Carb float shaft post broken
Discussion in 'XJ Technical Chat' started by joshs700n, Jan 17, 2020.
  1. joshs700n
    joshs700n Member
    mass
    Just wondering if this is fixable
  2. JetmechMarty
    JetmechMarty Active Member
    Coldwater, Mississippi
    Yes it is. First and easiest solution might be to replace the carburetor body. On mine, I had the post welded. Finding someone to do that could prove a challenge. I think that service was more expensive than a set of carburetors on eBay.
    Here is a repair tutorial:
    Don't be tempted to use adhesive such as JB Weld. That repair will eventually fail.
  3. XJ550H
    there are a few posts on fixing the post
    if you pick up a ebay rack you may want to fix the ebay set or just look for a carb body.
  4. Jetfixer
    My carbs had one post broke , the PO had drilled and had a pin , and JB weld on post . Was VERY solid had a time knocking it off . I put it back with JB weld , if one follows directions and patient ...takes 24 hours to set up is awesome stuff. I have repaired engine cases , when I worked as a kid at Ditch Witch one of my jobs was fixing Dana 44 rear ends that had cracked cases , I had to stop drill cracks going a trough and fill with JB WELD after set up filled with gear oil let sit for 24 hours never had one leak . The other product the works great is Liquid Steel , it is a two part putty stick , roll and knead into a ball , it sets up in about 5 minutes so you have to work fast .
  5. joshs700n
    joshs700n Member
    mass
    Hi-so I have another set of carbs but hey I'm going I just has big lead in her big mouth McGee big Lee has big mouth it sounds like I'm I got some more we leave here Mike I'm going to get this outfit
  6. joshs700n
    joshs700n Member
    mass
    hi thank you so I do have another set of carbs but the problem with those are the damn idle mixture screws are stuck in there and I tried to drill one out but it but I ended up drilling into the threads to on the carb so I don't know if they're even fixable now
  7. joshs700n
    joshs700n Member
    mass
    Hi I have another set of carbs but I tried Drilling one of the idle mixture screws out because there was stuck in there and I ended up drilling into the threads on the carb and I don't know if it's even fixable now
  8. Cattleman XJ
    Cattleman XJ Member
    Texas
    It can be welded- but there are only a few places that will do it and you’ll still have to strip the carb of any rubber or plastic parts.
    If you can find a competent machine shop they can drill both ends and add a pin + adhesive.
    Or send Chacal $200 and get a new body.
    I tried just globing on all of the JB weld, steel stick, marine stick, epoxy, etc and it gets wobbly soon after contact with fuel
    JetmechMarty likes this.
  9. XJ550H
    maybe that aluminum "welding" stick will work . the one you see then patching holes in a can with
  10. Polock
    i tried several times to use that stuff, R/C airplane engine, (fail,motor mount lug melted) lawn mower deck, (fail, couldn't get the deck hot enough) smartphone stand worked until i dropped it, (fail, looked good)
    i would think that while you keep the body hot enough to melt the stick, the post will melt
  11. Jetfixer
    I fell for it too epic fail ,it melted the post so I'm not sure if Mapp gas would have melted the stick better or not maybe one day I will try it. In the mean time I have a bunch of sticks:D
  12. Timbox
    Timbox Well-Known Member
    IMHO I would have to go with a replacement carb or carb rack. I don't know if I could ever stop thinking about that post holding up once it was repaired. Would I ride that bike as often as I should knowing it could stand me?
  13. hogfiddles
    Just get a replacement body
    Timbox likes this.
