How did you get here?
Discussion in 'Hangout Lounge' started by SnoSheriff, Jun 1, 2006.
  1. CactusJack578
    CactusJack578 Member
    Akron, Ohio
    Hi Andrew I love Scramblers. Don't know why I don't own any. I'm looking forward to your XJ750 scrambler pics.
  2. Attom
    Attom New Member
    Middle Tennessee
    Got an 82 750 Maxim last year. Was rough, but under $300. Every time I google search for a part or repair it has brought me here.
    It was spray painted red just about everywhere, had bald rotten tires, dented tank, no working signals, no tank gauge, no speedo, rats nest of a fuse block, and the kid thought the starter was out.
    So far I have:
    Removed the rattle can red from the rims, driveshaft, rotors, drum, tank, and shocks.
    Replaced the tires
    Painted the tank (like Bobba Fett's helmet, since the square lights made me think of Star Wars)
    I replaced the wheel speed sensor, but the new (used) one failed in less than a mile.
    Replaced the broken front signals with LEDs.
    Currently trying to get the flashers to work... new relay does nothing.
    Next up is rewiring the fuse block and taking another crack at the speedo.
    Areas that I could use some advice:
    Do I need a specific flasher relay? I got a three prong with the same pattern that is rated for LED or incandescent, but it does nothing, the old relay lights up but doesn't flash.
    Where can I find a battery cover?
    Best place to find a nice simple fuse block?
    Photo of bike still red doesn't show how bad it was. I failed to take before pics; this is the pic from the Facebook listing.
    Previously had an xs400 maxim, brother has a xj400 seca
    CactusJack578 likes this.
  3. XJ550H
    you need to use the oem relay it is 3 prong for a different reason what kind of bulbs are you using need to be 27 watt unplug the canceller unit se if bulbs flash clean bulb sockets
  4. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    He changed to led signals so he likely needs to unplug self cancel unit as suggested. I am unfamiliar with the 3 prong flasher units but I believe one of those needs to be grounded for some reason or another I think I've read that on here before.
  5. XJ550H
    this flasher from superbrightleds.com
    Flasher is LF1-S-FLAT
  6. CactusJack578
    Akron, Ohio
    Here's another guy, Attom who buys a POS and turns it into a great ride. Cool paint. Different. I have a confession.. I had to look up Bobba Fett. That makes the paint job AND the square headlight even cooler.
  7. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Whaaaaaaaat?!
    Stumplifter likes this.
  8. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    I found it through Google looking for parts, super glad I found you guys, I was ready to rebuild my motor needlessly!
  9. AndrewD
    AndrewD New Member
    Melbourne
    I am taking the thing apart right now and about to rebuild. I will post pics when I am done!
  10. Brian Jones
    Brian Jones New Member
    Tennessee
    Bought a 1981 Xj650 out of a barn for 450$, googled around for parts and found this forum :)
  11. lupz
    lupz New Member
    I simply purchased a XJ, typed in XJ forum into good old google and here I am.
  12. Steve Jorgensen
    Steve Jorgensen New Member
    Vancouver, WA
    This site comes up a lot whenever I search for Yamaha 'how to' as well as general XJ info.
  13. Curtis Weekes
    Curtis Weekes New Member
    Canada
    I bought an 82 XJ650 Seca and began looking for info via google and this was one of the top sites. So much amazing information here and obviously a great community of XJ owners.
  14. raskal
    raskal Active Member
    Abbotsford B.C. Canada
    I arrived like others, via google
    Just bought a '82 XJ750 Maxim. Will keep it stock to take advantage of B.C.'s ICBC collector plate program. Cheap insurance on anything 25 years or older. Without collector plates I'd be paying over $1000/year
    MattiThundrrr likes this.
  15. Ross B.
    Ross B. New Member
    Texas, U.S.A.
    Signing in from Corpus Christi, Texas. I just purchased a 1983 XJ750K Maxim(as my research leads me to believe at least) for a whopping $350. It has the YICS emblems on the engine side plates, and if I do say so myself, it is in pretty decent condition.
