTING BOLT, use 1 per side. For the following models: all XJ750 Maxim and Midnight Maxim models. Each:
$ 1.00
HCP2130 OEM passenger rear grab bar REAR MOUNTING BOLT, use 1 per side. For the following models: all XJ1100 models. Each:
$ 1.95
HCP6156 OEM passenger rear grab bar HANDLE MOUNTING BOLT, use 2 per side, where the side rails attach to the "U" bar. For the following models: all XJ750 Midnight Maxim models. Each:
$ 1.00
HCP2508 OEM passenger rear grab bar FLAT WASHER, use 1 per side on the [u[rear[/u] mounting bolt. For the following models: all XJ650 Maxim and Midnight Maxim models. Each:
$ 0.50
HCP2146 OEM passenger rear grab bar FLAT WASHER, use 1 per side on the rear side rail mounting bolt. For the following models: all XJ750 Maxim and Midnight Maxim models, and all XJ1100 models on the front mounting bolt. Each:
$ 3.75
HCP2391 OEM passenger rear grab bar handle mounting bolt FLAT WASHER, use 2 per side, where the side rails attach to the "U" bar. For the following models: all XJ750 Midnight Maxim models. Each:
$ 1.25
HCP6154 OEM passenger rear grab bar NUT, use 1 per side on the [u[rear[/u] mounting bolt. For the following models: all XJ650 Maxim models. Each:
$ 1.00
HCP4775 OEM passenger rear grab bar NUT, use 1 per side on the [u[rear[/u] mounting bolt. For the following models: all XJ650 Midnight Maxim models. Each:
$ 6.50
HCP2249 OEM passenger grab bar chrome-plated domed CROWN NUT. Fits all XJ550 Maxim, XJ650 Maxim and Midnight Maxim, and XJ750 Maxim and Midnight Maxim models where the shock absorber mounting stud comes through the grab rail. Each:
$ 5.00
HCP2249SET2 OEM passenger grab bar chrome-plated domed CROWN NUTS, set of 2:
$ 9.50
REAR SIDE STANDING HANDLES:
sh4) Original rear side SIDE STANDING HANDLES and their mounting hardware replaces missing, damaged, or incorrect pieces.
NOTE: "standing handles" are the shallow "u-shaped" grab handle that fits to the sides of the bike on models with tail light cowling covers, and are used to assist in picking up a fallen bike (it gives you something to grab hold of and "stand up" the bike) and when putting the bike onto the centerstand.
Standing Handles:
HCP4305 OEM rear side STANDING HANDLE, left side. For XJ750 Seca models only.
$ 25.95
HCP4306 OEM rear side STANDING HANDLE, left side. For XJ900RK Seca models only.
$ 18.95
HCP4314 OEM rear side STANDING HANDLE, right side. For XJ900RK Seca models only.
$ 18.95
Standing Handle Mounting Hardware:
HCP2181 OEM rear standing handle MOUNTING BOLT, use 1 per handle (for the rear mounting location), for all XJ550 Seca models.
$ 2.00
HCP2171 OEM rear standing handle MOUNTING BOLT, use 2 per handle, for all XJ650RJ Seca and XJ650 Turbo models. Each:
$ 1.50
HCP2171SET4 OEM rear standing handle mounting BOLTS, set of 4:
$ 5.50
HCP4208 OEM rear standing handle MOUNTING BOLT, use 2 per handle, for all XJ900RK Seca models. Each:
$ 1.25
HCP4208SET4 OEM rear standing handle mounting BOLTS, set of 4:
$ 4.00
HCP2537 OEM rear standing handle mounting bolt FLAT WASHER, use 1 per handle (for the rear mounting location), for all XJ550 Seca models.
