links to Yamaha parts in Canada
Discussion in 'XJ Technical Chat' started by XJ550H, May 7, 2019.
  1. XJ550H
  2. raskal
    raskal Active Member
    Abbotsford B.C. Canada
    and if you're not watching Fortnine youtube videos, you're missing out
    lostboy likes this.
  3. raskal
    hmmm Fortnine does not pass the sniff test for everything though
    this turn signal doesn't look right :mad:
    hopefully it's just the stock image that's wrong. They have a good customer service, so I'd suggest asking to make sure it's right before ordering
  4. k-moe
    Fitting the application, and being the correct part are not the same thing.
    Most repops are made for function over appearance, epsecially when the part can physically fit several makes and models.
  5. Uxbridge Brule
    Uxbridge Brule Active Member
    Uxbridge Ont
    I've used Fortnine for a couple of things with the XJ already, oil filter, spark plugs and gear oil they ship fast and are great if you have returns. I started using them for my Wr250 about 3 years ago. I have an oil filter bolt and mirrors for the XJ on order will let you know how that works.(mirrors are longer stem than stock PO changed the handle bars and now I have a great view of my elbows)
  6. Uxbridge Brule
    Uxbridge Ont
    Got the replacement mirrors (EMGO) delivered and put on the bike 2 days ago they look good but they aren't the quality of the originals, can see behind me now. The rest of the order was in the box, next oil change I will know if the oil bolt and filter fit but they look good.