    I intend on keeping it stock, with only a handlebar set and mirror updates possibly. I will clean her up, put a windshield and saddle bags like Sarah's so that this will be my wife's ride. I found that the only "tech data" I could find was a Haynes, so I delayed that and found y'all. I had to disassemble the carbs and perform a thorough cleaning, needless to say, I mixed and matched the jets the first 4 times I disassembled and assembled until I came across some of the great posts on this site. Last night I installed all the jets in their appropriate locations and man does she purr. A lot of work ahead of me, but I know it will be a great bike.
  16. spacetiger110
    spacetiger110 Member
    Pennsylvania
    I recently got an XJ900RK and a gentleman who was giving me advice on Reddit told me about this forum.
  17. dowski68
    dowski68 Well-Known Member
    Medford, Oregon
    This is the place for all your tech needs. Glad to see another member
    Ross B. likes this.
  18. Ryengoth
    Ryengoth Active Member
    Wilmington, NC
    Trying to find information on replacement VIN tags. Rebirthing a 1982 XJ550. Frame is almost torn down completely so I'll need a replacement sticker soon.
  19. 650MAX
    650MAX Member
    Denton Tx
    Familiar story for me I suppose. I had been thinking about getting a bike for a couple years off and on. I think it was last year I actually went to the local cycle center and sat on a couple new bikes. I kind of liked the Rebel 500 but it was more than I wanted to spend and I sure as heck wasn't about to finance a toy. Finally this Spring I took the MSF class and started watching Craigslist for a bike. My criteria were that it had to be under $1500 (preferably under $1000), had to be running, have a clear title and be capable of cruising my smiling face down the highway at 75 mph. Being a total noob to riding, I didn't want some ill-handling cobbled up junk, so I didn't look at the choppers. Also since I wanted to sit more or less upright and not have to be chewing on the handlebars, I didn't bother looking at sportbikes either. And being 55 years old, I didn't feel like the ninja or whatever really fit my mental image of what my bike ought to look like. Oh, and being mechanically inclined having worked on hotrods for several years, including daily driving a '65 Galaxie for a 5 year stretch I wasn't worried about age. I wasn't expecting to just get on and ride carefree at my budget.
    Queue up a Craigslist scammer or two and what appeared to be a decent deal on a bike that was a bit farther away than I had hoped to look, I end up making the trip. 1.5 hours or so drive, which might not seem all that bad, but this is all the way on the opposite side of Fort Worth from me. You'd think that I could find something in Dallas or Fort Worth, but no! Anyway, I get out to the place and they guy shows me the bike, fires it up and tells me all about it and the guys who have come to see it and made lowball offers etc. I end up getting the thing for $800, which might be a little high but probably not too terrible. I still check out bikes on Craigslist and have seen maybe one or two bikes that I would call a similarly good deal but nothing yet that really jumps out to me as being "better". As part of my shopping process I searched out whatever info I could on any bike that looked somewhat interesting, and xjbikes seemed like a great resource with plenty of long time happy owners. So you guys actually played a part in my purchase!
    I have bought a bit more than expected to get the bike in line, but it's looking like I'll be into it for around $1400 or so? Still seems like a great deal considering it looks good, runs good, has new tires and brakes, new horn,
    lights and electrical stuff is working properly, has new shocks on the back and by the end of next week will have the fork seals done too. Hopefully this weekend I'll be able to polish the engine side covers and clean up the wheels and do some general detailing to make it really look decent.
    Here she is, in orange as purchased and now after I've painted it.
    ksigurdsen and JetmechMarty like this.
  20. JBurch
    JBurch Active Member
    Owego, NY
    I got here with the help of Dave Fox. A friend of mine met him at a local car show, flea market this past week end. Steve got Dave's contact information , sent it to me, I called Dave , he sent me here.
    I have a 1982 650 Seca, needs some love, thanks in advance for your help.
    Jim Burch
    XJ550H likes this.
