 Latest: JimIndyV8
 New Today: 5
 New Yesterday: 6
 Overall: 8082
 Members: 10
 Visitors: 14
 Total: 24
Who Is Where: Members:01: 82maximXJ650Bobber > Forums
02: andrewlong > Forums
03: deadohiosky > Forums
04: dltaylor > Forums
05: Jay~Dub > Photo Gallery
06: jeishen > My Private Messages
07: kornele > Forums
08: mdee > Forums
09: Trumpetrhapsody > Forums
10: Untaim1 > Forums
04: Home
14: Calendar
We have received 35522947page views since August 9, 2005
Forums › XJBikes Talk › XJ Chat › Not firing on 2 & 4. But I think I might know what it is
Not firing on 2 & 4. But I think I might know what it isTechnical discussion ONLY for XJ Maxim/Seca...
marshallnoise 3rd gear
Posted: Sat May 22, 2010 11:44 pm Post subject: Not firing on 2 & 4. But I think I might know what it is |
So I got the carb assembly back into the bike and everything cleaned up REALLY well there. Bike fired up but is running on only two cylinders.
1 and 3 are running just fine and 2 and 4 are ice cold.
Plugs have been pulled and cleaned and all the wiring seems just fine.
I have not done any of the ignition tests so far, but I think I might have figured it out since studying people's trouble shooting right here.
On my bike there are two coils; one mounted on the left and one on the right. Cylinder 1 & 3 routed to the left one and 2 & 4 routed to the right.
If that his hooked up correctly, then only half of the each coil is firing properly.
My question is: Which combination is the proper combination for each coil? Does the left coil have 1 & 3 or is it supposed to be 1 & 4? Same for the other side?
_________________ 1983 XJ750 Seca - Work in Progress
1997 4Runner Limited - Locked in the rear with a mild lift
Igitur qui desiderat pacem, praeparet bellum. |
chacal XJ Wizard
Joined: Aug 01, 2006 Posts: 4232 Location: At My Computer
Posted: Sun May 23, 2010 12:07 am Post subject: Re: Not firing on 2 & 4. But I think I might know what it is |
The coil for the #1/4 spark plugs is mounted on the left side of the bike, and has the solid orange (ground) wire and the red-with-white-tracer-stripe (hot) wire input leading to it.
The coil for the #2/3 spark plugs is mounted on the right side of the bike, and has the solid grey (ground) wire and the red-with-white-tracer-stripe (hot) wire input leading to it.
_________________ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
xjbikes.com/Forums/vie.../f=23.html |
snowwy66 Red Liner
Joined: May 07, 2010 Posts: 449 Location: Salt Lake City, Utah
Posted: Sun May 23, 2010 4:29 am Post subject: Re: Not firing on 2 & 4. But I think I might know what it is |
pull the drain screws out and see if any fuel comes out. my guess would be no fuel or not enough fuel to run those two cylinders.
someone on here posted a pic of what the coils look like on the inside as i was wondering if my coils were bad at one point and time. the coil itself wouldnt' be bad and i don't thik it's possible to have only one connection inside the coil working. specially since 1 works on one coil with 4 and 2 works off the other coil with 3.
check your fuel level to make sure it's 3mm from the base of the carbs. with perfectly level carbs.
the plugs might not be firing inside the cylinders either.
if the engine is perfect. you'll have around 140 lbs compression inside the cylinders. spark plugs have a MUCH harder time firing under compression then they do standing out in plain air. compression plays a role in that resistance factor. just because plugs work outside don't mean they are working inside.
yamaman Red Liner
Joined: Jan 11, 2009 Posts: 644 Location: Staten Island, NY
Posted: Sun May 23, 2010 4:41 am Post subject: Re: Not firing on 2 & 4. But I think I might know what it is |
The correct answser is what chacal said, she should run perfect after u move the wires
_________________ 82 XJ 650RJ non-YICS SECA, 22K, daily rider
72 RD350 2 stroke - mint but rebuilding motor
07 CRF150R - weekend rider |
Posted: Sun May 23, 2010 7:12 am Post subject: Re: Not firing on 2 & 4. But I think I might know what it is |
Sweet! After church I will give it a shot.
I know it is not a fuel problem because when I spray engine start in it, only those two cylinders fire. This was before I cleaned up the carbs. I am almost positive I have fuel to all four.
