Why is my chair tensioner not tensioning ?
Discussion in 'XJ Technical Chat' started by swingmanu, Jun 19, 2022.
  1. swingmanu
    swingmanu Member
    Finland
    Hi,
    Rebuilding the engine is going well. I am now reinstalling the chain tensioner following the manual. I installed it and released the bolt (waiting to hear the chain. Tensioner tension the chain) but nothing is tightening.
    Chain doesnt seem to be tightened. Could it be tired spring?
    Any idea?
  2. Franz
    Franz Well-Known Member
    Scotland UK.
  3. Franz
    Scotland UK.
  4. XJ550H
    guide could be to worn to tighten chain
    plunger may not be pushing out due to a burr on the rod
    k-moe and Franz like this.
  5. k-moe
    It would be very helpful to know the model and year of your XJ. There are two types of cam chain tensioners, and both work somewhat differently.
  6. swingmanu
    swingmanu Member
    Finland
    Hi, yes @Franz that's the one.
    I have an xj650 4k0 Europe. The tensioner is the manual one with locking bolt.
    Prior to dismantling the bike, the chain was tensioned properly.
  7. swingmanu
    swingmanu Member
    Finland
  8. swingmanu
    swingmanu Member
    Finland
  9. Franz
    Scotland UK.
    Well if the plunger is faulty on your tensioner as @XJ550H suggested you are better getting an automatic one. Did you check the tensioner? Guide should be fine if the chain was tensioned property before.
  10. Franz
    Scotland UK.
    KO setup. Just wondering if there is a burr on your tensioner?
    https://images.cmsnl.com/img/partsl...300e1-camshaft-chain_big3IMG00996390_7fce.gif
    I posted a picture of the exhaust side chain guide for you where the guide goes into the pocket on the crankcase. The chain side guide if the bolt is too tight prevents the guide moving forward properly, well that's what l found. On my 900f engine l tightened the bolt B until it seated against the bottom of the chain guide. Then I backed the bolt off a quarter of a turn and tightened the locknut A.
    I cannot be sure this would stop it tensioning the chain but worth checking anyway, especially as it was all working before you rebuilt the engine. Just checking if you followed the procedure outlined above?
  11. swingmanu
    swingmanu Member
    Finland
    Ok this is interesting I didn't think I'd have to mess with that bolt. I only replace the head gasket that was broken so I didn't go further now dismantling and when rebuilding I just reinserted the chain tensioner as described in manual but now I see there is maybe more.
    What is a burr on the tensioner? I'm confused with the term
  12. Franz
    Scotland UK.
    A projection or indentation caused by manufacturing or wear. Someone else can perhaps explain better. I am no engineer but basically it is wear damage to the tensioner rod preventing the spring extending the plunger far enough to tension the cam chain I think.
    You did not disturb the tensioner blade bolt so it cannot be that as it was working fine before.
  13. swingmanu
    swingmanu Member
    Finland
    Right, could be. I just didn't hear a click or anything like stated in manual that would indicate that the tensioner went in proper position and I still have some slack on the chain on top. I assume, the chain should be tight
  14. swingmanu
    swingmanu Member
    Finland
    Maybe it's doing its job and pushing it enough and I am just confused on what I was supposed to hear and feel when installing it. The rod moves freely so it should go again the chain guide. Maybe that's all and I am overthinking this. How else could I make sure it's tensioning the chain?
  15. Franz
    Scotland UK.
    The chain should be tensioned when you release the tensioner. There should be no slack in the chain. When you fitted the cams did you make sure the chain was tight from the crankshaft sprocket to the exhaust camshaft sprocket? All the slack must be between the crankshaft sprocket and the inlet camshaft sprocket. If you get the chain tight when you release the tensioner and the timing marks are spot on it should be fine. Try this fully extend the tensioner and lock it. Then try fitting it to the engine by pushing it don't fit the bolts. If the tensioner and the cylinder block do not come into contact the tensioner rod must be pushing the guide fully forward. The only way the body of the tensioner can hit the cylinder block with the tensioner fully extended and locked is if the cam chain is worn out.
