Xj650 maxim.wont start in winter!
Discussion in 'XJ Technical Chat' started by Gary Brown, Jan 12, 2018.
  1. Gary Brown
    Gary Brown New Member
    Uk
    Hi,I have a trike with a xj650 maxim engine.
    The problem is its the yics engine and the previous owner has put on the carbs from a standard maxim (not yics)
    It wont start in winter,and takes a while to warm up in summer!do these carbs need rejetting?carbs have sponge filters on.
    Any help gratefully received!!
  2. Jetfixer
    YICS should not matter , sounds like your carbs need to be taken to church , Start there you will need to pull carbs off and break the rack while doing this replace the butterfly seals . You will need to soak the carbs to do full clean , this is reason butterfly seals need replaced soaking will destroy seals. The float bowls have a tiny enrichment jet that cannot be removed this is usual cause of hard starting , a piece of .20th safety wire or an equivalent guitar string and some carb cleaner is all you need to do , usually gets this back in working order.
    wgul likes this.
  3. Gary Brown
    Uk
  4. Gary Brown
    Uk
    Hi,thanks for that.
    It did run in summer but since we've had cold weather it just wont start!
    I will try what you suggested though.
    Many thanks!
  5. hogfiddles
    Charge the Battery good.
    If the carbs are 1980, the enricher well jet IS removable
    Jetfixer and k-moe like this.
  6. k-moe
    YICS carbs were jetted a tad leaner than non YICS carbs, which should make cold starts easier in your case.
    A good cleaning is in order (including new throttle shaft seals if they have not already been replaced).
    Jetfixer likes this.
  7. Polock
    you'll find the heater won't work either :)
    hogfiddles and Jetfixer like this.
