Do I have to re-jet or any other special mods in other to install Mac 4-1?
Discussion in 'XJ Technical Chat' started by KhoaDao, May 21, 2016.
  1. KhoaDao
    KhoaDao New Member
    San Jose
    I want to get the Mac 4-1 on my 81 XJ650, do i have to re-jet or do any special mods to the carb so the exhaust would work correctly? Thank you
  2. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    The first thing you would need to make sure that your bike is running as it did when it came out of the dealer.
    That will give you an ideal base line to modify your bike.
  3. k-moe
    Probably not. The stock exhaust is not very restrictive.
  4. XJ550H
    you will have to do a plug chop or two to confirm , or use a color tune tool to check for lean condition.
  5. fishinchickens
    fishinchickens Member
    Shepherdsville, KY
    I had to go up a size on my main jets and idle jets, other than that nothing else was done.
  6. XJ550H
    on what bike?
    added bike info on rejet
  7. fishinchickens
    Shepherdsville, KY
    It is a xj750rj.
