Lost spark
Discussion in 'XJ Technical Chat' started by Carey, Aug 9, 2017.
  1. Carey
    Carey New Member
    Portland, Ore
    1986 XJ700; has been chopped, been rewired by someone else, had it running great after carb rebuild for an afternoon but then lost all spark. Ign coils; 12v, pickups 118ohms, checked my grounds, I'm getting about 4 - 5 v from igniters during ign turnover. Could it be my igniters?
    k-moe Pie, Bacon, Burbon. Moderator Premium Member
    The Great American Desert
    What condition is the battery in?
    Reply back with the battery voltage at rest, and what the voltage drops to when you thumb the starter.
    Stumplifter likes this.
  3. Carey
    Carey New Member
    Portland, Ore
    New Lithium 12v 18amp 270cca;
    13.08 v rest 11.86v when thumb start.
  4. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    I don't think the battery will power the starter with less than 12 volts. That may be the problem.
  5. XJ550H
    9.8 -10 volts is the no start point
  6. Carey
    Carey New Member
    Portland, Ore
    Ok.... the igniters have already been swapped out once & I had spark until the bike was ridden for a cpl hrs (around the block, what not). It was running great & then died, the battery was @ 10.97v when lost spark, recharged battery to full 13.47v, still no spark. I thought it was a bad ground but can't narrow it down. Now thinking it may be the igniters again???
  7. XJ550H
    you need to repete voltage drop test first.
    attach meter to battery take reading
    press starter button what does the battery voltage drop to?
  8. XJ550H
    which xj700 do you have ? aircooled or watercooled
    also time to ohm out full ignition system.
    ignition coils primary and secondary
    pick up coils
    spark plug caps
    spark plugs.
    could be as simple as triming 1/4 inch off the end of the spark plug wires.
  9. Carey
    Carey New Member
    Portland, Ore
    My XJ700 is aircooled, I'll do a repeat of the voltage drop & double check the ohms. I did trim a litte off the plug wires alrdy but again cant hurt to repeat that. Thanks so much
  10. XJ550H
    on tci there is a black/white wire find the connector (not plug) and disconnect it. it grounds out tci killing spark
    specs
    XJ700 air-cooled models
    Pick-up coils:
    120 ohms +/- 20% = 96 ohms to 144 ohms acceptable range
    Ignition Coils:
    Primary side (input from main wiring harness):
    2.7 ohms +/- 10% = 2.43 ohms - 2.97 ohms acceptable range
    Secondary side (spark plug wires, without their end caps):
    12K ohms +/- 20% = 9,600 ohms - 14,400 ohms acceptable range
    Spark plug caps:
    1986 S/SC models: 10K +/- 20% = 8,000 to 12,000 ohms per cap acceptable range
    Spark plugs
    1986 S/SC models: 5K ohms per plug
  11. Carey
    Carey New Member
    Portland, Ore
    Hey guys, thanks for the all the help & XJ550H, you were right, in the process of re checking my ohm readings, I clipped my wires a bit & replaced my caps. Got spark now, sometimes you overlook the simple things...Thanks again..
  12. Carey
    Carey New Member
    Portland, Ore
    I spoke to soon, had spark after clipping wires & changing out caps then no spark. Re checked ohms; ign/pickup coils, caps, all good. Have 12.8 v to ign coils from switch. Wtf????
  13. Carey
    Carey New Member
    Portland, Ore
    XJ550h, in reference to your previous reply, re: disconnecting black/white off tci... can I simply cut that wire coming off the connector ?
  14. XJ550H
    if you push a sewing needle in to the connector from the front on the side of the contact with the tab that locks it into the connector body the contact will just slide out of the connector body. better than cutting the wire
