Quick Help on Engine Change between years!
Discussion in 'XJ Technical Chat' started by nejeff, May 8, 2012.
  1. nejeff
    nejeff New Member
    I have a n 80' Xj650 in need of a new motor. Someone is offering me a 82' XJ650 for a reasonable price. Is this a direct swap? THe 82' has yics but is everything else the same? Help! Need to know right away. Thanks
  2. TIMEtoRIDE
    There's a minor carb jetting difference, and maybe an issue with the tach cable??
  3. fintip
    fintip Member
    Austin
    If I remember right, reading somewhere, it should be close enough to make it work, if not completely straightforward.
  4. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Most everything should be the same but you'll have to go with an electronic tach because the 82 engine does not have a tach drive.
    MN
  5. nejeff
    nejeff New Member
    Thanks guys for your help! When I got there ( 2 hour drive) it turned out to be an 81' with the tach drive so I guess thats a bonus. Looks like some of the parts are off a 750 (like side covers). got to investigate further...
  6. nejeff
    nejeff New Member
    Engine code is 4h7-117202 so I am safe! For a minute thought I might have a 750
