XJBikes.com XJ4Ever
Toggle Content
Toggle Content Advertisement
Toggle Content Donate
Donate with PayPal!
Toggle Content Main Menu
Toggle Content User Info
Nickname
Password
Latest: JimIndyV8
New Today: 5
New Yesterday: 6
Overall: 8082
Members: 15
Visitors: 21
Total: 36
Who Is Where:
 Members:
01: 36Drew > My Private Messages
02: andrewlong > Forums
03: CaptNemo > Forums
04: dartman > Photo Gallery
05: dltaylor > Photo Gallery
06: finch > Forums
07: kornele > Forums
08: Lou627 > Forums
09: Ravenz07 > Forums
10: RefinedXJ > Forums
11: schooter > Forums
12: ski84 > Forums
13: TIMEtoRIDE > Forums
14: VanNorman6 > Forums
15: zombiehouse > Forums
 Visitors:
01: Forums
03: Photo Gallery
04: Photo Gallery
16: My Account
19: Forums
20: My Account
21: Forums
Staff Online:
No staff members are online!
Toggle Content Google Search
Toggle Content Total Hits
We have received
35524237
page views since
August 9, 2005
Forums › XJBikes Talk › XJ FAQ Suggestions › Pre carb-cleaning checklist
FAQ technical writeup. Available to all for discussion
Post new topic   Reply to topic   Printer Friendly Page    Forum Index XJ FAQ Suggestions
Author Message
LeSkid
2nd gear
2nd gear
PostPosted: Mon Mar 08, 2010 10:49 am    Post subject: Pre carb-cleaning checklist Reply with quote
I tore-down my carbs this weekend with pretty good results for 3/4 cylinders. Also uncovered a pinhole in one of the diaphragms.
But AFTERWARDS, I read Rick's carb cleaning guide and I clearly missed a lot. I didn't even touch the enrichment valves so I'm guessing that's why one of my cylinders isn't firing.
May as well RVT that pinhole in the diaphragm too.
So round 1 was just a practice run, to be repeated again, only better / complete with bench synching.
Before I attack round two, what should I have on-hand?
Carb cleaner: any particular brand better than others? that doesn't damage rubber bits & pieces? How many cans or what size of can?
Spraying-out clogs / debris should I use carb cleaner for this or compressed air? (I don't have a compressor)
Cleaning / prepping diaphragms for reinstall what's best to clean these things that won't damage the fragile rubber?
Anything Else that a novice home mechanic might not know about to make the job easier? (besides proper tools, of course)
_________________
1982 Seca 650
2003 FJR1300
Back to top
View user's profile
TIMEtoRIDE
XJ Wizard
PostPosted: Mon Mar 08, 2010 11:38 am    Post subject: Re: Pre carb-cleaning checklist Reply with quote
Since you have a running bike, you can pre-diagnose the 4 carbs before going back in.
* Spray water on the header pipes to see if a CYL is firing
* loosen then lift each "choke" fork individually, listen for a difference.
* run the pilot screw in and out (carefully) , listen again
* On the "dead" CYL, spray a whiff of starter fluid, to confirm it will fire.
* While running, check float levels using the clear tube method
* Take written notes of results.
The diaphragm can be patched with Liquid Electric tape and a piece from a Nitrilite disposable glove.
_________________
'83 Seca 900 - - '81 Seca 750 - - '88 Venture Royale - - '84 Venture Project
2006 FJR 1300
xjbikes.com/Forums/vie...ation.html
Tire date code check:
www.xjbikes.com/Forums...vious.html
Back to top
LeSkid
2nd gear
2nd gear
PostPosted: Mon Mar 08, 2010 11:55 am    Post subject: Re: Pre carb-cleaning checklist Reply with quote
I just used my hand on the exhaust, since I only ran it for 20-30 seconds. 1, 2 & 4 are running, #3 is the dead one.
OK, one more thing to add to my checklist
3 out of 4 drain screw are mush so I was thinking of using Manbot13s tip and use the one good float bowl to test each carb. Sounds like a long, messy & gas-wasting process but as long as I can validate the levels are good, it'll be worth it.
Excellent - thanks
Any particular brand or type of carb cleaner recommended?
