No key questions and other missing parts.
Discussion in 'XJ Technical Chat' started by Wingedwheel, Mar 4, 2022.
  1. Wingedwheel
    Wingedwheel Member
    MI
    Good morning guys, new to the forum but not to motorcycles. Saw a deal on FB marketplace that I had to check out. Well long story short it followed me home. 1982 XJ650 Maxim. Price was right so I’m taking a chance. Owner pulled the carbs and during a move lost them so I’ve got to source those. Also there is no key so I would appreciate info on how to release the seat and gas cap unless I can order a new key with the ser#? I’ll have plenty of questions I’m sure but the bike has 004798 on the odometer so I’m pretty sure I won’t have to pull the engine(fingers crossed) thanks in advance for any info. B0FA693C-C13A-4D63-A2AE-2F6E16E90756.jpeg 185658A9-99C8-47C9-97E7-A1577C9041B4.jpeg 6DF94407-4B3E-4B1B-8047-417465070900.jpeg
  2. a100man
    a100man Well-Known Member
    Bedford, UK
    The 'gas cap' can be picked quite easily - I did it on mine when I lost the key - the seat's probably the same - google 'DIY Bogota Rake' and if you have a grinder and an old hack saw blade you can make one. It's fun.
    Good luck
    cds1984 likes this.
  3. Dan Gardner
    Minneapolis, MN
    There is a code on the bottom of the ignition switch assembly that can be used to cut keys.
  4. Dan Gardner
    Minneapolis, MN
    Here is how I have used an inspection mirror to read the code:
    Andrew Nichols and chacal like this.
  5. Wingedwheel
    Wingedwheel Member
    MI
    Awesome Dan, that’s what I was looking for. Thanks
  6. Wingedwheel
    Wingedwheel Member
    MI
    Ok so I got the code, took it to a lock and key and had a key made, problem is it doesn’t work. The locksmith told me it wasn’t the right code but there’s not another one. I’m going to have to assume the key is cut wrong? CE9FEA7A-C6C0-44A4-AC2F-F5171EF24CC5.jpeg In any case I picked the seat lock so I was able to remove the seat and tank. Did a little cleanup and basically just seeing what’s there. 5F87537B-7A3E-4DEF-83B6-0AADE4047699.jpeg E5958D2B-D088-4583-8A3D-052E2D7E807F.jpeg 04C4D9DD-6B7F-40CE-89B9-582EF786A6B9.jpeg
    I also pulled the plugs to see what the cylinders looked like and they looked great! image.jpg
  7. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Airbox looks like it was used by a chipmunk or mice.
  8. Wingedwheel
    Wingedwheel Member
    MI
    I would say so I vacuumed all the shells out and got the box wiped out. There’s going to be a lot of cleaning the next few weeks.
  9. Wingedwheel
    Wingedwheel Member
    MI
    I had a guy I know offer me a set of carbs off an ‘86 XJ700. Will those be compatible?
  10. chacal
    Not really.
  11. Fuller56
    Fuller56 Well-Known Member
    A bit of a hassle but you can pull the ignition switch out and take it to your locksmith and let him work from there. I guess not as big a hassle as not having a key.....
    Oh, where are my manners, Welcome and Good Luck!
    StarGeneral likes this.
  12. Wingedwheel
    Wingedwheel Member
    MI
    Thank you for that information. I’m still searching the threads for more info.
  13. Wingedwheel
    Wingedwheel Member
    MI
    I managed to locate a set of carbs off a ‘81 XJ650. Can I assume those would work?
  14. Dan Gardner
    Minneapolis, MN
    Yes, they should work. You only need to be aware that the 81 Maxim did not have the YICS system, so I believe they were jetted slightly different. Not a big deal, bring the jets from the old rack or get some new ones.
    All the data and everything you ever wanted to know about what jets on what models can be found here: http://xj4ever.com/catalog/c-hitachi.html
  15. chacal
  16. Jeff Witt
    Jeff Witt New Member
    Port Washington, WI
    The helmet lock is easier to remove to bring to a lock smith than the ignition. Just don't forget to put the lock back or your bike will soon be missing the helmet lock like mine. :)
  17. chacal
    Helmet and seat locks are very rudimentary types of locks, and I don't think that you can use it's cylinder type as a guide for making a key that will also operate the main switch.
  18. Wingedwheel
    Wingedwheel Member
    MI
    Yep exactly what I did however I’m going out of town this week and might not get back over there. 36283557-32C5-4137-BE2E-A4D0EAAF031B.jpeg
    I was also able to pick up a set of carbs off an ‘81 that will be here tomorrow. DFC4E45C-F172-4784-BDC2-518ECCCA6463.jpeg
  19. Wingedwheel
    Wingedwheel Member
    MI
    I had a busy morning. Took the helmet lock back to the locksmith today. There was a different guy there and he read the wafers and compared it to the code I had. Said he had no idea where the other guy got his code but the first key was wrong so he cut a new key, cleaned up the core for me re-installed it in the mechanism, no charge. I thanked the guy went home and tried the key in the ignition with it working no problem. The tank however was a different story. It felt like there was something keeping the key from going in so back up to the locksmith I went with the tank. He picked the lock and went into the mechanism to release the core from the lock. I understand the principle of the retaining wafer but not how to get at it. He went under the cylinder o-ring and worked at it until he got the tab to release. Said it was stuck from sitting so he cleaned and lubed it and re-installed everything. While I was there I asked for a second key so two working keys for all three locks, over an hour of the locksmiths time and he charged me $22 because he said it was fun working on something you had to actually figure out. FE842E5B-5EB8-49D1-B132-6D71AC79BE33.jpeg
    while I had the tank finally open I was able to get a much better look in there also. It looks pretty clean and what little bit is there should clean up easily. 0DBB080B-5F8F-427B-8A52-1E06CEAD0CCA.jpeg E7787B97-084B-4CF4-ADD0-E499F3E4088B.jpeg
    The set of carbs I bought showed up today as well and although they reeked of gas varnish(as was expected) they weren’t too bad. I’ll have to do a little more reading on those before diving in. I’m no stranger to carbs but I want to learn a little more about this set. 86CA0D18-F3BA-4572-9776-351B5CB1447D.jpeg 289074FA-54AA-4FAA-B907-92F76D80CC09.jpeg 08F77B9D-9432-477F-8261-13A4352C5459.jpeg
    jayrodoh and JetmechMarty like this.
  20. Wingedwheel
    Wingedwheel Member
    MI
    First thing I did just for that reason….
    Jeff Witt likes this.
