 Latest: JimIndyV8
 New Today: 5
 New Yesterday: 6
 Overall: 8082
 Members: 9
 Visitors: 12
 Total: 21
Who Is Where: Members:01: bigfitz52 > Forums
02: dartman > Home
03: graniteyamaha > My Private Messages
04: Jay~Dub > Photo Gallery
05: JayEye > Forums
06: kirkn > Forums
07: mdee > Forums
08: plansea > Forums
09: strat > Forums
We have received 35522685page views since August 9, 2005
Forums › XJBikes Talk › XJ Chat › I thought I was an ok mechanic untill.....
I thought I was an ok mechanic untill.....Technical discussion ONLY for XJ Maxim/Seca...
Go to page 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 Next
Tiny 5th gear
Joined: Feb 05, 2009 Posts: 237 Location: Battle Ground, Wa
Posted: Fri May 29, 2009 4:56 am Post subject: I thought I was an ok mechanic untill..... |
I cant get the damn thing to spark. Picks show bounce on the volt meter when the engine cranks over, coils ohm out fine and i have a couple new used tci boxes. WHAT NOW?!?!?!?!?! I'm about ready to sell the damn thing as I've put about a grand into buying and trying to get the thing running and I haven't had so much as a backfire out of it. What now. I already replaced the fuse box and checked my conections a couple dozen times. The coils have tweleve volts running to them I just don't have so much as a hint of spark. I'm beyond desperate and ready to put it on craigslist. Please help me out here
_________________ 1980 Maxim 650 (Soon to be daily rider)
1980 Maxim 650 (Parts bike)
1985 Maxim 700 (Sadly parting out)
1970 DT1 (Long term restoration) |
protomillenium 5th gear
Joined: Aug 31, 2008 Posts: 231 Location: New Buffalo, Michigan
Posted: Fri May 29, 2009 5:10 am Post subject: Re: I thought I was an ok mechanic untill..... |
Tiny, you forgot to tell us what bike you're talking about, and I did not see you list 12 volts at the coil plugs. Give us more info.
Bill
Tiny 5th gear
Posted: Fri May 29, 2009 5:16 am Post subject: Re: I thought I was an ok mechanic untill..... |
Sorry bill. It's a 1980 xj 650 maxim.
mcrwt644 Red Liner
Joined: May 29, 2006 Posts: 763 Location: Winchester, VA
Posted: Fri May 29, 2009 6:58 am Post subject: Re: I thought I was an ok mechanic untill..... |
side stand relay. Disconnect it and see if you have spark. It is a light green/lime green connection in the headlight bucket. Make sure that the side stand switch is functioning correctly. I'm betting it is the relay. My buddy had the EXACT same problem on an 81 xj 650
_________________ Any moron can go fast in a straight line. It's in the twisties that seperate the men from the boys.'
1985 XJ700X 20xxx The 'EX' breaking in the new engine
1985 XJ700x, the 'Nahfick', current project |
sgknies 1st gear
Posted: Fri May 29, 2009 7:03 am Post subject: Re: I thought I was an ok mechanic untill..... |
Tiny, put a hold on the craigslist thing. The gurus here are WELL compitent enough to diagnose your issues. Just hang in there and see what they say. I have this exact bike...year and all and it runs like a top.
_________________ 1980 xj650 Maxim (now daily commuter) |
sgknies 1st gear
Posted: Fri May 29, 2009 7:04 am Post subject: Re: I thought I was an ok mechanic untill..... |
mc I don't think the 80 model has the relay on it. I could be wrong, but my bike doesn't have it and it's an 80 model
SLKid XJ Wizard
Joined: Feb 10, 2009 Posts: 1063 Location: Pungo, Va Beach, VA
Posted: Fri May 29, 2009 7:24 am Post subject: Re: I thought I was an ok mechanic untill..... |
Second that Side Stand relay. Got me twice bashing my head against a wall. "WHY WONT IT WORK" Is all I could say for an hour.
Sat on it, kicked the stand up, pressed start.
