XJBikes.com XJ4Ever
Toggle Content
Toggle Content Advertisement
Toggle Content Donate
Donate with PayPal!
Toggle Content Main Menu
Toggle Content User Info
Nickname
Password
Latest: Gator
New Today: 7
New Yesterday: 9
Overall: 8070
Members: 7
Visitors: 27
Total: 34
Who Is Where:
 Members:
01: Gator > Forums
02: inkdrops76 > Jokes
03: Militant_Buddhist > Forums
04: mosee.biker > Forums
05: nealsxj > Home
06: tensor8686 > Forums
07: ZaGhost > Forums
 Visitors:
01: Forums
04: Jokes
07: Calendar
08: Calendar
11: Home
16: Calendar
19: Forums
20: Forums
21: My Account
22: Forums
23: Forums
24: Forums
25: Forums
26: Forums
27: My Account
Staff Online:
No staff members are online!
Toggle Content Google Search
Toggle Content Total Hits
We have received
35449185
page views since
August 9, 2005
Forums › XJBikes Talk › XJ Chat › Clutch Adjustment & Clutch Cable Replacement Procedure
Go to page Previous  1, 2, 3  Next
Author Message
OnTheStorm
2nd gear
2nd gear
PostPosted: Thu Jul 22, 2010 7:11 pm    Post subject: Re: Clutch Adjustment & Clutch Cable Replacement Procedure Reply with quote
I removed the cover to replace clean out oil level window (Which is still foggy) Now I cannot get the cable back into the throw arm (this is the right jargon correct?) I oiled it up (with motor oil) pushed and pulled but nothing. It won't budge. It was a pain just getting the cover back on, it finally jived with the rod on the inside, but not it wont budge. Where to go from here?
On the oil level window note. I have 2.6 quarts in, just as recommended, and I was watching the window as i put in the final .6 quarts. I still have not seen a bubble, or any indication that it is filling up. Any suggestions to fix this problem?
[img][/img]
p.s. This might be a nice picture if someone wants to label it for the tech section. Since i am going through this and will probably have to take the cover off a again I will be happy to take picts of the innards and email them to a member wanting to diagram it.
_________________
1981 XJ550 Maxim--project bike, reviving from horrible PO
Coming home from very lonely places, all of us go a little mad: whether from great personal success, or just an all-night drive, we are the sole survivors of a world no one else has ever seen.
- John le Carre
Back to top
View user's profile
RickCoMatic
Moderator
PostPosted: Thu Jul 22, 2010 7:38 pm    Post subject: Re: Clutch Adjustment & Clutch Cable Replacement Procedure Reply with quote
Can you move the Shaft that goes down inside the Case?
Whenn you replace the Cover,... you need to capture the "Push-rod" (Which is really a "Pull" Rod") and ease the Cover on while turning the Shaft ... to take-out the slack while the Cover is buttoned-up.
Then, when you get ready to attach the Cable ...
You have to Rotate the Shaft Clockwise. Hold it.
Set the Throwout Arm upon the Splines.
Fasten it.
Lever the Throwout Arm clockwise to affix the Cable end.
Make the final adjustment.
If anything that's supposed to move, ... isn't moving.
Start from Square One.
_________________
Rick Massey
MODERATOR & Tech Writer
Use LOCATION Feature.
Back to top
yamaman
Red Liner
PostPosted: Thu Jul 22, 2010 8:01 pm    Post subject: Re: Clutch Adjustment & Clutch Cable Replacement Procedure Reply with quote
great Rick. In my collection of bikes I've joined other forums and almost non of them are as good as this one. The members' dedication is what makes it and yes folks, you know it, this is the text book example.
so remember my thread 2 weeks ago about my clutch being hard to pull, approximately 60lbs pressure!? I found the problem today.