$ 1.00
HCP1869 OEM rear standing handle mounting bolt FLAT WASHER, use 2 per handle, for all XJ650 Turbo models. Each:
$ 1.00
HCP1869SET4 OEM rear standing handle mounting bolt FLAT WASHERS, set of 4:
$ 2.50
HCP2185 OEM rear standing handle mounting bolt LOCK WASHER, use 1 per handle (for the rear mounting location), for all XJ550 Seca models.
$ 1.00
HCP315 OEM rear standing handle mounting bolt LOCK WASHER, use 2 per handle, for all XJ650RJ Seca and XJ650 Turbo models. Each:
$ 0.95
HCP315SET4 OEM rear standing handle mounting bolt LOCK WASHERS, set of 4:
$ 3.00
HCP2391 OEM rear standing handle mounting bolt LOCK WASHER, use 2 per handle, for all XJ900RK Seca models. Each:
$ 1.25
HCP2391SET4 OEM rear standing handle mounting bolt LOCK WASHERS, set of 4:
$ 4.50
info @ xj4ever.com
Posted: Sun Dec 21, 2008 10:39 pm Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION N:
BODY & FRAME:
-- Mirrors.
REAR VIEW MIRRORS:
bp7) OEM and aftermarket rear-view MIRRORS, complete units include the mirror head and the support stalk with threaded ends and adjuster nuts (no stalk or adjuster nut on 650 Turbo mirrors, of course!). All stalked mirrors feature the correct reverse-thread on the right side mirror to screw directly into the factory mirror mounts. Crystal-clear glass restores vision while retaining that factory original look.
NOTE: please note that all stock Yamaha mirrors use reverse (left-handed) threads on the right-side mirror post and also in the master cylinder mirror post mounting hole......so these tighten counter-clockwise (reverse from normal)......and ONLY yamaha uses these reverse-thread mirrors. So if you are trying to fit mirrors from or for any other model bike they will not thread into the master cylinder's threaded mirror mounting hole.
The left side mirror threads are standard right-hand threads, as are the threads in the clutch lever holder bracket.
Please note that XJ750 Seca models accept the mirror mounting post into the left or right side control switch housings (rather than the master cylinder or a separate clutch lever bracket).......but they, like all other Yamaha mirrors, feature that "reverse-thread" pattern on the right side mirror post.
XJ550, XJ650 Maxim and Midnight Maxim, and XJ1100 models:
HCP2059 OEM left side original CHROME RECTANGULAR MIRROR, correct for all XJ550 models, XJ650 Maxim models, and XJ1100 models.
$ 39.95
HCP2067 OEM right side original CHROME RECTANGULAR MIRROR, correct for all XJ550 models, XJ650 Maxim models, and XJ1100 models.
$ 39.95
HCP2059-67PAIR Pair of matched LH/RH original MIRRORS (one each HCP2059 and HCP2067):
$ 77.00
HCP6331 Aftermarket left side original-design CHROME RECTANGULAR MIRROR, correct for all XJ550 models, XJ650 Maxim models, and XJ1100 models. Very nice quality, good chrome finish.
$ 18.00
HCP6332 Aftermarket right side original-design CHROME RECTANGULAR MIRROR, correct for all XJ550 models, XJ650 Maxim models, and XJ1100 models. Very nice quality, good chrome finish.
$ 18.00
HCP6331-2PAIR Pair of matched LH/RH aftermarket MIRRORS (one each HCP6331 and HCP6332):
$ 34.00
HCP6328LH Aftermarket left side original-design CHROME RECTANGULAR MIRROR, correct for all XJ550 models, XJ650 Maxim models, and XJ1100 models. Very nice quality, good chrome finish, thicker black rubber gasket around the mirror allows for more contrast in the viewing area.
$ 19.95
HCP6328RH Aftermarket right side original-design CHROME RECTANGULAR MIRROR, correct for all XJ550 models, XJ650 Maxim models, and XJ1100 models. Very nice quality, good chrome finish, thicker black rubber gasket around the mirror allows for more contrast in the viewing area.
