cylinder bolts, plastic sleves?
Discussion in 'XJ Technical Chat' started by bensalf, Apr 18, 2014.
  1. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    does anyone know which of the twelve cylinder bolts have the plastic sleeves on.
    it looks like the centre 4 exhaust ones have them, and maybe the one on the far right of the picture.
    mine are non existant now, since stripping the engine.
    I'm going to use heat shrink tubing to replace them, but which ones?
    do any of the intake side ones have them.
    I assume the oil feed ones on the right side dont have them.(that's the left side in the picture.)
    thanks
    stu
  2. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Is that what that crustiness is? When I stripped my engine I took that as rust/corrosion, especially considering the amount of water in my engine. And especially considering one of my studs snapped when I removed the head. Thus, I removed all my cylinder studs and will simply glue the cylinder back onto the cases with JBWeld.
  3. bensalf
    yorkshire ,england
    W.T.F. ? :?
  4. PilotSmack
    PilotSmack Active Member
    Calgary, Canada
    That's sheathing. I know I put fresh ones on, but can'remember which studs got them. Len knows. Check his catalog.
  5. hogfiddles
    Bensalf..........I don't know as that will hold your engine together............
    dave
  6. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    Sheathing goes on the 4 exhaust side, except the outside stud that contains the oil passage
  7. Maxim677
    Maxim677 Member
    Holliston, Ma
    8O
  8. Bigshankhank
    Bastrop, TX
    Yeah it's too late in April for a good joke, plus I haven't been sleeping well lately. I did pull the studs out, but intend to replace them properly. JBWeld, bitch please...
  9. bigfitz52
    Dude, we had a now-vanished member that drilled additional holes in his crankshaft to "lighten" it. Another took his motor completely apart to scrub everything clean with soap and water not realizing what was involved with reassembling it. Anything's possible.
  10. Bigshankhank
    Bastrop, TX
    I am rebuilding an engine that had over a gallon of rainwater in it when I pushed it into my garage, so I don't blame you for assuming the worst of me. :lol:
  11. bensalf
    yorkshire ,england
    thanks guys, all sorted now
    chacal lists the sleeves as a set of 5, so I assume that's the 5 on the exhaust side, exept the oil feed .
    so I put 5 on the exhaust side and 5 on the intake side, as they are also exposed to the elements.
    I used heat shrink tubing ,and it makes a real nice job
    did a test fit of the barrels to make sure the sleeves don't foul anything
    all seems well
    cheers
    stu
  12. Bigshankhank
    Bastrop, TX
    How did you refinish your cases?
  13. bensalf
    yorkshire ,england
    with many ,many hours of wire wheels ,wire brushes, scotchbirte, wet/dry paper
    and this
    no primer needed just spray onto bare cases
    stu
  14. chacal
    Beautiful!
  15. jmilliken
    Dillsburg, PA
    that's some xj porn there.....
  16. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Awesome job!
