Exhaust gas analyzer for tuning mixture
Discussion in 'XJ Technical Chat' started by dkavanagh, Aug 25, 2019.
  1. dkavanagh
    Rochester, NY
    Hey, I could at least add a servo to adjust the mixture screw for me. (just joking, I don't trust something like that to not bugger up the screw, or a software error drive it hard into the seat)
  2. k-moe
    Why would he go to Finland? :p
    hogfiddles likes this.
  3. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Nowhere near it, but he will have the means to callibrate it!
  4. dkavanagh
    Rochester, NY
    3D printed a support for the air pump. It purrs nicely when energized and creates suction at a nice level for this application.
    The lambda temp could get to 600 degrees (per the spec sheet), so the test chamber must be metal. Plastics I could print melt under 500 degrees. I'm working on a design in CAD. I plan to braze inlet and outlet pipes, and may as well braze the cap. I'm planning a part that can be built on a lathe that the sensor screws into and has a fitting to draw gasses in near the end of the sensor and an outlet (to the air pump) near the base of the sensor, hopefully to give the gasses the best chance of being measured since the sensor has openings at the end. I need to think about condensation and drainage. I'll probably let the air outlet be low and act as a drain as well. The air pump can expel any drops of water along with the air. Keeping the test setup powered on after shutting off the engine would allow water to clear (more or less).
  5. hogfiddles
    GOOD ONE!!
  6. Polock
    i found it. the copper went up the pipe, the rubber hose went about 2 feet into a metal coffee can so any suck-back was still exhaust. worked on my VW, yamaha showed crazy wild swings
    and then i quit and went for a ride
    dkavanagh and jayrodoh like this.
  7. Minimutly
    West Wales, uk
    Is that silicon sealer? If so don't use it, I read somewher it damages lambds sensors (or was that catalytic converters?)
  8. Polock
    Minimutly likes this.
  9. dkavanagh
    Rochester, NY
    I just wired and powered up my lambda controller and gauge. I did the calibration in free-air and the gauge read 22.4. Not sure what's expected there. I also used a Fluke temperature meter to measure temperature at the threads of the sensor, which came out to 150F. That's low enough for PLA which melts around 400F. I may just 3D print a test chamber and see how that holds up.
  10. Polock
    air is about 21% O so that's close. i think if you rev it at all, your going to melt. print two
  11. dkavanagh
    Rochester, NY
    My goal was to design something that could be primarily made on a lathe out of metal. If course, if I had a torch, I'd make something pieced together from parts that could be welded together. I know exhaust gasses can get a lot hotter, so I suppose 3d printing one would be primarily for prototyping the design. I'll have to fit my temperature probe into the chamber so that I can shut things down before I get a melty mess over the sensor!
  12. dkavanagh
    Rochester, NY
    I love 3D printing. I is fairly fast to iterate and test a design. This took a little over an hour to print and has printed threads for the M18 1.5 threads of the O2 sensor. It threads in snugly as is preferable. I need to work on the holes for the air lines to improve their fit. I'll also thicken the wall around those holes so there is more overlap between the brass tube and the plastic. I was originally designing this to be easy to machine (and there's a separate cap that would be brazed on, but I'll 3D print it and super-glue it, or I could even melt it on with a soldering iron). I'll probably also add some mounting tabs to allow this to bolt on some spacers inside a case.
    IMG_20201220_095540414.jpg IMG_20201220_095509403.jpg IMG_20201220_095516053.jpg
  13. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    That is nifty. Dave, do you have that printer at home? What is the print resolution?
  14. dkavanagh
    Rochester, NY
    I built this printer back in 2017, and did a number of upgrades to make it safe and run better.
    It's super cheap and there are likely better cheap printers now, but this still serves me pretty well. It can do .1mm layer height and has a .4mm nozzle.
  15. k-moe
    Once you get it dialed in (and if you have the desire to take on a new hobby) get some green sand, a kiln, all the aluminum cans your neighbors will spare, and commence to casting.
  16. dkavanagh
    Rochester, NY
    So many skills I'd like to learn, so little time (and spare $$s at the moment).
    hogfiddles, Franz and k-moe like this.