$ 19.95
HCP6328LHRH Pair of matched LH/RH aftermarket MIRRORS (one each HCP6328LH and HCP6328RH):
$ 36.00
HCP6333 Aftermarket left side original-design BLACK RECTANGULAR MIRROR, correct for the XJ650 Midnight Maxim model only, but it's the same size, shape, fitment etc. as the chrome mirrors used on all XJ550 models, XJ650 Maxim models, and XJ1100 models, and thus for people who want to go for the "black-is-beautiful" look can substitute these mirrors and still have an OE-like look and fit.
$ 18.00
HCP6334 Aftermarket right side original-design BLACK RECTANGULAR MIRROR, correct for the XJ650 Midnight Maxim model only, but it's the same size, shape, fitment etc. as the chrome mirrors used on all XJ550 models, XJ650 Maxim models, and XJ1100 models, and thus for people who want to go for the "black-is-beautiful" look can substitute these mirrors and still have an OE-like look and fit.
$ 18.00
HCP6333-4PAIR Pair of matched LH/RH aftermarket MIRRORS (one each HCP6333 and HCP6334):
$ 34.00
XJ650 Turbo models:
HCP2061 OEM left side original BLACK WEDGE MIRROR, correct for all XJ650 Turbo models. Does not include the mounting gasket "boot".
$ 82.95
HCP2062 OEM right side original BLACK WEDGE MIRROR, correct for all XJ650 Turbo models. Does not include the mounting gasket "boot".
$ 82.95
XJ700 models:
HCP2069 OEM left side original CHROME OVAL MIRROR, correct for all XJ700 models. NOTE: there is no "Yamaha" wording on the chrome "front" facing of these mirrors as original; other than that, they are identical to the originals.
$ 43.95
HCP2070 OEM right side original CHROME OVAL MIRROR, correct for all XJ700 models. NOTE: there is no "Yamaha" wording on the chrome "front" facing of these mirrors as original; other than that, they are identical to the originals.
$ 43.95
HCP206970PAIR Pair of matched LH/RH original MIRRORS (one each HCP2069 and HCP2070):
$ 81.95
HCP8676 Aftermarket left side original CHROME OVAL MIRROR, correct for all XJ700 models. NOTE: there is no "Yamaha" wording on the chrome "front" facing of these mirrors as original; other than that, they are identical to the originals.
$ 18.00
HCP8675 Aftermarket right side original CHROME OVAL MIRROR, correct for all XJ700 models. NOTE: there is no "Yamaha" wording on the chrome "front" facing of these mirrors as original; other than that, they are identical to the originals.
$ 18.00
HCP867576PAIR Pair of matched LH/RH aftermarket MIRRORS (one each HCP8675 and HCP8676):
$ 34.00
XJ750 and XJ900RK models:
HCP2068 OEM right side original BLACK RECTANGULAR MIRROR, correct for all XJ750 models and XJ900RK Seca models.
$ 67.00
HCP9604LH Aftermarket left side original-style BLACK RECTANGULAR MIRROR, correct size and shape for all XJ750 Seca and XJ900RK Seca models. NOTE: there is no "Yamaha" wording on the "front" facing of these mirrors as original; other than that, they are identical to the originals.
$ 18.00
HCP9604RH Aftermarket right side original-style BLACK RECTANGULAR MIRROR, correct size and shape for all XJ750 Seca and XJ900RK Seca models. NOTE: there is no "Yamaha" wording on the "front" facing of these mirrors as original; other than that, they are identical to the originals.
$ 18.00
HCP9604LHRH Pair of matched LH/RH aftermarket MIRRORS (one each HCP9604LH and HCP9604RH):
$ 32.95
info @ xj4ever.com
Posted: Sun Dec 21, 2008 11:00 pm Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION N:
BODY & FRAME:
-- Footpegs.