it was the cable, a Brand New Cable, but it was the cable. the cable had no resistance At All when disconnected so when it gets connected and the resistance comes back it leads someone to look eslewhere. But today, with a bud, we routed the cable the most simplest way possible without the tank on and gave it a tug and it was better. I couldn't beleive it. so I put my finger on it and pushed it agains the frame as if the tank was on and Bam it was tight. WD40 fixed it but I'm still going to buy a high quality new one immediately. So now the cable is coming down the right side of the bike, UNDER the tank, not on the inside tunnel of it. Good luck everyone Smile
_________________
82 XJ 650RJ non-YICS SECA, 22K, daily rider
72 RD350 2 stroke - mint but rebuilding motor
07 CRF150R - weekend rider
Back to top
RickCoMatic
Moderator
PostPosted: Thu Jul 22, 2010 8:10 pm    Post subject: Re: Clutch Adjustment & Clutch Cable Replacement Procedure Reply with quote
You'd have been better-off using 3-In-1 Oil or a Capfull of the Oil you buy for the Bike.
WD-40 is closer to a Cleaner than it is a Lubricant.
_________________
Rick Massey
Back to top
loggerbomb
1st gear
1st gear
PostPosted: Thu Jul 22, 2010 8:20 pm    Post subject: Re: Clutch Adjustment & Clutch Cable Replacement Procedure Reply with quote
Hey guys, I need some clarification on this. Finally got the stripped bolts of the clutch casing(?) and was able to get the cable back onto its perch, but it looks nothing like the drawing. Is there a difference with this on the 400s than the bigger bikes?
Ok, that pic does make it official, there is a difference on mine.
Can someone quickly tell me how to adjust the clutch play on my set up or point me in the right direction?
_________________
'83 Yamaha XS Maxim 400
Soon to come - '85 Kawasaki 750 LTD
Back to top
View user's profile
yamaman
Red Liner
PostPosted: Thu Jul 22, 2010 8:29 pm    Post subject: Re: Clutch Adjustment & Clutch Cable Replacement Procedure Reply with quote
Agreed, and I actually said I wanted to use Motor Oil Laughing but how the hell do I get it in there?! I used a Cable Luber Tool that accepted the straw of the aresol can
_________________
Back to top
RickCoMatic
Moderator
PostPosted: Thu Jul 22, 2010 8:48 pm    Post subject: Re: Clutch Adjustment & Clutch Cable Replacement Procedure Reply with quote
You undo the Cable from the Lever.
Elevate as high as possible.
Pass Cable end through neck of small funnel.
Duct Tape the Funnel Nect to the Cable ... Oil tight.
Keep the Cable and Funnel elevated.
Fill the Funnel with enough Oil to submerge the Cable end.
Let Gravity go to work.
As the Oil seeps into the Cable it find its way to the other end.
Where you need to put paper towels.
A bunch.
Until you drain the Funnel and stop the flow.
It can get messy but its very effective.
_________________
Rick Massey
Back to top
OnTheStorm
2nd gear
2nd gear
PostPosted: Thu Jul 22, 2010 10:03 pm    Post subject: Re: Clutch Adjustment & Clutch Cable Replacement Procedure Reply with quote
Started from square . Still couldn't move the lever...by hand. Reread this thread and saw something about my hand not having the mechanical advantage. I knew the rods were locked in right because i heard them click in, I could also move the throw out arm when I replaced the cover with the arm 180 degrees opposite of where it should be.
I Used a pair of vice grips to spin the throw out arm and got the cable back in its nook. Clutch feels more or less the way it used to, just a smidge tighter. Will do fine tuning in the morning.
_________________
- John le Carre
Back to top
View user's profile
todd
1st gear
1st gear
PostPosted: Thu Jul 22, 2010 10:11 pm    Post subject: Re: Clutch Adjustment & Clutch Cable Replacement Procedure Reply with quote
Don't forget you can remove the c-clip from the clutch attachment and move it over a couple of splines until the tention is close enough to adjust from the clutch handle.
Back to top
andrewlong
2nd gear
2nd gear
PostPosted: Fri Jul 23, 2010 12:26 am    Post subject: Re: Clutch Adjustment & Clutch Cable Replacement Procedure Reply with quote
And I was thinking to myself today 'man do I need to adjust my clutch!'...lo and behold here is this discussion. Thanks Rick!
I had to basically let out the handle all the way before the clutch would catch, now it works just like it should.
_________________
1992 xj600 Seca II - 20k
Back to top
bigfitz52
XJ Wizard
PostPosted: Fri Jul 23, 2010 5:02 am    Post subject: Re: Clutch Adjustment & Clutch Cable Replacement Procedure Reply with quote
If the bike is on the sidestand you won't see any oil.
