Clogged Jet Troubles
Discussion in 'XJ Technical Chat' started by englishsandwich, May 6, 2008.
  1. englishsandwich
    englishsandwich Member
    South Bend, Indiana
    I am in the middle of a full carb clean on my project bike. There was rust buildup in the carbs as thick as icing on a glazed donut. I couldn't even get the floats to move by pressing on them. I was able to get all my jets cleared except one. It's a size 40 so I can't find anything narrow enough to stick in it, I even tried a wire tie with all the paper stripped off. The carb cleaner just sprays back.
    Does anyone have a great idea? Or, is there somewhere I can buy another one?
    I was able to get everything else pretty well cleaned, just one jet.
    As always, thanks for your help,
    Stephen
  2. MiCarl
    A single bristle from a wire brush should get in there. Don't overdo it as the brass jet is soft.
    If all else fails I believe a member named Chacal sells them.
  3. englishsandwich
    South Bend, Indiana
    thanks, I am going to try that now.
  4. englishsandwich
    South Bend, Indiana
    Worked superbly. If you ever make it a little south, I owe you lunch!
  5. MiCarl
    You might regret that. I can eat a lot.
