1981 SUZUKI GS 650
Discussion in 'Other Motorcycles' started by wizard, Mar 31, 2013.
  1. wizard
    Can't do anything with it at the moment, except sit on it & make brrrm brrrrm noises.
    GS 650
  2. Polock
    Re: 1981 SUZUKI GX 650
    sometimes that's all you need.
  3. bigfitz52
    You're back in the UK?
    Looks cleaner than most of the bikes you latch onto.
  4. wizard
    Yes, back in Blighty, Fitz. Bike looks OK, know more when I pick it up.
  5. adrian1
    adrian1 Active Member
  6. Bushy
    Bushy Active Member
    :0)
  7. wizard
    Just brushed some of the dust off, making a tentative start, rotor cover is cracked, found a s/h on the bay, had to drill & re-tap one of the bolt holes.
    GS650
  8. wizard
    Starter motor in need of some TLC.
    GS
  9. spinalator
    spinalator Member
    Regina, CANADA
    Yikes! Is it as bad as it looks?
  10. wizard
    Still working fine, believe it or not.
  11. wizard
    Comp' test shows 150 psi across the 4, I will put the valves in spec & test again, but looking good, so far.
  12. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    Can't wait to see the job you do on this one Wiz
  13. wizard
    It never looked this bad from the top.
    SEAT PAN
  14. wizard
    Valve clearance, using Polock's plastic shim replacements.
    Method:
    Take all readings.
    Remove the shims that need changing & slip in the plastic shims, you can then go on turning the motor without damaging cam lobe or bucket, sort out all your swops & replacements.
    Makes life a whole lot easier.
    PLASTIC SHIMS
  15. wizard
    Seat refurbished using the original cover & foam / pan.
    seat
  16. wizard
    Started on the carbs, diaphrams look OK P/M screws I have pulled, were at 1-3/4 turns, all looking fine.
    CARBS
  17. bigfitz52
    That side-pull choke linkage is a thing of beauty. Interesting to see cast "hats" too.
  18. wizard
    Motor running fine, smoked a lot at first but cleared. Pictures of mk2 bike lift & 4 into 2 pipes I found, but need headers for 2 & 3.
    Will start the strip down.
    4 into 2
  19. wizard
  20. thietkelogo
    thietkelogo New Member
    Vietnam
    i still like this one made in 1981