_________________
1982 Seca 650
2003 FJR1300
Back to top
View user's profile
schooter
XJ Wizard
PostPosted: Mon Mar 08, 2010 1:07 pm    Post subject: Re: Pre carb-cleaning checklist Reply with quote
Honestly, I think all carb cleaners are the same- just some kind of alcohol or soemthing, I but the $1.70 a can walmart delux and find it works fine, just grab 2 cans, it comes in hany soemtimes to clean grease and whatnot
the carb clean will work fine to clear cebris... also, I would reccomment buying soemthing like a dentist tool set orsomething pokey to clear out all the holes
*be sure to clear out EVERY hole in the emulsion tubes*
also, i always do this now- I clean the seat for the floats by cutting a q-tip in half, putting it in a drill, and putting some brasso (llike $2.50) on the end of the q-tip to ensure a good seat for the floats so they're not over flowing... you'll be amazed what the q-tips look like when you're done
you can use your hand too if you dont have a drill...
_________________
~WILLIAM "BILL" SCHMITT~
~R.I.P~
85 maxim 700
83 seca 750
81 cb750c
Back to top
View user's profile
TIMEtoRIDE
XJ Wizard
PostPosted: Tue Mar 09, 2010 9:20 am    Post subject: Re: Pre carb-cleaning checklist Reply with quote
I have found some carb cleaners stronger than others, but Brake Parts cleaner seems to have more "kick" than carb cleaner, and is slightly cheaper- - go figure !!
Le Skid - - have you checked your valve clearances yet??
That needs to be done before all your fine- tuning.
Setting the floats IS a messy, gas wasting experience.
Don't do it indoors next to a pilot light !! Go outside and freeze Shocked
_________________
2006 FJR 1300
Back to top
xyxj650
Red Liner
PostPosted: Tue Mar 09, 2010 9:37 am    Post subject: Re: Pre carb-cleaning checklist Reply with quote
I use RickoMatics method to set float heights. When the carbs are off the bike use windshield washer fluid and a clear hose. Then you don't smell like gas when you are done. Just be sure after you are done you clean it out really good ,make sure you pull the needle seats and clean the fuel rail out good also.
BTW I like using Gumout carb cleaner or the blue cans from walmart. I actually think the blue cans work better cause it burns alot more than gumout when you get it in your eyes or on your skin. Shocked
_________________
80 xj650 project keep finding things to fix! It will be new by the time I am done!
parting out 81 xj650
82 xj750 New project. Wifes bike!
Back to top
TIMEtoRIDE
XJ Wizard
PostPosted: Tue Mar 09, 2010 1:53 pm    Post subject: Re: Pre carb-cleaning checklist Reply with quote
xyxj650 wrote:
I use RickoMatics method to set float heights. When the carbs are off the bike use windshield washer fluid and a clear hose. Then you don't smell like gas when you are done. . .
I thought we weren't doing that anymore due to incorrect density ??
The floats are set in a "window" of less than 3 MM
Your floats would be set too high- - causing flooding and richness.
_________________
2006 FJR 1300
Back to top
ManBot13
Red Liner
PostPosted: Tue Mar 09, 2010 1:58 pm    Post subject: Re: Pre carb-cleaning checklist Reply with quote
Not only incorrect density with windshield washer fluid, but I think it crystalizes if you don't clean it all out (probably dependnig what's actually in the mixute). Use (or buy) a small engine gas tank with a valve, and you shouldn't make too much of a mess.
_________________
1982 XJ 750RJ Seca 28,400 miles and counting...Aftermarket 4-2 exhaust with perforated/packed baffles. Needs paint and front end work to be finished!
1981 Suzuki GN400 - Next Project
1982 XJ750LJ Turbo Seca - HARD Project
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
Quick painting question!
Last post by Ravenz07 in General Lounge on Sep 10, 2010 at 20:58:40
XJ Experts, Am I rich or lean
Last post by kornele in XJ Chat on Sep 10, 2010 at 20:57:00
Hello from Nebraska
Last post by Lou627 in General Lounge on Sep 10, 2010 at 20:55:24
CL find Metro Detroit low miles Seca 750 dammit
Last post by bigfitz52 in Sell, Trade, Swap, Wanted on Sep 10, 2010 at 20:51:41
rice-o-rama
Last post by markie in General Lounge on Sep 10, 2010 at 20:47:37
Starts in neutral dies in gear
Last post by kornele in XJ Chat on Sep 10, 2010 at 20:45:17
Charging system
Last post by markie in XJ Chat on Sep 10, 2010 at 20:42:10
Ignition Coil 2+ 3 Difficulties
Last post by Untaim1 in XJ Modifications on Sep 10, 2010 at 20:27:57
1981 Yamaha XJ 750 Seca Needs a new home Southern MO
Last post by bigfitz52 in Sell, Trade, Swap, Wanted on Sep 10, 2010 at 20:27:05
Lower fairing
Last post by Jay~Dub in XJ Chat on Sep 10, 2010 at 20:25:35
