1981 xj650 axle
Discussion in 'XJ Technical Chat' started by glennyboy, Jun 11, 2022.
  1. glennyboy
    glennyboy Member
    central cali
    XJ650 AXLE 1.jpg AXLE 2 650.jpg I had the axle off cleaning it up and painting all back together then i looked at pictures in the handbook and thought what is missing here or what axle do i have last owners have had the swing arm off before
  2. glennyboy
    glennyboy Member
    central cali
    looking at other axles there is a flange and spring.
  3. glennyboy
    glennyboy Member
    central cali
    the flange part does not stick out on my 650 like all the others
  4. jayrodoh
    jayrodoh YimYam Premium Member
    Cleveland
    Does that coupling slide out of the swing arm assembly? I've never seen one like that, unsure if there was a different style or maybe the bolt that holds the coupler in place on the gear housing broke and its stuck on the driveshaft!
  5. glennyboy
    glennyboy Member
    central cali
    Never tried to pull the coupling out of the swing arm, would it be a problem putting it back, i think it is a different style have to take a look at others again... that flange on the shaft butts up against the pinion bearing, dont look like anything is broken, reason i ask about this is i found some metal on the drain plug, looks like the casing of a needle roller bearing, plus not a good sound when i spin it, was full of oil.... looking at pictures of other 650 axles mine dont look like any.... could my axle be from another model, who knows what over the 41 years..... never road tested this project bike yet, waiting for tubeless valve stems.... production date of bike is 6/1980....
  6. glennyboy
    glennyboy Member
    central cali
    After looking at the picture in the Hanyes book it looks like the thread/nut on the drive pinion has gone ... looks like i will be looking for complete swing arm/axle
  7. glennyboy
    glennyboy Member
    central cali
    Looks like i will have to pull that shaft here is a picture of what the flange should look like
  8. jayrodoh
    Cleveland
    Every rear end I have in the garage looks like that last pic, I'm thinking that the input shaft where the coupler is attached to the gearcase has broken off. Pulling whats left of the coupler off that shaft in the swing arm will confirm. If that's the case good thing you found that before riding it!
  9. glennyboy
    glennyboy Member
    central cali
    yeah lol ... last owner was riding like that for three years... must have been deaf
    jayrodoh likes this.
  10. glennyboy
    glennyboy Member
    central cali
    Got the shaft out and yes the thread/nut snapped off .. used axle on its way from ebay
  11. k-moe
    That's what I'd have suggesed you do anyway. Reassembly of the final drive requires special tools. They can be fabricated, but given how inexpensive a used final drive is it's not really worth the bother.
  12. glennyboy
    glennyboy Member
    central cali
    Pulled apart the pinion bearing is shot, last owner would not hear the noise from the diff the baffles in exhaust are gone, burnt out over the past 41 years