FOOTRESTS AND FOOTREST PADS:
Footrest Mounting Brackets:
frh3) The rear footrest bracket (and, on most models, the mufflers) attach to this bright polished triangular aluminum bracket (painted black on some models).
HCP6237 OEM footrest MOUNTING BRACKET is bright polished aluminum is correct for all XJ550 Maxim models, and the 1981 XJ550 Seca models. NOTE: will also properly fit the 1982-83 XJ550 Seca models, but those brackets were painted low gloss black (rather then being bright polished). Fits the left side.
$ 52.95
HCP6238 OEM footrest MOUNTING BRACKET is correct for all 1981 XJ750 Seca models, but will also correctly fit the 1982-82 models. Fits the left side.
$ 72.95
HCP6254 OEM footrest MOUNTING BRACKET is correct for the XJ900RK Seca models. Fits the left side.
$ 89.95
HCP6255 OEM footrest MOUNTING BRACKET is correct for the XJ900RK Seca models. Fits the right side.
$ 109.95
Footrest Bracket Mounting Hardware:
HCP3936 OEM footrest mounting bracket BOLT, mounts the bracket to the frame. Fits all of the following models: XJ550 all models (use 2 per side), XJ650 Maxim and Midnight Maxim models (use 2 per side), XJ650RJ Seca (use 2 per side), and XJ650 Turbo models (use 1, front lower corner on the left bracket only). NOTE: some models used a black-finished bolt originally, which are not available. This bolt has a bright plated finish. Each:
$ 3.95
HCP6260 OEM footrest mounting bracket BOLT, mounts the bracket to the frame. Fits XJ650 Turbo models (use 1, center upper position on the left bracket only). Each:
$ 1.95
HCP4956 OEM footrest mounting bracket BOLT, mounts the bracket to the frame. Fits XJ650 Turbo models (use 1, lower rear position on the right bracket only). Each:
$ 1.95
HCP4034 OEM footrest mounting bracket NUT, mounts the bracket to the frame. Fits XJ650 Turbo models (use 2 per side). Each:
$ 1.50
HCP6264 OEM footrest mounting bracket NUT, mounts the bracket to the frame. Fits XJ650 Turbo models (use 1, lower rear position on the right bracket only). Each:
$ 10.95
HCP6256 OEM footrest mounting bracket BOLT, mounts the bracket to the frame. Fits all XJ700 models (use 1 per side, forward position only). Each:
$ 1.75
HCP3966 OEM footrest mounting bracket polished, dome-head flanged BOLT, mounts the bracket to the frame. Fits all XJ700 models (use 1 per side, rear position only). Each:
$ 1.50
HCP3937 OEM footrest mounting bracket BOLT, mounts the bracket to the frame. Fits all of the following models: XJ750 Maxim and Midnight Maxim models (use 2 per side) and XJ750 Seca models (use 3 per side). NOTE: some models used a black-finished bolt originally, which are not available. These bolts have a bright plated finish. Each:
$ 3.95
HCP3929 OEM footrest mounting bracket BOLT, mounts the bracket to the frame. Fits all XJ900RK models (use 2 per bike, left side only). Each:
$ 2.95
HCP6261 OEM footrest mounting bracket BOLT, mounts the bracket to the frame. Fits all XJ900RK models (use 2 per bike, right side only). Each:
$ 1.75
HCP3930 OEM footrest mounting bracket BOLT, mounts the bracket to the frame. Fits all XJ1100 models (use 3 per side). Each:
$ 5.75
Complete Front Footrest:
bp32) OEM complete front FOOTREST ASSEMBLY includes the mounting bracket and the rubber pad.
HCP4030 OEM front (driver) FOOTREST ASSEMBLY, bracket with pad, fits the right side, for all XJ550 models. Each:
$ 89.95
HCP4126 OEM front (driver) FOOTREST ASSEMBLY, bracket with pad, fits the right side, for all XJ750 Maxim models. Each:
$ 99.95
HCP4128 OEM front (driver) FOOTREST ASSEMBLY, bracket with pad, fits the left side, for all XJ750 Seca models. Each:
$ 104.95
Front Footrest Pads Only:
bp31) OEM and aftermarket molded rubber FOOTREST PADS perfectly replace the worn, torn, rotted, or missing originals pads. Tread pattern is similar to the original.
