Rack of carbs
Discussion in 'For Sale, Trade/Swap, Wanted' started by Fuller56, Oct 19, 2019.
  1. Fuller56
    Fuller56 Well-Known Member
    For Sale, a complete carb rack reputedly from a 1980 Maxim. Not pristine but they worked on my XJ750 while Dave Hogfiddled a set. I have installed new throttle shaft seals and a float. They have been cleaned but did not go to church. An expert suggested I ask $75 plus shipping so we will start there. 15715139519703173656372624136481.jpg 15715140234956573453485235031893.jpg 15715140601117269968005745768894.jpg
    did it have fine or course mixture screw threads? that would help ID the year.
  3. Fuller56
    I will have to look at them but not sure I will know the difference.
    John
  4. chacal
  5. Fuller56
    Thanks Len. Tomorrow I will check and see which I have and so edit my post.
    John
  6. Fuller56
    Upon further examination the mixture screws are coarsely threaded. Thanks again to that seemingly endless source of XJ info, Chacal.
    John
  7. vashtsdaytona
    vashtsdaytona Active Member
    Fargo
    For my curiosity, what year or model does it make it? Weather being course or fine?
  8. chacal
    The coarse-threaded mixture screws were used on 1980-81 XJ650 Maxim and XJ650 Midnight Maxim models, and some of the early XJ650 Euro model carbs. Some early-production 1982 XJ650RJ Seca models may have also used them. We have never seen them used in the 1981-82 XJ750 model carbs, which is odd, since the bare carb bodies are (for all practical purposes) identical between the 650 and 750 model Hitachi carbs...….
  9. XJ550H
    only real reason to know is that you set course mixture screw different than a fine screw for the initial soft bottom install. I think 1.8 turns vs 2-1/2 turns.
    some of the older carbs have less screws on the frame and a different carb bowl drain set up
  10. vashtsdaytona
    Fargo
    Thank you. I found fin interesting :) I like knowing things like that
  11. Fuller56
    Well, if no one NEEDS a rack of carbs, who WANTS them. Feel free to make a reasonable offer.
    John
  12. Polock
    someday half the people on here are going to wish they had those carbs. cut loose people
  13. Fuller56
    A deal has been struck, the carbs are spoken for, SOLD.
    thanks all who looked.
    John
    Rooster53 likes this.
