Xj750r seca 1982
Discussion in 'XJ Modifications' started by joe elliff, Aug 11, 2017.
  1. joe elliff
    joe elliff Active Member
    illinois
    Who out there has used a direct replacement set of fork tubes? What did you use and why? I began disassembly of my original fork tubes for my seca and followed the manual for disassembly to a T. I can not separate the stanchion from the lower leg. It will not pull out
    I am considering a new style of forks but if I can come out with the originals for the bike that would be preferable.
    Help please
  2. Rooster53
    Dadoseven likes this.
  3. joe elliff
    illinois
    Excellent write up I thank you for leading me to it. The only thing in comparing the write up to what I've done differently is..... the dampening rod bolt on the bottom spins freely. I did not take it out all the way just because of the bolt rubber making it not drop right out. I can't think it'd still be attached whatsoever, but given the article showing it on the bench I will go and do the same. Past that, this one leg is a pita. Attaching it to a vise I was using both hands and fully pulling
    I'll let you all know. Hopefully it'll be something silly like I still had one thread attached Although I dont think that'll be the case
  4. joe elliff
    illinois
    Either way now I am in no hurry. Looks like I've got to order some upper stanchion rubbers now to go above the air inlet and below the upper clamp from chacal and more I'm sure.
  5. Rooster53
  6. joe elliff
    illinois
    IMG_1055.JPG Hmmm. Well, it's apart now I am very happy to have the link you sent. It'll help with reassembly after I start ordering rebuild parts. I somehow can't find the other half of the spring washer
    There is still one more part within the tube that won't fall out. I'm figuring the other half if the spring washer is bound up into it somewhere
  7. hogfiddles
    Joe, another simple option is to swap the 750 seca forks out for a pair of 750 Maxim forks.
    The only thing that changes, is you don't have the anti-dive stuff (to worry about) anymore.
    Dave Fox
  8. joe elliff
    illinois
    I have a set of them mocked up in the tree right guy now. I say mocked up as I don't have the rubber bushings any longer that go just under the top clamp and above the air direct valves
    They're too dry and brittle and broke upon disassembly
    Still need to try and find them here through chacal and I'll once again be able to ride it
