Gear oil
Discussion in 'XJ DIY How-To Instructions' started by Joe34, Sep 29, 2017.
  1. Jeremy Washburn
    Jeremy Washburn New Member
    Kansas City
  2. Jeremy Washburn
    Kansas City
    I don't know why it double posted the pictures lol I took that side cover off because it was leaking. Is this where gear oil goes?
  3. XJ550H
    If you are talking about the transmission (gearbox) it uses/shares the motor oil which is filled at the oil cap on the clutch cover
    gear oil is for rear end like in a car
    you can edit your post for a few minutes to remove extra photos
    or a moderator can edit out extra photos
  4. Jeremy Washburn
    Kansas City
    Did you see my picture of the cover where the shifter is? That is the one that was leaking. Is that the oil from the engine or gear oil from the final drive?
  5. XJ550H
    that is engine oil . the motor is a one piece unit with the gears inside the motor case uses same sump to supply oil to both sections
    look at this thread for a better understanding of the internals of motor
    XJ750 Engine removal and split - Pictures.
  6. Jeremy Washburn
    Kansas City
    Oh okay thanks for your help everyone on here are always so helpful
  7. Jeremy Washburn
    Kansas City
    I just have one more question when you guys said 80w hypnoid gear oil all I have been seeing is 80-90 is that right?
  8. XJ550H
    yes that works too.
    and to be clear IT does not go in motor just rear hub:rolleyes: at axle
  9. Jeremy Washburn
    Kansas City
    Lol yeah I know I have changed my oil a few times just haven't done anything with the rear drive gear oil.
  10. XJ550H
    I figured that . I sometimes forget that I am not talking to someone but writing things and that is to people with different skill sets and terminology of bike parts.
    I just did it in another post about red warning light forgot about the Atari red warning light and focused on oil light. I just fixed my oil light had to high of a wattage bulb and poor contacrt.
    I have a Atari cluster on my 82 750 maxim
    just like the oil plug on top (but it is not on top just the highest plug) and you saw the vent on top I must be careful not to misdirect and cause people problems
  11. Jeremy Washburn
    Kansas City
    Yeah lol I have been thinking about getting rid of my atari but I don't know if I want to try that yet lol
  12. XJ550H
    I still have and use my original Nintendo deck ......… oh we were talking about speedo tach clusters
  13. Jeremy Washburn
    Kansas City
  14. k-moe
    k-moe Pie, Bacon, Burbon. Moderator Premium Member
    Dust in the Wind
    As an occasional (unfortunately) long-distance rider, I can vouch for the ATARI being a useful device. Even been riding along oblivious of the obvious? Just enjoying the day? Maybe a bit too far from a gas station, and on reserve?
    Ya...warnings help avoid that problem.
    Jetfixer and Jeremy Washburn like this.
  15. Jeremy Washburn
    Kansas City
    Yeah I would agree however I need to figure out why my fuel gauge isn't working. Any idea?
  16. Jetfixer
    Are the wires hooked up to the sending unit under the tank ?
    Jeremy Washburn likes this.
  17. XJ550H
    "sending unit in tank may be bad
  18. k-moe
    Dust in the Wind
    The plug for the sending unit is under the seat. Easy to check. White flat plug with two wires coming from directly under the fuel tank.
    Fairly often when I do maintenance that requires that the tank be lifted or removed, I forget to plug it back in.
  19. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    My low fuel light never worked till i pulled the tank for paint, removed the sender and found the little wire inside broken at the solder point. Resolder, fixed! May be that simple.
  20. Jeremy Washburn
    Kansas City
    I haven't been able to check yet. However I rode to work today and on the way home when I turn a corner my bike just died. It started right back up. And did it again when I turned into my driveway and started right up any ideas?