HCP3056 OEM front (driver) rubber footrest PADS, fits either right or left side, for all XJ550 and all XJ650 models. Each:
$ 19.95
HCP252 Aftermarket front (driver) rubber footrest PAD, fits either right or left side, for all XJ550 and all XJ650 models. Very nice reproduction of the original. Each:
$ 13.95
HCP3060 OEM front (driver) rubber footrest PAD, fits either right or left side, for all 1985 XJ700 models. Each:
$ 27.95
HCP3061 OEM front (driver) rubber footrest PAD, fits either right or left side, for all 1986 XJ700 models. Each:
$ 19.95
HCP3064 OEM front (driver) rubber footrest PAD, fits either right or left side, for all XJ750 models. Each:
$ 24.95
HCP3052 OEM front (driver) rubber footrest PAD, fits either right or left side, for all XJ900RK models. Each:
$ 19.95
HCP3069 OEM front (driver) rubber footrest PAD, fits either right or left side, for all XJ1100 models. Each:
$ 18.95
HCP6090 OEM front (driver) rubber footrest pad MOUNTING NUT, fits either right or left side, for all 1986 XJ700 models. Use 2 per pad. Each:
$ 1.50
HCP3047 OEM front (driver) rubber footrest pad MOUNTING NUT, fits either right or left side, for all XJ900RK models. Each:
$ 1.50
Front Footrest Assembly Mounting Hardware:
HCP4025 OEM front footrest bracket-to-frame MOUNTING BOLT, use 1 per side, for all XJ550 models. Each:
$ 1.50
HCP4069 OEM front footrest bracket-to-frame MOUNTING BOLT, use 2 per side, for all XJ700 models. Each:
$ 1.50
HCP3931 OEM front footrest bracket-to-frame MOUNTING BOLT, use 2 per side, for all XJ750 Seca models. Each:
$ 1.50
HCP4033 OEM front footrest bracket-to-frame MOUNTING BOLT, use 1 per side, for all XJ900RK Seca models. Each:
$ 5.75
HCP4111 OEM front footrest bracket-to-frame mounting bolt WASHER, use 2 per bolt, forward position, for all XJ750 Seca models. Each:
$ 3.50
HCP4081 OEM front footrest bracket-to-frame mounting bolt WASHER, use 1 per side, for all XJ900RK models. Each:
$ 2.25
HCP4034 OEM front footrest mounting bolt NUT. Use 1 per bolt. For all XJ750 Seca models. Each:
$ 1.50
Front Footrest Swivel Hardware:
HCP4106 OEM front footrest swivel bracket CLEVIS PIN. Use 1 per footrest. For all XJ550, XJ750 Seca, and XJ1100 models. Each:
$ 4.25
HCP4072 OEM front footrest swivel bracket CLEVIS PIN. Use 1 per footrest. For all XJ700 models. Each:
$ 3.95
HCP4113 OEM front footrest swivel bracket CLEVIS PIN. Use 1 per footrest. For all XJ750 Maxim models. Each:
$ 3.95
HCP4108 OEM front footrest clevis pin WASHER. Use 1 per footrest. For all XJ550 models, XJ750 Seca, and XJ1100 models. Each:
$ 1.00
HCP4074 OEM front footrest swivel bracket COTTER PIN, retains the clevis pin. Use 1 per footrest. For XJ700 models. Each:
$ 1.00
HCP4114 OEM front footrest swivel bracket COTTER PIN, retains the clevis pin. Use 1 per footrest. For XJ750 Maxim and Midnight Maxim models. Each:
$ 1.25
HCP4107 OEM front footrest swivel bracket SPRING. Use 1 per footrest. For all XJ550 models, XJ750 Seca, and XJ1100 models. Each:
$ 2.50
