Oil API ratings
Discussion in 'XJ Technical Chat' started by tabaka45, Nov 16, 2017.
  1. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    my xj700 calls for “SE” oil. I generally thought that motorcycle oil rated SE or higher would be fine, but now I’m not so sure. I stopped by Walmart to get some oil, synthetic is what I use, and found Valvoline rated SF, SG, SJ, JASO MA2; Mobil 1 rated API, SH, JASO MA/MA2; and Castrol Actevo part synthetic rated SL, JASO MA2. I just read an article on the web that said not to use “SL”. What say you?
  2. Door dude
    Door dude Active Member Premium Member
    Mountain Home Arkansas
    Everything iv'e read is that synthetic oil does not play well with the wet clutch system. I don't know for sure iv'e never used it.
  3. Toomanybikes
    Tsawwassen bc
    Se, sh, etc and sl ever few years they change that so sl is the most current rating.
    The important part is JASO ma/ma2
    For wet clutch motorcycle engines.
  4. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    I've been having a difficult time finding JASO ratings on oil, even on motorcycle specific Castrol oil. I wonder if it's not a Canadian thing...
  5. Craig B
    Craig B Active Member
    Ontario, Canada
  6. Polock
  7. Toomanybikes
    Tsawwassen bc
    Torco oil has JASO rating but it's not cheap
  8. MattiThundrrr
    I can find the stuff, but most have no JASO ratings on the bottle. Makes me second guess myself at the store. Never seen the Torco around here.
    Hmm. Amsoil Metric is sold in a quart bottle. Irony or ignorance?
  9. Craig B
    Ontario, Canada
    Or in a 4L Jug. Or a Pail or a Drum.
    Whats your point?
    I find the one quart (litre) containers quite handy considering the bikes only require approximately 3 quarts/litres.
  10. MattiThundrrr
    My point is that quart isn't metric. That bottle is 946ml. 1 litre would be metric. I was attempting comedy. I am aware that the product is marketed towards metric bikes. I pretend stupid sometimes, but I ain't dmub.
    Stumplifter likes this.
  11. Craig B
    Ontario, Canada
    Ahhhh gotcha.
    That one went right over my head. lol
  12. kosel
    MInneapolis, MN
    It seems a lot of oils intended for diesel use meets JASO MA/MA2 requirements. Out of curiosity...Why?
  13. tabaka45
    Brunswick, Georgia
    As I understand it diesel oil has no "energy saving" friction modifiers and is heavier on the zinc than normal oil. Both apparently good for motorcycle engines and wet clutches.
  14. MattiThundrrr
    The Rotella oil by shell is a diesel oil that is quite popular with bikes on this and other forms. High quality and low priced. Available in quart and/or litre bottle.;)
  15. tabaka45
    Brunswick, Georgia
    I used Amsoil last time and have had absolutely no problems. For that reason I will probably use a synthetic oil again since the change intervals can be doubled. However, if I used non-synthetic, I think it would be Rotella. But, I have come to the conclusion that if it is JASO MA/MA2 rated it's ok to use, synthetic or non-synthetic.
  16. Polock
    all sorts of ratings and prices for our bike oil but the reason i use mobil is it has a nifty pop up spout on the bottle. :)
    doesn't really matter on the bike because i'm being kind of careful but the mower and lawn tractor not so much
  17. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Amsoil is twice the price or more of Rotella. So, even if the oil change interval is doubled, it works out to about the same, or more.
    I've had very good luck with Rotella over the last 3 years. I can buy it on sale at local farm stores or discount stores by the gallon at certain times of the year.
    My mid season oil change only takes 15 minutes since I only change the filter every other oil change.
