Pod Filters?
Discussion in 'XJ Modifications' started by Scizor, Nov 14, 2010.
  1. sybe
    sybe Active Member
    NYC - Brooklyn
    Just want to mention, direct water from a hose onto the filters with the wraps, will allow some water to go through. This is for rain and splashes of water. when i wash my bike i never spray the wraps directly
    Mobius Williams likes this.
  2. Mobius Williams
    Mobius Williams Member
    Wisconsin
    Agreed. I actually cover mine completely with a bag or something and take care not to spray directly at them as well.
  3. GoCrazy
    GoCrazy Member
    Poland
    So mamy people replied to this post and nobody mentioned that CV carbs + pods usually ends up in dissapointment. I have seen a few Xj600 and 750 custom bikes that went pods and each of the projects had the same issues. It usually started with cheap pods from China and some modifications using some kind of additional filtering material and after hours of checking different jets setups people would end up with the bike running ok either in low or mid/high range. One of my friends went with K&N pods and this seemed to be a nice improvement. However, to achieve this result my friend had to visit a tunning shop and they used a color tune spark plug, professional dyno and a 02 sensor. The only reason my friend did not go bancrupt was the fact that his brother in law was an employee of the shop :)
    Also, I remeber talking to a bike builder during some customs bike show about pods and CV carbs and he said that he came up with a solution for getting rid of the stock airbox - it was a custom stainless airbox with cylindrical foam filters, but again this involved some time to get the jetting right + it is definitely not beginner friendly process.
  4. XJ550H
    posted on first page, no point to beating a dead horse
  5. k-moe
    We've been beating that horse for over a decade. It's saved people (well some people) a lot of frustration.
  6. Kweb1889
    Kweb1889 Member
    Traverse city mi
    So I bought an 81 xj550j maxim that came with pods on it no air box also it has a straight pipe exhaust (4 individual pipes). What jet changes will I need to make for this to work right? I am new to this so sorry for my ignorance.
  7. Kweb1889
    Kweb1889 Member
    Traverse city mi
    Is their a specific jet kit to use for this mod? I recently bought an 81 xj550j maxim and it already had pods on it (didn't come with airbox) and I want to make these pods work.
  8. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    I am a little late to this party...
    Pods, especially the cheap eBay ones, are terrible filters. They will keep out sand and gravel, but they let in far more dust than foam filters.
    UNI foam pods filter well, and are generally better made. If you have to with pods, go with them.
    Performance-wise, there is no rational way for pods to improve anything. "More airflow" is nonsense. The airflow can only possibly be limited by the air filter at wide open throttle. The rest of the time the limiting factor is the opening between the bore and butterfly. If you really want more airflow, you need bigger carbs, at least until you hit your intake port limitations.
    Pods are extremely cheap, cheaper than airboxes and foam filters. Manufacturers would have been all over a cost savings like that, if they could actually make them work same or better. But... they spent money on airboxes instead.
    Yes, they can be made to work, but you only gain in looks.
    Yes. It's possible.
    However, I haven't seen anyone complete such a project yet. There are a couple of threads here with people in various stages of doing it. One guy has been at it three years, I think, but he isn't working on it full time.
    There are no ready made kits. There are a couple of ECM options, but you need to find a throttle body that fits, make your own wiring harnesses, and weld in a bung for O2 somewhere. You also need to make a crank trigger. Fortunately, on XJ the crank trigger part is relatively easy.
  9. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    One point I have to comment on here -
    "Performance-wise, there is no rational way for pods to improve anything. "More airflow" is nonsense. The airflow can only possibly be limited by the air filter at wide open throttle. The rest of the time the limiting factor is the opening between the bore and butterfly. If you really want more airflow, you need bigger carbs, at least until you hit your intake port limitations."
