XJBikes.com XJ4Ever
Toggle Content
Toggle Content Advertisement
Toggle Content Donate
Donate with PayPal!
Toggle Content Main Menu
Toggle Content User Info
Nickname
Password
Latest: kyblaze33
New Today: 0
New Yesterday: 9
Overall: 13330
Members: 0
Visitors: 23
Total: 23
Who Is Where:
 Visitors:
01: Forums
06: Archives
09: Home
12: My Account
16: Home
18: Home
19: Forums
20: Forums
21: Members List
22: Forums
23: Forums
Staff Online:
No staff members are online!
Toggle Content Google Search
Toggle Content Total Hits
We have received
97387729
page views since
August 9, 2005
Forums › XJBikes Talk › XJ Chat › bike is acting very strange (JET HELP)
Go to page 1, 2, 3  Next
Author Message
Bobbybonez
6th gear
6th gear
PostPosted: Sun May 20, 2012 8:28 am    Post subject: bike is acting very strange (JET HELP) Reply with quote
I was trying color tune but the bike kept acting really weird. At first it ran OK but would slowly stall with out choke. When i took it for a little ride to warm it up it ran great although i had to take off with choke on then i could shut it off. Then when i came back the engine would ra e up to about 3000 - 5000 rpm with choke on and stall with it off. I reset the mixture screws a few times to make sure that wasnt the problem and turned the idol way down the brought it back up to get the bike to a point where it would run. Later it was racing with our with out choke. Im gonna try getti g a better sync today and if that doesnt work, pull the carbs again and check to make sure the butterflys arnt sticking. Anywhere else i should look?
_________________
1981 XJ650 Midnight Maxim. Mostly put together but not quite done.
1982 XJ650 Maxim - selling
1981 XJ550 Maxim
1971 CB350K3
1978 Honda XL175 - sold
1969??? Honda PC50 moped - selling
Photobucket - s1236.photobucket.com/...onez/index
Back to top
View user's profile Send e-mail Visit poster's website
mlew
XJ Wizard
PostPosted: Sun May 20, 2012 9:27 am    Post subject: Re: bike is acting very strange Reply with quote
Classic sign of vacuum leak. Get a can of starter fluid and spray around the throttle shaft seals when it is running, if the idle speed goes up then you have found it. If the carbs are way out of sync that can also cause your problems.
_________________
83 Venture Royale
86 V-Max
82' XJ1100
80' XS1100
79 'XS1100
Past Rides
82 XJ750(My first)
75 CB 550
87 750 Vulcan
86 250 Rebel(my wife's first)
Back to top
View user's profile Send e-mail Photo Gallery
Bobbybonez
6th gear
6th gear
PostPosted: Sun May 20, 2012 9:34 am    Post subject: Re: bike is acting very strange Reply with quote
I tried testing with a propane torch didn't get any out of the "ordinary". Got the carbs off right now. Going to go through them make sure nothing is plugged and really bench sync.
_________________
1981 XJ550 Maxim
1971 CB350K3
Back to top
bigfitz52
XJ Wizard
PostPosted: Sun May 20, 2012 10:44 am    Post subject: Re: bike is acting very strange Reply with quote
Be sure to "wet-verify" the float levels; that could also be part of your problem.
_________________
Technical Writer & Advisor
Back to top
Bobbybonez
6th gear
6th gear
PostPosted: Sun May 20, 2012 12:27 pm    Post subject: Re: bike is acting very strange Reply with quote
I did set the floats steady but will double check when I take the carbs off the bike.... again. Using starter fluid I found a very small vacuum leak. Will have to change boots and throttle shaft seals.
_________________
1981 XJ550 Maxim
1971 CB350K3
Back to top
Bobbybonez
6th gear
6th gear
PostPosted: Sun May 20, 2012 8:03 pm    Post subject: Re: bike is acting very strange (JET HELP) Reply with quote
I was reading another memebers post and some one said something about stock jet size. This made me wonder if mine were stock or not. I looked it up and found that I should have a 110 main fuel jet and a 40 pilot fuel jet. For the air jets it should be 50 main and 195 pilot. What I have in mine is 107 for main fuel and 45 for pilot and 55 for main air and 195 for the pilot. The only one that is right is the pilot air and the rest seem out of wack to me from what I read on what they should be at. This could be a big part of problems.
These bikes are tuned low to meet emission standards right? When I order new jets, should I maybe order a size up? Or should I just go with stock?
Im 1257 feet above sea level if that matters at all too.
_________________
1981 XJ550 Maxim
1971 CB350K3
Back to top
Kwiski
3rd gear
3rd gear
PostPosted: Sun May 20, 2012 10:19 pm    Post subject: Re: bike is acting very strange (JET HELP) Reply with quote
Go back to original settings. Once I cleaned, bench synced, and all the other fun stuff according to the book. I also had larger jets. Went back to stock, I ride from the 3500 ft level down to the 1500 ft level. Mine runs 42 MPG. I have it stock except a jardine 4 into 1, I only run my pilots at 2 3/4 to 3 turns out. I have been fighting this carb set-up for months. Good Luck . Be patient and most of all go back to stock settings and start there.
_________________
82 XJ 650 Maxim (installed 900 motor). 85 Miles ridden a day.
Back to top
RickCoMatic
Moderator
PostPosted: Mon May 21, 2012 4:07 am    Post subject: Re: bike is acting very strange (JET HELP) Reply with quote
Check ALL your AIR Jets:
Air Jets are OPPOSITE from Fuel Jets.