  16. swingmanu
    swingmanu Member
    Finland
    Interesting, there lies maybe my problem. When I removed the engine, there was slack between the two camshaft. In the middle section... So I assume that was normal. Otherwise also I don't know how someone can replace the camshaft with the chain in place... so maybe that's the issue.
    I'll take pictures and investigate this further.
  17. swingmanu
    swingmanu Member
    Finland
    I don't have many pictures from before dismantling (stupid mistake). But here are two pics and one is one I took to remember the cam shaft holders and you can clearly see the slack between camshafts when that "middle plastic chain support" is taken off and the chain tensioner was removed...
    I have the same slack and the same amount of "pins" now when rebuilding.
    Manu
  18. Franz
    Scotland UK.
    Yes l think so. The chain must be tight from the crankshaft sprocket to the exhaust camshaft sprocket and to the inlet camshafts sprocket. The slack in your photograph between the camshaft sprockets should not be there (correction) it is there because the tensioner is removed.
  19. swingmanu
    swingmanu Member
    Finland
    ok, I'm gonna try again, moving the engine to "C" and reinsert the chain tensioner.
  20. Franz
    Scotland UK.
    Yes just follow your manual.
  21. swingmanu
    swingmanu Member
    Finland
    Yes, that's what I'm doing but somehow it doesn't always make sense to me :) Thanks for the help !!
  22. Franz
    Scotland UK.
    Let us know how it goes so we can advise you more.
    swingmanu likes this.
  23. swingmanu
    swingmanu Member
    Finland
    Ok updates !
    I removed the chain tensioner and repeated the whole operation like the manual. Rotated to C mark and released the plunger of the belt tensioner. Hears it go in position but here is the issue.
    When I rotate the engine everything is perfect until right before the T mark and the chain tension loses and it becomes loose on top. I included pictures. '
    So I removed the tensioner once more, rotated the engine to C mark and checked through the hole the chain guide. I can push it with my finger and it moves a little bit but it's very small. I'd say the chain tensioner is barely pushing. So my question is... Could there be something preventing the chain guide to move freely and put tension on the chain? Otherwise all the marks are aligned and it's all good...
    Pictures are first when the chain is under tension, then when the chain loses tension and then a picture of the exact position on the timing and then a picture of the chain guide
  24. Franz
    Scotland UK.
    Looking at the guide through the opening it is not centred. The bolt and locknut that secures the guide you should reset that. I know you did not disturb it but try it to see if that corrects the problem. Turning the engine anticlockwise you should not be getting any slack in the chain. The inlet cam guide is not moving freely and the slack is happening because the camshaft is getting rotated by valve spring pressure.
  25. swingmanu
    swingmanu Member
    Finland
    good point and good eye ! I have to now find that bolt when I head back to the garage. maybe can also try to move in centred with fingers. I didn't disturb it but its true the guide isn't moving freely
  26. Franz
    Scotland UK.
    It's not your tensioner it's the guide l am sure of that. Good you put that photograph on that is the problem. Also the face of the guide that the chain runs on has a slightly raised section in the middle that sits between the links along the length of the chain. Make sure it is centred at the top under the cam cover.
  27. Franz
    Scotland UK.
    Reset this and you should be able to centre the guide.
  28. swingmanu
    swingmanu Member
    Finland
    Ok I don't find that info in the Haynes. Do you a wider picture on the procedure? Am I supposed to loosen it wiggle the guide and tighten it again?
    Manu
  29. Franz
    Scotland UK.
    Slacken the locknut A. Then slacken the bolt B half a turn and then tighten it just till you get resistance because it has then hit the cam chain guide. Then slacken B a quarter of a turn. Keep it there and tighten locknut A. Yes try and square the guide during the process.
  30. XJ550H
    A a burr is a sliver of metal that could have been taken off the tensioner rod by the bolt. You would be able to feel it with your finger. Or with the cam chain tensioner out the rod won't pull out of the housing after you release the bolt.
