Ok to Lay Bike on it's Side?
Discussion in 'XJ Technical Chat' started by Dark-Farmer, May 12, 2021.
  1. Dark-Farmer
    Dark-Farmer Member
    Vancouver Canada
    Hey Guys
    Was hoping to get opinions if it's a bad idea to lay my bike on it's side?
    (it's an 82 XJ650 Maxim)
    My kickstand broke the other day and I'm looking for a welder to weld it back in place.
    One welder I'm talking to asked if it's ok to lay the bike on it's side to do the work?
    I initially said no, but figured I'd get a second opinion.
    Also thinking if I drained the oil and took the gas tank off and drained the carb it might be ok to do so?
  2. dkavanagh
    Rochester, NY
    The carbs will dump fuel, so avoid laying it down if you can.
    Prop it up with something sturdy if you can. An unexpected tip-over can hurt someone or hurt the bike.
  3. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Take the tank off, drain the fuel from the carbs or run it until it stops, remove the battery, as you say. It will be fine.
  4. k-moe
    Battery removal is a must if it's a normal Wet Lead-Acid battery. If it's anything else it can be left in place.
    Jetfixer likes this.
  5. XJ550H
    lay it on its side:eek: not if your rolling down the road;)
    Andrew Nichols likes this.
  6. tj.
    tj. Active Member
    Canada
    Disconnect the ground if your not going to remove the battery...welding can do strange things to electronics.
  7. Jetfixer
    Drain the oil , and the carbs , and has been stated remove tank , and battery you are not going to have it on side for long .
  8. Brent NZ
    Brent NZ Active Member
    Tauranga, New Zealand
    If your engineer can't weld in-situ I would question their ability, recommend getting someone else to do the job.
    XJ550H likes this.
  9. Polock
    if your welding the kick stand bracket to the frame you should make sure there's a frame there to weld to
    that's where frames rust from the inside
    Jetfixer, XJ550H and Franz like this.
  10. JCH
    JCH Active Member
    seattle wash
    Yes you need to drain the engine oil or it can go into the air box and saturate your air filter via the PCV vent hose.
  11. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    This is a very important point. Why is this broken? How about a pic?
  12. Dark-Farmer
    Dark-Farmer Member
    Vancouver Canada
    Thanks for all the advice guys.
    It seems like the welder will be able to it without tipping it.
    It didn't look very rusty to me, I'll post a pic.
    (Excuse the pictures it's sort of tough getting a photo under the bike)
    Beside the removing the battery is there anything else welding could damage that I should protect?
  13. Simmy
    That weld failed because there was no penetration.
    Clean it as best you can, remove the wiring in the way, remove the paint, try to remove the old weld filler.
    Get the bike leaned over so your welder is comfortable, once he sticks his head under there he won't have room to work his stinger.
  14. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Wow, the weld had no penetration!
  15. dkavanagh
    Rochester, NY
    I'd be inclined to unplug the TCI.
    tj. likes this.
  16. Dark-Farmer
    Dark-Farmer Member
    Vancouver Canada
    I know nothing about welding ....
    That's why I'm looking for someone for this job.
    Funny it lasted so long.
    I've owned the bike for at least 7 years myself.
    Nothing is telling me this has been repaired in the past either; but I know nothing about welding lol.
    I had the bike standing all day at work on the kick stand and it didn't fail.
    Went to a gas station to fill up on my way home and almost dropped the bike cause it was like the kick stand wasn't there.
    Could have been worse I guess, would have sucked to find my bike on it's side in a parking lot or my garage.
  17. hogfiddles
    Why not just use the center stand?
  18. Dark-Farmer
    Dark-Farmer Member
    Vancouver Canada
    I have been. I like the kickstand a lot better.
    I read the "tricks" for the centre stand on here cause I was having a tough time with it.
    Definitely made it easier when I knew how to do it properly.
    But I'm not the largest guy, if I had maybe 20 more pounds to me I think it would be easier.
    I just miss my kickstand .....
  19. dkavanagh
    Rochester, NY
  20. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I literally rode my bike for 20 years and never could get it on the center stand by myself...until I read correct technique on youtube one night. I went into the garage at midnight to try and viola....easy peasy when you use the right technique. I was laughing at myself so hard in the garage moving the bike on and off the stand repeatedly... my wife came out to see what I was doing....LOL.
    hogfiddles, tj., Huntchuks and 3 others like this.