    Mostly this is correct, but it assumes that the standard filter is not restrictive at wide open throttle at high rpms. If it is, then a good pod filter could gain you additional airflow. The problem is likely to be, that at this point the carburrettor settings are going to be exceeded, or at least the jetting will be. The problem is of course, that in order to gain wot airflow you have buggered up the jetting everywhere else the carburrettor operates, (as well as at wot). Hence it turns into an almighty job to get it all right.
    JPaganel likes this.
  10. 50gary
    50gary Active Member
    Saginaw, Mi. USA
    I bought my 750 Maxim as a non-running but mostly complete bike. I say mostly because the PO sold the airbox and carbs off the bike. I will put on another four carbs other than the Stock CV set.
    CV carbs are not performance carbs, not that it's a bad thing just saying.
    Cheers, 50gary
  11. JPaganel
    Minneapolis
    What happens at WOT is mostly irrelevant to a street bike. Unless you are a racer on a track, you will pretty much never get there.
  12. JPaganel
    Minneapolis
    Aw, just FI it.
    :D
  13. Minimutly
    West Wales, uk
    Really? Only if you live somewhere flat in my experience? And if it were true, why would Yamaha fit the X with a 16V engine, or build a 900, or anything more powerful? Exup 1000 anyone? My vmax opens a carb commoning pipe at 6000 rpm, all hell breaks loose...
  14. hogfiddles
    1. X has 20 valves
    2. Want an engine with more HP or displacement?—- much easier to just go buy another bike already designed and built that way from the factory
    3. vmax... well, I have my 1984, and my 2002——
  15. k-moe
    I must be some sort of weirdo then. I hit WOT fairly often when I merge onto a freeway with a short entrance ramp, or go to pass traffic on a 2-lane road. In both situations reliable power delivery becomes critical.
    Remember, WOT can happen in any gear, and at most speeds.
    XJ550H likes this.
  16. 50gary
    Saginaw, Mi. USA
    Lead us not into temptation but deliver us fuel, amen.
    Fuel injection is a factory level difficulty project. Substituting different carburetors
    is maybe not easy but at least it's straight forward. my 750 is just 4 x 187cc it's not magic hocus pocus but a ICE that needs fuel and air.
    Cheers, 50ary
  17. XJ550H
    for the 550 stock jetsMain FUEL Jet Size: #112.5 Pilot FUEL Jet Size: #35
    with pods and open exhaust
    up 6 main jet sizes
    HCP6928 Aftermarket Mikuni MAIN FUEL JET #117.5 (not quite 6 steps)
    HCP6929 Aftermarket Mikuni MAIN FUEL JET #120 ( 8 steps up)
    up 2 sizes in the pilot jets
    HCP6952 Aftermarket Mikuni PILOT FUEL JET #37.5. This jet does not have fuel passage holes within the jet shaft.
    you may want to consider using the seca 550 spec slide needles too
    read the catalog for discription on the seca550 pod
    http://www.xj4ever.com/catalog/c-mikuni.html
    you are looking at about 45 to 50$ for the initial jet change
    then about 25$ per main jet size if you need to go up or down a set.
    mains first then do tests then change pilots do tests and see where your at.
    you will lose out on the 50 mpg a stock 550 gets.
  18. JPaganel
    Minneapolis
    I've been researching it for a fairly long time. The same long time I have worked on this FJ600 rack. Literally years. I gave up and sent it out to be rebuilt, but even after that I fought overflowing for months.
    I think I got it, but if it doesn't run without leaks sometime this winter, I will start that project. Yes, I hate carburetors that much at this point.
    The most difficult part is finding a throttle body to fit. Otherwise you are making manifolds, and I am not equipped for that.
    There is nothing straightforward about replacing carburetors. There is a ton of guesswork, unless you have a gas analyzer, which most people don't. The constant need to remove-replace the rack to change anything. Pulling plugs. In the end, you still get a "close enough".
  19. Yammaat
    Yammaat Active Member
    Netherlands
    WOT = ??
  20. hogfiddles
    Wide Open Throttle
    Yammaat likes this.