And nearly passed out with relief
_________________ "Maxine" Gold and Green
'85 Yamaha Maxim XJ700 16k miles. Runnin like a champ
38MPG Daily Stress Relief
Highest MPH: 122 at 8.6k
To Do:New Rear Shocks, New Exhaust, New Valve Cover Gasket/Donuts, Fine Polish Stuff, Re-paint Frame, Replace rusted bolts and hardware, Rebuild Calipers, Replace Brake lines, Replace Brake Pads.
| bill wrote: |
You're having way too much fun Chris  |
sgknies 1st gear
Posted: Fri May 29, 2009 7:58 am Post subject: Re: I thought I was an ok mechanic untill..... |
Not to distract from Tiny's issue, but I am now confused. Does the 1980 models HAVE the kickstand relay on them? I can start mine sitting on the kickstand. I was under the impression that the 1980 models did not have the relay installed on them yet. Can someone clarify this for me?
Robert Moderator
Joined: Feb 06, 2006 Posts: 6791 Location: Ventura CA
Posted: Fri May 29, 2009 8:23 am Post subject: Re: I thought I was an ok mechanic untill..... |
No, the 80-81 650 Maxims do not have a sidestand relay.
They do have a clutch switch...
_________________ Robert
'81 XJ750RH Seca (ditto)
Past glory includes:
'86 XVZ1300 Venture Royal
'86 XT125
'84 GPz750A1 Ninja
'83 VF750F Interceptor |
sgknies 1st gear
bill XJ Wizard
Joined: Jun 20, 2008 Posts: 2813 Location: Raleigh, NC
Posted: Fri May 29, 2009 8:55 am Post subject: Re: I thought I was an ok mechanic untill..... |
You can start a bike with the sidestand relay IF it is in neutral with the stand down. It won't crank in gear with the sidestand down....
The 80 is simpiler and cuts off the starter unless in neutral or in gear with clutch in. Later models have starter and TCI cutoff.
But not the issue here - Spins, 12V to coils, TCI appears to functioning, pickups appear good. Coils test good with ohm meter. No spark.
Let me some basic questions, just bear with me. When stumped I like to go back to ground zero.
How are you determining you have no spark other than no start?
Have you check the coils ground all the way back to the battery?
When you check a coil you should remove the plug caps. Assuming you did that are you sure your plug caps are any good?
How about the connection to the wire for the caps? Very common for this to corrode. You can snip a bit off the wire for a better connection - just watch your length.
_________________ 82 XJ650J Maxim 43k miles and climbing - all stock
82 XS400J 16k miles (project bike right now)
Past rides:
66 Honda Superhawk (partial rebuild - sold in 2008)
71 Honda CB350 (sold after rebuilding engine)
81 XS850 Midnight special (never should have sold it)
| wizard wrote: |
| Yamaha Induction Control System, or in lay terms, a hole in the head. |
Robert Moderator
Posted: Fri May 29, 2009 8:59 am Post subject: Re: I thought I was an ok mechanic untill..... |
I'm with Bill, back to basics and build a foundation of knowledge to further the effort.
'86 XT125
'84 GPz750A1 Ninja
Tiny 5th gear
Posted: Fri May 29, 2009 1:37 pm Post subject: Re: I thought I was an ok mechanic untill..... |
Bill, I have no spark to the plug. I pulled the wire and stuck my finger in it to make sure. Plug caps are good. I have not traced my ground back to the battery. I'll do that this evening. No corrosion in the caps. sgknies, I have no doubt they can figure out what the issue is, its just a matter of how much more time and money it will take to get it running. Im beyond frustrated and I refuse to spend another pennie on this thing until I see spark.
bill XJ Wizard
Posted: Fri May 29, 2009 2:30 pm Post subject: Re: I thought I was an ok mechanic untill..... |
I can understand your frustration I tuned my bike Saturday and just now had to clean 2 plugs (again) to get her running on all 4.It's a labor of love. Most of us have reached that point. Best thing to do is take a bit of a break.
Once you are ready let me clarify. When you say ""I pulled the wire and stuck my finger in it to make sure." you mean with the plug cap on or off?
Have you examined the wire where the plug screws into?
I see you have a parts bike have you tried the other coils?
Sorry if you have been through all this before just trying to see what the heck is going on. Has to be a logical reason.
Past rides:
| wizard wrote: |
Tiny 5th gear
Posted: Fri May 29, 2009 9:12 pm Post subject: Re: I thought I was an ok mechanic untill..... |
| bill wrote: |
I pulled the cap off the plug and stuck my finger where it conects to the spark plug to see if I felt a shock. nothing. I tried the coils off my parts bike and still no luck. I don't think I can possibly have four bad coils.
