What is this tank off?
Discussion in 'Hangout Lounge' started by Minimutly, Nov 26, 2020.
  1. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
  2. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    It is not for a 550. The 550 tank has an oblong mounting hole on the rear flange.
  3. Minimutly
    West Wales, uk
    Thanks. Then I would say it's a650 seca?
  4. XJ550H
    except for that rod connectiong both sides
    looks like rust through and patch left rear of tank
    looks seca 650 not a 900 tank because of the fuel cap
    650 seca is a very close fit you would need the 650 seca mounting rubber in the rear then add a little to it or gentld dent in the tank where it hits the 900 frame
  5. Minimutly
    West Wales, uk
    Except the "bar" is the rear mounting?
    I have a 650seca tank which I have tried, and it is doable, as hoggfiddles thread outlines, then I would just need to make some side panels and sort the seat...
  6. XJ550H
    I was in on that conversation about the 650 tank I know it is doable.
    the add photo shows what looks like a rod on the tank or is that the flat mounting bar?