HCP4076 OEM front footrest swivel bracket SPRING. Use 1 per footrest. For all 1986 XJ700 models. Each:
$ 3.75
Complete Rear Footrests:
HCP4031 OEM rear passenger FOOTREST ASSEMBLY, bracket with pad, fits the left side, for all XJ550 models. Each:
$ 55.95
HCP4039 OEM rear passenger FOOTREST ASSEMBLY, bracket with pad, fits the left side, for all XJ650 Maxim and Midnight Maxim models. NOTE: these are bright plated, correct for Maxim and incorrect for Midnight Maxims. Each:
$ 59.95
HCP4041 OEM rear passenger FOOTREST ASSEMBLY, bracket with pad, fits the right side, for all XJ650 Maxim and Midnight Maxim models. NOTE: these are bright plated, correct for Maxim and incorrect for Midnight Maxims. Each:
$ 59.95
HCP4052 OEM rear passenger FOOTREST ASSEMBLY, bracket with pad, fits the left side, for all XJ650 Turbo models. Each:
$ 52.95
HCP4058 OEM rear passenger FOOTREST ASSEMBLY, bracket with pad, fits the left side, for all 1985 XJ700 models. Each:
$ 149.95
HCP4059 OEM rear passenger FOOTREST ASSEMBLY, bracket with pad, fits the right side, for all 1985 XJ700 models. Each:
$ 149.95
HCP4124 OEM rear passenger FOOTREST ASSEMBLY, bracket with pad, fits the left side, for all XJ750 models except Midnight Maxims. Each:
$ 79.95
HCP4118 OEM rear passenger FOOTREST ASSEMBLY, bracket with pad, fits the left side, for all XJ750 Midnight Maxim models. NOTE: these will also fit all other XJ750 models (Maxim and Seca) but they are not bright plated as original. Each:
$ 79.95
HCP4119 OEM rear passenger FOOTREST ASSEMBLY, bracket with pad, fits the right side, for all XJ750 Midnight Maxim models. NOTE: these will also fit all other XJ750 models (Maxim and Seca) but they are not bright plated as original. Each:
$ 79.95
HCP4086 OEM rear passenger FOOTREST ASSEMBLY, bracket with pad, fits the left side, for all XJ900RK Seca models. Each:
$ 134.95
HCP4087 OEM rear passenger FOOTREST ASSEMBLY, bracket with pad, fits the right side, for all XJ900RK Seca models. Each:
$ 134.95
Rear Footrest Pads Only:
HCP3057 OEM rear (passenger) rubber footrest PADS, fits either right or left side, for all XJ550 models. Each:
$ 12.50
HCP3058LH OEM rear (passenger) rubber footrest PAD, for the left side, for all XJ650 models. Each:
$ 21.95
HCP3058RH OEM rear (passenger) rubber footrest PAD, for the right side, for all XJ650 models. Each:
$ 21.95
HCP3059LH OEM rear (passenger) rubber footrest PAD, for the left side, for all 1985 XJ700 and XJ1100 models. Each:
$ 22.95
HCP3059RH OEM rear (passenger) rubber footrest PAD, for the right side, for all 1985 XJ700 and XJ1100 models. Each:
$ 22.95
HCP3062 OEM rear (passenger) rubber footrest PAD, for the left or right side, for all 1986 XJ700 models. Each:
$ 19.95
HCP3053 OEM rear (passenger) rubber footrest PAD, for the left or right side, for all XJ900RK models. Each:
$ 17.95
HCP4067 OEM rear (passenger) rubber footrest pad MOUNTING BOLT, fits either right or left side, for all 1986 XJ700 models. Each:
$ 1.25