Put it on the centerstand (or hold it vertical for 5 minutes if you don't have a centerstand) then check.
_________________
'81 XJ550RH Seca- Recommissioned original classic daily rider; 26K miles- stock except bars, seat, shocks and SS brake lines.
'83 XJ550RK Seca- "Toxic Asset"; 10K miles- restored, modernized and personalized (nearly stock)
Wish I hadn't sold my SR500
Back to top
RickCoMatic
Moderator
PostPosted: Sat Jul 24, 2010 9:52 pm    Post subject: Re: Clutch Adjustment & Clutch Cable Replacement Procedure Reply with quote
If ... :
You clunk shifting from Neutral into first.
Have the Bike "Pulling" on you when the Lever is pulled, ... the famous "Red Light Creep".
Have to fight with the Bike to get it into Neutral.
Can't get into Neutral to move the Bike.
Take 45-Minutes and do a Complete Clutch adjustment.
You will be happy you did.
_________________
Rick Massey
Back to top
streetbrawler750
6th gear
6th gear
PostPosted: Wed Aug 04, 2010 7:44 pm    Post subject: Re: Clutch Adjustment & Clutch Cable Replacement Procedure Reply with quote
Perhaps an obvious question, but if the clutch is adjusted properly but starts slipping around 6500+, is it time for a new clutch?
_________________
1982 Maxim 750 Bone Stock
1982 Maxim 750 Cut up www.xjbikes.com/Forums...23003.html
Back to top
RickCoMatic
Moderator
PostPosted: Thu Aug 05, 2010 5:06 pm    Post subject: Re: Clutch Adjustment & Clutch Cable Replacement Procedure Reply with quote
When you know the Clutch ISN'T Tight. And, it starts slipping "Under Load" ... You have probably used-up all the fun that that Clutch had to deliver.
Don't let it slip.
Don't "Burn-up" the Steel Driven Plates.
You might be able to replace just the FRICTION Plates.
But, if you Scorch or Blue-burn the DRIVERS you can't leave them in there. You'll have a Clutch that GRABS or doesn't take-up smoothly because the DRIVERS are Burned, Warped or worse.
Be honest with the job.
Replace any blued DRIVEN Plates when you replace all the FRICTION Plates and all the Fun and Performance will return.
_________________
Rick Massey
Back to top
superluckycat
1st gear
1st gear
PostPosted: Fri Aug 06, 2010 11:24 am    Post subject: Re: Clutch Adjustment & Clutch Cable Replacement Procedure Reply with quote
New clutch cable and adjust per Rick's guide done this past weekend. Can't believe I didn't do it sooner. Easy as pie.
_________________
1985 Maxim XJ700 14K
Back to top
View user's profile
Display posts from previous:
Page 2 of 3
Jump to:
Here's some good news for some of us...
Last post by ZaGhost in General Lounge on Sep 08, 2010 at 23:48:33
Over revved now all gears are "neutral"
Last post by Militant_Buddhist in XJ Chat on Sep 08, 2010 at 23:47:19
high idle
Last post by WinstonC in XJ Chat on Sep 08, 2010 at 23:44:04
another XJ resurrected
Last post by ZaGhost in General Lounge on Sep 08, 2010 at 23:41:48
On this date in 1974
Last post by ZaGhost in General Lounge on Sep 08, 2010 at 23:39:31
WANTED 700 Maxim Exhaust Mufflers
Last post by MANA in Sell, Trade, Swap, Wanted on Sep 08, 2010 at 23:34:51
running real bad after rain
Last post by Militant_Buddhist in XJ Chat on Sep 08, 2010 at 23:33:21
Need selling advice on a complete 85 Maxim X
Last post by Gator in Sell, Trade, Swap, Wanted on Sep 08, 2010 at 23:33:18
Michigan Xj people...... who is up for a cruise?
Last post by dfknoll in Eastern US and Canada on Sep 08, 2010 at 23:30:24
Minimal wiring troubles XJ650
Last post by vulcan750 in XJ Chat on Sep 08, 2010 at 22:58:56
