XJBikes.com XJ4Ever
Toggle Content
Toggle Content Advertisement
Toggle Content Donate
Donate with PayPal!
Toggle Content Main Menu
Toggle Content User Info
Nickname
Password
Latest: Docwits
New Today: 0
New Yesterday: 0
Overall: 13244
Members: 3
Visitors: 33
Total: 36
Who Is Where:
 Members:
01: broberg > Forums
02: Polock > Forums
03: sektorgaz > Forums
 Visitors:
01: Forums
04: My Account
07: Photo Gallery
10: My Account
19: Forums
20: Forums
21: Forums
22: Forums
23: Home
24: Forums
25: Forums
26: Forums
27: Forums
28: Forums
29: Forums
30: Forums
31: Forums
32: Forums
33: Forums
Staff Online:
No staff members are online!
Toggle Content Google Search
Toggle Content Total Hits
We have received
97064210
page views since
August 9, 2005
Forums › XJBikes Talk › XJ Chat › Carb pilot screw question - sort of
Author Message
junkmn
4th gear
4th gear
PostPosted: Thu Jun 14, 2012 9:24 pm    Post subject: Carb pilot screw question - sort of Reply with quote
I have been tinkering with this bike (82 650 Maxim) for awhile. Float heights have been the bane of my existence. However broke down and bought the gauge from Len. All floats are 3 to 3.5 mm at the meniscus. Pilot screws at 2.5 turns out. Bike started right up ran smoother than ever.
Then I discovered what appeared to be a dead cylinder on #4. How did I know? No color with ColorTune on cylinder #4. Checked coils, and spark all are good. It turns out that cylinder 4 doesn't want to run until I get to 6.5 turns out on the pilot screw.
I am a tard when it comes to carbs. What should I be looking for?
By the way all carbs were broken from rack. Taken apart and ultrasonically cleaned. All new seals, float needle valve assembly, pilot washer and O ring. Polished throats to insure clunk test. New butterfly screws. Diaphragms are good, no pin holes. Checked all passages with guitar strings and blew through with compressed air. Carbs are synched with CarbTune
What
_________________
1982 Maxim 650 (two of 'em)
1983 Maxim 650
1982 Suzuki GS650
1983 Venture
2004 VStar 1100 Classic
2000 VStar 1100 Custom
Back to top
View user's profile
Polock
XJ Wizard
PostPosted: Thu Jun 14, 2012 9:46 pm    Post subject: Re: Carb pilot screw question - sort of Reply with quote
did you try a running sync?
_________________
Stay thirsty my friends
Back to top
junkmn
4th gear
4th gear
PostPosted: Thu Jun 14, 2012 9:49 pm    Post subject: Re: Carb pilot screw question - sort of Reply with quote
yep. Its all synched and colortuned. Just the #4 pilot screw is at 6.5 turns out. That can't be right.
_________________
1983 Maxim 650
1982 Suzuki GS650
1983 Venture
Back to top
View user's profile
chacal
Supporting Vendor
PostPosted: Thu Jun 14, 2012 9:51 pm    Post subject: Re: Carb pilot screw question - sort of Reply with quote
Try using a bit of choke and see if cylinder #4 comes alive............if so, then the pilot circuit for that carb is still plugged.
In our experience ultrasound is not a very good way of cleaning the tiny internal passages within these carbs....they are, of course, tiny, and they make a lot of bends, too. It has to be a mighty powerful ultrasonic cleaner to produce any results in there. Carb dip and pressure (i.e. air compressor and//or carb or brake aerosol cleaner pressure) is about the only way to insure that the pilot circuit internal passages are truly cleared of all blockage (i.e. fuel varnish, which can turn hard as a rock).
_________________
Back to top
junkmn
4th gear
4th gear
PostPosted: Thu Jun 14, 2012 9:57 pm    Post subject: Re: Carb pilot screw question - sort of Reply with quote
EDIT ::
Choke just kills the engine
I'll give it a whirl! Thanks for the suggestion.
