Atari delete
Discussion in 'XJ Modifications' started by Scottie1, Jan 25, 2018.
  1. Scottie1
    Scottie1 Active Member
    Columbia SC
    Well after reading through the forum about Atari delete I dove head first into it. I must say it was very easy to do following the instructions posted. I managed to fit a aftermarket acewell digital Speedo and tach. Everything is working wonderful and I have everyone who posted about the Atari delete and also fitting led turn signals. You guys here are fantastic I couldn’t of done it with your help.
    Jeremy Washburn likes this.
  2. Scottie1
    Columbia SC
    Typo there it should of said I have everyone who posted about the delete and led turn signals to thank
  3. Chops
    Chops New Member
    Newstead
    I just commenced the same task this morning, deleting the Atari, getting rid of the rectangular headlamp and fitting LED indicators. Great to know all the info I need in on here.
    Have you got a link to the thread I need or can I just search Atari delete?
  4. Scottie1
    Columbia SC
    Just search for Atari delete it will come up with excellent directions and a diagram of what wires to cut and join
    Jeremy Washburn and Chops like this.
  5. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Did you switch the headlight as well? Any pictures from other angles?
  6. Scottie1
    Columbia SC
    i have a cb650 housing and 7 inch round headlight coming next week. i shall get pictures when its all done
  7. XJ550H
    wifflebat, Scottie1 and Chops like this.
  8. Scottie1
    Columbia SC
    Update with new 7 inch headlight and housing . Now just need to relocate ignition and put Speedo in the center
  9. Pattiwack
    Pattiwack New Member
    Orange county
    did you get the gas gauge working on the new speedo? i couldn't get mine to work.
  10. Scottie1
    Columbia SC
    Yeah just connected the lead from sender unit and it worked like a charm
  11. Scottie1
    Columbia SC
    Did you have the same Speedo?
  12. Pattiwack
    Orange county
    I have the Danmoto SP-00002. Same look as the Acewell. Im going to have to give it another go at the wiring then.
  13. Scottie1
    Columbia SC
    It’s just one lead that needs to be connected from the positive side
  14. Pattiwack
    Orange county
  15. Scottie1
    Columbia SC
    Also I did see something about OHMs for the fuel sensor on my one. It could be the same as yours I don’t fully understand it and I left my setting as it was on the Speedo. I think it was 100 ohms.
  16. Pattiwack
    Orange county
    Ok thanks for letting me know
  17. Jeremy Washburn
    Jeremy Washburn New Member
    Kansas City
    Wow that looks good. Where did you find all the lights and speedo? I would like to change mine. IMG_1517546238365.jpg
  18. Jeremy Washburn
    Kansas City
    Hey I just got some led turn signals did you have to do anything special when you installed them in order for them to work or did you have to change the flasher or anything like that?
  19. Polock
    here's where my ignition switch wound up, tricky to get in there but the holes that were there lined up perfect. no the key never fell out
  20. Scottie1
    Columbia SC
    i got a 1979 Honda CB650 headlight bucket and a 7 inch round headlight with extended fork arms to bolt it to