HCP168 OEM rear (passenger) rubber footrest pad MOUNTING SCREW, fits either right or left side, for all XJ900RK models. Each:
$ 1.00
Rear Footrest Mounting Hardware:
HCP3936 OEM rear footrest MOUNTING BOLT, use 1 per side, for all XJ550 models. Each:
$ 3.95
HCP4033 OEM rear footrest bracket-to-frame MOUNTING BOLT, use 1 per side, for all XJ650 Maxim and Midnight Maxim models, all XJ750 models, and XJ1100 models. Each:
$ 5.75
HCP4034 OEM rear footrest mounting bolt NUT. Use 1 per bolt. For all XJ550 models, all XJ650 models, all XJ750 Maxim models, XJ900RK, and XJ1100 models. Each:
$ 1.50
HCP4120 OEM rear footrest mounting bolt NUT. Use 1 per bolt. For all XJ750 Midnight Maxim models. Each:
$ 1.25
Rear Footrest Swivel Hardware:
HCP4045 OEM rear footrest shaft-to-swivel bracket WASHER. Use 1 per footrest. For all XJ550 models and XJ650RJ Seca and XJ650 Turbo. Each:
$ 2.95
HCP4065 OEM rear footrest shaft-to-swivel bracket WASHER. Use 1 per footrest. For all 1986 XJ700 models. Each:
$ 6.50
HCP4105 OEM rear footrest swivel bracket CLEVIS PIN. Use 1 per footrest. For all XJ550 and XJ750 models. Each:
$ 4.95
HCP10060 OEM rear footrest swivel bracket CLEVIS PIN. Use 1 per footrest. For all XJ650RJ Seca and XJ650 Turbo models. Each:
$ 1.00
HCP4071 OEM rear footrest swivel bracket CLEVIS PIN. Use 1 per footrest. For all XJ700 models. Each:
$ 2.25
HCP10059 OEM rear footrest swivel bracket CLEVIS PIN. Use 1 per footrest. For all XJ1100 models. Each:
$ 1.25
HCP4046 OEM rear footrest swivel bracket COTTER PIN, retains the clevis pin. Use 1 per footrest. For XJ550 models, XJ650RJ Seca and XJ650 Turbo models, all XJ700 models, and all XJ750 Maxim and XJ750 Seca models. Each:
$ 2.95
HCP3480 OEM rear footrest swivel bracket COTTER PIN, retains the clevis pin. Use 1 per footrest. For XJ750 Midnight Maxim and all XJ1100 models. Each:
$ 3.95
HCP4066 OEM rear footrest swivel bracket SPRING. Use 1 per footrest. For all 1986 XJ700 models. Each:
$ 1.95
info @ xj4ever.com
Posted: Sun Dec 21, 2008 11:07 pm Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
SECTION N:
BODY & FRAME:
-- Kickstand, Centerstand, and Hardware.
SIDE KICKSTANDS AND HARDWARE:
cks2) Original-profile sidestands or KICK STANDS correctly replaces damaged or incorrect originals. Kickstand springs, hardware, and other accessory parts are also listed below.
HCP3904 OEM sidestand or KICK STAND, fits all XJ550 models, low gloss black finish as original.
$ 59.95
HCP3907 OEM sidestand or KICK STAND, fits all XJ700 models, low gloss black finish as original.
$ 65.95
HCP3908 OEM sidestand or KICK STAND, fits all XJ900RK Seca models, low gloss black finish as original.
$ 74.95
HCP3913 OEM sidestand or kickstand RETURN SPRING, fits all XJ550 models, this is the thinner (inner) spring.
$ 6.95
HCP3915 OEM sidestand or kickstand RETURN SPRING, fits all XJ550 models, this is the fatter (outer) spring.
$ 6.95
HCP3911 OEM sidestand or kickstand RETURN SPRING, fits all 1980-81 XJ650 Maxim and Midnight Maxim models.
