  1. turpentyne
    turpentyne Active Member
    Desert SW
    Phew! Just finished wet setting the carbs. Taking a 'fresh air' break before the final check.
    I got lucky and the dry set came pretty close. Only mishap: Watching fuel come pouring out the mouth for a second... then seeing the float needle sitting on the table! Wha??! Hah! Not sure how I managed that!
    amiel1157 likes this.
  2. chacal
    Hey Turpentyne, I think that it was you that stated in another thread that you found a heater by-pass hose at O'Reillys to use in place of the crankcase breather, you might want to keep an eye on it, it's made from EPDM material which is strongly attacked by oils and fuels.........it may turn to mush rather quickly!
  3. turpentyne
    Desert SW
    ah... damn... That kinda crossed my mind, but I told myself, "maybe nothing but air will go through and I'm fine," after I couldn't find anyplace with large enough fuel line to work, which is what I assumed was the best bet.
    ok... back to the drawing board. What's the best hose material I should look for, aside from fuel line?
  4. XJ550H
    get a spare
  5. Jetfixer
    So sad put bike away for winter , temp hit 50 degrees would have been nice to go for a ride , had not started bike in 3 weeks , hit half choke fired right up :D counting down days till spring .
  6. XJ550H
    the winter put my bikes away early snow followed by more snow 50 degrees your so lucky
    Jetfixer likes this.
  7. Tim O
    Tim O Active Member
    Charlottesville, VA
    58 here Sunday... leading a 120 mile ride with 3 others... ;)
    Franz and joe elliff like this.
  8. XJ550H
    give the throttle a twist for me :) I am going to have coffee with my bikes tomorrow morning and cover them with their blankets and read them a bed time story
  9. chacal
    Buna or Nitrile, i.e. fuel hose and probably vac hose, too. If you can find a PCV breather hose with the correct configuration that would be the best.
  10. biggo
    biggo Member
    Kapiti Coast New Zealand
    Took off my Exhaust system for a proper clean today not bad for 32 years of service ...........
    46401800_339806556818424_1641781438221123584_n.jpg 46489453_311384516366491_4705133034930700288_n.jpg
  11. Franz
    Franz Well-Known Member
    Scotland UK.
    Looks good for all those years.
  12. Richard Elbon
    Richard Elbon Active Member
    LaCenter Washington
    Picked up a barn find 82 Seca 750 last month and decided to do a little lower frame cosmetics and am having a difficult time getting the rear brake light switch adjusted. It only moves 1/16” to activate and doesn’t want to retract enough to shut off the light. Anyone have any ideas?
  13. XJ550H
    brake switch.JPG brake2.JPG the switch body has A NUT that hold it to bracket that is how you adjust the switch by moving it up or down with the nut
    also spray cleaner and dry silocone spray to lube
    edit about nut
  14. Richard Elbon
    LaCenter Washington
    I may need a new switch. The spring that moves it may have to be bent a little more. Movement of 1/16 inch to activate and release seems a little tight.
  15. XJ550H
  16. amiel1157
    amiel1157 Member
    Philippines
    Today I watch image of a honda cb super4 get smaller and smaller in my rear view mirror try harder next time kids...
    Chitwood, kosel and Jetfixer like this.
  17. Praxeus
    Praxeus Member
    British Columbia
    What did I do with my Yamaha today?
    I just finished reading every post of every page in this 287 page thread! A little sad that it’s finished, but proud of the accomplishment. Today a 17 year-old student advised me not to drill a lower hole on carb boot number 4 but to instead get a carbide bit and re-drill my broken tap that I left in. He was not impressed by my temporary solution, which I thought was brilliant at the time, to clamp the top corner on with a custom bracket. Look at the bottom left of the pic and tell me if you think it will work or if I’m going to get a massive vacuum leak lol.
    I think I’ll follow my student’s advice and get the best Bosch drill bit I can find and go to town on it tonight. Tonight’s other chore includes matching my eBay universal LH handlebar controls with my wiring harness. (The controls have no wiring diagram.). Then attaching my Acewell gauge. The wiring is harder for me than any other part on this build! P.S. where can I buy Kroil in Canada? I think PB blaster is the best I have seen for stubborn bolts.
  18. raskal
    raskal Active Member
    Abbotsford B.C. Canada
    I'm just glad you didn't say you were using WD-40
    I found this quote;
    "Machinist's Workshop magazine actually tested penetrants for break
    out torque on rusted nuts. They arranged a subjective
    test of all the popular penetrants with the control being the torque
    required to remove the nut from a "scientifically rusted" environment.
    Penetrating oil .......... Average load
    None ..................... 516 pounds
    WD-40 .................... 238 pounds
    PB Blaster ............... 214 pounds
    Liquid Wrench ............ 127 pounds
    Kano Kroil ............... 106 pounds
    ATF-Acetone mix............ 53 pounds
    The Automatic Transmission fluid (ATF)-Acetone mix was a "home brew" mix
    of 50 - 50 automatic transmission fluid and acetone.
    Note the "home brew" was better than any commercial product in this
    one particular test. A local machinist group mixed up a batch and all now
    use it with equally good results. Note also that "Liquid Wrench" is about
    as good as "Kroil" for about 20% of the price."
    Franz likes this.
  19. Franz
    Scotland UK.
    I read somewhere that vegetable oil and acetone mix were good too for soaking corroded fastners. Think I will try that and the ATF-Acetone mix.
  20. Franz
    Scotland UK.
    What did you bolt the bracket to?
