XJ650 Seca Seized Engine Help
Discussion in 'XJ Technical Chat' started by Rebem, Jul 28, 2016.
  1. Rebem
    Rebem Member
    Perth, Western Australia
    Hi everyone. I recently purchased a 1980 (Australian model) XJ650 Seca from its second owner for the princely sum of $500, so although it looks complete, I'm under no illusions that it will be perfect. It has about 56,000km on it and although dirty from country dust, it's in excellent condition.
    I've progressed through a carb rebuild but when it came time to turn the engine over, electrical issues prevented me from doing so. However I can't even turn it over with a roll start or by crossing the solenoid terminals. It appears to be stuck hard. PO had described a flood of fuel from the carbs and then left it for a couple of years completely drained, so I'm guessing zero oil anywhere.
    So before I rip the head off and look further I was wondering if you had any obvious steps I could look at? So far I've done the following based on the extensive information on this site:
    - Removed and tested the starter - it's all good
    - Opened the left shifter case and looked through the inspection hole for guide breakage - all clear and in great condition in there
    - Poured ATF and Acetone in a 50/50 mix into the cylinders and left them for days, just bumping the bike in 5th to try to loosen up possible stuck pistons - no dice
    - Removed the left crank cover and used a 19mm spanner to turn the crank - little to no movement
    It feels like stuck pistons and I can deal with that but before I settle on root-cause is there anything else that can seize it?
    Thanks in advance.
  2. Toomanybikes
    Tsawwassen bc
    Next is pull valve cover and see if any valves stuck down with big clearance to cam
    Try diesel in cylinder and heat from head gun for a few hours or more
    Next is try a propane torch on each cyl
    Were any of the plugs rusty when you took them out?
    with no oil and was full of gas at some point rings are probably rusted to cylinder
    If all fails go looking for a spare engine (750is a direct drop in) just a touch of rejet or use 750 carbs
  3. Rebem
    Rebem Member
    Thanks for the quick response! I'll pull the valve cover tonight then heat it up a bit after that.
    Plugs were surprisingly clean - bit rich on a couple of cylinders but no rust whatsoever.
  4. Toomanybikes
    Tsawwassen bc
    I'm out on the wet coast and I have had many bikes lock up after sitting a few years from rusty cylinders.
  5. MiGhost
    MiGhost Well-Known Member
    You shouldn't need a complete engine. Just the cylinders and pistons if you find that the ones you have are badly damaged from the seizure.
    Not sure what the parts availability is in OZ but you could do a 750 crank, rods, pistons, and cylinders if necessary. Just be aware that using just 750 pistons on the 650 crank/rods will give extremely lower compression. You need the complete assembly if you go that route.
    The XJ750A would be your same bike with the 750 motor in it and was available in your market. Its also very possible that you might have gotten the XJ750E in your market which is a fuel injected version. Just to give you a couple possible option for parts.
    If you come across any OZ based parts diagrams in your searches. Please post the links for them. I would like to have a look at them.
    ~Ghost
  6. Rebem
    Rebem Member
    Will do MiGhost and thanks for the feedback guys. I'm still hopeful that I won't need any parts given the good condition of everything else. The bike was in a shed in what we call the Wheatbelt which is inland country areas in Western Australia. Dry and hot during summer, dry and cold at night during winter.
  7. Rebem
    Rebem Member
    Valve cover is off and all the valve clearances look fine. I'm wondering if I pop the head off or try heat first. Any opinions?
  8. Toomanybikes
    Tsawwassen bc
    Heat first with diesel in the cylinders. Try and
    Free up the engine before you pull the top end
  9. k-moe
    If you can borrow a block heater that would be best. It'll heat the cylinders evenly without risk of damaging o-rings, or starting a fire. A heat gun will also work, or a torch with a diffuser tip.
  10. Toomanybikes
    Tsawwassen bc
    Have even seen a hot plat under the engine set about an nick from the oil pane and left for an hour or 2 and wrap cylinder wth foil to keep the heat in but remove exhaust first
  11. Nuch
    Nuch Well-Known Member
    Suffolk County, NY
    I have to say... that looks like a nice bike... especially for the price. Hope you free it with minimal expense.
  12. sybe
    sybe Active Member
    NYC - Brooklyn
    how can you check clearances without turning the crank? If you turn the crank then the pistons are moving...
  13. k-moe
    He couldn't have, without removing the head.
  14. sybe
    sybe Active Member
    NYC - Brooklyn
    i quoted the wrong post! but... yes i think its odd he said the valve clearances are in spec
  15. Rebem
    Rebem Member
    Sorry, I wasn't very clear with what I said. The valve clearances looked fine, not in spec - i.e. there wasn't a huge clearance indicating a stuck valve.
    So by way of update, I used a heat gun for a while on the block (both sides) with penetrant in the cylinders. No difference so I got heavy with it and removed the head. Again, valves are fully retracted so no issue there. Cylinders have evidence of surface rust, particularly #2 and there was quite a bit of crud in there mixed in with the fluids. I've cleaned it all up and sprayed more WD40 in just to keep it soaking.
    Next step is to wait I guess. I'll keep trying to move it but is it possible it's something else? Just to cover my bases, I'm happy to eliminate other possible causes.
  16. k-moe
    WD-40 isn't a penetrating oil.
    Make sure the transmission is in neutral. You might want to go ahead and remove the clutch basket just to make sure the transmission isn't the culprit.
  17. Rebem
    Rebem Member
    Good point - I'll grab some diesel.
    I may have eliminated the transmission earlier when I tried turning the crank from the 19mm square plate thing under the left crank cover. It was in neutral and still wouldn't turn but now I have the head off I'll give that a go again.
    Thanks for the help so far guys. Very much appreciated.
  18. k-moe
    If the shift forks are bent, the transmission may not be in neutral. If the alternator chain guide has failed, a chunk may be preventing the input shaft from spinning.
  19. Polock
    take a block of wood and a hammer and tap the front then back of the pistons, not the top or sides. keep tapping harder, if it doesn't break loose, start unbolting your new boat anchor.
  20. hogfiddles
    Seeing that there is no Airbox.... And not even pods on the carbs--- could be any number of things, not just rain, could have crawled in there....
