Need HELP>>>throttle wont snap back... 82 750 maxim
Discussion in 'XJ Technical Chat' started by Timothy M., Aug 26, 2019.
  1. Timothy M.
    Timothy M. New Member
    Removed carbs for cleaning....snapped back fine before. Reinstalled carbs....choke cable works as should but throttle wont return on own. Any help would be great!!! Thanks Tim
    first is throttle cable hooked to the throttle linkage not the choke?
    choke is the outside hook up with the clamp.
    did you change the routing of the cable?
    is the linkage on carbs hitting any thing.
    remove cable and make sure the throttle linkage is working smoothly on the carbs.
    could be the butterfly disc is rubbing
  3. k-moe
    Made sure that the throttle cable and tube are clean and lubricated (grease in the cable, and grapite between the throttle tube and the bar)?
    Franz and Toomanybikes like this.
  4. cds1984
    cds1984 Active Member
    Perth, Western Australia
    carb clamp screw up against the carb linkage got me once.
  5. Timbox
    Timbox Well-Known Member
    If you have a throttle lock make sure that is off (not that I have even done that) lol
  6. Polock
    me too
    take the cable off the carb end and see if the linkage snaps back
    raskal likes this.
