carb tune up
Discussion in 'XJ Technical Chat' started by keyboard, Jun 26, 2013.
  1. keyboard
    keyboard New Member
    Windsor, Ontario,Canada
    Hi
    If I remove the carburator and send it out.....Is it possible, to do a complete carb overhaul ?
    thanks
    Ron
  2. bigfitz52
    Sure. How effective it is depends on who you send them to/how much you wanna spend.
    Once overhauled, there will be "on the bike" adjustments to be made (running vacuum sync w/YICS blocked) for which your VALVE CLEARANCES will need to be IN SPEC.
  3. keyboard
    keyboard New Member
    I am in Windsor Ontario.... Can someone recommend a place where I can get this done the proper way ?
    Ron
  4. SilentRaven
    SilentRaven Member
    Sioux Falls, SD
    have you tried doing it yourself? i was worrisome at first about doing it myself but its really not that complicated. there are a lot fo great write up here on the site to help you through
  5. jayo84
    jayo84 Member
    Irwin PA
    :idea: Business opportunity for BigFitz maybe?? Ha Ha