$ 9.95
HCP3914 OEM sidestand or kickstand RETURN SPRING, fits all 1982-84 XJ650 Maxim, all XJ700, and all XJ1100 models.
$ 8.95
HCP3912 OEM sidestand or kickstand RETURN SPRING, fits all 1982 XJ650RJ Seca models, all XJ650 Turbo, all XJ750 models, and XJ900RK Seca models.
$ 8.95
HCP3910 OEM sidestand or kickstand return spring LINK, fits all XJ550 Maxim and all XJ700 models.
$ 8.95
HCP9820 OEM sidestand or kickstand GUIDE, fits all 1982 XJ650RJ Seca models, all XJ650 Turbo, all XJ750 models, and XJ900RK Seca models.
$ 11.95
HCP8643 OEM sidestand or kickstand shouldered MOUNTING BOLT, fits all XJ550, XJ650, XJ700, XJ750, XJ900RK, and XJ1100 models.
$ 4.95
HCP2557 OEM sidestand or kickstand mounting bolt NUT, fits all XJ550, all XJ650 and XJ750 except Midnight Maxim models, all XJ900RK and XJ1100 models.
$ 2.95
HCP3976 OEM sidestand or kickstand mounting bolt NUT, fits all XJ650 Midnight Maxim and XJ750 Midnight Maxim models.
$ 1.50
HCP3977 OEM sidestand or kickstand mounting bolt NUT, fits all XJ700 models.
$ 3.95
CENTERSTANDS AND HARDWARE:
cks4) Original-profile CENTERSTANDS correctly replaces damaged or incorrect originals. Springs, hardware, and other accessory parts are also listed below.
HCP3892 OEM CENTERSTANDS fits all XJ700 models, low gloss black finish as original.
$ 94.50
HCP3902 OEM CENTERSTANDS fits all XJ900RK Seca models, low gloss black finish as original.
$ 109.95
HCP3898 OEM centerstand RETURN SPRING, fits all XJ650 Maxim and Midnight Maxim models and all XJ700 models.
$ 9.95
HCP3895 OEM centerstand RETURN SPRING, fits all XJ650 Turbo and all XJ750 Seca models.
$ 12.95
HCP3965 OEM centerstand shouldered MOUNTING BOLT, fits all XJ550, all XJ650 Maxim and XJ650RJ Seca models, all XJ700 models, and all XJ750 Maxim and Midnight Maxim models. Use 2 per bike. Each:
$ 1.95
HCP3938 OEM centerstand shouldered MOUNTING BOLT, fits all XJ650 Turbo models. Use 2 per bike. Each:
$ 8.95
HCP9841 OEM centerstand shouldered MOUNTING BOLT, fits all XJ750 Seca nd XJ900RK models. Use 2 per bike. Each:
$ 10.50
HCP3970 OEM centerstand mounting bolt WASHER, fits all XJ550, all XJ650 Maxim and XJ650RJ Seca models, all XJ700 models, and all XJ750 Maxim and Midnight Maxim models. Use 2 per bike. Each:
$ 1.95
HCP2258 OEM centerstand mounting bolt WASHER, fits all XJ650 Midnight Maxim models. Use 2 per bike. Each:
$ 3.50
HCP9945 OEM centerstand mounting bolt NUT, fits all XJ650 Turbo models. Use 2 per bike. Each:
$ 4.95
HCP9946 OEM centerstand mounting bolt NUT, fits all XJ750 Seca, and XJ900RK models. Use 2 per bike. Each:
$ 4.95
HCP3973 OEM centerstand mounting bolt NUT, fits all XJ1100 models. Use 2 per bike. Each:
$ 3.95
info @ xj4ever.com
xjbikes.com/Forums/vie.../f=23.html |
Posted: Sun Dec 21, 2008 11:15 pm Post subject: Re: XJ MAXIM, SECA, AND TURBO PARTS CATALOG |
This post left empty on purpose!
