 Latest: Docwits
 New Today: 0
 New Yesterday: 0
 Overall: 13244
 Members: 2
 Visitors: 28
 Total: 30
Who Is Where: Members:02: XJOE550 > Forums
02: Home
06: Home
07: Home
15: My Account
16: Home
17: Home
19: Forums
20: Forums
21: Forums
22: Forums
23: Home
24: Forums
25: Home
26: Forums
27: Forums
28: Forums
Hidden: 1
We have received 97027349page views since August 9, 2005
Forums › XJBikes Talk › XJ Chat › What is a 3.50 front tire.
What is a 3.50 front tire.Technical discussion ONLY for XJ Maxim/Seca...
Ass.Fault XJ Wizard
Joined: Aug 09, 2007 Posts: 1037 Location: College Station, Texas
Posted: Wed Apr 02, 2008 1:08 pm Post subject: What is a 3.50 front tire. |
I currently have a 3.50 H 19 Metzler Laser Front skin.
I NEED some new skins....
I know the 19 is wheel diameter, the H is the speed rating, but what is 3.50? Inches?
Accually my REAL question is "What is the conversion to metric?"
3.50 is tough to find w/ the tires I like
Thanks from me and the beauty
_________________ '82 Yamaha XJ750RJ SECA
Done:Carbs cleaned, fusebox replaced, Jardine slip-on mufflers, Uni air filter, Oil cooler added, new intake boots and bolts, fork seals done, fenders removed and plates relocated, ignition switch hardwired, handlebars from an XB-9, LED rear turn signals, electronic flasher relay.
Arm extended. Hand down low. Thats how I say hello!
Click On
www.xjbikes.com/dfmaps.html
See Where Other XJBikes Members Live Around your State |
woot Moderator
Joined: Jan 05, 2006 Posts: 1251 Location: 44.777479/-63.676489
Posted: Wed Apr 02, 2008 1:13 pm Post subject: Re: What is a 3.50 front tire. |
110-90-19 IIRC was the front tire size of the 650 maxim...
I think the rear rim was 3.5 inches wide, and the front was 2.5 inches wide. That's the rim width, not the tire width.
Again - I can't really remember to be sure.
_________________ Halifax, Nova Scotia, Canada
2000 CBR 600
1981 XJ650 Maxim (SOLD)
1995 ZX600r Ninja (SOLD) |
dlanthripe 2nd gear
Joined: Mar 07, 2008 Posts: 54 Location: OKC,Oklahoma
Posted: Wed Apr 02, 2008 1:19 pm Post subject: Re: What is a 3.50 front tire. |
Mr. Fault,
I just bought a rear tire about an hour ago. My rim says 3.00 x 16. The tire on it before the change was 130/80 r16. Now it is a 130/90 r16, as recomended to me. I GOOGLED " motorcycle tire conversion " and found alot of information on it. But none of it worked out to what my rim says to the tire that was put on it. Maybe I am reading the information wrong.
_________________ 1981 650 Maxim - W.I.P.
3rd Owner as of March '08 |
Ass.Fault XJ Wizard
Posted: Wed Apr 02, 2008 1:30 pm Post subject: Re: What is a 3.50 front tire. |
A bit off-topic, but do you ever head out to the Davis Mountains dlanthripe?
Turner Falls or any other parks?
That tire is what is on there now, and wondering what other sizes could replace that...simmilar sizes of course.
The Metzler LaserTec is the only one I have found that has 3.50's
Any suggestions?
PS If the 650 Maxim and 750 Seca are the same then woot, You Da Man!
Click On
MiCarl XJ Wizard
Joined: Jul 27, 2006 Posts: 4016 Location: Livonia, MI (Metro Detroit)
EdinaDad 3rd gear
Posted: Sun May 11, 2008 6:04 am Post subject: Re: What is a 3.50 front tire. |
For the 1983 XJ750 M Midnight Maxim, the tires are:
Front: 3.25-19
Rear: 130/90 -16 67H
I got this info from going to bikebandit.com and looking at the oem parts descriptions.
The 3.25-19 is not all that easy to find anymore, so the metric equivalent is 100/90 -19 (also sometimes shown as 1MM/90 -19.
The first # is the section width (in milimeters)
The second # refers to the height of the sidewall, or the Aspect Ratio.
The third is the wheel diameter in inches.
The fourth # is the load index or how much weight a tire can support in pounds.
The last item is the speed rating.
If there is an "R" prior to the diameter, that would mean that the tire is a Radial.
So, using my rear tire as an example:
The Section Width of the tire is: 130.
The Aspect Ration is: 90 (the tire is almost as tall as wide)
The Wheel Diameter is: 16
The Load Index is: 67 ( or 677 lbs)
and the Speed Rating is: H ( up to 130 mph)
You can get a lot of info here:
www.discounttire.com/d...dewall.dos
Now all I need to do is figure out how to install the darn things.
_________________ 1983 Yamaha XJ750 Midnight Maxim
New for me on 5/2/2008
1983 Honda CB650sc Nighthawk
Work in progress for flipping
Old Bikes:
1984 Honda Nighthawk CB750sc |
argh1961 2nd gear
Joined: Oct 13, 2007 Posts: 74 Location: St. Albert, Alberta, Canada
Posted: Sun May 11, 2008 9:14 am Post subject: Re: What is a 3.50 front tire. |
I had similar questions last week when I was getting new tires for my Maxim. I found a couple of fitment guides that were very helpful in determining the size I wanted. The guides show the OE size as well as some suggestions for replacements.
www.motorcycleproshop....itment.asp
This might help you come to a decision.
Cheers!
_________________ '81 550 Maxim
"If you take something apart and put it back together often enough, you will eventually have two of them" - Anon. |
