Turn signal mod question - XJ550 Seca
Discussion in 'XJ DIY How-To Instructions' started by Michael R, Apr 13, 2018.
  1. Michael R
    Michael R Member
    Seattle
    I’m installing aftermarket, smaller turn indicators on an ‘82 Seca with a fairing. I’m having a hard time figuring out a front extension option so I’m thinking about eliminating them. Problem is, the rear blinkers will only work when from blinkers are connected.
    How can I disconnect the front system to just run rear blinkers?
    Yes I know there are state laws, etc.
  2. Chitwood
    Chitwood Active Member
    Fort Atkinson, Wisconsin
    Change the flasher for an electronic one and disconnect the self cancelling unit
  3. XJ550H
    you could add load resistors , flasher needs two 27 watt bulbs to work
