XJBikes.com XJ4Ever
Toggle Content
Toggle Content Advertisement
Toggle Content Donate
Donate with PayPal!
Toggle Content Main Menu
Toggle Content User Info
Nickname
Password
Latest: Docwits
New Today: 0
New Yesterday: 0
Overall: 13244
Members: 8
Visitors: 75
Total: 83
Who Is Where:
 Members:
01: broberg > Forums
02: chacal > My Private Messages
03: Hamster > Forums
04: jmilliken > Forums
05: KDub > Forums
06: MercuryMan > Home
07: openeagle13 > Forums
08: tcoop > Forums
 Visitors:
01: Forums
04: My Account
13: Home
19: Forums
20: Forums
21: Forums
22: Forums
23: My Account
24: Forums
25: Forums
26: Forums
27: Forums
28: My Account
29: Forums
30: Forums
31: Forums
32: Forums
33: Forums
34: Forums
35: Forums
36: Forums
37: Forums
38: Forums
39: My Account
40: Forums
41: Forums
42: Forums
43: Forums
44: Forums
45: Forums
46: Forums
47: Forums
48: Forums
49: Forums
50: Forums
51: Forums
52: Forums
53: Forums
54: Home
55: Forums
56: Forums
57: Forums
58: Forums
59: Forums
60: Forums
61: Forums
62: Forums
63: Forums
64: Forums
65: Forums
66: Forums
67: Forums
68: Forums
69: Forums
70: Forums
71: Forums
72: Forums
73: Forums
74: Forums
75: Forums
Staff Online:
No staff members are online!
Toggle Content Google Search
Toggle Content Total Hits
We have received
97162003
page views since
August 9, 2005
Forums › XJBikes Talk › XJ Chat › turn signal bad, usually
Author Message
burtmonro
1st gear
1st gear
PostPosted: Mon May 14, 2007 5:42 pm    Post subject: turn signal bad, usually Reply with quote
1982 XJ1100. Start the bike and the turn signals work, though the right blinks slower. When riding, the turn signals work only as long as I hold the switch in position. As soon as I release it, they shut off. A real pain while trying to turn, work the clutch, and hold the turn signal so it stays on. The right signals are slower. Possible solutions: bad switch, bad flasher, lose wire, dirty connections. Anything else I could check?
Back to top
View user's profile
samsr
Red Liner
PostPosted: Mon May 14, 2007 10:41 pm    Post subject: Re: turn signal bad, usually Reply with quote
since you are having to hold the switch. I would say it is time for a teardown of the switch and a good cleaning. Electronic cleaner works well here. Just dont for get the dielectric grease when you are done. Take it off and take it appart. I usually do this over a nice white rag, just in case something falls out. Take it appart slowly. So you know how it goes back together. Good luck,ride safe.
_________________
1982 XJ750J maxim Sold (sniff, sniff)
1985 xj700
stock, but very polished, 9500 miles on the ticker
Dark blue pearl in color
National Cycle wind screen
operating 6000 feet in elevation, next to gods country. Rocky Mountains
Back to top
RickCoMatic
Moderator
PostPosted: Mon May 14, 2007 11:26 pm    Post subject: Re: turn signal bad, usually Reply with quote
Alternator bushes.
You're losing the battle to keep your electric demands satisfied.
Pop the cover.
Measure the brushes.
You need 11mm -- Minimum on that bike.
_________________
Rick Massey
MODERATOR & Tech Writer
Use LOCATION Feature.
Back to top
burtmonro
1st gear
1st gear
PostPosted: Tue May 15, 2007 5:21 am    Post subject: Re: turn signal bad, usually Reply with quote
The bike only has 14,000 miles on it. Would the brushes go bad this soon? Would there be other evidence of the brushes being worn?
Back to top
View user's profile
KiwiXJ750D
Red Liner
PostPosted: Tue May 15, 2007 6:41 am    Post subject: Re: turn signal bad, usually Reply with quote
Maybe, it is a case of undoing 3 bolts and having a look at the brushes and the condition of the surfaces they run on to make sure. Might as well to discount the brushes as a cause.
They can cause other problems, battery not charging, bike not starting, dim lights, etc.
Does your bike have self cancelling turn signals? The unit might be faulty.
Check for corrosion on contacts and plugs. Check or (better) replace the fuse box, even if it is ok eventually they give problems.
_________________
1984 XJ750D EFI Model 22N 134,000 Km Police bike cams n head
Back to top
samsr
Red Liner
PostPosted: Tue May 15, 2007 6:56 am    Post subject: Re: turn signal bad, usually Reply with quote
Here is a good pic of the alt brushes and contact plate. If you look closely on the bruches you can see the wear line on them. Even if it not the brushes. It is definately good peice of mind to know. I am still betting the switch has junk in it that needs cleaned out, since you have to hold the switch.Brushes pic
_________________
1985 xj700
Back to top
burtmonro
1st gear
1st gear
PostPosted: Tue May 15, 2007 7:10 am    Post subject: Re: turn signal bad, usually Reply with quote
[quote="KiwiXJ750D)
Check for corrosion on contacts and plugs. Check or (better) replace the fuse box, even if it is ok eventually they give problems.[/quote]
I haven't noticed any other electrical problems. The self cancelling turn signal unit worked when I first got the bike, about two weeks ago, but it didn't last long. I wouldn't bother fixing that, but if it's somehow related to the other turn signal problem, then I will.
Back to top
View user's profile
KiwiXJ750D
Red Liner
PostPosted: Wed May 16, 2007 2:07 am    Post subject: Re: turn signal bad, usually Reply with quote
It could be related. Did the other problems start after the self cancelling unit stopped working?
You should be able to bypass the unit.
_________________
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
Can you say "hideous"?
Last post by jmilliken in General Lounge on May 20, 2013 at 16:55:06
Does Chacal have a bike?
Last post by jmilliken in General Lounge on May 20, 2013 at 16:53:05
Need to replace the mufflers
Last post by Tony66 in XJ Chat on May 20, 2013 at 16:24:12
How much is a CB 350 4 cyl worth
Last post by BruceB in Other Motorcycles on May 20, 2013 at 16:22:48
worth it?550 xj needs some work
Last post by 550fella in XJ Chat on May 20, 2013 at 16:18:08
XJ 750 clocks
Last post by robbiemcvee in Sell, Trade, Swap, Wanted on May 20, 2013 at 16:14:47
dumb question on Tach Glass
Last post by bigfitz52 in General Lounge on May 20, 2013 at 16:05:59
Seca 650 turbo
Last post by jmilliken in XJ Chat on May 20, 2013 at 15:59:47
Odd brake issue
Last post by jmilliken in XJ Chat on May 20, 2013 at 15:55:02
Anyone need a 750 tank + random bits?
Last post by jmilliken in General Lounge on May 20, 2013 at 15:41:39