Main = Smaller [o]
Pilot = Larger [O]
This Illustration is 750 Maxim:
When you make any adjustments:
Seal the Manifolds to the Head.
Bench Sync with the Throttles as CLOSED as Possible:
3X5 Card Strip, Business Card Strip, Resume' Paper Strip or Thin Strips of 35mm Film Negative.
Attend to any possible Manifold Leaks
Fill with Black Epoxy • Coat with several applications of Liquid Elect Tape • Shine with Black Nail Polish.
Vacuum Nipples seated & Air Tight
_________________
Rick Massey
MODERATOR & Tech Writer
Use LOCATION Feature.
Back to top
Bobbybonez
6th gear
6th gear
PostPosted: Mon May 21, 2012 12:03 pm    Post subject: Re: bike is acting very strange (JET HELP) Reply with quote
Cool thanks guys. Back to stock it is then. Im hoping changing the jets will solve most of my problems. gotta get that vac leak fixed too though.
_________________
1981 XJ550 Maxim
1971 CB350K3
Back to top
Bobbybonez
6th gear
6th gear
PostPosted: Tue Jun 05, 2012 12:23 pm    Post subject: Re: bike is acting very strange (JET HELP) Reply with quote
Got the jets changed, throttle shaft seals replaced, carb boots repaired and it starts. Now it is only running on two cylinders (1 and 2). Before I pull the carbs to clean them.... AGAIN. Could this be caused by the sync being off? With the number 3 carb being the main one that you sync everything to, I figure that would be one that is running.
_________________
1981 XJ550 Maxim
1971 CB350K3
Back to top
Bobbybonez
6th gear
6th gear
PostPosted: Tue Jun 05, 2012 3:47 pm    Post subject: Re: bike is acting very strange (JET HELP) Reply with quote
anyone?
_________________
1981 XJ550 Maxim
1971 CB350K3
Back to top
dmccoach
Red Liner
PostPosted: Tue Jun 05, 2012 4:05 pm    Post subject: Re: bike is acting very strange (JET HELP) Reply with quote
Did 2 & 4 fire prior to carb cleaning? Are they sparking? Well -- What does color tune tell you is going on in there (2 & 4?????? )
? OT from your question, but someone will ask if you've done valve gaps
Stock jets should be #110 main and #40 pilot for the 650
Generally cold cylindres would be an electrical issue -- even way out of synch carbs should allow the bike toi run although poorly...
Unless you are providing NO fuel
So, use the color tune to see if 2 and 4 are sparking?
_________________
1981 XJ650 Maxim
xjbikes.com/Forums/vie...35179.html
Back to top
View user's profile
Bobbybonez
6th gear
6th gear
PostPosted: Tue Jun 05, 2012 4:09 pm    Post subject: Re: bike is acting very strange (JET HELP) Reply with quote
It was running on all four before I changed the jets back to stock. Put them all back together and on the bike and its not wanting to start and only running on 1 and 2 when it does start. I did check for spark too and it is sparking. Yes I did my valves and the floats and cleaned the carbs multiple times and rebuilt them. Im stummped.
_________________
1981 XJ550 Maxim
1971 CB350K3
Back to top
dmccoach
Red Liner
PostPosted: Tue Jun 05, 2012 4:14 pm    Post subject: Re: bike is acting very strange (JET HELP) Reply with quote
Check float levels -- WITH THE CLEAR TUBE METHOD WHILE ON THE BIKE -- got fuel in those bowls? So, it's a fuel issue somewhere? -- go slowly, think carefully, and it sounds like you need to validate fuel level. But, regardless you'll have to pull em and double check all...
Maybe not - it may be weak spark, but I agree seems unlikely however, there is a way to test the strength of the "spark" -- got a manual?
_________________
1981 XJ650 Maxim
Back to top
View user's profile
Bobbybonez
6th gear
6th gear
PostPosted: Tue Jun 05, 2012 4:16 pm    Post subject: Re: bike is acting very strange (JET HELP) Reply with quote
I have the haynes manual. and the XJ CD. I opened up the drain screw on all four and there is gas in them. I really hope its not the floats. I had a hell of a time setting them the first time.
_________________
1981 XJ550 Maxim
1971 CB350K3
Back to top
Display posts from previous:
Page 1 of 3
Jump to:
seca 550 won't crank
Last post by jeremiah84 in XJ Chat on May 24, 2013 at 09:36:19
New commutator
Last post by adrian1 in XJ Chat on May 24, 2013 at 09:32:26
Time for this guy to sell the bike... :D
Last post by MercuryMan in General Lounge on May 24, 2013 at 08:30:35
Yamaha YICS Timing Cover Mod
Last post by RobbieRobot in XJ Modifications on May 24, 2013 at 08:24:28
broken engine!! :(
Last post by MercuryMan in XJ Chat on May 24, 2013 at 08:11:43
1977 BMW R75/7
Last post by Kickaha in Other Motorcycles on May 24, 2013 at 08:00:09
Ethanol treatments to reduce adverse effects
Last post by MercuryMan in General Lounge on May 24, 2013 at 07:54:16
Kawasaki Vulcan 2009 500 ltd- Thoughts?
Last post by Metal_Bob in Other Motorcycles on May 24, 2013 at 07:33:17
Repainting, Tank Emblem Question
Last post by boldstar in General Lounge on May 24, 2013 at 07:16:48
Can you say "hideous"?
Last post by LVSteve2011 in General Lounge on May 24, 2013 at 06:49:17
