Wanted Tank to fit a 82 XJ550 Maxim
Discussion in 'For Sale, Trade/Swap, Wanted' started by Mancub, Mar 26, 2021.
  1. Mancub
    Mancub Member
    Pleasant Grove
    Had a terrible situation where the Radiators shop returned my tank destroyed and said sorry... I'm newer to this so don't want to do hard modifications. I'm wanting to do a slight conversion to a cafe racer style. I would love some help finding a tank, trading for one with other parts I'm taking off, or finding other options. Thank you.
  2. Toomanybikes
    Tsawwassen bc
    Looks like idiot pumped 100 psi into it and boom. The upside is if you keep it on the bike it will hold at least another gallon of gas :)
    Mechanic1978 likes this.
  3. hogfiddles
    Seems to me they owe you a tank
    Mechanic1978 and jayrodoh like this.
  4. Mancub
    Mancub Member
    Pleasant Grove
    He’s trying to say that even if he fixed the tank, because of the original sealer rusting off from behind inside, and it not coming out in his dip and he’s “tried everything on these old tanks before” that nomatter what the tank is junk. So his contribution is just him being nice... I don’t know if he’s right or not. I can have him straighten it out and stuff if someone knows a way to take care of the inside. That sealer seems indestructible and there are chunks of it in there as well as pulling of the walls.
  5. hogfiddles
    Sounds like he’s trying to weasel out of making things right. If he’s “tried everything before”, why didn’t he tell you that first and decline the job?????
    the metal on the underside looks darn solid from here. It looks like he attempted to to widen the tunnel!! What does the rest of the tank look like??
    you can remove ANY loose pieces. It just takes a bit of time, finesse, Long tweezers or other tools to grab pieces, break up larger pieces, vacuum, Stick with gum on the end, creativity, etc...... you can (normally) see down to the bottom of the right side of the Tank. So if you can SEE debris, you CAN remove it. It may not be easy, but we’ve all done it.
    Now if you’re looking for some other shaped tank, lick you wounds, walk away and get a different tank.
    But from what I see,I still call BS on him
    XJ550H likes this.
  6. Mancub
    Mancub Member
    Pleasant Grove
    Anyone have any more advice or options for a tank? He offered to take the tank back and fix it all up (doubt he can) but he claims that the inside is so bad it’s not worth anything anyways it’s just gonna keep clogging things up and that slush inside is gonna keep breaking down. Or he will give me $50 bucks to use to find something else...
    I would be fine doing another type of tank, I just haven’t been able to find anything that will fit easily. I heard basically a first gen Radian(86 I think), then the maxim and seca 550’s are all that will work. However I can’t find any of those.
    Council would be appreciated, thanks guys!
  7. James Schreiner
    James Schreiner New Member
    Versailles, KY
    If you’re still looking, I have a solid tank off a 82 maxim XJ550.
  8. Mechanic1978
    Mechanic1978 Active Member
    NOYB
    Fill a pillow case with sand half way lay flat till its about 3" thick, then roll the opens end up the last half and staple entire length closed. Remove all attachments from tank, and flush outside with water hose thoroughly. Shake remaining water out, flip upside down onto pillow case sandbag. Jiggling it and pushing into bag seating it firmly. Use or borrow an oxy\acetylene torch, start heating at lowest bent area moving torch side to side, purpose is to get areas glowing yellow to light orange and using a large rubber mallet to slowly pound it back into as close to original shape. As it starts to pound out (when u see metal moving) move torch around as well, never get any spot to a (glowing Red) color, and especially don't pound that spot or burn thorough metal (keep it moving). Slowly work heat to high points. A rubber mallet will push big areas flat, where as a steel hammer will push (ping) small dimples. That's why I said rubber,you don't want to make inside look like a mountain range. Hit colder areas that will force a wider area of metal to move the softer heated area preventing mallet from melting and smoking in your face. Don't worry about remaining water inside, heating metal that hot will make it evaporate and be bone dry when done. (I) could have that looking good in about 2 hrs myself and paint stripped, and in primer in 4.
    I don't know your metal working experience, so if little or none then prepare to move slow with it.
  9. Mechanic1978
    NOYB
    How much you want for your damaged tank?
  10. Mechanic1978
    NOYB
    you willing to sell/shipp that tank, Im interested if so.
  11. Andrew Nichols
    Andrew Nichols Active Member
    Minneapolis, MN
    I've got a tank from a 400 Seca for sale.
  12. Mechanic1978
    NOYB
    I dont have any other XJ's in my posession, so not interested in anything xj related at the moment except for the 550 tank and swing arm. but thank you for the offer.
  13. hogfiddles
    Pm’d
  14. Andrew Nichols
    Minneapolis, MN
    20210413_222749.jpg 20210413_222749.jpg 20210413_222749.jpg 20210413_222807.jpg 20210413_222749.jpg 20210413_222807.jpg 20210413_222905.jpg 20210413_222929.jpg 20210413_222956.jpg Dave, here are the pictures of the 400 Seca tank.
  15. hogfiddles
    Dang it, same damage, same holes.
  16. hogfiddles
    For those who don’t know what this is, it’s a baby cousin..... the XS400rj Seca. Here is one of mine so you can see what one looks like.
    eventually my other one will get there, too...
    dave f
    TheCrazyGnat likes this.
  17. Mechanic1978
    NOYB
    nice little twin...
  18. Andrew Nichols
    Minneapolis, MN
    That's cute, you should do a post about these.
  19. chacal
    Look ma, no frame tubes in front of the engine!
    Andrew Nichols and hogfiddles like this.
  20. Mechanic1978
    NOYB
    hey dave, whats the redline on that thing? and is it 4,5, or 6 speed?
