Clutch Access
Discussion in 'XJ Technical Chat' started by Kylew11, Aug 17, 2010.
What should I do about the clutch cover gasket?
  1. Reuse
    0 vote(s)
    0.0%
  2. Replace
    0 vote(s)
    0.0%
  1. Kylew11
    Kylew11 Member
    Victoria, BC
    I just installed new friction plates and springs but I have concerns since the operating range isn't very large. I want to take a look at the clutch again but have this question. Do I need a new clutch cover gasket or can I reuse the 1 week old one given I don't wreck it on removal?
  2. iwingameover
    iwingameover Active Member
    I voted reuse. As long as you don't tear it.
  3. bigfitz52
    By all means reuse as long as you don't tear it.
    I've been working on a clutch parts eval for a while now, requiring multiple teardowns, and find I am able to re-use the gaskets at least once, if not twice, as long as I don't rip them at the holes.
  4. Kylew11
    Kylew11 Member
    Victoria, BC
    apparently there was not much action range because the retaining wire or whatever you call it from the clutch boss was gone.. i replaced that and reused the gasket.. works like a charm. Thanks for the votes
