130 on the rear. Fits good!
Discussion in 'Hangout Lounge' started by KrS14, May 31, 2013.
  1. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Just put a 130 on the rear of the Seca, She spins fine, will take pics of clearance later for reference.
  2. mikel269
    mikel269 New Member
    Lafayette, La.
    What is the full size? 130/ /18. I'm in the middle of my build now and would like to see a wider tire on the rear
  3. mtnbikecrazy55
    Should be a 130/90-18
    I'm running a 130/90-16 on my maxim
  4. mtnbikecrazy55
  5. mikel269
    mikel269 New Member
    Lafayette, La.
    Awsome. Any help is appreciated.
  6. 750maxim
    750maxim New Member
    Gallatin, TN
    Im running 130 on my 750 maxim. Had to grind a weld a little smoother cause it was rubbing the raised letters but all is good now.
  7. Ted
    Ted Member
    Sioux Falls, SD
    Would love to see some pics of these!
  8. lo_zarro
    lo_zarro New Member
    Italy
    nice!
    but is it street legal?? (i don't know american laws about tyre size changes!)
  9. mwhite74
    mwhite74 Member
    Me too! I know you mentioned you were gonna get a new one, what kind did you wind up with?
  10. scrubby
    scrubby Member
    bevent Wi
    I'm running a 130 on both my maxim bikes the 650. And 700 both look good and fit good
  11. Polock
    i took a little weld off the Maxim swingarm, the seca didn't need anything.
    both 750's, both 130/90 kenda
  12. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Yee, it's a Kenda 130/90R18, pics today, check back tonight.
  13. k-moe
    In the US we are allowed to change tire sizes without penalty.
  14. KrS14
    KrS14 Active Member
    St Marys, Ontario
  15. zombiehouse
    zombiehouse Member
    Pomona, Ca
    I have run a 130 on my 550 Seca for years. I did have to remove the chain guard though. My bike felt more stable with the 130.
  16. bigfitz52
    I've got a 4.00-18 (Avon) on my '83 550 Seca and it feels PLANTED. (I haven't run a 4.00-18 since I had my Triumph, back in the day.)
    Going to a 120 (from the stock 110) on a 550 Seca is pretty much as far as you can go without mods, like chain guard removal.
    That being said, you should be able to up ONE size on any of (most of) our bikes without issue. Which means a 650/750 Seca can do a 130 instead of the stock 120; a 550 Seca can run a 120 without issue; the only thing I can't speak from experience on is the Maxims. A 130 (16") is stock on both the 550s and 650/750 and I can't say if a 140 will necessarily fit in all instances.
  17. KrS14
    KrS14 Active Member
    St Marys, Ontario
    The 130 was a bit of a pain to get by the wheel housing, a 140 may not fit past it.
  18. mtnbikecrazy55
    Yeah no way a 140 would fit on a maxim 750 with the 16 rear.
    I run 130/90-16's and it's always been a tighttt fit.
    Just put on another today as a matter of fact
  19. mtnbikecrazy55
    Unless you notched the shaft drive housing