    Franz likes this.
  31. swingmanu
    swingmanu Member
    Finland
    The tensioner rod goes out when I release the bolt. So it seems it has to do with the guide
  32. Franz
    Scotland UK.
    Yes the guide is not sitting square. Can you take a picture from the top of the engine where the guide is in relation to the chain, if you have enough clearance?
  33. swingmanu
    swingmanu Member
    Finland
    I will try, it's tight but will do. I'm gonna do the manipulation you suggested.
  34. Franz
    Scotland UK.
    Yes I hope that fixes the problem.
  35. swingmanu
    swingmanu Member
    Finland
    Ok I seem to have fixed it but couldn't do the technique you mentioned. I inserted the tensioner loose so with the spring fully extended and I suspect the rubber part of the tensioner positioned itself better and now I don't have chain slack when turning the engine.
    So I guess it's fixed. Thanks for the help
    Franz and Huntchuks like this.
  36. swingmanu
    swingmanu Member
    Finland
    To further describe the issue I think the tensioner rubber had pressed so long against the guide that it had created a "groove" so when I reinserted it loose it was able to centre itself back on the guide it seems.
  37. Franz
    Scotland UK.
    The guide will be centred now. Have you started the engine?
  38. swingmanu
    swingmanu Member
    Finland
    Im far from starting the engine unfortunately… still waiting on one throttle shaft seal and i need to change valve shims as i redid the valve surface a little
  39. Franz
    Scotland UK.
    Oh that's right I remember now. Should run well with all the work you have done.
  40. swingmanu
    swingmanu Member
    Finland
    I hope thanks, i realised just now though that i might not have placed the valve springs in the right orientation…
    Im wondering if i should reopen it all,… :(
  41. Franz
    Scotland UK.
    So did you have the valves out to lap them or do you mean you put the buckets the shims sit in in the wrong places.
  42. swingmanu
    swingmanu Member
    Finland
    I replaced everything in its right place but I replaced the valves seals and i didn't specifically paid attention to the orientation of the valves springs when reinstalling the valves in place. I read later in manual they have an orientation... I suspect this is primarily for oscillation issues in the long run
  43. Franz
    Scotland UK.
    Yes better to check them if the manual states that.
  44. swingmanu
    swingmanu Member
    Finland
    If I reopen, can I reuse that head gasket? I already closed the head and tightened the bolts to the right torque
  45. Franz
    Scotland UK.
    My understanding is that it can be used because the engine has not been started but l have not tried it so l cannot be sure.
  46. Franz
    Scotland UK.
    Has anyone reused a head gasket when the head was torqued down but the engine was not started?
  47. swingmanu
    swingmanu Member
    Finland
    I believe it seals when crushed so I don't think it can be reused.
    I'll leave and see what happens.
    Franz likes this.
  48. swingmanu
    swingmanu Member
    Finland
    Ok so one of the camshaft bolt is stripped... Maybe precious owner but it doesn't hold torque and spins...
    I'm hopeless. Willing to let the bike go to anybody for any price at this point. It's in Helsinki
  49. Franz
    Scotland UK.
    This is for a stripped cam cover thread and l am not an engineer but your camshaft bolt thread in the head can be repaired.
    https://xjbikes.com/forums/threads/valve-cover-bolt-hole-stripped.32070/
    Here is the thread for the cam cover thread. Yours should be repairable with a hellicoil insert which a machine shop can do. Some of the people who have done this might chime in.
  50. swingmanu
    swingmanu Member
    Finland
    Yes I understand the procedure... Unfortunately I don't know if the bike is worth the trouble. I've never done it and can't afford 300-400eu for the job to be done somewhere...
    That's areal bummer. Wonder if red loctite would be enough. The bolt grabs on threads but doesn't torque. It spins at the bottom.
    Looks like I'm gonna have to pass this project to someone else. So much work put in thanks to all your help but this will get off budget for me...
