Aftermarket rearset adapters
Discussion in 'XJ Modifications' started by Fredr1kh, Jan 17, 2014.
  1. Fredr1kh
    Fredr1kh New Member
    Oslo, Norway
    In my build I need to get adapters for new my new rearsets.
    I have an almost finished design already, all I need is a little help.
    Realizing rearset mounting points on the EURO and US XJ650 Seca might be different, I'd still like to try.
    And if someone here needs adapters, i can quickly change the dimensions in the model to accommodate that.
    anyway, my measurement of the mounting is 116mm center to center.
    The adapters take M10 allen bolts, and has a an extra 1 mm margin to wiggle in.
    I have added mounting for 107mm and 88mm rearsets.
    I'm still waiting on the rearsets so I can confirm either the 88 or 107 mounting.
    I think the difference between upper and lower 88 mount is very close to 3/4", so it's possible to accommodate different riders
    After all this reading, i guess a picture is in order
  2. lacucaracha
    lacucaracha Member
    Napa, CA
    Sorry, a bit confused on the question...Do you want to confirm the measurements between the Euro Seca and the US version?
  3. Fredr1kh
    Fredr1kh New Member
    Oslo, Norway
    If they are the same, then I can go ahaed and get them sent to cutting.
    if not, I can alter the measurements and put up a set of files so that anyone who want to fit aftermarket rearsets can do so.
    On the other hand, this is only for the left side, as my right side is shorter.
    need to fix that when i get home to the bike. (and I do have a a set of aftermarket rearsets made for this bike, except i don't like them.)
    It's not that I don't trust my own measurements, it's just so that if anyone want's it, they can have it.
