AIRHEAD VALVE ADJUSTMENT with Pics
Discussion in 'XJ DIY How-To Instructions' started by bigfitz52, Jan 6, 2009.
Thread Status:
Not open for further replies.
  1. Craig B
    Craig B Active Member
    Ontario, Canada
    Well thats mature.
    I have owned the bike since 1987.
    What I have stated is FACT.
    Live with it.
  2. Craig B
    Ontario, Canada
    Well thats mature.
    Live with it.
  3. k-moe
    That fact is highly unusual. Not impossible, but highly unusual.
    hogfiddles likes this.
  4. Craig B
    Ontario, Canada
    Maybe unusual but fact none the less.
    Previous question was concerning how long an engine would go.
    My response was to answer his question.
    Perhaps the its the "school of dont fix whats not broken" or the dilegent use of synthetic motor oil.
    Whichever the case those are the specs I measured this afternoon.
  5. Paul Howells
    Paul Howells Active Member
    Victoria, BC
    I read that the synthetic oil will slip the wet clutch. What kind of oil have you been using? You could get a sponsorship with that kind of testimony.
  6. hogfiddles
    Oh boy--- here we go.... Time to make big bowl of popcorn.
    Ian Vanore and Rooster53 like this.
  7. k-moe
    I think the conversation needs it's own thread.
  8. Craig B
    Ontario, Canada
    If anyone cares for more information.
    Feel free to send me a PM.
  9. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    I'd say at least 300,000km!
  10. Carson
    Carson Member
    colorado
    I followed the directions on this thread and everything WAS fine. No leaks for a couple weeks. Now my new valve cover gasket is leaking from the semi circle cam shaft parts on the right side of the engine (brake side). I got the gasket off eBay so I'm hoping it's a bad gasket? Does it make sense that it would work for a bit and then start randomly leaking?
  11. Jasonh
    Jasonh '81 XJ750 Seca
    Toronto, Ontario
    I'm running semi-synthetic. My $.02 is engine is quieter and smoother than with non synthetic and changes gears better. I do notice a little more slip on the clutch when starting, but makes for a smoother start. My clutch plates are in last 1/4 of life so I'm not aggressive off the line. I was told not to use full synthetic unless you've got a tight, rebuilt engine and fairly fresh clutch.
  12. k-moe
    Please note the title of the thread before posting. This is not an oil discussion.
    Stumplifter likes this.
  13. k-moe
    You may have missed the comments about using a thin smear of RTV on the half-moon seals
  14. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    The RTV smear as Kmoe suggested. Also - I do not use a torque wrench on my valve cover (gasp! :eek:). Mine is an 81 XJ650 Maxim - no donuts - so I just snug those screws down to that 'just right' 3rd and 4th finger torque setting. I also torque in a symmetrical fashion from the center to the outside corners. If a seep is recognized I will 're-torque' a series of screws towards the seep area.
    Be cautious as over torqueing will strip the threads in the aluminum head. Even properly torque settings can stripped compromised threads . . . been there done that - hate it! (fortunately have not done it on my XJ).
  15. k-moe
    The bolts have a shoulder that rests on the head. Over-tightening can do more than strip threads; it can crack the head. Fortunately the torque spec just happens to be finger tight.
  16. Wintersdark
    Wintersdark Well-Known Member
    Calgary, Alberta, Canada
    My Maxim's got a stripped valve cover bolt hole, front left bolt. Noticed it was a bit higher than the rest, and sure enough... It comes right out and the holes stripped. I just so happen to have a spare head, but I'd rather not replace the whole head as that seems like a terribly large amount of work... There a good way to fix that? I've never had to deal with that before. It's not leaking as it is, so it's a little lower on the priority list, but it's obviously going to have to be dealt with.
  17. Craig B
    Ontario, Canada
    Helicoil.
    Wintersdark likes this.
  18. Baxter
    Baxter New Member
    Nebraska
    A very old but, very good post.
    Does anyone have these pictures saved? I am doing mine now but the pictures really do tell a thousand words.
    Plug likes this.
  19. Dstrong77
    Dstrong77 Member
    Iowa
    On most of the pics in this forum I am seeing a Photobucket 3rd party image instead of the actual photos. Anyone else?
  20. XJ550H
    photo bucket now requires payment to post photo links on comercial sites
Thread Status:
