What's your favorite cigar/ brand of cigars?
Discussion in 'Hangout Lounge' started by smeagol21b, Aug 5, 2017.
  1. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Oooh! I forgot about those... Mmmmmm.
    I have a pocket humidor. It's a leather case that has a cedar lining. Holds 2 cigars, and there is a little block of cedar you soak to provide humidity. Not a great long term option, but nice for concealed carrying.
    Dadoseven and smeagol21b like this.
  2. smeagol21b
    smeagol21b Active Member
    hanover,pa
    I conceal carry a .380 sub compact, never thought of concealed carry in cigars! Lol!
    What is the name of your pocket humidor?
  3. MattiThundrrr
    1502381346774-418106228.jpg Smoking Jacket.
    smeagol21b likes this.
  4. MattiThundrrr
    Next question: what do you use to cut your cigar? One of the guillotine things? Scissors? Rip the end off with your teeth? I have a device that cuts a 1/4" hole in the tip and pulls out a little plug of tobacco. Very tidy, but just shreds dry wrap, so it's gotta be fresh.
  5. smeagol21b
    hanover,pa
    If it's a figurado I'll usually snip or bite it, if it's a parejo I cut a star pattern * with a pocket knife, very simple and gives a knife full draw!
  6. Dadoseven
    Dadoseven Active Member
    Omaha
    Guillotine usually; V-Cutter frequently; Punch (9 mm) sometimes- got to keep it sharp and use a slight twist to prevent shredding.
    Uugggh! Cringe!
  7. smeagol21b
    hanover,pa
    I should specify that biting is when nothing else is available lol
  8. MattiThundrrr
    How do you sharpen a circular blade? I use diamond steel and leather for a straight blade, but can't figure how to do the punch!
  9. smeagol21b
    hanover,pa
    Go to a wood working website, you can get ceramic sharpening rods and semi-circle ceramic stones, technique depends on what you're trying to sharpen and where the bevel is...as you make your Stokes rotate the rod/ stone at same time food by a piece of leather on a dowel rod with a good stropping compound....what are you trying to sharpen?
  10. MattiThundrrr
    My cigar punch. The blade is bent into a 1/4" circle that pulls a core-section out of the cigar. It retracts with a twist, popping the core out. Pretty baller!
  11. smeagol21b
    hanover,pa
    Is the bevel on inside or outside? I'm assuming outside... personally for that I'd use small long flat stone at an angle and rotate the punch as you make your Stokes then use a round ceramic rod to take out the bur on the inside...you could even use the top edge of your car window to sharpen it lol
  12. Dadoseven
    Omaha
    Chuck it in a drill if you can. I have seen spent shell casings with a sharpened edge used as punches.
    TheCrazyGnat and smeagol21b like this.
  13. smeagol21b
    hanover,pa
    Redneck style!
  14. smeagol21b
    hanover,pa
    So here is another questions, what is your preferred method of lighting your sticks? Wood matches, regular buttane lighter, butane torch, cedar spill? Other? I'm partial to spills myself but it's a pain to toast the foot properly....
  15. Dadoseven
    Omaha
    Fire.
    Really, whatever is available. Torch usually, especially if outdoors where there is a breeze. Never mess with spills.
  16. smeagol21b
    hanover,pa
    I had that trouble this morning with the wind
