 Latest: Fishdoc
 New Today: 0
 New Yesterday: 0
 Overall: 13293
 Members: 7
 Visitors: 34
 Total: 41
Who Is Where: Members:01: Beck > Forums
02: BeckyB > Forums
03: k-moe > Home
04: quebecois59 > Forums
05: ScreamingGigabyte > Forums
06: tstroud > Forums
07: XJOE550 > Jokes
08: Home
19: Forums
20: Forums
21: Home
22: Forums
23: Forums
24: Forums
25: Forums
26: Forums
27: Forums
28: Forums
29: Forums
30: Forums
31: Forums
32: Forums
33: Forums
34: Forums
We have received 97356452page views since August 9, 2005
Forums › XJBikes Talk › XJ Chat › Battery w/sensor
Battery w/sensorTechnical discussion ONLY for XJ Maxim/Seca...
bstig60 4th gear
Joined: May 16, 2008 Posts: 168 Location: Nevada City, CA
Posted: Sun Sep 27, 2009 8:22 pm Post subject: Battery w/sensor |
My son needs to replace the battery in his XJ750RK. He went to Sears and got a Diehard, but it doesn't have the sensor. I told him he needs to take the battery back and get the correct one. If I remember correctly, the new battery should come with a new sensor....... Is that correct? Or does the battery just need the screw in caps so the old sensor will screw into the proper one?
_________________ Bill
1999 Virago XV1100LC (Daily Rider)
1983 XJ750RK
1983 XV920K Virago (Sold)
1984 XR200R (Sold)
1984 XL350R (Dual Sport)
1987 TLR200 (Sold)
Bikes I have owned: 1986 XV1100; 1983 XJ750 Maxim; 1980 XT250F; 1977 XS750 Triple; 1970 CT1 175 Enduro; 1969 AT1 125 Enduro; 1966 YDS3 250 twin 2 stroke |
SQLGuy XJ Wizard
Joined: Jun 07, 2008 Posts: 1354 Location: Colorado Springs, Colorado USA
Posted: Sun Sep 27, 2009 8:57 pm Post subject: Re: Battery w/sensor |
Some of the Yuasa battery models come with a sensor. Yuasa has been discontinuing a lot of those, though.
I've been using off-the-shelf lead acid batteries, like Diehards and Exides, and drilling and/or tapping mounting holes for the sensor as needed.
_________________ '82 SECA 750 - converted to fuel injection with Microsquirt and a bunch of home-made pieces.
'83 GPz 750 - mostly stock... for now |
bstig60 4th gear
Posted: Sun Sep 27, 2009 9:09 pm Post subject: Re: Battery w/sensor |
Can you explain in a little more detail?
1983 XJ750RK
1984 XR200R (Sold)
1987 TLR200 (Sold)
chacal Supporting Vendor
Joined: Aug 01, 2006 Posts: 4845 Location: At My Computer
Posted: Sun Sep 27, 2009 9:23 pm Post subject: Re: Battery w/sensor |
Most aftermarket replacement batteries for the Yamaha models do not come with a sensor nor with provision (threaded cap holes) for the original screw-in sensor. Yuasa (the original battery supplier) offers their replacement batteries for this model both in a sensor and non-sensor versions. The non-sensor versions are less expensive, and although their sensor-version battery comes with the sensor, it is a different sensor from the original sensor.
Which brings up an important point.........what SQL is referring to is that you can use an original sensor on an aftermarket battery if you use a proper-sized bolt to "cut" threads in the aftermarket battery cap hole (so that it will have threads that the original screw-in sensor can now thread into); but, be aware that the original sensor probe tip may be "too deep" for the type of battery you purchase; the original sensor tip is rather deep and if it contacts the plates in the aftermarket battery, well, that's very definitely not a good thing.
So you may end up having to modify (cut off) some length of the probe tip of the original sensor, or use some type of rubber or plastic "shims" to space up the original sensor so that the sensor probe tip does not contact the plates within the replacement battery (as well as having to "thread" the cap hole of the replacement battery to accept the original screw-in sensor). We carry such shims (and the correct thread-cutting bolt) for use in modifying replacement batteries (as well as the correct original sensor, and original and replacement batteries of various types).
And, of course, the "permanently sealed" maintenance-free replacement batteries may not even have removable/replacable port caps, in which case an original sensor cannot be adapted to it in any manner.
_________________ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
xjbikes.com/Forums/vie.../f=23.html |
joshua 5th gear
Posted: Sun Sep 27, 2009 9:47 pm Post subject: Re: Battery w/sensor |
u can use a bolt to thread the threads into the 2 ports you need for yur sensor. ask chacal about the thread size cause he knows it and i forgot it. he is the parts guru here and can be found in the forums.
_________________ 82 XJ750RJ 83 XJ750RK in state of shock/disassy 03 ZX9 (sold)
First Bike 74 kz550 triple 2 stroker may she rest in peace
80 suzuki GS750 dead and buried |
bstig60 4th gear
Posted: Sun Sep 27, 2009 11:00 pm Post subject: Re: Battery w/sensor |
What is the proper bolt size and what is the procedure? Must a hole be drilled in the new battery or can one of the existing holes be threaded? What is the cost of the shims?
1983 XJ750RK
1984 XR200R (Sold)
1987 TLR200 (Sold)
