New to the forum, just bought an '82 XJ650RJ...........
Discussion in 'XJ Technical Chat' started by Blackfnttruck, Nov 11, 2015.
  1. Blackfnttruck
    Blackfnttruck Member
    Harrisburg Pa
    The idle speed was low and kept dropping out and shutting down the bike. I adjusted the idle screw in, about a turn, and that seems to have corrected it. For those of you with this bike or similar, what is the typical idle rpm with the bike warmed up?
  2. k-moe
    1100 rpm is the spec. A little higher won't hurt, but go no lower.
  3. Blackfnttruck
    Harrisburg Pa
    Thank you, that is about where I have it, much lower and it dies.
  4. quebecois59
    One turn ! That sounds like a lot !
  5. XJ550H
    time to find a manual.
    theres a lot instructions in the diy forum for things you want to fix
  6. Blackfnttruck
    Harrisburg Pa
    Yup...thanks, the bike came with a manual. I thought the original owner tried different things to get the idle back up...apparently not. In the end it was probably about 1/2 to 3/4 turn, once I backed it back down to around that 1100-1200 range. Gauge is not all that accurate.
