For Sale '82 Yamaha Maxim XJ750J
Discussion in 'For Sale, Trade/Swap, Wanted' started by fiveofakind, Aug 21, 2017.
  1. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    Original owner bike, I have had this bike for 35+ yrs.
    Gas tank cleaned & lined - Johnson's Gas Tank Liner - professionally by radiator shop.
    Gas tank professionally painted by motorcycle shop
    Carbs fully cleaned, rebuilt, & sync'd - new throttle shaft seals, new fuel o-rings, idle mixture washers & o-rings. New vac caps.
    New fuel & vacuum lines. Petcock rebuilt.
    New throttle, clutch & speedometer cable.
    New EBC clutch friction discs.
    New Progressive front springs, oil & dust seals, & new fork oil. New air joint cushions.
    New tires - front & rear - Shinko
    New clutch.
    New AGM maint. free battery - June 2017
    All wiring connections dremeled & cleaned. All original wiring - everything working.
    Tapered bearings - Upper & Lower
    New brake pads & brake shoes
    New caliper piston & seals
    New stainless steel brake lines with new brake fluid flush.
    Seat is flawless.
    This bike is all dialed in & running great.
    One pic says it all......$2.500 or OBO
  2. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Are you sure? Like, sure sure?
    You will miss her...
    I only had my Seca for a couple of years, never even rode it, definitely wasn't the only owner, and I still miss her. Did I mention that the new owner put on pods?
    Playing the devil's advocate, good luck with the sale.
  3. fiveofakind
    San Diego, CA
    I am seeing what interest there is, if any at my price point.....
    I will keep my Maxim if I don't get what I want for it......my Xj is pretty much restored.......
    Is it in mint, like new, or excellent condition....no...but it is in very good condition.....so will see if it sparks interest in anyone.....
    That test drive on the Honda VT1800F snapped my neck back.......pure muscle......awesome bike......
  4. MattiThundrrr
    1800 cc... The fastest car I built was 1800 cc! Can't imagine how hard it would pull with 2500 less pounds!
  5. hogfiddles
    Yeh, Five's is a Nice bike. I've watched it and seen it here for a long time. Dutiful, beautiful, and his price is worth it.
    Dave
  6. fiveofakind
    San Diego, CA
    Dave,
    Thank you for your thoughts.
    Just wanted to mention that this bike was first purchased in Colorado in '82 and then transferred to California in '85.....
    Always garaged most of the 35 yrs......so this bike is not weather beaten......in other words.....no corosion going on.
  7. schmuckaholic
    California
    Seeing as how the Honda engine is 2.4x larger than that of the Maxim, I would think so. :) My cars have smaller engines.
  8. Madmax-im
    Madmax-im Member
    Wendell NC aka Southern Comfort
    Is this still forsale? Mileage? 2nd gear fix?
  9. Madmax-im
    Madmax-im Member
    HELLO..ANYONE HOME???