I'm getting real good at pulling em off and puttin em on. 15 minutes both ways heheheheh
_________________
1983 Maxim 650
1982 Suzuki GS650
1983 Venture
Back to top
View user's profile
adrian1
XJ Wizard
PostPosted: Fri Jun 15, 2012 3:46 am    Post subject: Re: Carb pilot screw question - sort of Reply with quote
Re check float level on no. 4 pot
_________________
1987 XJ 900
Back to top
View user's profile
junkmn
4th gear
4th gear
PostPosted: Tue Jun 19, 2012 10:09 pm    Post subject: Re: Carb pilot screw question - sort of Reply with quote
Rechecked float height off the bike, its dead on. Put back on the bike and checked it again against all the others. All were within 1 mm of each other.
While off the bike I cleaned all passages on the carb with guitar wire and carc cleaner. All passages allow a steady stream of cleaner through them. #4 still wont run until its 6.5 turns out.
Also put a different float in just in case.
_________________
1983 Maxim 650
1982 Suzuki GS650
1983 Venture
Back to top
View user's profile
wwj750
Red Liner
PostPosted: Tue Jun 19, 2012 10:16 pm    Post subject: Re: Carb pilot screw question - sort of Reply with quote
Are the valves in spec?
_________________
XJ 750 Seca-Daily driver
Back to top
View user's profile Send e-mail Photo Gallery
junkmn
4th gear
4th gear
PostPosted: Tue Jun 19, 2012 10:24 pm    Post subject: Re: Carb pilot screw question - sort of Reply with quote
valves are all in spec
_________________
1983 Maxim 650
1982 Suzuki GS650
1983 Venture
Back to top
View user's profile
MiGhost
XJ Wizard
Location: Lower 48 in general. Otherwise Central Mitten.
PostPosted: Tue Jun 19, 2012 11:16 pm    Post subject: Re: Carb pilot screw question - sort of Reply with quote
It sounds like possibly a leak around the intake boot, or gasket causing the #4 cylinder to run extremely lean. If there are any cracks in the intake boots. Coat them with RTV sealer, and apply a bead of sealer around the boot where it meets the head.
Ghost
_________________
Doesn't matter if it don't run. That I can fix! It Better STOP!!
BigFitz's Delamination Post
Wire Wheels and a 150 Rear - Virago 700 style!!
Present Rides:
83 XJ750MK Midnight Maxim, current ride, Running Restoration project, Full Dress Tour Deluxe w/ X-1 Fairing
80 CB650C - Currently in mockup. Old School Bagger Project (OEM Hard Bags, Wixom Fairing, Jardine turnouts)
83 XJ750K Maxim 22R-3637 9/82 - Resuscitation Project, Old School Style Chopper. (Up 4, Out 2, 45* rake, 10" over forks, Virago Wires & Front end, 900/750 engine)
83 XJ900RK Seca, #....1194, Long term affair, Euro spec restoration project
82 XJ750J Resuscitation, Bagger Project (OEM Sport Fairing, Bates Bags, Round Gauges/lights)
Back to top
View user's profile
junkmn
4th gear
4th gear
PostPosted: Tue Jun 19, 2012 11:34 pm    Post subject: Re: Carb pilot screw question - sort of Reply with quote
Ghost
I'll look into it but I had glued all the cracks then gave the boots 4 coats of Spray Liquid Electrical Tape.
Looks like I am going to pull my carbs off my other Maxim and give them a whirl. I might have a spare carb boot around here.
The problem bike is a parts bike I used for various parts to finish mine but am putting it back together for my brother. He cant afford a bike so getting this going will be a big surprise for him.
_________________
1983 Maxim 650
1982 Suzuki GS650
1983 Venture
Back to top
View user's profile
pauldale999
3rd gear
3rd gear
PostPosted: Fri Jun 29, 2012 5:12 pm    Post subject: Re: Carb pilot screw question - sort of Reply with quote
Did you take the pilot mixture screw, spring, washer and o-ring out, and clean thoroughly, check for wear, clean the shaft, squirt carb cleaner down the hole, on the #4 carb?
