Shaft Lengths
Discussion in 'XJ Modifications' started by junkmn, Aug 9, 2010.
  1. k-moe
    Even if you own a machine shop stuff is expensive to make, especially when making low-demand items.
    Stephen Downey, Umé and XJ550H like this.
    hill climbers and drag racers want a longer shaft other than that doing it to just do it is not worth the expense, as it affects the geometry of the bike to much to keep it safe.
    Umé likes this.
  3. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    This is true, however it will likely make it more stable, not less. Modern "hot shot" bikes are as short as you'd think possible.
    my own experiments have come up with the xj900s diversion - around 5 inches longer. If anyone wants one I can post to US....
    Umé likes this.
  4. Umé
    Umé New Member
    Indiana
    Sounded like he was well on his way. I expected some pics, or something. Oh well.
  5. Umé
    Umé New Member
    Indiana
    I saw the front/rear conversion. Looked pretty good.
    XJ550H likes this.
  6. Umé
    Umé New Member
    Indiana
    I ran across an xj650 pic online with an extended swingarm. No details. Just a pic on a trailer. Big knobby tire on back. You've done this??
  7. Minimutly
    West Wales, uk
    No, just accidentally came across one.
    Umé likes this.
  8. XJ550H
    yes thats why hillclimbers and drag racers do it but the longer the bike the harder it is to turn.
    then the problem of welder shaft coming apart when you need it the most
    Umé likes this.
  9. Polock
    how far do we want to go?
  10. Minimutly
    West Wales, uk
    Once you learn how to weld shafts to transmit 100 bhp direct to wheels, joining shafts running at 1/3rd of the torque is maybe not easy, but at least not an issue to do reliably.
  11. 50gary
    50gary Active Member
    Saginaw, Mi. USA
    Thread jack, minor crime level.
    I have a winter project to remove the final drive gears and polish them. I have a good friend that
    does coatings in his shop. just his year he started doing Isotropic Super Finishing (which is not a coating BTW) but vibratory polishing with a special
    fluid and special particles. It does a great job on all type of gears, transmissions, rear ends, does automotive crankshafts etc. Cranks and rods, gears come out looking like chrome.
    Lots of friction reduction, friction is heat, power loss. Should be fun.
    Cheers, 50gary
    Dave in Ireland and Umé like this.