Did you put them back in the right order: i.e. o-ring, washer, spring, screw, in that order?
Only asking this because it is very easy to reassemble wrongly.....
If not, it could be the reason(s) why you are having to turn it out 6 and a half times (a wonder it hasnt popped out!?) to get it rich enough to fire....?
_________________
MY BIKE: XJ650 RJ SECA 1982, 29,000+ MILES (NON-YICS)
USA MODEL, IMPORTED TO UK. LATE 80s/EARLY 90s (?)
9 previous owners.
No record of USA owners
Back to top
pauldale999
3rd gear
3rd gear
PostPosted: Fri Jun 29, 2012 5:19 pm    Post subject: Re: Carb pilot screw question - sort of Reply with quote
_________________
9 previous owners.
Back to top
RickCoMatic
Moderator
PostPosted: Fri Jun 29, 2012 7:27 pm    Post subject: Re: Carb pilot screw question - sort of Reply with quote
Assure Pilot FUEL Jet is Correct SIZE and Clean.
Pull the Pilot Screw.
Remove ALL the Parts.
1. Screw
2. Spring
3. Micro-flat
4. O-ring.
Shine a Light down into the Hole.
You should see the SHINY HOLE that's open to the Intake Neck.
Probe the Hole with a LONG DARNING NEEDLE.
See if there is any debris or ---> A Flattened-out O-ring down in there.
Heat the Tip of a Darning Needle or a LARGE Safety Pin.
Hook the End with Needle-nosed Pliers.
Go fishing.
Extract anything in the Hole not part of the Pilot Screw Assy.
::: There might be an O-ring squished flat. There might be a Fragment of an O-ring loose and stuck in the Passage or Inlet Orifice. :::
• Insure you have CORRECTLY --> "Sized" --and-- "Placed" Pilot AIR Jet. < !!
• FLUSH Pilot Air~Fuel Passage.
> JET
> JET passage -to- AIR Jet
(Use Bubble Syringe filled with a load of Carb Cleaner sprayed into a Container to collect Carb Cleaner for use in Syringe)
Block Mix Screw Hole and Intake Neck Micro-orifice.
• FLUSH AIR Jet -to- MIX SCREW Hole
Block FUEL Jet.
Test Passages.
Use Bubble Syringe.
Stuff mini fuel line in Pilot Fuel Jet Orifice. Other end in container of Carb Cleaner. Evacuate Bubble Syringe. Insert Syringe into AIR Jet. Block Mix Hole and Intake Neck Orifice. Draw cleaner from Hose into Bubble.
BUBBLE SYRINGE -->> a.k.a. "'Lil Baby Booger-sucker"
_________________
Rick Massey
MODERATOR & Tech Writer
Use LOCATION Feature.
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
Can you say "hideous"?
Last post by Polock in General Lounge on May 19, 2013 at 06:15:20
YICS eliminator tool question
Last post by Polock in XJ Modifications on May 19, 2013 at 06:07:19
Now I've gone and done it - carbs in surgery
Last post by Polock in XJ Chat on May 19, 2013 at 05:50:22
Valve cover gasket
Last post by Tat2demon in XJ Chat on May 19, 2013 at 05:49:29
For Sale: 1985 XJ700X Deep Scarlet gas tank
Last post by tumbleweed_biff in Sell, Trade, Swap, Wanted on May 19, 2013 at 05:44:33
Looking for colletor 85 750 maximx
Last post by tumbleweed_biff in Sell, Trade, Swap, Wanted on May 19, 2013 at 05:43:43
deer hits
Last post by ElkHavenSeca in General Lounge on May 19, 2013 at 05:40:22
xj700n part out
Last post by tumbleweed_biff in Sell, Trade, Swap, Wanted on May 19, 2013 at 05:33:35
Parting out 85 maxim 700
Last post by tumbleweed_biff in Sell, Trade, Swap, Wanted on May 19, 2013 at 05:31:26
Decent looking XJ550 - $800
Last post by tumbleweed_biff in Sell, Trade, Swap, Wanted on May 19, 2013 at 05:28:42
